Page 46 of 184
Re: Dashticz v2.0, custom positioning and multiple screens
Posted: Saturday 15 April 2017 13:20
by wizjos
I've just added a textual representation of the dimmer percentage behind the name of the dimmer (eg. Dimmername: 40%)
I've done this by altering the dimmer-code in main.js:
html+='<strong class="title">'+device['Name']+'</strong><br />';
in
html+='<strong class="title">'+device['Name']+': '+device['Level']+'%'+'</strong><br />';
at line 663 (the block starting with: else if(device['SwitchType']=='Dimmer'){)
Regards,
Wizjos
Posted: Saturday 15 April 2017 13:21
by SwordFish
It is hard to keep up with all the new updates
Its nice to see how everyone can customize his on dashboard.
@Robgeerts, thanks for al your hard work
Posted: Saturday 15 April 2017 13:32
by EdwinK
I agree. Thanks for your works, Rob. Now... why don't you go celebrate some Easter
Posted: Saturday 15 April 2017 13:45
by SwordFish
wizjos wrote:I've just added a textual representation of the dimmer percentage behind the name of the dimmer (eg. Dimmername: 40%)
in
Regards,
Wizjos
Thanks, that looks nice
Posted: Saturday 15 April 2017 13:50
by robgeerts
in
Nice, added this to the latest version, wich will be pushed later!
Dropshot wrote:
Thank you, I've the icon working now! Is it also possible to switch the title and value for the custom sensors? As I've showed earlier, it's different compared to temperature and lux for instance:
In next version it's possible to use:
blocks[233] = {}
blocks[233]['switch'] = true;
Stay tuned
EdKo66 wrote:Now... why don't you go celebrate some Easter
Because i'm busy with:
Dropshot wrote:Could it be possible to see the graps, of for instance the temperature, when I press on the block?
Posted: Saturday 15 April 2017 14:23
by Dropshot
You're a legend.
Maybe some easter-eggs then?
Posted: Saturday 15 April 2017 14:32
by robgeerts
Please test this in latest version
blocks[233] = {}
Stay tuned
Posted: Saturday 15 April 2017 14:45
by repoman
Hi All,
This is my first post on this forum. I've been reading this for about a week and installed it for the first time on april 10.
It was very easy to get it up and running. Great job making this dashboard!
On april 14 I downloaded a new version and put in in a new folder (dashboard2)
Then I copied my settings.js from folder dashboard1 to dashboard 2 and expected it to work.
Strangely I get the same problem as b00n. There are no devices/sensors etc anymore.
Then I edited the default config in dashboard2 and only changed the ip:port and saved it as config.js
Still no devices/sensors.
Today I downloaded a new version and put it in folder dashboard3.
Changing the ip:port still does't show devices. Everything else is left as default.
The version from april 10 still works...
Am I missing something? I don't understand whats the problem could be.
While I'm at it. My smoke detector also says "smoke detected" while the status is normal.
At last I've a request. Is it possible to add a parameter to show in the devices the date/time when last changed?
(or only time if it's today and also date if not today)
I would like to see if a motion sensor has been triggered recently...
Thanks all and keep up the good work!
Pascal
Posted: Saturday 15 April 2017 14:48
by SwordFish
repoman wrote:Hi All,
Pascal
Can you post your config file so that we can see what you have at the moment.
Posted: Saturday 15 April 2017 14:50
by robgeerts
Whats the output of your smoke device?
Posted: Saturday 15 April 2017 14:58
by Dropshot
robgeerts wrote:Dropshot wrote:Could it be possible to see the graps, of for instance the temperature, when I press on the block?
Great work already (and so fast!!
). It seems to add a graph when I press for instance 'laatste uren' or 'afgelopen maand' and these graphs seems to become bigger and bigger every time:
blocks[233] = {}
Stay tuned
It works!
Posted: Saturday 15 April 2017 15:04
by freakshock
You're an animal Rob!
For current power usage, daily power usage and daily gas usage I get this as a result, probably not coded yet?
The first few tries I just got a Loading... screen.
Posted: Saturday 15 April 2017 15:10
by SwordFish
Its not working for al the temperature, its only working for me on the motherboard temperature.
Posted: Saturday 15 April 2017 15:14
by repoman
Ok, this is my settings.js It works in my download from april 10 but not in the versions downloaded april 14 & 15...
