Page 44 of 51
Posted: Monday 02 November 2020 21:24
by nfuse
Lokonli wrote: Monday 02 November 2020 16:53
nfuse wrote: Monday 02 November 2020 14:56 annybody any idea how to make the blocks smaller? high: is not an options in blocks and cannot figure it out.
like this
You can add the following to custom.css:
div.mh {
    height: 50px;
    padding-top: 1px !important;
    padding-bottom: 1px !important;
Spot On! thank you very much
Posted: Tuesday 03 November 2020 13:19
by Chris12
When a graph is shown (pop-up) using a black enabled theme/background, the close button X of the pop-up graph screen is hardly visible.
How can I alter the css to increase the close button and change the color of it ?
Posted: Monday 09 November 2020 8:54
by Chris12
Chris12 wrote: Tuesday 03 November 2020 13:19 When a graph is shown (pop-up) using a black enabled theme/background, the close button X of the pop-up graph screen is hardly visible.
@HansieNL or @Lokonli, any ideas?
Posted: Monday 09 November 2020 12:26
by Lokonli
Chris12 wrote: Monday 09 November 2020 8:54
.close {
    color: white !important;
    opacity: 1;
Posted: Monday 09 November 2020 12:33
by Chris12
Lokonli wrote: Monday 09 November 2020 12:26
.close {
    opacity: 1;
great that works fine!
Posted: Sunday 22 November 2020 9:21
by webrazor
joostnl wrote: Friday 30 October 2020 21:09 I made a new dashboard just trying different stuff.
How did you get the Roborock map in de dashticz? I found the python plugin for xiaomi roborock to control it but i can't find anything about the map.
Posted: Saturday 12 December 2020 19:22
by madpatrick
HI Guys,
I'm trying to get the text in the block to the left-bottom, but no luck
Getting it to the center is working, but getting it to the bottom not
.block_lms 				{height: 200px !important;display:flex;align-items:center;text-align: left !important}
.block_lms .value 			{font-size: 14px !important;color:grey !important;}
Posted: Saturday 12 December 2020 22:13
by Lokonli
madpatrick wrote: Saturday 12 December 2020 19:22 HI Guys,
You want to move the value part to the bottom? It's not a <div>, but a <span>.
I think there are two ways.
1)
maximize the height of the data block, and move the span via absolute positioning to the bottom left:
.block_lms .col-data {
    height: 100%
.block_lms .value {
    margin: 4px 4px;
    left: 0px;
    bottom: 0px;
    position: absolute;
2)
Change the line-height. Try:
.block_lms .value {
   line-height: 100px
You have to experiment with the line-height value in this case.
Posted: Saturday 12 December 2020 22:30
by Lokonli
3)
With display:flex:
    display: flex;
    flex-direction: column;
    justify-content: space-between
Posted: Sunday 13 December 2020 9:40
by madpatrick
unfortunately these option don't work, but you gave a direction to seach.
This is working now for me:
.block_lms  {
height: 150px !important;
display:flex;
align-items:flex-end;
The option ".block_lms .col-data" is not doing anything
Posted: Friday 25 December 2020 11:34
by cornesch
Hello everyone,
For everyone who also displays Dashticz on a 7 inch touchscreen, here's a preview of my project.
I have enlarged all blocks and texts, so that it can also be read from a distance.
Posted: Friday 25 December 2020 11:38
by madpatrick
Hi cornesc,
Looks nice.
Can you share your config.js and custom.css
Posted: Friday 25 December 2020 16:24
by Sjonnie2017
cornesch wrote: Friday 25 December 2020 11:34 Hello everyone,
It must be me but I can't see the screenshot :oops: Can you share it via another platform than google?
TIA
Posted: Friday 25 December 2020 20:27
by EdwinK
I also just saw a big MINUS symbol.
