homebridge-edomoticz Plugin
- TheRamon
- Domoticz version: BETA
Re: homebridge-edomoticz Plugin
Alrighty, I have just updated the master branch.
Please note, mqtt-integration is discontinued!
In order to switch branches on git, please use:
$ git checkout master
Or wait a bit, @Marci will update npm soon. After that, you'd just use
$ npm install homebridge-edomoticz
MacJL
- Target OS: OS X
Thank you TheRamon. I've rebuild my docker homebridge container, and I have no problem anymore with the authentication with the mqtt branch. Now I'm rebuilding it again with the master branch.TheRamon wrote:Whoops! There was still one small bug with authorization going on. I have just fixed this on the MQTT branch.
[EDIT] It's OK for master branch too [/EDIT]
- TheRamon
Great news, good to hear!
Artic1980
root@octopi:/home/pi# sudo npm install -g homebridge
sudo: npm: command not found
Whi??
Whi??
Try...
sudo apt-get install npm
- Marci
- Domoticz version: 3.8153
You can't blindly follow a guide and presume all works. For the errors you're seeing something has gone wrong with one of the commands.Artic1980 wrote:root@octopi:/home/pi# sudo npm install -g homebridge
Whi??
Start again from scratch, preferably using one of the Domoticz images, rather than a barebones Jessie install, which as stated in the first post, is for folks who know what they're doing and are capable of resolving basic Linux issues that may arise for themselves.
Essentially, you haven't got a working install of node / npm on your system, therefore nothing will have installed correctly, hence everything responds with 'command not found'.
- Marci
Done! Version now nudged to v1.0.0!TheRamon wrote:Or wait a bit, @Marci will update npm soon. After that, you'd just use
Folks already running homebridge-edomoticz can update via npm update!
rwijbenga
@TheRamon:
I have updated the the latest master branch, but no dice on color changing... How can I test if the HTTP fallback works? Or what do you need for debugging
Mazzokun
I have updatedTheRamon wrote:The whole point of MQTT is that changes you make in your HomeKit app get sent immediately. Also, when switching a value in Domoticz itself, the HomeKit app gets updated immediately. Works really nice.
sudo npm update -g homebridge-edomoticz --unsafe-permWhere is my mistake? Thank you for hard work
Artic1980
now have this error
root@octopi:/home/pi# npm install -g homebridge
npm WARN engine [email protected]: wanted: {"node":">=4.3.2"} (current: {"node":" 0.10.29","npm":"1.4.21"})
npm WARN engine [email protected]: wanted: {"node":">=4.3.2"} (current: {"node": "0.10.29","npm":"1.4.21"})
npm WARN `git config --get remote.origin.url` returned wrong result (git://githu b.com/KhaosT/node-srp) Please run git without sudo, your regular user account is enough
npm ERR! git clone git://github.com/KhaosT/node-srp Please run git without sudo, your regular user account is enough
npm ERR! Error: Command failed:
npm ERR! at ChildProcess.exithandler (child_process.js:647:15)
npm ERR! at ChildProcess.emit (events.js:98:17)
npm ERR! at maybeClose (child_process.js:755:16)
npm ERR! at Process.ChildProcess._handle.onexit (child_process.js:822:5)
npm ERR! If you need help, you may report this *entire* log,
npm ERR! including the npm and node versions, at:
npm ERR! <http://github.com/npm/npm/issues>
npm ERR! System Linux 4.4.27-v7+
npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" "-g" "homebridge"
npm ERR! cwd /home/pi
npm ERR! node -v v0.10.29
npm ERR! npm -v 1.4.21
npm ERR! code 1
npm ERR!
npm ERR! Additional logging details can be found in:
npm ERR! /home/pi/npm-debug.log
npm ERR! not ok code 0
npm ERR! code 1
npm ERR!
