Page 45 of 76
Re: Pass2PHP
Posted: Sunday 05 May 2019 10:47
by Trigun
sincze wrote:please have a look on the example files e.g. _cron60.php
Look for an example with function past(60) in it.
And issue the sw function but now off. :)
Dit you implement cron.sh the Domoticz monitor and also used for pass2php crons??
Ok great! Will look into it! I am getting more and more excited Image
Euh no I didn’t where do I need to put it?
Is it also automatically restarting Domoticz when it crashes?
Re: Pass2PHP
Posted: Sunday 05 May 2019 11:10
by poudenes
Hi All,
My problems are solved for so far. Test script work now when I switch "Switch-Hall-MEEK" then also dressoir is going in.
I was forget:
<?php to start
?> to end the file.
Still I don't get log lines in domoitcz.log but thats probably just a path thing...
Re: Pass2PHP
Posted: Sunday 05 May 2019 12:05
by sincze
Yes it restarts Domoticz when it crashes. Beautiful :) does not happen often luckily
I put it in /home/pi/domoticz/scripts/pass2php
I automatically backup the Domoticz directory to a NAS so if I keep everything in this directory it is automatically backupped. :)
Now edit
sudo nano /etc/crontab
Add the script here to run every minute and. Voila a working keep Domoticz alive Monitor.
Sent from my ONEPLUS A6003 using Tapatalk
Re: Pass2PHP
Posted: Sunday 05 May 2019 12:08
by sincze
poudenes wrote:Hi All,
I was forget:
<?php to start
?> to end the file.
Should be /var/log/***
If it can't create the file the rights have to be adjusted...
Cheat:
cd /var/log
touch filename.***
sudo chmod www-data:www-data filename.***
Now it should be possible for the Apache machine to add data. This works for nginx so I assume apache is also using www-data as a user.
Re: Pass2PHP
Posted: Sunday 05 May 2019 12:37
by Trigun
sincze wrote: Sunday 05 May 2019 12:05
Now edit
ok, put the script in the /home/pi/domoticz/scripts/pass2php folder and gave it the 777 rights.
is this crontab filled in correctly(as it looks different).
2019-05-05 12_37_18-192.168.1.200.png (156.87 KiB) Viewed 1057 times
Re: Pass2PHP
Posted: Sunday 05 May 2019 12:47
by sincze
Looks okay on my phonescreen.
User root will call the file Evey minute ;) :D
Usually you pipe the output to something with the > But don't know that by heart. Give it a Google search what the best option would be. This could work.
Re: Pass2PHP
Posted: Sunday 05 May 2019 13:25
by Trigun
sincze wrote:Looks okay on my phonescreen.
I got it to pipe the output to a cronlog.log file in the same directory but now my Domoticz is restarting every minuteImage. Do I have to change the cron.sh file? When I open the file I see it is looking at different Cron.php files and a smappeepower.php file in the secure directory. I don’t have those files in there
Re: Pass2PHP
Posted: Sunday 05 May 2019 14:40
by Trigun
Ok, putting the cron.php file in the right directory did the trick Image I am not sure how the cron is working for switching the light off after x seconds. As I see multiple variables doing lots of things. Where do I put in the number of seconds the switch has to turn off?
Re: Pass2PHP
Posted: Sunday 05 May 2019 14:51
by sincze
Please Have a look at the example Cron like _cron60
if ($d['wc']['s']=='On'
&& past('wc')>300
sw('wc', 'Off');
In this case if wc light is on for 5 minutes or longer... Switch it off.
Re: Pass2PHP
Posted: Sunday 05 May 2019 15:00
by Egregius
The first 84 lines of https://github.com/Egregius/PHP-Floorpl ... cron10.php switch of several lights based on multiple things.
The wc light in cron60 is a simple example.
In cron.sh you and cron.php you decide wich scripts are executed.
I’ll post my crontab a bit later and add it to cron.sh as explanation.
