Dashticz - Module - Garbage collector Topic is solved
peter68
- Domoticz version: 2020.2
Re: Dashticz - Module - Garbage collector
thanks for the quick response. will switch to beta
sammyke007
- Domoticz version: 2022.1
Is it me or did recycleapp stopped working once again?
Gianni
yep stopped again
- jvdz
- Domoticz version: 4.107
Just tested my set of scripts and that still seems to work with your details?:sammyke007 wrote: Tuesday 14 December 2021 9:50 Is it me or did recycleapp stopped working once again?
Schedule: vri 17 dec: restafval, glas ; vri 24 dec: pmd, gft ; woe 29 dec: papier-karton -
sammyke007
The Domoticz script is working fine, it's the Dashticz part/code that stopped working.jvdz wrote: Tuesday 14 December 2021 15:27Just tested my set of scripts and that still seems to work with your details?:sammyke007 wrote: Tuesday 14 December 2021 9:50 Is it me or did recycleapp stopped working once again?JosCode: Select all
I get the following errors in console:
Failed to load resource: the server responded with a status of 500 (Internal Server Error)
and
Error loading garbage: Object
(anonymous) @ js/components/garbage.js:952
Lokonli
Fixed in latest beta.sammyke007 wrote: Tuesday 14 December 2021 15:51The Domoticz script is working fine, it's the Dashticz part/code that stopped working.jvdz wrote: Tuesday 14 December 2021 15:27Just tested my set of scripts and that still seems to work with your details?:sammyke007 wrote: Tuesday 14 December 2021 9:50 Is it me or did recycleapp stopped working once again?JosCode: Select all
Running latest betaCode: Select all
Failed to load resource: the server responded with a status of 500 (Internal Server Error) and Error loading garbage: Object (anonymous) @ js/components/garbage.js:952
You can update with:
git pull
sammyke007
Faster than fast! Tnx!!
networkerict
Hi lokonli,
Since a couple of days/weeks the garbage module for Purmerend isn't working anymore.
It's https://afvalkalender.purmerend.nl/overzicht for instance for the combination 1445GJ, number 11.
I was using 3.8.3 and have upgraded to 3.9 master (but it doesn't work there as well).
Lokonli
I've checked my 'allgarbage' test config, and indeed Purmerend, and also Blink, De Afval App and Suez are not working at the moment.
The other 35 garbage providers are ok.
I'll try to fix this in the coming days.
networkerict
Great! Thanks for your continuous support and optimizations in Dashticz!Lokonli wrote: Friday 04 March 2022 16:13 I've checked my 'allgarbage' test config, and indeed Purmerend, and also Blink, De Afval App and Suez are not working at the moment.
Lokonli
Fixed in latest beta.networkerict wrote: Friday 04 March 2022 14:31 Hi lokonli,
NilsNijenhuis
Does anyone have the same problem that the garbage info of circulus berkel doesn't give results back?
couple of days ago it still worked and i haven't changed anything?!
- circulus berkel.png (29.84 KiB) Viewed 6289 times
Lokonli
Circulus Berkel indeed doesn't work at the moment. I'll try to fix it.NilsNijenhuis wrote:Does anyone have the same problem that the garbage info of circulus berkel doesn't give results back?
Verstuurd vanaf mijn SM-A526B met Tapatalk
NilsNijenhuis
Oké thanks
marmachine
- Domoticz version: 3.4834
Same issue here, i was just looking into it and came accross your post and see that Lokonli is looking into it as well...NilsNijenhuis wrote: Saturday 02 April 2022 14:58 Does anyone have the same problem that the garbage info of circulus berkel doesn't give results back?
Nice "Afval" graphic you have by the way!
Lokonli
Fixed in latest Dashticz beta.NilsNijenhuis wrote: Saturday 02 April 2022 14:58 Does anyone have the same problem that the garbage info of circulus berkel doesn't give results back?
Can you test?
NilsNijenhuis
sorry for the late response, will test it as soon as possible and will let it know
NilsNijenhuis
It works, thanks @Lokonli
- garbage.png (30.84 KiB) Viewed 6091 times
NilsNijenhuis
do you mean the afval icon? if you want to use it, see the attachment belowmarmachine wrote: Tuesday 12 April 2022 23:39Same issue here, i was just looking into it and came accross your post and see that Lokonli is looking into it as well...NilsNijenhuis wrote: Saturday 02 April 2022 14:58 Does anyone have the same problem that the garbage info of circulus berkel doesn't give results back?
couple of days ago it still worked and i haven't changed anything?!great and thanks in advance!
- garbage1.png (9.07 KiB) Viewed 6091 times
Snowdude
Can someone give a a push in the right direction. I'm not getting the right date format.
My calendar items show up nicely in the Su 15.05 format, but the garbage is in 5/10/2020
These settings are in my config file:
config["language"] = "nl_NL";
config["timeformat"] = "DD-MM-YY HH:mm";
config["calendarformat"] = "dd DD.MM HH:mm";
config["calendarlanguage"] = "nl_NL";
I found it. I was updating my config.js file in the wrong place.
