Controlicz - Easy Domoticz to Alexa Integration Topic is solved
Alexa, Google Home and Siri
Madgeni
Re: Controlicz - Easy Domoticz to Alexa Integration
Post by Madgeni »
Am investigating an issue with Controlicz that is affecting service. Will update you asap
hayman
Domoticz version: 3.8153
Post by hayman »
Hier olso Not working
Madgeni
Post by Madgeni »
Ok - service is back, but will be watching it for any other issues. Will update if anything else occurs.
For those using firewall rules, please note the IP change (you'll see it in your logs). I've switched to an elastic IP, which whilst short term pain, is long term gain.
hayman
Post by hayman »
Yes working again
freijn
Domoticz version: Stable
Post by freijn »
"Alexa switch on Xmastree" "Xmastree is not responding" heemmmmm suddenly getting conscious of our usage of Alexa and Controlicz :-)
Still not working :-( Netherlands...
Madgeni
Post by Madgeni »
Let me take a look - can you mail me from your Controlicz profile?
freijn
Post by freijn »
ok, got it working indeed by opening the firewall for 35.178.116.149.
Madgeni, what is an elastic ip ? How long will you keep this ip address ?
I refuse opening my Domoticz to the whole world. ( definitely will be troubles )
Madgeni
Post by Madgeni »
This is the last time it will change. this allows me to perform any infrastructure changes i need without changing the IP address. Should have done it at the start, but just didn't :/
freijn
Post by freijn »
THanks for the explain, and thanks for the always perfect service !
Wish you happy new year with much health and much time to Control :-)
RvdB
Post by RvdB »
Madgeni wrote: Sunday 30 December 2018 18:44 Ok - service is back, but will be watching it for any other issues. Will update if anything else occurs.
Madgeni,
since you're now "in business" and running a paid service, this is a change that should have been communicated to your customers prior to being implemented.
So would you please inform us next time you plan to change something with major impact. ;)
Thanks in advance.
Madgeni
Post by Madgeni »
Hi, apologies, will make sure any change like that is communicated in future - it was done as a side change to the wider issues caused by google's auth issue.
Carlosfandango
Post by Carlosfandango »
Controlicz can access my domoticz with the test. Alexa can search for devices, however all devices are unresponsive, and can't figure out why as this was working fine. Nothing has changed. I have reset everything and still get the same issue. Any ideas?
Madgeni
Post by Madgeni »
Carlosfandango wrote: Friday 11 January 2019 0:25 Controlicz can access my domoticz with the test. Alexa can search for devices, however all devices are unresponsive, and can't figure out why as this was working fine. Nothing has changed. I have reset everything and still get the same issue. Any ideas?
Hi - just contact me from your Controlicz profile and i'll take a look
Skwi
Post by Skwi »
Hi, same here. Was working fine until this morning. All my devices are now "not responding" in alexa. I tried to delete one to add again but alexa discover nothing
l0gic
Domoticz version: Latest
Post by l0gic »
+1 with the non responsive issue since this morning.
All working around 10:30 last night, nothing working 7:00 this morning.
The test from the web site indicates connection is ok.
Checking my firewall I can see the call coming in ok.
Domoticz fails to switch anything, there are no errors in the domoticz log.
Happy to help diagnosis if required.
ATB
kevin
Non credus crepitus
Scoobydoo
Post by Scoobydoo »
+1 mines also unresponsive since this morning.
Test connection says working ok but nothing working.
Has been fine for months since today.
Skwi
Post by Skwi »
Quick response from the creator : disactivate & reactivate the skill did the job for me, thanks !
jaschu
Domoticz version: 3.8184
Post by jaschu »
Same problem here but here is the solution:
Disable and re-enable the Controlicz skill. After that every switch, scene, thermostat etc. worked again.
Scoobydoo
Post by Scoobydoo »
Skwi wrote: Friday 18 January 2019 20:59 Quick response from the creator : disactivate & reactivate the skill did the job for me, thanks !
This worked for me too.
Madgeni
Post by Madgeni »
Hi -
just came in to apologise - i have some background security checks which remove expired OAUTH tokens, however it inadvertently removed active ones. This shouldn't happen again, but apologies for any issues caused.
A simple disable/enable will resolve it