Posted: Saturday 26 December 2020 8:15
by cornesch
CONFIG.js
var config = {}
config['domoticz_ip'] = 'http://????????????';
config['language'] = 'nl_NL';
config['dashticz_refresh'] = '77';
//config['slide_effect'] = 'fade';
config['auto_swipe_back_after'] = '60';
config['auto_slide_pages'] = false;
config['vertical_scroll'] = 0;
config['use_favorites'] = 0;
config['hide_topbar'] = 1;
config['settings_icons'] = [];
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['shorttime'] = 'HH:mm';
config['longtime'] = 'HH:mm';
config['longdate'] = ' ';
config['weekday'] = ' ';
config['calendarlanguage'] = 'nl_NL';
config['lineColors'] = ['#aaa9a9', '#7e7e7e'];
config['standard_graph'] = 'day';
config['disable_update_check'] = 1;
config['enable_websocket'] = true;
config['domoticz_timeout'] = 2000;
config['enable_swiper'] = 1;
config['swiper_touch_move'] = 0;
config['units'] = {
  names: {
    kwh: ' kWh',
    watt: ' W',
    gas: ' m3',
    water: ' Liter',
    time: ''
  decimals: {
    kwh: 3,
    watt: 0,
    gas: 1,
    water: 0,
    time: 0
//weersvoorspelling
config['owm_api'] = '????????????????????????';
config['owm_city'] = '??????????';
config['owm_name'] = '';
config['owm_country'] = 'nl';
config['owm_lang'] = 'nl';
config['owm_cnt'] = '4';
config['owm_min'] = true;
config['owm_days'] = false;
config['static_weathericons'] = false;
//afvalkalender
config['garbage_company'] = 'rova';
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = '???????????';
config['garbage_street'] = '????????????????';
config['garbage_housenumber'] = '????????????????';
config['garbage_maxitems'] = '1';
config['garbage_width'] = '2';
config['garbage_use_names'] = true;
config['garbage_use_colors'] = false;
config['garbage_icon_use_colors'] = true;
config['garbage_use_cors_prefix'] = false;
config['calendarlanguage'] = 'nl';
config['garbage'] = {
gft: {kliko: 'green', 	code: '#f9e231', name: '', icon: 'img/garbage/kliko_green.png'},
pmd: {kliko: 'orange', 	code: '#FF8C00', name: '', icon: 'img/garbage/kliko_orange.png'},}
//////////////////////////////////////////////////////////////Instellingen hier boven
var blocks = {}
blocks[75] = {
  width: 12,
  iconOn : 'fas fa-toggle-on',  //Warm water
  iconOff : 'fas fa-toggle-off',
  switch : 0,
  hide_data : 1,
  last_update : 0,
blocks[33] = {
  width: 12,
  iconOn : 'fas fa-toggle-on',  //Lampengroep tuin
  switch : 0,
  hide_data : 1,
  last_update : 0,
blocks[27] = {
  width: 12,
  iconOn : 'fas fa-toggle-on',    //Lampen woonkamer
  switch : 0,
  hide_data : 1,
  last_update : 0,
blocks[227] = {
  width: 12,
  iconOn : 'fas fa-toggle-on',    //Kerstboom
  switch : 0,
  hide_data : 1,
  last_update : 0,
blocks['s1'] = {
  width: 12,
  title: 'Sonos',
  iconOn : 'fas fa-toggle-on',  //Sonos
  switch : 0,
  confirmation : 0,
  hide_data : 1,
  last_update : 0,
blocks['s3'] = {
  width: 12,
  title: 'Zolder',
  iconOn : 'fas fa-toggle-on',  //Zolder
  switch : 0,
  protected: 1,
  hide_data : 1,
  last_update : 0,
blocks[56] = {
  width: 6,
  title: 'Was',
  imageOn : 'roofwindow_open.svg',  //Dakraam zolder was
  imageOff : 'roofwindow_closed.svg',
  switch : 0,
  //hide_data : 1,
  last_update : 0,
blocks[57] = {
  width: 5,
  title: 'Logé',
