pi@raspberrypi:~/domoticz $ sudo apt-get install -y build-essential python-rpi.gpio nodejs
Reading package lists... Done
Building dependency tree
Reading state information... Done
build-essential is already the newest version.
nodejs is already the newest version.
nodejs set to manually installed.
python-rpi.gpio is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@raspberrypi:~/domoticz $ sudo apt-get install libavahi-compat-libdnssd-dev
The following extra packages will be installed:
libavahi-client-dev libavahi-common-dev libavahi-compat-libdnssd1 libdbus-1-dev
The following NEW packages will be installed:
libavahi-client-dev libavahi-common-dev libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libdbus-1-dev
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 401 kB of archives.
After this operation, 1,160 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main libavahi-compat-libdnssd1 armhf 0.6.31-5 [42.9 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main libavahi-common-dev armhf 0.6.31-5 [61.4 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ jessie/main libdbus-1-dev armhf 1.8.20-0+deb8u1 [184 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ jessie/main libavahi-client-dev armhf 0.6.31-5 [55.4 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian/ jessie/main libavahi-compat-libdnssd-dev armhf 0.6.31-5 [57.7 kB]
Fetched 401 kB in 1s (286 kB/s)
Selecting previously unselected package libavahi-compat-libdnssd1:armhf.
(Reading database ... 121774 files and directories currently installed.)
Preparing to unpack .../libavahi-compat-libdnssd1_0.6.31-5_armhf.deb ...
Unpacking libavahi-compat-libdnssd1:armhf (0.6.31-5) ...
Selecting previously unselected package libavahi-common-dev.
Preparing to unpack .../libavahi-common-dev_0.6.31-5_armhf.deb ...
Unpacking libavahi-common-dev (0.6.31-5) ...
Selecting previously unselected package libdbus-1-dev:armhf.
Preparing to unpack .../libdbus-1-dev_1.8.20-0+deb8u1_armhf.deb ...
Unpacking libdbus-1-dev:armhf (1.8.20-0+deb8u1) ...
Selecting previously unselected package libavahi-client-dev.
Preparing to unpack .../libavahi-client-dev_0.6.31-5_armhf.deb ...
Unpacking libavahi-client-dev (0.6.31-5) ...
Selecting previously unselected package libavahi-compat-libdnssd-dev.
Preparing to unpack .../libavahi-compat-libdnssd-dev_0.6.31-5_armhf.deb ...
Unpacking libavahi-compat-libdnssd-dev (0.6.31-5) ...
Setting up libavahi-compat-libdnssd1:armhf (0.6.31-5) ...
Setting up libavahi-common-dev (0.6.31-5) ...
Setting up libdbus-1-dev:armhf (1.8.20-0+deb8u1) ...
Setting up libavahi-client-dev (0.6.31-5) ...
Setting up libavahi-compat-libdnssd-dev (0.6.31-5) ...
Processing triggers for libc-bin (2.19-18+deb8u6) ...
pi@raspberrypi:~/domoticz $ sudo apt-get install git
git is already the newest version.
git set to manually installed.
pi@raspberrypi:~/domoticz $ sudo apt-get install mosquitto
mosquitto
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 101 kB of archives.
After this operation, 190 kB of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main mosquitto armhf 1.3.4-2 [101 kB]
Fetched 101 kB in 0s (136 kB/s)
Selecting previously unselected package mosquitto.
(Reading database ... 121863 files and directories currently installed.)
Preparing to unpack .../mosquitto_1.3.4-2_armhf.deb ...
Unpacking mosquitto (1.3.4-2) ...
Processing triggers for man-db (2.7.0.2-5) ...
Processing triggers for systemd (215-17+deb8u5) ...
