Page 46 of 51
Posted: Sunday 31 January 2021 21:31
by Lokonli
damdub wrote: Sunday 31 January 2021 15:58
Is there any way to prioritize the garbage type or, even better, a way to display a combination of images depending on the types collected on the next day ?
I tried to adjust the event times in home made garbage google calendar :
Plastic at 09.00 and Bio at 10.00
Even like this, the first item displayed in the list (and icon displayed) is always Bio bag.
Any idea ?
Combining would be a bit more difficult, but in latest beta the garbage collection will be sorted based on the order of the keys in 'garbage' parameter.
Posted: Monday 01 February 2021 0:22
by damdub
Great news !
Thank you @Lokonli !
Posted: Tuesday 02 February 2021 0:36
by damdub
Hello
another question about new calendar block
Is it possible to limit the list to the next 7 days events ?
It seems like this is only possible with layout 2 via parameter weeks
Why is it limited t this layout only ?
Thank you for your help
Posted: Saturday 06 February 2021 19:06
by HansieNL
damdub wrote: Saturday 30 January 2021 22:44
I added a few calendar blocks and one of them contains only "all day" events (birthday dates)
Is it possible to hide the "hour" column for these events or for an entire calendar even if events are not all day events ?
Check out latest beta. You can now use
layout:3 or
layout: 4 for that.
See:
https://github.com/Dashticz/dashticz/bl ... y-calendar
Posted: Monday 08 February 2021 15:50
by RuudP1987
Hello all,
New to dashticz but already came far with my skills. See attached screenshot after a few hours of testing and editing. I looked through this topic but couldn't find it so that is why I am asking.
I am looking for a few options to add:
- Sonos possibility to add my 3 speakers
- How can I group and arrange things better? Now it's a bit of a mess. I want to have the switches for my lamps and groups in a row on the left. Then my News + Buienradar radar image and forecast from owm. and last but not least my energy consumption in a third row on the right. How can I fix this?
- How can I add buienradar radar image to dashticz?
- In the topbar there is now maandag 8 february 2021. Is it possible to make it "Maandag 8 February 2021"? So with upperclass? Also I added 'sunrise' here but this doesn't show up.
Attached there is my config.JS
var config = {}
config['language'] = 'nl_NL'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SV
config['domoticz_ip'] = 'http://192.168.1.2:8080';
config['app_title'] = 'xxxx';
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
config['spot_clientid'] = 0;
config['hide_seconds'] = 1;
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['spot_clientid'] = 'xxxxxxx';
config['hide_mediaplayer'] = 1;
config['use_favorites'] = 0; //Request all Domoticz Devices, not only favorites
config['auto_positioning'] = 0; // Use 0 this if you have defined your own columns
config['owm_api'] = 'xxxxx';
config['owm_city'] = '2757345';
config['owm_name'] = 'Delft';
config['owm_country'] = 'nl';
config['owm_lang'] = 0;
config['owm_cnt'] = '3';
config['owm_days'] = true;
config['owm_min'] = true;
config['background_image'] = 'img/bg12.jpg';
blocks = {} //only once
blocks[40] = {
title: 'Huisbediening',
width: 4
//headerbar
var columns = {}
columns['bar'] = {}
columns['bar']['blocks'] = ['logo','miniclock','sunrise','settings'],
//Definition of columns
// Woonkamer, Slaapkamer, Keuken en Thermostaat
columns = {}
columns[1] = {
blocks : [40,'s1','s2', 34, 43],
//In this example: No blocks are defined in this column
//This column will be empty
width: 6
//energiemeter, gasmeter//
columns[2] = {
blocks : [2, '4_1'],
width: 6
//spotify
columns[3] = {
blocks : ['spotify'],
width: 4
//energieverbruik grafiek
columns[4] = {
blocks : ['graph_2'],
devices: [2],
legend: true,
width: 4
//gasverbruik grafiek
columns[5] = {
blocks : ['graph_4'],
devices: [4],
legend: true,
width: 4
//weerbericht
columns[6] = {}
columns[6]['blocks'] = ['currentweather_big_owm','weather_owm']
columns[6]['width'] = 3;
Posted: Monday 08 February 2021 15:58
by madpatrick
RuudP1987 wrote: Monday 08 February 2021 15:50
Hello all,
To arrange your thing, play with the collums and blocks
for ex.
Place your block to the blocks section
devices: [2],
legend: true,
width: 4
devices: [4],
legend: true,
width: 4
columns[4] = {'graph_2', 'graph_4', width: 8}
This will place the both graph next to each other.
Posted: Monday 08 February 2021 16:30
by Lokonli
First decide how many screens you want to have. Then for the first screen: how many columns do you want to have?
Make the sum of the column width 12: (=100% screen width)
So, if your column width is 4, then that column will occupy 4/12 = 33% of the screen width.
Then you can a start adding blocks to each column. Per column-row, Dashticz again can fill up to a width of 12.
So, in one column row you can place three blocks each having width 4, one with width 12, or 6 with width 2. If a block doesn't fit anymore in the current row, it will shift to the next row (of the same column).
Define a block:
blocks['buienradar'] = {width:12, isimage:true, refresh:60, btnimage: 'https://image.buienradar.nl/2.0/image/animation/RadarMapRainNL?height=300&width=360&extension=gif&renderBackground=True&renderBranding=False&renderText=True&history=3&forecast=6&skip=1', url: 'https://www.buienalarm.nl/amsterdam-noord-holland-nederland/52.3727,4.8936'}
This will become a so called 'button' block, containing an image, and an url which will open on click.