  imageOn : 'roofwindow_open.svg',  //Dakraam zolder slaap
  switch : 0,
  //hide_data : 1,
  last_update : 0,
blocks[72] = {
  width: 1,
  //title: '',
  icon : '',  //temperatuur binnen
  //image : '',
  switch : true,
  hide_title : 1,
  hide_data : 1,
  protected: 1,
  last_update : false,
blocks[79] = {
  width: 1,
  //title: '',
  icon : '',  //temperatuur buiten
  //image : '',
  switch : true,
  hide_title : 1,
  hide_data : 1,
  protected: 1,
blocks[206] = {
  width: 2,
  title: '',
  icon : '',  //laagste temperatuur binnen >24h
  //image : '',
  switch : true,
  hide_title : 1,
  hide_data : 1,
  protected: 1,
blocks[211] = {
  width: 2,
  //title: '',
  icon : '',  //hoogste temperatuur binnen >24h
  //image : '',
  switch : true,
  hide_title : 1,
  hide_data : 1,
  protected: 1,
blocks[238] = {
  width: 1,
  title: '',
  icon : '',  //laagste temperatuur buiten >24h
  //image : '',
  switch : true,
  hide_title : 1,
  hide_data : 1,
  protected: 1,
blocks[239] = {
  width: 1,
  //title: '',
  icon : '',  //hoogste temperatuur buiten >24h
  //image : '',
  switch : true,
  hide_title : 1,
  hide_data : 1,
  protected: 1,
blocks[198] = {
  width: 12,
  title: '',
  imageOn : 'Wasmachine.png',  //Wasmachine
  iconOff : '',
  switch : 0,
  hide_title : 1,
  hide_data : 1,
  protected: 1,
  last_update : 0,
  //gotoslideOn: 5,
blocks[184] = {
  width: 12,
  title: '',
  imageOn : 'dishwasher_240px.png',  //Vaatwasser
  //imageOn : 'washer1.svg',  //Vaatwasser
  iconOff : '',
  switch : 0,
  hide_title : 1,
  hide_data : 1,
  protected: 1,
  last_update : 0,
  //gotoslideOn: 5,
blocks[234] = {
  width: 12,                //Luchtkwaliteit Woonkamer
  //title: '',
  //iconOff : '',
  icon : 'fas fa-home',
  switch : 1,
  hide_title : 1,
  //hide_data : 1,
  //protected: 1,
  last_update : 0,
  //gotoslideOn: 5,
blocks[235] = {
  width: 12,                //ppm/% Woonkamer
  //title: '',
  //iconOff : '',
  //switch : 1,
  //hide_title : 1,
  //hide_data : 1,
  //protected: 1,
  last_update : 0,
  //gotoslideOn: 5,
blocks['164_1'] = {
  width: 12,
  icon : 'fas fa-fire-alt',  //Gasverbruik
  switch : 1,
  hide_title : 1,
  hide_data : 1,
  protected: 1,
  last_update : 0,
  popup: 'popup_gas'
blocks['popup_gas'] = {
   title: 'Gasverbruik vandaag',
   devices: [164],
   toolTipStyle: false,
   //datasetColors: ['red', 'yellow'],
   graph: 'bar',
custom : {
        "laatste uren": {
            range: 'day',
            filter: '4 hours',
            data: {
                m3: 'd.v_164*0.1'            }
  "vandaag": {
            range: 'day',
            filter: '12 hours',
            data: {
               m3: 'd.v_164*0.1'            }
  "afgelopen maand": {
            range: 'month',
            //filter: '7 days',
            data: {
                m3: 'd.v_164'            }
blocks['160_2'] = {
  width: 12,
  icon : 'fas fa-plug',  //Stroomverbruik
  switch : 1,
  hide_title : 1,
  hide_data : 1,
  protected: 1,
  last_update : 0,
  popup: 'popup_stroom'
blocks['popup_stroom'] = {
   title: 'Stroomverbruik vandaag',
   devices: [160],
   graph: 'bar',
custom : {
        "laatste uren": {
            range: 'day',
            filter: '4 hours',
            data: {
                watt: 'd.v_160*1+d.v2_160*1'            }
