Page 46 of 114
Posted: Saturday 03 February 2018 11:14
by superustas
Madgeni, please leave the thermostat control
it works fine!
Posted: Saturday 03 February 2018 19:52
by Madgeni
I know! I don't know what the problem Google has with me, but i'm trying very hard to get this into live.
Posted: Sunday 04 February 2018 10:01
by jonaslo
Dear Madgeni! Can you enable my account? I subscribed in your website with email jonasarts at gmail. thank you!
Its appears a very good project!
Posted: Sunday 04 February 2018 11:10
by TracingETn
Dear Madgeni,
Could you enable my account? I subscribed to your website with email tracingetn at gmail.
Thank you
Eager to try it.
Posted: Sunday 04 February 2018 13:05
by getget
Hello, same for me, 404 when trying to associate
404: Not Found
Error: Not Found
at /opt/bitnami/apps/Controlicz/app.js:77:11
at Layer.handle_error (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/layer.js:71:5)
at trim_prefix (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:310:13)
at /opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:280:7
at Function.process_params (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:330:12)
at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:271:10)
at /opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:618:15
at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:256:14)
at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/route.js:121:14)
at Layer.handle_error (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/layer.js:67:12)
at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/route.js:129:13)
at loaded (/opt/bitnami/apps/Controlicz/node_modules/oauth2orize/lib/middleware/transactionLoader.js:36:25)
at SessionStore.load (/opt/bitnami/apps/Controlicz/node_modules/oauth2orize/lib/txn/session.js:27:22)
at transactionLoader (/opt/bitnami/apps/Controlicz/node_modules/oauth2orize/lib/middleware/transactionLoader.js:42:24)
Home
Posted: Sunday 04 February 2018 14:42
by Madgeni
I've just unlinked and relinked my account fine - i'm going to guess that it's either a timing issue, or that the google request is occasionally wrong
Posted: Sunday 04 February 2018 20:07
by phtinix
Hello madgeni, for information i had the same sync problem, i had to unlink/link my account and just before the link, i had to go to the link you provided on your mail (the [test]controlicz was not in the list of all boxes on google home after the unlink)
Posted: Sunday 04 February 2018 23:29
by gijsje
Is there an issue with changing the dim level to ...%?
It is not doing what it should do for my mi-light bulbs anymore
If i ask 100% i do get 14%
Posted: Monday 05 February 2018 8:38
by DewGew
phtinix wrote: Sunday 04 February 2018 20:07
I have the same issue..
EDIT: I had to go to actions on Google and start test again. It has stopped for some reason. Now I can link controlicz again.
Posted: Monday 05 February 2018 9:17
by Madgeni
gijsje wrote: Sunday 04 February 2018 23:29
I'll take a look - i've not made any changes in a couple of weeks to lights
Posted: Monday 05 February 2018 12:28
by Madgeni
Smith wrote: Monday 05 February 2018 8:45
Hello
how am I going to know if my account is active ?
thank you
If you requested access via your profile on Controlicz, you'll receive an email with instructions
Posted: Tuesday 06 February 2018 15:13
by Madgeni
eww! Delete that message, don't post your email address on forums! If you'd requested access via your profile, you would have access to GH
oh, and "Email addresses and domains must be associated with an active Google Account or Google Apps account."
Posted: Tuesday 06 February 2018 20:22
by Madgeni
you should have an email with instructions now - any problems, email me
Posted: Tuesday 06 February 2018 23:58
by Madgeni
had a really good call with Google earlier - i've asked them to retest (against Hue and LIFX bulbs as well as Nest thermostat).
But they also wanted another thermostat - what do you guys use?
Posted: Wednesday 07 February 2018 8:45
by Fred78
Posted: Wednesday 07 February 2018 8:52
by Madgeni
Thanks Fred - and it works fine with Controlicz? You can set/query temperature? Does it need a hub, or can it connect directly to Domoticz?
Posted: Wednesday 07 February 2018 9:35
by Fred78
Hi Madgeni,
It works fine with Controlicz.
- I can query the value (I still have the "thermostat xxxxx is off" bug, but I guess it's normal for the moment)
- I can set the value (still have Google's bug about comma and decimals here in France)
It's recognized perfectly by domoticz. You don't need a hub. Just the zwave controler. The thermostat shows up two devices: a thermometer sensor and a thermostat setpoint.
Posted: Wednesday 07 February 2018 12:45
by kimhaak
I am still having issues, is there someone who could help me, i would be grateful
Kim
kimhaak wrote: Thursday 01 February 2018 21:13
Hi!
Thank you for adding me to the google-test. However, the instructions is a bit unclear, as i do not know what we are trying to achieve, and how conversions.com are related.
I received one link :
https://console.actions.google.com/proj ... atorcreate which just says "There was an error completing your request, try again". (Link is censored, in case there was an unique ID in it)
If i follow the conversions guide, i kind of end up with my own project, which i don't think is correct.
Could someone explain to med what the link (
https://console.actions.google.com/proj ... atorcreate) is for?
Am i supposed to import this in my actions.google.com account somehow?
Sorry if this is comes of as negativity, i just did not understand what to do, and why. (And i am generally not a n00b in these kind of things)
If this project works and is good, i will definately donate to support the work.
Kim
Posted: Wednesday 07 February 2018 12:47
by Madgeni
PM sent
Posted: Wednesday 07 February 2018 14:18
by getget
Hello, today, no 404
l have blinds defined in domoticz. What should I say to open them ?
When I say "ouvre le velux" (open the blind called velux in french) Google says "ok J'allume la lumière velux" (ok I turn on the light velux" ans the blind .... Closes.