Mazzokun
Step by step this guide and you can't failArtic1980 wrote:now have this error
sudo raspi-config <- adjust time in advanced
sudo apt-get update
sudo apt-get upgrade
sudo reboot
sudo rpi-update
sudo reboot
mkdir ~/domoticz
cd ~/domoticz
wget http://releases.domoticz.com/releases/release/domoticz_linux_armv7l.tgz
tar xvfz domoticz_linux_armv7l.tgz
rm domoticz_linux_armv7l.tgz
sudo cp domoticz.sh /etc/init.d
sudo chmod +x /etc/init.d/domoticz.sh
sudo update-rc.d domoticz.sh defaults
cd ~/domoticz
sudo ./domoticz
[ctrl-c]
sudo service domoticz.sh start
# INSTALL HOMEBRIDGE
cd ~/
sudo apt-get install apt-transport-https
sudo apt-get remove nodejs
sudo rm -rf /usr/local/{lib/node{,/.npm,_modules},bin,share/man}/{npm*,node*,man1/node*} /var/db/receipts/org.nodejs.*
hash -r
wget https://nodejs.org/dist/v6.3.1/node-v6.3.1-linux-armv7l.tar.gz
tar -xvf node-v6.3.1-linux-armv7l.tar.gz
cd node-v6.3.1-linux-armv7l
sudo cp -R * /usr/local/
cd ~/
sudo apt-get install libavahi-compat-libdnssd-dev
sudo npm install -g homebridge --unsafe-perm
sudo npm install -g homebridge-edomoticz --unsafe-perm
mkdir ~/.homebridge
sudo pico ~/.homebridge/config.json
——Config.json
"bridge": {
"name": "Homebridge",
"username": "CC:21:4E:E7:DF:33",
"port": 51826,
"pin": "031-45-154"
"description": "Configuration file for (e)xtended Domoticz platform.",
"platforms": [
"platform": "eDomoticz",
"name": "eDomoticz",
"server": "127.0.0.1",
"port": "8080",
"ssl": 0,
"roomid": 0
"accessories": []
sudo find / -name homebridge
sudo pico /lib/systemd/system/homebridge.service
[Unit]
Description=HomeBridge Service
After=multi-user.target
[Service]
User=pi
Type=idle
ExecStart=/usr/bin/homebridge <- adjust here with the correct path find with previous sudo find ;)
[Install]
WantedBy=multi-user.target
sudo chmod 644 /lib/systemd/system/homebridge.service
sudo systemctl daemon-reload
sudo systemctl enable homebridge.service
sudo reboot
#STATUS HOMEBRIDGE
sudo systemctl status homebridge.service -l-
Artic1980
error
root@octopi:~# sudo npm install -g homebridge --unsafe-perm
npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/KhaosT/node-srp.git /root/.npm/_git-remotes/git-github-com-KhaosT-node-srp-git-7ab735e3: Please run git without sudo, your regular user account is enough
npm ERR! Linux 4.4.27-v7+
npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "-g" "homebridge" "--unsafe-perm"
npm ERR! node v6.3.1
npm ERR! npm v3.10.3
npm ERR! code 1
npm ERR! Command failed: git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/KhaosT/node-srp.git /root/.npm/_git-remotes/git-github-com-KhaosT-node-srp-git-7ab735e3
npm ERR!
npm ERR!
npm ERR! If you need help, you may report this error at:
npm ERR! <https://github.com/npm/npm/issues>
npm ERR! Please include the following file with any support request:
npm ERR! /root/npm-debug.log
npm ERR! code 1
npm ERR!
npm ERR!
Mazzokun
you haven't done the guide step by step, format, install raspbian and start from the very beginningArtic1980 wrote:error
npm ERR! code 1
npm ERR!
npm ERR!
- TheRamon
Ehhh, could you check the domoticz log? (Not homebridge)rwijbenga wrote:@TheRamon:
You can view the log on the website. (Probably localhost:8080/#/Log)
Upon sending a "colour" command, you should either see something like "Command sent" or something like "Could not parse mqtt command".
Could you try a few times and post that log here?
Thanks.
I'm not really sure, but try to go to your homebridge folder, and do a simple:Mazzokun wrote:I have updatedTheRamon wrote:The whole point of MQTT is that changes you make in your HomeKit app get sent immediately. Also, when switching a value in Domoticz itself, the HomeKit app gets updated immediately. Works really nice., removed Home from iCloud, changed Mac SN and pin in Config.json and restart the PI and reconfigured the home in iOs. Nothing changed, if i switch a value in Domoticz, HomeKit doesn't get updated.Code: Select all
$ npm update homebridge-edomoticz
You're installing homebridge-edomoticz with -g, that means globally. Could be that your homebridge folder already has a node_modules folder with the old version of homebridge-edomoticz. Either remove that folder or run the above command.
rwijbenga
@TheRamon:
This is the log I got:
Let me know if you need more info.