  "vandaag": {
            range: 'day',
            filter: '12 hours',
            data: {
            range: 'month',
            //filter: '7 days',
            data: {
                kWh: 'd.v_160*1+d.v2_160*1'            }
blocks['42_1'] = {
  width: 12,
  icon : 'fas fa-faucet',  //Waterverbruik
  switch : 1,
  hide_title : 1,
  hide_data : 1,
  protected: 1,
  last_update : 0,
  popup: 'popup_water'
blocks['popup_water'] = {
   title: 'Waterverbruik vandaag',
   devices: [42],
   graph: 'bar',
custom : {
        "laatste uren": {
            range: 'day',
            filter: '4 hours',
            data: {
                liter: 'd.v_42*100'            }
  "vandaag": {
            range: 'day',
            filter: '12 hours',
            data: {
            range: 'month',
            //filter: '7 days',
            data: {
                liter: 'd.v_42*1000'            }
blocks['dial_zolder'] = {
        idx: 232,
        title: 'Was Zolder',
        type: 'dial',
        setpoint: 60,
        min: 40,
        max: 80,
        width: 4,
        shownumbers: true,
        last_update: false,
values: [
                        value:'Humidity',
                        unit:' %',
                        value:'Temp',
                        unit:' °C',
blocks['dial_badkamer'] = {
        idx: 183,
        title: 'Badkamer',
        type: 'dial',
        setpoint: 60,
        min: 40,
        max: 80,
        width: 4,
        shownumbers: true,
        last_update: false,
values: [
                        value:'Humidity',
                        unit:' %',
                        value:'Temp',
                        unit:' °C',
blocks['dial_netatmo'] = {
        idx: 234,
        title: 'Woonkamer',
        type: 'dial',
        setpoint: 60,
        min: 40,
        max: 80,
        width: 4,
        shownumbers: true,
        last_update: false,
values: [
                        value:'Humidity',
                        unit:' %',
                        value:'Temp',
                        unit:' °C',
blocks['nefiteasy'] = {
        idx: 230,
        title: 'Nefit Easy',
        type: 'dial',
        width: 4,
blocks['sonos_controller'] = {
        idx: 237,
        title: 'Sonos Radio',
        type: 'dial',
        width: 6,
blocks['sonos_volume'] = {
        idx: 39,
        title: 'Sonos Volume',
        type: 'dial',
        shownumbers: true,
        min: 0,
        max: 25,
   	width: 6,
blocks['blocktitle_1'] = {
  type: 'blocktitle',
  //title: 'Schakelaars',
  width: 12
blocks['blocktitle_2'] = {
  type: 'blocktitle',
  //title: 'Menu',
  width: 12
blocks['blocktitle_3'] = {
  type: 'blocktitle',
  //title: 'Info',
  width: 12
var buttons = {}
buttons.p2 = {key: "button0",width:2, isimage:true, icon:'fas fa-bars',  title: '', slide:2}
buttons.p1 = {key: "button1",width:2, isimage:true, icon:'fas fa-reply',  title: '', slide:1}
buttons.p3 = {key: "button2",width:2, isimage:true, icon:'fas fa-music',  title: '', slide:3}
buttons.p4 = {key: "button3",width:2, isimage:true, icon:'fas fa-info',  title: '', slide:2}
var columns = {}
columns['bar0'] = {}
columns['bar0']['blocks'] = [79,239,238,'miniclock',206,211,72]
columns['bar1'] = {}
columns['bar1']['blocks'] = [buttons.p1]