Setting up mosquitto (1.3.4-2) ...
pi@raspberrypi:~/domoticz $ sudo npm install -g node-red --unsafe-perm
sudo: npm: command not found
pi@raspberrypi:~/domoticz $ sudo apt-get install npm
gyp libc-ares-dev libjs-node-uuid libssl-dev libssl-doc libv8-3.14-dev node-abbrev node-ansi node-ansi-color-table node-archy
node-async node-block-stream node-combined-stream node-cookie-jar node-delayed-stream node-forever-agent node-form-data
node-fstream node-fstream-ignore node-github-url-from-git node-glob node-graceful-fs node-gyp node-inherits node-ini
node-json-stringify-safe node-lockfile node-lru-cache node-mime node-minimatch node-mkdirp node-mute-stream node-node-uuid
node-nopt node-normalize-package-data node-npmlog node-once node-osenv node-qs node-read node-read-package-json node-request
node-retry node-rimraf node-semver node-sha node-sigmund node-slide node-tar node-tunnel-agent node-underscore node-which
nodejs-dev
Suggested packages:
node-hawk node-aws-sign node-oauth-sign node-http-signature
nodejs-dev npm
0 upgraded, 54 newly installed, 0 to remove and 0 not upgraded.
Need to get 3,689 kB of archives.
After this operation, 13.3 MB of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main gyp all 0.1~svn1729-3 [201 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main libjs-node-uuid all 1.4.0-1 [12.6 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ jessie/main libssl-dev armhf 1.0.1t-1+deb8u5 [1,094 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ jessie/main libssl-doc all 1.0.1t-1+deb8u5 [1,167 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian/ jessie/main libv8-3.14-dev armhf 3.14.5.8-8.1+rpi1 [108 kB]
Get:6 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-async all 0.8.0-1 [24.6 kB]
Get:7 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-node-uuid all 1.4.0-1 [9,194 B]
Get:8 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-underscore all 1.7.0~dfsg-1 [34.2 kB]
Get:9 http://mirrordirector.raspbian.org/raspbian/ jessie/main libc-ares-dev armhf 1.10.0-2+deb8u1 [131 kB]
Get:10 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-abbrev all 1.0.5-2 [3,540 B]
Get:11 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-ansi all 0.3.0-2 [8,608 B]
Get:12 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-ansi-color-table all 1.0.0-1 [4,408 B]
Get:13 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-archy all 0.0.2-1 [3,620 B]
Get:14 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-inherits all 2.0.1-1 [3,230 B]
Get:15 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-block-stream all 0.0.7-1 [4,550 B]
Get:16 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-delayed-stream all 0.0.5-1 [4,482 B]
Get:17 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-combined-stream all 0.0.5-1 [4,918 B]
Get:18 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-cookie-jar all 0.3.1-1 [3,570 B]
Get:19 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-forever-agent all 0.5.1-1 [3,066 B]
Get:20 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-mime all 1.2.11-1 [18.1 kB]
Get:21 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-form-data all 0.1.0-1 [6,084 B]
Get:22 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-rimraf all 2.2.8-1 [5,668 B]
Get:23 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-mkdirp all 0.5.0-1 [4,634 B]
Get:24 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-graceful-fs all 3.0.2-1 [7,070 B]
Get:25 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-fstream all 0.1.24-1 [17.5 kB]
Get:26 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-lru-cache all 2.3.1-1 [5,344 B]
Get:27 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-sigmund all 1.0.0-1 [3,750 B]
Get:28 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-minimatch all 1.0.0-1 [13.9 kB]
Get:29 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-fstream-ignore all 0.0.6-2 [5,536 B]
Get:30 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-github-url-from-git all 1.1.1-1 [2,986 B]
Get:31 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-once all 1.1.1-1 [2,552 B]
Get:32 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-glob all 4.0.5-1 [13.1 kB]
Get:33 http://mirrordirector.raspbian.org/raspbian/ jessie/main nodejs-dev armhf 0.10.29~dfsg-2 [247 kB]
Get:34 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-nopt all 3.0.1-1 [9,484 B]
Get:35 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-npmlog all 0.0.4-1 [5,516 B]
Get:36 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-osenv all 0.1.0-1 [3,734 B]
Get:37 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-tunnel-agent all 0.3.1-1 [3,840 B]
Get:38 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-json-stringify-safe all 5.0.0-1 [3,356 B]
Get:39 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-qs all 2.2.4-1 [8,474 B]
Get:40 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-request all 2.26.1-1 [15.7 kB]
Get:41 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-semver all 2.1.0-2 [14.9 kB]
Get:42 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-tar all 0.1.18-1 [16.9 kB]
Get:43 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-which all 1.0.5-2 [3,610 B]
Get:44 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-gyp all 0.12.2+ds-1 [19.4 kB]
Get:45 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-ini all 1.1.0-1 [4,720 B]
Get:46 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-lockfile all 0.4.1-1 [5,150 B]
Get:47 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-mute-stream all 0.0.4-1 [4,056 B]
Get:48 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-normalize-package-data all 0.2.2-1 [8,604 B]
Get:49 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-read all 1.0.5-1 [4,262 B]
Get:50 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-read-package-json all 1.2.4-1 [7,740 B]
Get:51 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-retry all 0.6.0-1 [6,124 B]
Get:52 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-sha all 1.2.3-1 [4,064 B]
Get:53 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-slide all 1.1.4-1 [6,078 B]
Get:54 http://mirrordirector.raspbian.org/raspbian/ jessie/main npm all 1.4.21+ds-2 [354 kB]
Fetched 3,689 kB in 10s (347 kB/s)
Extracting templates from packages: 100%
Selecting previously unselected package gyp.