Re: Pass2PHP
Posted: Sunday 05 May 2019 18:45
by Trigun
sincze wrote: Sunday 05 May 2019 14:51 Please Have a look at the example Cron like _cron60
&& past('wc')>300
sw('wc', 'Off');
cool! I created a file called _cron60.php with the following code.
<?php
if ($d['PIR-Bijkeuken']['s']=='On'
&& past('PIR-Bijkeuken')>60
sw('PIR-Bijkeuken', 'Off');
and put in the/var/www/html/secure/pass2php
but it doesn't automatically switch off.
Re: Pass2PHP
Posted: Sunday 05 May 2019 18:55
by Egregius
I have my cron scripts just in the secure folder, take a look at the file/folder structure at github.
I just added a comment to the cron.sh script with my crontab:
# m h  dom mon dow   command
* * * * * /usr/bin/nice -n20 /var/www/html/secure/cron.sh >/dev/null 2>&1
*/2 * * * * /usr/bin/nice -n20 curl -s "http://127.0.0.1/secure/cron.php?cron120" >/dev/null 2>&1
0 * * * * /usr/bin/nice -n20 curl -s "http://127.0.0.1/secure/cron.php?cron3600" >/dev/null 2>&1
0 0 * * * /usr/bin/nice -n20 curl -s "http://127.0.0.1/secure/cleandomoticzdb.php" >/dev/null 2>&1
1 0 * * * /usr/bin/nice -n20 /var/www/_SQLBackup/sqldaily.sh >dev/null 2>&1
Make sure to check the cleandomoticzdb.php script before adding it to the crontab!
cron.sh handles the cron10, cron60, heating and rollers script.
in cron.sh you can remove the smappee lines of you don't have a smappee.
Re: Pass2PHP
Posted: Sunday 05 May 2019 21:05
by Trigun
Don’t know but all of a sudden nothing works anymore.
I can’t seem to tail anything anymore as it sticks to some old rules
Any ideas?
Re: Pass2PHP
Posted: Sunday 05 May 2019 21:06
by Trigun
Trigun wrote:Don’t know but all of a sudden nothing works anymore.
Any ideas?
Oh yeah, I already restarted Domoticz :)
Re: Pass2PHP
Posted: Sunday 05 May 2019 21:33
by Trigun
Any ideas?
And for some reason it is working again Image
Had to set the correct rights again and now tail etc is working again.
Re: Pass2PHP
Posted: Sunday 05 May 2019 23:30
by sincze
Any ideas?
Make 1 typo in a crucial place... And it is back to the Apache/nginx logs. :)
Re: Pass2PHP
Posted: Sunday 05 May 2019 23:34
by sincze
Egregius wrote:I have my cron scripts just in the secure folder, take a look at the file/folder structure at github.
Interesting never heard of;
/usr/bin/nice
What is the catch :)
Never to old to learn new tricks.
Re: Pass2PHP
Posted: Sunday 05 May 2019 23:36
by sincze
&& past('wc')>300
sw('wc', 'Off');
<?php
Did not work with my Xiaomi motion sensors as well they don't like to be switched off :)
Can you give it a go with a lamp?
If motion sw lamp on
After 60 sec and lamp on.. switch lamp off.
Re: Pass2PHP
Posted: Monday 06 May 2019 7:00
by Egregius
sincze wrote: Sunday 05 May 2019 23:34 Interesting never heard of;
/usr/bin/nice
nice is a program that handles priorities.
Priorities are from 0 to 39 on linux. Default is 20.
A positief nice number lowers the priority (but the number is raised so it's kind of reversed). This way you make sure that less important stuff doesn't get in the way of the more important stuff. You can see this in top in the columns PR and NI.
Re: Pass2PHP
Posted: Monday 06 May 2019 7:03
by Egregius
sincze wrote: Sunday 05 May 2019 23:30 Make 1 typo in a crucial place... And it is back to the Apache/nginx logs. :)
True! Forget one ' ) ; } and it's done, no more reaction.
But then there's logs.php and log.php to the rescue. log.php is a script that reads in realtime a logfile and show it in the browser.
You should always have the apache error log open while changing stuff.