2016-10-27 12:26:18.117 MQTT: Topic: domoticz/in, Message: {"command":"switchlight","idx":291,"switchcmd":"On"}
2016-10-27 12:26:18.117 RFLink Sending: 10;MiLightv1;f748;01;0000;ON
2016-10-27 12:26:18.285 (RFLink) Lighting Limitless/Applamp (Bureau Lamp)
2016-10-27 12:26:18.397 MQTT: Topic: domoticz/in, Message: {"command":"switchlight","idx":291,"level":100,"switchcmd":"Set Level"}
2016-10-27 12:26:18.398 RFLink Sending: 10;MiLightv1;f748;01;00fc;ON
2016-10-27 12:26:18.579 RFLink Sending: 10;MiLightv1;f748;01;00fc;BRIGHT
2016-10-27 12:26:18.734 (RFLink) Lighting Limitless/Applamp (Bureau Lamp)
2016-10-27 12:26:30.443 User: Admin initiated a switch command (291/Bureau Lamp/setcolbrightnessvalue)
2016-10-27 12:26:34.705 User: Admin initiated a switch command (291/Bureau Lamp/setcolbrightnessvalue)
2016-10-27 12:26:37.297 User: Admin initiated a switch command (291/Bureau Lamp/setcolbrightnessvalue)
2016-10-27 12:26:39.005 User: Admin initiated a switch command (291/Bureau Lamp/setcolbrightnessvalue)
2016-10-27 12:26:40.737 User: Admin initiated a switch command (291/Bureau Lamp/setcolbrightnessvalue)
2016-10-27 12:26:42.030 User: Admin initiated a switch command (291/Bureau Lamp/setcolbrightnessvalue)
2016-10-27 12:26:43.336 User: Admin initiated a switch command (291/Bureau Lamp/setcolbrightnessvalue)- TheRamon
It actually looks like switching colours on your Bureau Lamp is not broken. It even sends the command over HTTP like intended.
You're basically sending the below command. Will you try this one out in your browser please? (Should change lamp to red)
domoticz_url:8080/json.htm?type=command¶m=switchlight&idx=291&switchcmd=setcolbrightnessvalue&hex=FF0000
Also, try out the command below, does this one work for you? (Should change lamp to blue)
domoticz_url:8080/json.htm?type=command¶m=switchlight&idx=291&switchcmd=setcolbrightnessvalue&hue=240&brightness=100&iswhite=false
If the one above works, please try out this one: (Should change lamp to green)
domoticz_url:8080/json.htm?type=command¶m=switchlight&idx=291&switchcmd=setcolbrightnessvalue&hue=120&brightness=100&sat=100&iswhite=false
rwijbenga
I get an error about hardware:
When I use this JSON command it changes the color:
Output:
I use the RFLink hardware in combination wit MiLight's. Maybe the JSON command are different?
"message" : "Error sending switch command, check device/hardware !",
"status" : "ERROR",
"title" : "SwitchLight"
}Code: Select all
http://domoticz_url:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=291&hex=FFC700Code: Select all
"status" : "OK",
"title" : "SetColBrightnessValue"
simon_rb
- Target OS: -
Marci,
Was wondering if you could modify the way edomoticz exposes the Nest Thermostat to Homebridge/kit. Currently it always says heating and the other day when out I set the house to warm up for when we got home. I later asked the house if heating was on and Siri said your house is heating when it wasn't. Mrs wasn't happy to arrive home to a cold house.
Anyways, there is a heating on switch which is automatically added when you add the nest to domoticz. Would there be away to link that to homebridge to expose that as an indication if the heating is on or not? Might be a little complicated if you need the IDX number as that would be different for each person. Maybe each user edits a config file themselves with the IDX number, or maybe it can be grabbed by device name and everyone names it as heating.
Maybe it isn't possible, just thought I'd ask the question. Cheers mate!!!!!
- G3rard
- Target OS: -
- Domoticz version: No
@TheRamon and @Marci, just updated to the latest version of eDomoticz (had to do some updates on homebridge and nodejs before everything was working, had still old versions running).
It is working great. The MQTT solution is really fast! Also curious to see how the caching solution is working.
Thank you for this superb software
Not using Domoticz anymore
Mazzokun
I format and then reinstalled everything from beginning, but still can't see any change in iOS App if I type a command into domoticz webpageTheRamon wrote:I'm not really sure, but try to go to your homebridge folder, and do a simple:
sudo apt-get update
sudo reboot
sudo rpi-update
sudo reboot
sudo apt-get install libdevice-serialport-perl
sudo apt-get install telnet
mkdir ~/domoticz
cd ~/domoticz
cd ~/domoticz
sudo ./domoticz
[ctrl-c]
cd ~/
hash -r
cd ~/
sudo npm install homebridge
sudo npm install homebridge-edomoticz
mkdir ~/.homebridge
——Config.json
"bridge": {
"port": 51826,
"pin": "031-45-154"
"platforms": [
"port": "8080",
"ssl": 0,
"roomid": 0
"accessories": []
[Unit]
[Service]
User=pi
Type=idle
ExecStart=/home/pi/node_modules/homebridge/bin/homebridge
[Install]
sudo reboot
#STATUS HOMEBRIDGE
#UPDATE
sudo npm update -g homebridge --unsafe-perm
sudo systemctl restart homebridge
Thank you for support