(Reading database ... 121893 files and directories currently installed.)
Preparing to unpack .../gyp_0.1~svn1729-3_all.deb ...
Unpacking gyp (0.1~svn1729-3) ...
Selecting previously unselected package libjs-node-uuid.
Preparing to unpack .../libjs-node-uuid_1.4.0-1_all.deb ...
Unpacking libjs-node-uuid (1.4.0-1) ...
Selecting previously unselected package libssl-dev:armhf.
Preparing to unpack .../libssl-dev_1.0.1t-1+deb8u5_armhf.deb ...
Unpacking libssl-dev:armhf (1.0.1t-1+deb8u5) ...
Selecting previously unselected package libssl-doc.
Preparing to unpack .../libssl-doc_1.0.1t-1+deb8u5_all.deb ...
Unpacking libssl-doc (1.0.1t-1+deb8u5) ...
Selecting previously unselected package libv8-3.14-dev.
Preparing to unpack .../libv8-3.14-dev_3.14.5.8-8.1+rpi1_armhf.deb ...
Unpacking libv8-3.14-dev (3.14.5.8-8.1+rpi1) ...
Selecting previously unselected package node-async.
Preparing to unpack .../node-async_0.8.0-1_all.deb ...
Unpacking node-async (0.8.0-1) ...
Selecting previously unselected package node-node-uuid.
Preparing to unpack .../node-node-uuid_1.4.0-1_all.deb ...
Unpacking node-node-uuid (1.4.0-1) ...
Selecting previously unselected package node-underscore.
Preparing to unpack .../node-underscore_1.7.0~dfsg-1_all.deb ...
Unpacking node-underscore (1.7.0~dfsg-1) ...
Selecting previously unselected package libc-ares-dev:armhf.
Preparing to unpack .../libc-ares-dev_1.10.0-2+deb8u1_armhf.deb ...
Unpacking libc-ares-dev:armhf (1.10.0-2+deb8u1) ...
Selecting previously unselected package node-abbrev.
Preparing to unpack .../node-abbrev_1.0.5-2_all.deb ...
Unpacking node-abbrev (1.0.5-2) ...
Selecting previously unselected package node-ansi.
Preparing to unpack .../node-ansi_0.3.0-2_all.deb ...
Unpacking node-ansi (0.3.0-2) ...
Selecting previously unselected package node-ansi-color-table.
Preparing to unpack .../node-ansi-color-table_1.0.0-1_all.deb ...
Unpacking node-ansi-color-table (1.0.0-1) ...
Selecting previously unselected package node-archy.
Preparing to unpack .../node-archy_0.0.2-1_all.deb ...
Unpacking node-archy (0.0.2-1) ...
Selecting previously unselected package node-inherits.
Preparing to unpack .../node-inherits_2.0.1-1_all.deb ...
Unpacking node-inherits (2.0.1-1) ...
Selecting previously unselected package node-block-stream.
Preparing to unpack .../node-block-stream_0.0.7-1_all.deb ...
Unpacking node-block-stream (0.0.7-1) ...
Selecting previously unselected package node-delayed-stream.
Preparing to unpack .../node-delayed-stream_0.0.5-1_all.deb ...
Unpacking node-delayed-stream (0.0.5-1) ...
Selecting previously unselected package node-combined-stream.
Preparing to unpack .../node-combined-stream_0.0.5-1_all.deb ...