And then add this button to a column:
columns[3] = {
blocks: ['buienradar']
Posted: Monday 08 February 2021 16:38
by RuudP1987
Thanks for the quick answer. But with the blocks I got this syntax error now:
SyntaxError: Unexpected token ':'. Parse error. at line 34, which is this line:
Also I added the blocks title to my switches but this Block title won't show up
blocks[40] = {
width: 4
devices: [2],
legend: true,
width: 4
devices: [4],
legend: true,
width: 4,
//headerbar
var columns = {}
columns['bar'] = {}
columns = {}
columns[1] = {
width: 6
//spotify
columns[3] = {
width: 4
//energiegrafieken
//weerbericht
columns[6] = {}
Posted: Monday 08 February 2021 16:44
by madpatrick
Try:
blocks['graph_2'] = {
devices: [2],
legend: true,
width: 4
blocks['graph_4'] = {
devices: [4],
legend: true,
width: 4,
Posted: Monday 08 February 2021 17:42
by RuudP1987
I am getting there but the layout is getting messier and messier haha. Buienradar works now!
Is there somewhere a guide on setting up blocks and more?
Posted: Monday 08 February 2021 17:46
by Sjonnie2017
RuudP1987 wrote: Monday 08 February 2021 17:42
Start here:
https://dashticz.readthedocs.io/en/master/
HTH
Greetz,
Sjonnie
Posted: Tuesday 09 February 2021 9:44
by RuudP1987
Hello all,
I have been busy working with columns and blocks.. My first block I got set up properly but when I add my second row it all goes wrong again.. What am I doing wrong? I calculated the width of the blocks and as Lokonli said a block is 12 and a column can be divided in 12 again. But I want the OWM and buienradar on their own line so I made these both 6 width. Attached a screenshot and my new code. My light switches and thermostat are at the correct place. The buienradar and OWN needs to go right of that block.
blocks['s1','s2',34,43] = {
Width:4
columns[1] = {
blocks: ['s1','s2',34],
width: 4,
columns[2] = {
blocks: [43],
width: 12,
blocks['buienradar','currentweather_big_owm','weather_owm'] = {
Width:4
columns[3] = {
blocks: ['buienradar'],
width: 3,
columns[4] = {
blocks: ['currentweather_big_owm','weather_owm'],
width: 3,
Also if I start using
blocks['s1'] = { //Select group/scene with Domoticz index 12
title: 'Slaapkamer'
Then I can name these easily and implement them in a block instead of 's1' I use 'Slaapkamer' right?
Posted: Tuesday 09 February 2021 9:57
by madpatrick
How does your screens setup look ?
for example:
//Definition of screens
screens = {}
screens[1] = {
columns: [1, 2]
Posted: Tuesday 09 February 2021 10:16
by Lokonli
RuudP1987 wrote: Tuesday 09 February 2021 9:44
Hello all,
Width:4
columns[1] = {
width: 4,
columns[2] = {
blocks: [43],
width: 12,
Width:4
columns[3] = {
width: 3,
columns[4] = {
width: 3,
title: 'Slaapkamer'
The keys are case sensitive. So use 'width' instead of 'Width'
And probably the next statement is incorrect:
Width:4
Width:4
Start the simple way, and define your blocks like:
blocks['s1'] = {
width: 4
blocks['s2'] = {
width: 4
width: 4,
//add the other parameters like btnimage and url here as well
Posted: Tuesday 09 February 2021 10:35
by RuudP1987
madpatrick wrote: Tuesday 09 February 2021 9:57
for example:
screens = {}
screens[1] = {
columns: [1, 2]
I don't use screens as I just only want 1 screen at the moment. Does it make any difference?
Posted: Tuesday 09 February 2021 11:00
by Lokonli
RuudP1987 wrote: Tuesday 09 February 2021 10:35
for example:
screens = {}
screens[1] = {
columns: [1, 2]
If you don't define screens[1] in CONFIG.js, then by default a screens[1] will be created that contains all columns you defined.
So, it should work ...
Your column 1 contains three blocks, and has width 4.
Your column 2 contains one block '43'. I assume this is the Thermostaat device. The column has width 12, so this second column doesn't fit right of the first column.
That means column 2 will start on a new row, below column 1.
Column 3 has width 3. However, column 2 (width 12) already covers the whole screen width. That means column 3 will start a new row, below column 2.
Column 4 has width 3. This column will fit right of column 3. The two columns together will fit within the left 50% of the screen.
So it seems the screenshot exactly shows how you defined your columns.
Posted: Tuesday 09 February 2021 13:29
by RuudP1987
Lokonli wrote: Tuesday 09 February 2021 11:00
for example:
screens = {}
screens[1] = {
columns: [1, 2]
I think I now get it. Back to the drawing bord!
Posted: Tuesday 09 February 2021 15:00
by Lokonli
Looking forward to see the results!
Posted: Wednesday 10 February 2021 16:55
by RuudP1987
Making a lot of progress these days! Almost happy with the result!
Although I want a graph with bars. But when I have set up this code nothing shows up anymore. What am I missing that it only displays the title and the usage and the custom buttons but not the graph?
title: 'Mijn verbruik',
devices: [2],
graph: 'bar',
width: 12, //12 is 100% column breedte
custom : {
"Last 2 weeks": {
range: 'month',
filter: '14 days',
"Last 6 months": {
range: 'year',
filter: '6 months',
legend: true,
Posted: Monday 15 February 2021 11:26
by RuudP1987
Almost done!
Only question left is my graph and how to center the Buienradar screen in my 2nd column?