var _LANGUAGE = 'nl_NL'; //or: en_US, fr_FR, hu_HU
var _HOST_DOMOTICZ = 'http://192.168.90.10:8080';
var _APIKEY_WUNDERGROUND = 'xx';
var _WEATHER_CITY = 'Moerbeke';
var _WEATHER_COUNTRY = 'BE';
var _USE_AUTO_POSITIONING = true; //don't want to configure positions, use auto positioning
var _USE_FAVORITES = true; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK = true; //do not show the seconds in the clock
var _NEWS_RSSFEED = 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT = false;
var _STANDBY_AFTER_MINUTES = false; //enter amount of seconds like: 5 (5 seconds)
var buttons = {}
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=180', url: 'http://www.weer.nl/verwachting/nederland/son/189656/'}
buttons.camera1 = {width:12, isimage:true, refreshimage:60000, image: 'http://192.168.90.20:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=repoman&pwd=C4/fYkBr', url: 'http://192.168.90.20:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=xxpwd=xx'}
buttons.camera2 = {width:12, isimage:true, refreshimage:60000, image: 'http://192.168.90.17/axis-cgi/jpg/image.cgi', url: 'http://192.168.90.17/axis-cgi/jpg/image.cgi'}
CUSTOM POSITIONING:
//defining wich blocks to show, de numbers represents the IDX of the device in Domoticz
//only define if you want to use a custom width instead of the default
var blocks = {}
blocks[1] = {}
blocks[1]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
blocks[204] = {} //dimmer
blocks[204]['width'] = 12;
blocks[248] = {} //dimmer
blocks[248]['width'] = 12;
blocks[295] = {} //dimmer
blocks[295]['width'] = 12;
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Schakelaars';
//defining number of columns, their contents en widths
//width can be a number 1 to 12, but total widths of all columns should always be 12
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1',1,2,62,'144_2',204,248,295] //remark: idx 144 produces 2 blocks, so you can use: '144_1' and '144_2' (or of course, just 144 if you want one)
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['currentweather_big','weather',5,'144_1']
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['clock','sunrise','horizon',buttons.buienradar,buttons.radio,buttons.calendar,buttons.nunl,buttons.nzbget]
columns[3]['width'] = 2;
//if you want to use multiple screens, use the code below:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg1.jpg';
//screens[2] = {}
//screens[2]['background'] = 'bg3.jpg';
//screens[2]['columns'] = [4,5,6]
Posted: Saturday 15 April 2017 15:33
by robgeerts
This is still BETA, have to extend the functionality
Posted: Saturday 15 April 2017 15:35
by robgeerts
repoman wrote:Ok, this is my settings.js It works in my download from april 10 but not in the versions downloaded april 14 & 15...
var buttons = {}
CUSTOM POSITIONING:
var blocks = {}
blocks[1] = {}
var columns = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
var screens = {}
screens[1] = {}
//screens[2] = {}
Just tested your config.js and worked over here...
Could you clean your browsercache?
Posted: Saturday 15 April 2017 15:38
by Blueone
I changed the code from the stand-by functionality a little bit so it also comes out of standby with a higher brightness. Also I added a check if the stand-by is active so is doesn't send the request every few seconds, also changed the stand-by time from minutes to seconds.
//STANDBY FUNCTION
if(parseFloat(_STANDBY_AFTER_MINUTES)>0){
setInterval(function(){
standbyTime+=1000;
},1000);
if(standbyActive!=true){
if(standbyTime>=((_STANDBY_AFTER_MINUTES*1000)){
$('body').addClass('standby');
if(typeof(_STANDBY_CALL_URL)!=='undefined' && _STANDBY_CALL_URL!==''){
$.get(_STANDBY_CALL_URL);
standbyActive=true;
},5000);
$('body').bind('mousemove', function(e){
disableStandby();
$('body').bind('click', function(e){
disableStandby();
function disableStandby(){
if(standbyActive==true){
standbyTime=0;
$('body').removeClass('standby');
if(typeof(_END_STANDBY_CALL_URL)!=='undefined' && _END_STANDBY_CALL_URL!==''){
$.get(_END_STANDBY_CALL_URL);
standbyActive=false;
//END OF STANDBY FUNCTION
Maybe it is helpfull
Posted: Saturday 15 April 2017 15:44
by robgeerts
Thanks Blueone!
But, did it work for your raspberry pi??
Posted: Saturday 15 April 2017 15:48
by Blueone
robgeerts wrote:Thanks Blueone!
Yes, my screen does go to a lower brightness know when it enters stand-by! and also comes up again. Btw, I also changed the stand-by time to seconds instead of minutes
I only notice that it hangs sometimes so probably I did something wrong in de main.js, I have to check that.
Stand-by to do:
Create a css which is only showing the time big, termperature big and the weather so I can see those things from a distance when is is in stand-by. Going on a holiday but after that I'm going to create something like this.
And I have to optimze the css further for the raspberry touchscreen.
A bit like this in stand-by and the full experience in active mode:
- toonstandby.jpg (57.95 KiB) Viewed 1965 times
Attached a short video
https://vimeo.com/213339928
Posted: Saturday 15 April 2017 15:59
by repoman
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Normal",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 1,
"HardwareName" : "RepoRFXCom",
"HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
"HardwareTypeVal" : 1,
"HaveDimmer" : false,
"HaveGroupCmd" : false,
"HaveTimeout" : false,
"ID" : "15E400",
"LastUpdate" : "2016-12-25 10:09:12",
"MaxDimLevel" : 0,
"Name" : "smoke detector",
"Notifications" : "true",
"PlanID" : "6",
"PlanIDs" : [ 6 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : 7,
"Status" : "Normal",
"StrParam1" : "aHR0cDovLzE5Mi4xNjguOTAuMTAvdHJpZ2dlci5waHA/dHJpZ2dlcj1zbW9rZV9hbGFybV9vbg==",
"StrParam2" : "aHR0cDovLzE5Mi4xNjguOTAuMTAvdHJpZ2dlci5waHA/dHJpZ2dlcj1zbW9rZV9hbGFybV9vZmY=",
"SubType" : "KD101 smoke detector",
"SwitchType" : "Smoke Detector",
"SwitchTypeVal" : 5,
"Timers" : "false",
"Type" : "Security",
"TypeImg" : "smoke",
"Unit" : 0,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "18"