Unpacking node-combined-stream (0.0.5-1) ...
Selecting previously unselected package node-cookie-jar.
Preparing to unpack .../node-cookie-jar_0.3.1-1_all.deb ...
Unpacking node-cookie-jar (0.3.1-1) ...
Selecting previously unselected package node-forever-agent.
Preparing to unpack .../node-forever-agent_0.5.1-1_all.deb ...
Unpacking node-forever-agent (0.5.1-1) ...
Selecting previously unselected package node-mime.
Preparing to unpack .../node-mime_1.2.11-1_all.deb ...
Unpacking node-mime (1.2.11-1) ...
Selecting previously unselected package node-form-data.
Preparing to unpack .../node-form-data_0.1.0-1_all.deb ...
Unpacking node-form-data (0.1.0-1) ...
Selecting previously unselected package node-rimraf.
Preparing to unpack .../node-rimraf_2.2.8-1_all.deb ...
Unpacking node-rimraf (2.2.8-1) ...
Selecting previously unselected package node-mkdirp.
Preparing to unpack .../node-mkdirp_0.5.0-1_all.deb ...
Unpacking node-mkdirp (0.5.0-1) ...
Selecting previously unselected package node-graceful-fs.
Preparing to unpack .../node-graceful-fs_3.0.2-1_all.deb ...
Unpacking node-graceful-fs (3.0.2-1) ...
Selecting previously unselected package node-fstream.
Preparing to unpack .../node-fstream_0.1.24-1_all.deb ...
Unpacking node-fstream (0.1.24-1) ...
Selecting previously unselected package node-lru-cache.
Preparing to unpack .../node-lru-cache_2.3.1-1_all.deb ...
Unpacking node-lru-cache (2.3.1-1) ...
Selecting previously unselected package node-sigmund.
Preparing to unpack .../node-sigmund_1.0.0-1_all.deb ...
Unpacking node-sigmund (1.0.0-1) ...
Selecting previously unselected package node-minimatch.
Preparing to unpack .../node-minimatch_1.0.0-1_all.deb ...
Unpacking node-minimatch (1.0.0-1) ...
Selecting previously unselected package node-fstream-ignore.
Preparing to unpack .../node-fstream-ignore_0.0.6-2_all.deb ...
Unpacking node-fstream-ignore (0.0.6-2) ...
Selecting previously unselected package node-github-url-from-git.
Preparing to unpack .../node-github-url-from-git_1.1.1-1_all.deb ...
Unpacking node-github-url-from-git (1.1.1-1) ...
Selecting previously unselected package node-once.
Preparing to unpack .../node-once_1.1.1-1_all.deb ...
Unpacking node-once (1.1.1-1) ...
Selecting previously unselected package node-glob.
Preparing to unpack .../node-glob_4.0.5-1_all.deb ...
Unpacking node-glob (4.0.5-1) ...
Selecting previously unselected package nodejs-dev.
Preparing to unpack .../nodejs-dev_0.10.29~dfsg-2_armhf.deb ...
Unpacking nodejs-dev (0.10.29~dfsg-2) ...
Selecting previously unselected package node-nopt.
Preparing to unpack .../node-nopt_3.0.1-1_all.deb ...
Unpacking node-nopt (3.0.1-1) ...
Selecting previously unselected package node-npmlog.
Preparing to unpack .../node-npmlog_0.0.4-1_all.deb ...
Unpacking node-npmlog (0.0.4-1) ...
Selecting previously unselected package node-osenv.
Preparing to unpack .../node-osenv_0.1.0-1_all.deb ...
Unpacking node-osenv (0.1.0-1) ...
Selecting previously unselected package node-tunnel-agent.
Preparing to unpack .../node-tunnel-agent_0.3.1-1_all.deb ...
Unpacking node-tunnel-agent (0.3.1-1) ...
Selecting previously unselected package node-json-stringify-safe.
Preparing to unpack .../node-json-stringify-safe_5.0.0-1_all.deb ...
Unpacking node-json-stringify-safe (5.0.0-1) ...
Selecting previously unselected package node-qs.
Preparing to unpack .../node-qs_2.2.4-1_all.deb ...
Unpacking node-qs (2.2.4-1) ...