columns[1] = {
  blocks:  ['blocktitle_1',75,33,227,'s1','s3'],
  width: 5
columns[2] = {
  blocks:  ['blocktitle_3',56,57,'42_1','160_2','164_1',235],
  width: 5
columns[3] = {
  blocks:  ['dial_netatmo','dial_badkamer','dial_zolder'],
  width: 10
columns[4] = {
  blocks:  ['sonos_controller','sonos_volume'],
  width: 10
columns['menu0'] = {
  blocks:  ['blocktitle_2',buttons.p2,184,198,'garbage'],
  width: 2
columns['menu1'] = {
  blocks:  [buttons.p1,buttons.p4,buttons.p3],
  width: 1
columns[5] = {
  width: 1
columns['menu2'] = {
  blocks:  [buttons.p2],
  width: 1
var screens = {}
screens[1] = {
  columns: ['bar0','menu0',1,2],
  background: 'bg0.jpg',
screens[2] = {
  columns: ['menu1', 3],
screens[3] = {
  columns: ['menu1', 4],
custom.css
CUSTOM CSS FILE
.transbg.col-xs-1,.transbg.col-xs-2,.transbg.col-xs-3,.transbg.col-xs-4,.transbg.col-xs-5,.transbg.col-xs-6,.transbg.col-xs-7,.transbg.col-xs-8,.transbg.col-xs-9,.transbg.col-xs-10,.transbg.col-xs-11,.transbg.col-xs-12 {
	padding-top:0px;
	padding-bottom:15px;
	border: 1px solid rgba(255,255,255,0);		/* border: 7px -> 3px - Smaller space between blocks */
	background: rgba(0,0,0,1.0);
	background-clip: padding-box;
	border-radius: 0px;						/* Round corners */
.transbg.dark.col-xs-1, .transbg.dark.col-xs-2, .transbg.dark.col-xs-3, .transbg.dark.col-xs-4, .transbg.dark.col-xs-5, .transbg.dark.col-xs-6, .transbg.dark.col-xs-7, .transbg.dark.col-xs-8, .transbg.dark.col-xs-9, .transbg.dark.col-xs-10, .transbg.dark.col-xs-11, .transbg.dark.col-xs-12 {
    border: 1x solid rgba(255,255,255,0);
    height: 50px !important;
    //border-bottom: 4px solid #fff !important;
    //border-radius: 50px;
.col-data .title {font-size:30px; margin-left: 60px;}
.col-data .state {font-size:24px; margin-left: 60px;}
.col-data .value {font-size:30px; margin-left: 60px; font-weight: bold; position: absolute; bottom: -30px !important;}
.col-data .lastupdate {font-size:24px; margin-left: 60px;}
.far,.fas,.wi,.fab{
   font-size:70px !important;
.blocktitle {
    background: grey !important;
    height: 1px !important;
.block_27 .on {
  color:#F1C300;
.block_27 .off {
  color:#fff;
.block_33 .on {
  color:#F1C300;
.block_33 .off {
  color:#fff;
.block_33 .title {
  position: absolute;
  bottom: -55px !important;
.block_56 {
  max-width: 160px;
.block_56 .state {
  font-size: 20px !important;
  font-weight: bold;
.block_56 img.icon {
	max-width: 200px !important
.block_57 {
  max-width: 160px;
.block_57 .state {
  font-weight: bold;
.block_57 img.icon {
.block_72 {
  height: 0px !important;
  margin-left: -110px;
  background-color: rgba(0,0,0,0) !important;
  bottom: 5px !important;
.block_72 .title {
  font-size: 45px !important;
.block_79 {
  margin-left: -85px;
.block_79 .title {
.block_75 .on {
  color:#F1C300;
.block_75 .off {
  color:#fff;
.block_75 .title {
  position: absolute;
.block_206 {
  margin-left: -200px;
  bottom: -25px !important;
.block_206 .title {
  //color: blue;
.block_211 {
  bottom: -5px !important;
.block_211 .title {
  //color: red;
.block_238 {
  margin-left: -67px;
.block_238 .title {
  //color: blue;
.block_239 {
  margin-left: 60px;
.block_239 .title {
  //color: red;
.block_227 .on {
  color:#F1C300;
.block_227 .off {
  color:#fff;
