Page 48 of 114
Posted: Saturday 10 February 2018 14:37
by Fred78
getget wrote: Thursday 08 February 2018 20:34
Fred78 wrote: Wednesday 07 February 2018 15:27
getget wrote: Wednesday 07 February 2018 14:18
Hello, today, no 404
l have blinds defined in domoticz. What should I say to open them ?
When I say "ouvre le velux" (open the blind called velux in french) Google says "ok J'allume la lumière velux" (ok I turn on the light velux" ans the blind .... Closes.
Hmmm...funny. Because when I say "Ouvre le volet du salon", it works fine. I mean it says "ok j'allume la lumière volet du salon" and it opens the shutter.
What kind of device are you using for you're blinds? My shutter is managed by a Qubino Zwave module that is recognized by domoticz as a dimmer.
Thanks for the answer.
Hi. Well I guess that the difference between your configuration and mine is that I'm using a 'Dimmer' instead of a Blind.
My device is recognized as a dimmer and I never tried to switch the declaration to a 'Blind'.
I've just checked in Domoticz and there's a 'Blinds Inverted' type. Would switching to this type solve your problem?
EDIT :
I've just tried out the 'Blinds Percentage Inverted'. It works fine. If I say 'Ouvre le volet du salon' it opens the shutter. I a say 'Ferme le volet du salon', it closes the shutter. If I say 'Règle le volet du salon à 40%', it opens (or closes) the shutter up the 40%.
So try to switch from 'Blinds' to 'Blinds Inverted' in your domoticz configuration.
Posted: Saturday 10 February 2018 15:06
by Madgeni
sandervanpelt wrote: Saturday 10 February 2018 11:46
mark.sellwood wrote: Saturday 30 December 2017 19:54
Hi, My Google Home has stopped connecting to my Domoticz, when I ask Google to sync devices i get "Sorry an error occurred syncing Controlicz" When I look at my firewall logs I don't see any incoming connections. If I go to
https://www.controlicz.com login and click "Test connection to your Domoticz" this passes and I see an incoming connection on my firewall from an Amazon IP address.
Is something broken?
Since a few days I am also no longer able to sync my devices, Google Home responds with 'An error occurred while syncing Controlicz'. I am still able to control my devices. Any suggestions?
Sander
so weirdly, I can see lots of control requests for you, but NO sync requests - like Controlicz isnt being called
Posted: Saturday 10 February 2018 16:28
by sandervanpelt
Madgeni wrote: Saturday 10 February 2018 15:06
Sander
Even more weird is that after a few hours controlling devices also resulted in an error. Unlinking and linking in the Google home app resolved the issue
Posted: Saturday 10 February 2018 16:41
by Madgeni
i think (hope) some of these connectivity issues will be resolved when it's finally released into Live. Controlicz is up, and stable - but i'm definitely seeing issues in request/response between GA/GH and Controlicz
Posted: Saturday 10 February 2018 23:55
by maxtrash
I'm struggling with the authorization to work. For a while I couldn't connect from controlicz to my domoticz instance. Today, suddenly the lights responded to my google home. I unlinked google home and had to unfortunately reboot my rpi. Now it doesn't work anymore. Testing the connection from the controlicz website fails. Domoticz is telling me this in the log:
Error: [web:443] Failed authentication attempt, ignoring client request (remote address: 35.176.67.167)
so the router seems to be correctly setup. I have addded an account in domoticz (setup / more options / edit users). The user is enabled, has user rights and sharing enabled).
What more can I do?
Posted: Sunday 11 February 2018 9:16
by superustas
Hi, Madgeni!
Controlicz, apparently, does not quite work correctly with thermometers / thermostats
I have simple temperature sensors in the system.
But apparently, Google Home takes them as thermostats (the thermostat is also there, but he is one).
If I say "set the thermostat to 24 degrees," then the answer is "9 thermostats set to 24 degrees."
If to ask "what temperature outside" there will be an answer something of type "-2 degrees and it is off"
Posted: Sunday 11 February 2018 10:24
by Madgeni
Hi -
You're right - kind of
Controlicz DOES understand the difference between thermostats/sensors - but Google DOES NOT.
https://developers.google.com/actions/s ... thermostat
I have to treat all heating as thermostats - so that's why it's setting all to 24 degrees. I would suggest naming your thermostat to something else (you can use the Controlicz override in your Domoticz description.
The 'and it is off' issue is with Google to fix - i pass state to Google, it just ignores it
Posted: Sunday 11 February 2018 10:25
by Madgeni
maxtrash wrote: Saturday 10 February 2018 23:55
What more can I do?
Can you PM your email address, and i'll take a look. That error suggests it doesn't like the username/password you've specified in Controlicz.
if you try curl-ing this in a terminal: curl "https://yourusername:password@yourhost:port/json.htm?type=command¶m=getSunRiseSet"
What happens?
Posted: Sunday 11 February 2018 16:42
by maxtrash
I agree it looks like I didn't put in the right password. Again, the curl-answer suggests so:
<html><head><title>Unauthorized</title></head><body><h1>401 Unauthorized</h1></body></html>
I have sent my email address.
Posted: Sunday 11 February 2018 16:50
by Madgeni
So in Domoticz, change the password, then update your Controlicz profile with that password, and try again?
Posted: Monday 12 February 2018 13:36
by Madgeni
Apart from opening/closing/up/down - what other things can you do with your blinds via Domoticz? can you set them to a certain height/width/percentage?
Posted: Monday 12 February 2018 18:58
by Madgeni
Had some interesting conversations today - Blinds/Notifications/SelectorSwitches and real-time status updates are coming - I think the last ones are tied to the CES announced Google Home displays that are being launched.
Lots of fun for you all, more work for me!
Update: Controlicz has been published !
Posted: Monday 12 February 2018 21:07
by alanlsmith
Madgeni wrote: Monday 12 February 2018 18:58
Very well done Nick! your perseverance and skills obviously finally got through to the big boys.
Posted: Monday 12 February 2018 21:31
by gijsje
Posted: Monday 12 February 2018 22:34
by windhoos
Looks very good! Any Heads uo from Google for becoming a actual plugin rather than a testing plugin?
Posted: Monday 12 February 2018 22:37
by Madgeni
should be tomorrow (if it hasn't missed the window, if it did, then it's next Tuesday)
Posted: Monday 12 February 2018 22:43
by windhoos
Thats freggin awesome congratz!
Posted: Monday 12 February 2018 22:48
by windhoos
Error: [web:443] Failed authentication attempt, ignoring client request (remote address: XX.XXX.XXX)
Dude please dont post your public addess!!!!!!!!!
Posted: Monday 12 February 2018 22:52
by Madgeni
that's ok - that's the Controlicz site address
Posted: Tuesday 13 February 2018 0:11
by garrywma
Fabulous news Nick - congratulations.