Selecting previously unselected package node-request.
Preparing to unpack .../node-request_2.26.1-1_all.deb ...
Unpacking node-request (2.26.1-1) ...
Selecting previously unselected package node-semver.
Preparing to unpack .../node-semver_2.1.0-2_all.deb ...
Unpacking node-semver (2.1.0-2) ...
Selecting previously unselected package node-tar.
Preparing to unpack .../node-tar_0.1.18-1_all.deb ...
Unpacking node-tar (0.1.18-1) ...
Selecting previously unselected package node-which.
Preparing to unpack .../node-which_1.0.5-2_all.deb ...
Unpacking node-which (1.0.5-2) ...
Selecting previously unselected package node-gyp.
Preparing to unpack .../node-gyp_0.12.2+ds-1_all.deb ...
Unpacking node-gyp (0.12.2+ds-1) ...
Selecting previously unselected package node-ini.
Preparing to unpack .../node-ini_1.1.0-1_all.deb ...
Unpacking node-ini (1.1.0-1) ...
Selecting previously unselected package node-lockfile.
Preparing to unpack .../node-lockfile_0.4.1-1_all.deb ...
Unpacking node-lockfile (0.4.1-1) ...
Selecting previously unselected package node-mute-stream.
Preparing to unpack .../node-mute-stream_0.0.4-1_all.deb ...
Unpacking node-mute-stream (0.0.4-1) ...
Selecting previously unselected package node-normalize-package-data.
Preparing to unpack .../node-normalize-package-data_0.2.2-1_all.deb ...
Unpacking node-normalize-package-data (0.2.2-1) ...
Selecting previously unselected package node-read.
Preparing to unpack .../node-read_1.0.5-1_all.deb ...
Unpacking node-read (1.0.5-1) ...
Selecting previously unselected package node-read-package-json.
Preparing to unpack .../node-read-package-json_1.2.4-1_all.deb ...
Unpacking node-read-package-json (1.2.4-1) ...
Selecting previously unselected package node-retry.
Preparing to unpack .../node-retry_0.6.0-1_all.deb ...
Unpacking node-retry (0.6.0-1) ...
Selecting previously unselected package node-sha.
Preparing to unpack .../node-sha_1.2.3-1_all.deb ...
Unpacking node-sha (1.2.3-1) ...
Selecting previously unselected package node-slide.
Preparing to unpack .../node-slide_1.1.4-1_all.deb ...
Unpacking node-slide (1.1.4-1) ...
Selecting previously unselected package npm.
Preparing to unpack .../npm_1.4.21+ds-2_all.deb ...
Unpacking npm (1.4.21+ds-2) ...
Setting up gyp (0.1~svn1729-3) ...
Setting up libjs-node-uuid (1.4.0-1) ...
Setting up libssl-dev:armhf (1.0.1t-1+deb8u5) ...
Setting up libssl-doc (1.0.1t-1+deb8u5) ...
Setting up libv8-3.14-dev (3.14.5.8-8.1+rpi1) ...
Setting up node-async (0.8.0-1) ...
Setting up node-node-uuid (1.4.0-1) ...
Setting up node-underscore (1.7.0~dfsg-1) ...
Setting up libc-ares-dev:armhf (1.10.0-2+deb8u1) ...
Setting up node-abbrev (1.0.5-2) ...
Setting up node-ansi (0.3.0-2) ...
Setting up node-ansi-color-table (1.0.0-1) ...
Setting up node-archy (0.0.2-1) ...
Setting up node-inherits (2.0.1-1) ...
Setting up node-block-stream (0.0.7-1) ...
Setting up node-delayed-stream (0.0.5-1) ...
Setting up node-combined-stream (0.0.5-1) ...
Setting up node-cookie-jar (0.3.1-1) ...
Setting up node-forever-agent (0.5.1-1) ...
Setting up node-mime (1.2.11-1) ...
Setting up node-form-data (0.1.0-1) ...
Setting up node-rimraf (2.2.8-1) ...
Setting up node-mkdirp (0.5.0-1) ...
Setting up node-graceful-fs (3.0.2-1) ...
Setting up node-fstream (0.1.24-1) ...
Setting up node-lru-cache (2.3.1-1) ...
Setting up node-sigmund (1.0.0-1) ...