.block_227 .title {
  position: absolute;
.block_235 img.icon {
  max-width: 100px !important;
.block_s1 .on {
  color:#F1C300;
.block_s1 .off {
  color:#fff;
.block_s1 .title {
  position: absolute;
.block_s3 .on {
  color:#F1C300;
.block_s3 .off {
  color:#fff;
.block_s3 .title {
  position: absolute;
.block_184 {
  height: 95px !important;
.block_184 img.icon {
  margin-left: -15px;
.block_198 {
.block_198 img.icon {
  max-width: 80px !important;
  margin-left: -5px;
.block_42_1 .title {
  position: absolute;
.block_160_2 .title {
  position: absolute;
.block_164_1 .title {
  position: absolute;
/* Weersvoorspelling  */
.block_currentweather_big_owm {
  height: 80px !important;
  bottom: 10px !important;
 .block_currentweather_big_owm .skycon {
  max-width: 100px;
  width: 140px;
  margin-left: -30px;
 .block_currentweather_big_owm .title {
  font-size: 42pt;
  margin-left: 40px;
 .block_currentweather_big_owm .weatherloc {
  font-size: 14pt;
/* Afvalkalender Rova  */
 .dt_state .trashrow {
    font-size: 20px;
    font-weight: bold;
    position: absolute;
    //bottom: -95px !important;
    margin-left: -18px;
 .dt_state .trashtoday {
    font-size: 20px;
    font-weight: bold;
    position: absolute;
    margin-left: -18px;
 .dt_state .trashtomorrow {
    font-size: 20px;
    font-weight: bold;
    position: absolute;
    margin-left: -18px;
.trashcan {
    height: 110px;
    width: 110px;
    max-width: 150px !important;
    margin-left: -25px;
.block_garbage {
  width: 220px !important;
  height: 100px !important;
  margin-left: -20px;
  bottom: 0px !important;
/* Miniklok  */
.colbar.transbg .miniclock span{
  font-size:0px !important;
  font-weight:bold !important;
  margin-left: 0px;
.colbar.transbg {
    padding-left: 200px !important;
    padding-right: 0px !important;
    padding-top: 2px !important;
    padding-bottom: 2px !important;
.miniclock span{
  font-size:45px !important;
  margin-left: -10px;
/* Miniklok  */
/* Alle Grafieken   */
.graphbuttons .fas {
    display:none
.graphtitle .fas {
    display: none
.graphheight {
  height: 900px;
  max-height: 1000px !important;
.graphwidth {
  width: 780px;
/* Tekstkleuren  */
.textred {	color: red !important;}
.textorange {	color: orange !important;}
.textgreen {	color: green !important;}
.warningblue {    color: green !important;  }
/* Tekstkleuren  */
.swiper-pagination-bullet {
    display: none !important
/* Iconkleuren  */
.fas.fa-fire-alt {
   color: grey !important;
.fas.fa-plug {
.fas.fa-faucet {
.fas.fa-home {
/* Iconkleuren  */
/* Menuknoppen  */
[data-id='button0']  {
 //background-color: red !important;
 max-height: 70px !important;
 width: 80px;
[data-id='button1']  {
 width: 80px;
[data-id='button2']  {
 width: 80px;
[data-id='button3']  {
 width: 80px;
/* Menuknoppen  */
Posted: Saturday 26 December 2020 9:57
by EdwinK
Looks nice ;)
Posted: Wednesday 30 December 2020 14:12
by red73390
I'm a fresh user of dashticz (few hours), but a more older user of domoticz.
Here's my actual version, i think you can find a lot of your example here.
I still didn't implement it on a tablet in permanent, but using it on a tablet and computer.
My next goal is to try to set up the transport api from stib/mvib.
Thank you for your example.
