Page 46 of 120
Re: Domoticz app 2.0
Posted: Monday 11 April 2016 11:21
by Jordyboytjuh
I've a problem with the app that my battery is drain very fast. I've deleted it temporally now, and my battery stays the same. Is this a known problem by you guys? I've also a question about the blinds. It sends a stop command only even when I push the up or down button. I want to send an on / off signal. Keep up the good work!
Posted: Monday 11 April 2016 11:24
by galadril
Jordyboytjuh wrote:I've a problem with the app that my battery is drain very fast.
We don't know about this. Do you use geofencing??
Jordyboytjuh wrote: It sends a stop command only even when I push the up or down button. I want to send an on / off signal. Keep up the good work!
The blind issue is fixed on the beta.
Will go to production very soon!
Posted: Monday 11 April 2016 11:43
by Jordyboytjuh
No i'm not using that. Maybe it was a problem that i've installed both domoticz apps (free and licensed). I will monitor my battery status today and then add Domoticz licensed again. Can I use the beta as well? Thanks for the quick reply :)
Posted: Monday 11 April 2016 11:47
by galadril
Jordyboytjuh wrote:Can I use the beta as well? Thanks for the quick reply :)
the beta version is public so everybody can use them, IF you have the paid version
Posted: Monday 11 April 2016 12:42
by woody4165
I'm on the latest beta and I cannot see/add Local Wifi SSID in the Advanced Server Setting.
I have wifi on a it's connected, but the Local Wifi SSID is greyed out.
I'm on a LG G4 with Android 6.0 V20-d, NO root.
Have tried on a Nexus 5 with 6.0.1 rooted and it's working.
Any suggestion ?
Posted: Monday 11 April 2016 12:49
by Jordyboytjuh
I've bought the paid version of Domoticz, is the beta also included or should I download another app? Then I will try the blinds tonight.
Posted: Monday 11 April 2016 14:45
by galadril
Jordyboytjuh wrote:I've bought the paid version of Domoticz, is the beta also included or should I download another app? Then I will try the blinds tonight.
This is already explained only a few posts back:
RoadXY wrote:
martk wrote:Perhaps a stupid question, but how do I test the beta? I can't seem to find the download link? Or do I have to subscribe?
https://play.google.com/apps/testing/nl ... cz.premium
But only for premium users.
Posted: Monday 11 April 2016 15:49
by doh
Any chance of getting this working with my.domoticz.com?
thanks
Posted: Monday 11 April 2016 16:27
by galadril
doh wrote:Hi
thanks
Maybe in the future
Posted: Monday 11 April 2016 17:36
by HansieNL
galadril wrote:
doh wrote:Hi
thanks
Maybe in the future
Near future I hope ;)
Posted: Monday 11 April 2016 20:46
by Henk
Problem in the latest version (0.1.253) with a blinds switch. Performs fine in Domoticz, but in the app there's no response on switching on or off. However, when I change the settings for switch in the settings menu, I can control my blinds. However the graphics from the blinds switch don't alter no matter what position the setting in the setting menu is for the switch. A bit difficult to explain, but I think I made my point.
Posted: Tuesday 12 April 2016 0:30
by NiklasO
Love this app. Using it every day but I'm missing some widgets.
I would really like to see some new sizes for widgets.
Like 1x1 (takes up one icon space) with the temperature reading from one sensor but the one I miss the most from another app is the 1x1 toggle widget for switches.
Just a suggestion.
Posted: Tuesday 12 April 2016 6:49
by jannl
In the new stable the blinds work fine. Keep up the good work.
Verstuurd vanaf mijn XT1580 met Tapatalk
Posted: Tuesday 12 April 2016 8:41
by Jordyboytjuh
The blinds are working perfect. I've the beta also. Works great! Keep up the good work!
Posted: Tuesday 12 April 2016 10:29
by galadril
Henk wrote:Problem in the latest version (0.1.253) with a blinds switch. Performs fine in Domoticz, but in the app there's no response on switching on or off. However, when I change the settings for switch in the settings menu, I can control my blinds. However the graphics from the blinds switch don't alter no matter what position the setting in the setting menu is for the switch. A bit difficult to explain, but I think I made my point.
I'll look into the switch functionality
Posted: Tuesday 12 April 2016 11:37
by four2six
Thanks for having worked on the NFC ability.
It does work when i use 'real' switches (those that are triggering RFXtrx433 directly to send out a switch signal).
Unfortunately I'm not able to either to attach multiple of those switches to one NFC.
Working around it and trying to use a dummy switch (which has a Blockly script running behind it) doesn't seem to work, as the app doesn't save the switch to a NFC tag, even though it shows the dummy switch in the list.
Am I using the dummy switches correctly? I added a dummy switch as new hardware. In 'switches' i added a new virtual switch manually with the dummy switch as the hardware and X10 as the type. The Blockly script is working fine and causes multiple switches to be switched.
Re: Domoticz app switches do not work
Posted: Tuesday 12 April 2016 14:45
by Peracoles
Hello everyone,
I'm new at this so forgive me for any wrong posts and so. I'm using the latest version of the domoticz app and since then the switches do not respond. I'm using version 0.1.253. I would like to roll back to a previous version but have no knowledge in doing so. Maybe you could look into my problem. Scenes do react in the app.
Thanks in advance,
Peracoles
Posted: Wednesday 13 April 2016 13:08
by RFMuser
I like the app very much. I use the widget functionality to select different scenes. I also use geofences in combination with sunset to switch on the lights. However when I'm at home many times it signals 'away' and 'entering zone' it would be nice to have it solved. I guess what happens is that the gps signal is poor and domoticz app is registering this position as outside the fence. I tried to increase the range but doesn't work. I have no view on the exact programmed function but I hope you can implement some kind of delay or 'reliability' check for the position. To detect a faulty position. Maybe implement it as some kind of gps sensitivity,selectable by the user.
Posted: Thursday 14 April 2016 12:43
by woody4165
I have an issue with a custom sensor in latest beta.
When I try to see the graph, it shows up for a second and then it returns to the devices list.
Posted: Friday 15 April 2016 15:10
by martk
Blinds not working anymore in latest stable version.
In previous version you could set a slider to open or close, now it gives you 2 buttons, On and Off, both don't do anything.