Setting up node-minimatch (1.0.0-1) ...
Setting up node-fstream-ignore (0.0.6-2) ...
Setting up node-github-url-from-git (1.1.1-1) ...
Setting up node-once (1.1.1-1) ...
Setting up node-glob (4.0.5-1) ...
Setting up nodejs-dev (0.10.29~dfsg-2) ...
Setting up node-nopt (3.0.1-1) ...
Setting up node-npmlog (0.0.4-1) ...
Setting up node-osenv (0.1.0-1) ...
Setting up node-tunnel-agent (0.3.1-1) ...
Setting up node-json-stringify-safe (5.0.0-1) ...
Setting up node-qs (2.2.4-1) ...
Setting up node-request (2.26.1-1) ...
Setting up node-semver (2.1.0-2) ...
Setting up node-tar (0.1.18-1) ...
Setting up node-which (1.0.5-2) ...
Setting up node-gyp (0.12.2+ds-1) ...
Setting up node-ini (1.1.0-1) ...
Setting up node-lockfile (0.4.1-1) ...
Setting up node-mute-stream (0.0.4-1) ...
Setting up node-normalize-package-data (0.2.2-1) ...
Setting up node-read (1.0.5-1) ...
Setting up node-read-package-json (1.2.4-1) ...
Setting up node-retry (0.6.0-1) ...
Setting up node-sha (1.2.3-1) ...
Setting up node-slide (1.1.4-1) ...
Setting up npm (1.4.21+ds-2) ...
npm WARN engine [email protected]: wanted: {"node":">=0.10.32"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine [email protected]: wanted: {"node":">= 0.12"} (current: {"node":"0.10.29","npm":"1.4.21"})
> [email protected] install /usr/local/lib/node_modules/node-red/node_modules/bcrypt
> node-gyp rebuild
make: Entering directory '/usr/local/lib/node_modules/node-red/node_modules/bcrypt/build'
CXX(target) Release/obj.target/bcrypt_lib/src/blowfish.o
CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt.o
CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt_node.o
In file included from ../src/bcrypt_node.cc:1:0:
../node_modules/nan/nan.h:324:47: error: ‘REPLACE_INVALID_UTF8’ is not a member of ‘v8::String’
static const unsigned kReplaceInvalidUtf8 = v8::String::REPLACE_INVALID_UTF8;
bcrypt_lib.target.mk:84: recipe for target 'Release/obj.target/bcrypt_lib/src/bcrypt_node.o' failed
make: *** [Release/obj.target/bcrypt_lib/src/bcrypt_node.o] Error 1
make: Leaving directory '/usr/local/lib/node_modules/node-red/node_modules/bcrypt/build'
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/share/node-gyp/lib/build.js:267:23)
gyp ERR! stack at ChildProcess.emit (events.js:98:17)
gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:809:12)
gyp ERR! System Linux 4.4.26-v7+
gyp ERR! command "nodejs" "/usr/bin/node-gyp" "rebuild"
gyp ERR! cwd /usr/local/lib/node_modules/node-red/node_modules/bcrypt
gyp ERR! node -v v0.10.29
gyp ERR! node-gyp -v v0.12.2
gyp ERR! not ok
npm WARN engine [email protected]: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN deprecated [email protected]: you can use npm install i18next from version 2.0.0
npm WARN This failure might be due to the use of legacy binary "node"
npm WARN For further explanations, please read
/usr/share/doc/nodejs/README.Debian
> [email protected] install /usr/local/lib/node_modules/node-red/node_modules/ws/node_modules/utf-8-validate
> node-gyp rebuild
make: Entering directory '/usr/local/lib/node_modules/node-red/node_modules/ws/node_modules/utf-8-validate/build'
CXX(target) Release/obj.target/validation/src/validation.o
In file included from ../src/validation.cc:15:0:
validation.target.mk:84: recipe for target 'Release/obj.target/validation/src/validation.o' failed
make: *** [Release/obj.target/validation/src/validation.o] Error 1
make: Leaving directory '/usr/local/lib/node_modules/node-red/node_modules/ws/node_modules/utf-8-validate/build'
gyp ERR! cwd /usr/local/lib/node_modules/node-red/node_modules/ws/node_modules/utf-8-validate
gyp ERR! not ok
npm WARN optional dep failed, continuing [email protected]
> [email protected] install /usr/local/lib/node_modules/node-red/node_modules/ws/node_modules/bufferutil
> node-gyp rebuild
make: Entering directory '/usr/local/lib/node_modules/node-red/node_modules/ws/node_modules/bufferutil/build'
CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
In file included from ../src/bufferutil.cc:16:0:
bufferutil.target.mk:84: recipe for target 'Release/obj.target/bufferutil/src/bufferutil.o' failed
make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Error 1
make: Leaving directory '/usr/local/lib/node_modules/node-red/node_modules/ws/node_modules/bufferutil/build'
gyp ERR! cwd /usr/local/lib/node_modules/node-red/node_modules/ws/node_modules/bufferutil
gyp ERR! not ok
> [email protected] install /usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport
> node-pre-gyp install --fallback-to-build
node-pre-gyp ERR! Tried to download: https://github.com/voodootikigod/node-serialport/releases/download/3.1.2/serialport-v3.1.2-node-v11-linux-arm.tar.gz
node-pre-gyp ERR! Pre-built binaries not found for [email protected] and [email protected] (node-v11 ABI) (falling back to source compile with node-gyp)
make: Entering directory '/usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/build'
CXX(target) Release/obj.target/serialport/src/serialport.o
In file included from ../src/./serialport.h:7:0,
from ../src/serialport.cpp:1:
serialport.target.mk:84: recipe for target 'Release/obj.target/serialport/src/serialport.o' failed
make: *** [Release/obj.target/serialport/src/serialport.o] Error 1
make: Leaving directory '/usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/build'
gyp ERR! command "nodejs" "/usr/bin/node-gyp" "build" "--fallback-to-build" "--module=/usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/build/Release"
gyp ERR! cwd /usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute 'node-gyp build --fallback-to-build --module=/usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/build/Release' (1)
node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:98:17)
node-pre-gyp ERR! stack at maybeClose (child_process.js:755:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:822:5)
node-pre-gyp ERR! System Linux 4.4.26-v7+
node-pre-gyp ERR! command "node" "/usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport
node-pre-gyp ERR! node -v v0.10.29
node-pre-gyp ERR! node-pre-gyp -v v0.6.28
node-pre-gyp ERR! not ok
/usr/local/bin/node-red -> /usr/local/lib/node_modules/node-red/red.js
/usr/local/bin/node-red-pi -> /usr/local/lib/node_modules/node-red/bin/node-red-pi
[email protected] /usr/local/lib/node_modules/node-red
├── [email protected]
├── [email protected] ([email protected])
├── [email protected] ([email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
└── [email protected] ([email protected])
pi@raspberrypi:~/domoticz $ sudo wget https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/nodered.service -O /lib/systemd/system/nodered.service
--2016-10-28 09:50:15-- https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/nodered.service
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.12.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.12.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 888 [text/plain]
Saving to: ‘/lib/systemd/system/nodered.service’
/lib/systemd/system/nodered.serv 100%[============================================================>] 888 --.-KB/s in 0s
2016-10-28 09:50:15 (4.00 MB/s) - ‘/lib/systemd/system/nodered.service’ saved [888/888]
pi@raspberrypi:~/domoticz $ sudo wget https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/node-red-start -O /usr/bin/node-red-start
--2016-10-28 09:50:24-- https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/node-red-start
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.16.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.16.133|:443... connected.
Length: 1863 (1.8K) [text/plain]
Saving to: ‘/usr/bin/node-red-start’
/usr/bin/node-red-start 100%[============================================================>] 1.82K --.-KB/s in 0s
2016-10-28 09:50:25 (12.8 MB/s) - ‘/usr/bin/node-red-start’ saved [1863/1863]
pi@raspberrypi:~/domoticz $ sudo wget https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/node-red-stop -O /usr/bin/node-red-stop
--2016-10-28 09:50:29-- https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/node-red-stop
Length: 226 [text/plain]
Saving to: ‘/usr/bin/node-red-stop’
/usr/bin/node-red-stop 100%[============================================================>] 226 --.-KB/s in 0s
2016-10-28 09:50:29 (94.0 MB/s) - ‘/usr/bin/node-red-stop’ saved [226/226]
pi@raspberrypi:~/domoticz $ sudo chmod +x /usr/bin/node-red-st*
pi@raspberrypi:~/domoticz $ sudo npm install -g homebridge --unsafe-perm
npm WARN engine [email protected]: wanted: {"node":">=4.3.2"} (current: {"node":"0.10.29","npm":"1.4.21"})
> [email protected] install /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/curve25519-n
> node-gyp rebuild
make: Entering directory '/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/curve25519-n/build'
CXX(target) Release/obj.target/curve/node_curve.o
In file included from ../node_curve.cc:9:0:
curve.target.mk:82: recipe for target 'Release/obj.target/curve/node_curve.o' failed
make: *** [Release/obj.target/curve/node_curve.o] Error 1
make: Leaving directory '/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/curve25519-n/build'
cwd /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/curve25519-n
gyp ERR! not ok
> [email protected] install /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/mdns
> node-gyp rebuild
gyp ERR! UNCAUGHT EXCEPTION
gyp ERR! stack Error: ENOENT, no such file or directory
gyp ERR! stack at process.cwd (/usr/lib/nodejs/graceful-fs/polyfills.js:8:19)
gyp ERR! stack at Object.exports.resolve (path.js:309:52)
gyp ERR! stack at configure (/usr/share/node-gyp/lib/configure.js:26:23)
gyp ERR! stack at Object.self.commands.(anonymous function) [as configure] (/usr/share/node-gyp/lib/node-gyp.js:66:37)
gyp ERR! stack at run (/usr/share/node-gyp/bin/node-gyp.js:72:30)
gyp ERR! stack at process._tickCallback (node.js:419:13)
cwd = origCwd.call(process)
at errorMessage (/usr/share/node-gyp/bin/node-gyp.js:119:28)
at issueMessage (/usr/share/node-gyp/bin/node-gyp.js:125:3)
at process.<anonymous> (/usr/share/node-gyp/bin/node-gyp.js:109:3)
at process.emit (events.js:95:17)
at process._fatalException (node.js:272:26)
npm ERR! Error: ENOENT, lstat '/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/nopt/README.md'
npm ERR! If you need help, you may report this *entire* log,
npm ERR! including the npm and node versions, at:
npm ERR! <http://github.com/npm/npm/issues>
npm ERR! System Linux 4.4.26-v7+
npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" "-g" "homebridge" "--unsafe-perm"
npm ERR! cwd /home/pi/domoticz
npm ERR! node -v v0.10.29
npm ERR! npm -v 1.4.21
npm ERR! path /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/nopt/README.md
npm ERR! fstream_path /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/nopt/README.md
npm ERR! fstream_type File
npm ERR! fstream_class FileWriter
npm ERR! code ENOENT
npm ERR! errno 34
npm ERR! fstream_stack /usr/lib/nodejs/fstream/lib/writer.js:284:26
npm ERR! fstream_stack Object.oncomplete (evalmachine.<anonymous>:107:15)
npm ERR! error rolling back Error: ENOTEMPTY, rmdir '/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/npmlog'
npm ERR! error rolling back [email protected] { [Error: ENOTEMPTY, rmdir '/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/npmlog']
npm ERR! error rolling back errno: 53,
npm ERR! error rolling back code: 'ENOTEMPTY',
npm ERR! error rolling back path: '/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/npmlog' }
npm ERR! Error: ENOENT, lstat '/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/semver/README.md'
npm ERR! path /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/semver/README.md
npm ERR! fstream_path /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/semver/README.md
npm ERR! errno 34
npm ERR! Error: ENOENT, lstat '/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/tar/LICENSE'
npm ERR! path /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/tar/LICENSE
npm ERR! fstream_path /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/tar/LICENSE
npm ERR! errno 34
> [email protected] install /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/ed25519
> node-gyp rebuild
pi@raspberrypi:~/domoticz $ sudo npm install -g homebridge-edomoticz --unsafe-perm
npm WARN engine [email protected]: wanted: {"node":">=0.12.0","homebridge":">=0.2.5"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN deprecated [email protected]: ReDoS vulnerability parsing Set-Cookie https://nodesecurity.io/advisories/130
[email protected] /usr/local/lib/node_modules/homebridge-edomoticz
├── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
└── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