Posted: Monday 11 January 2021 15:12
by JuanUil
Hai Rob,
Nice work, I like Dashticz very much.
But I have way to many 'items' for 1 dashboard, so by creating more dashboards (screens) I'll keep swiping, so In my opinion there was only one thing missing, a mainmenu, I can now jump to the desired screen by a click/touch.
So with a little change in main.js I was able to create a menu with buttons, once clicked/touched will slide to the desired screen.
Maybe another option for Dashticz, but I like to see it in an ordered fashion, something in Config.js saying var Menu{} etc..
Or maybe keep the dashboard 'look', and create a mainmenu in the topbar.
Mainmenu
Mainmenu
Screenshot-2017-10-13 Dashticz (1).png (312.74 KiB) Viewed 4165 times
Mainmenu button on other screens
Screenshot-2017-10-13 Dashticz (2).png (239.6 KiB) Viewed 4165 times
This is what I did.
Main.js
Config.js
Custom.css
Frank
Hi Frank,
like this menu idea very much.
but what I get is this:
my Config.js
var config = {}
config['domoticz_ip'] = 'http://192.168.2.20:8080';
config['app_title'] = 'Kerkstraat Dashticz';
config['login_timeout'] = '60';
config['domoticz_timeout'] = '2000';
config['room_plan'] = 0;
config['user_name'] = '0';
config['pass_word'] = '0';
config['colorpicker'] = '2';
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = '7';
config['default_cors_url'] = 0;
config['dashticz_php_path'] = './vendor/dashticz/';
config['standby_call_url'] = 0;
config['standby_call_url_on_end'] = 0;
config['theme'] = 'mijn_thema';
config['background_image'] = 'img/bg2.jpg';
config['standby_after'] = 0;
config['start_page'] = 1;
config['enable_swiper'] = '2';
config['vertical_scroll'] = '2';
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = 0;
config['slide_effect'] = 'slide';
config['standard_graph'] = 'hours';
config['blink_color'] = '255, 255, 255, 1';
config['calendarurl'] = 0;
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = 0;
config['gm_zoomlevel'] = 0;
config['gm_latitude'] = '51.398937';
config['gm_longitude'] = '5.75042009';
config['speak_lang'] = 'nl-NL';
config['wu_api'] = 0;
config['wu_city'] = 'Amsterdam';
config['wu_name'] = 0;
config['wu_country'] = 'NL';
config['owm_api'] = 0;
config['owm_city'] = 'Mainaschaff';
config['owm_name'] = 0;
config['owm_country'] = 'de';
config['owm_lang'] = 0;
config['idx_moonpicture'] = 0;
config['longfonds_zipcode'] = 0;
config['longfonds_housenumber'] = 0;
config['switch_horizon'] = 0;
config['host_nzbget'] = 0;
config['spot_clientid'] = 0;
config['sonarr_url'] = 0;
config['sonarr_apikey'] = 0;
config['sonarr_maxitems'] = 0;
config['garbage_company'] = 'blink';
config['google_api_key'] = 0;
config['garbage_calendar_id'] = 0;
config['garbage_zipcode'] = '5721GW';
config['garbage_street'] = 'Kerkstraat';
config['garbage_housenumber'] = '74';
config['garbage_housenumberadd'] = 'a';
config['garbage_maxitems'] = '3';
config['setpoint_min'] = '5';
config['setpoint_max'] = '40';
config['evohome_boost_zone'] = '60';
config['evohome_boost_hw'] = '15';
config['disable_update_check'] = 0;
config['loginEnabled'] = 0;
config['enable_websocket'] = 1;
config['auto_positioning'] = 1;
config['last_update'] = 1;
config['disable_googleanalytics'] = 0;
config['hide_topbar'] = 0;
config['swiper_touch_move'] = 1;
config['security_button_icons'] = 0;
config['security_panel_lock'] = 0;
config['edit_mode'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['owm_days'] = 0;
config['owm_min'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 0;
config['hide_mediaplayer'] = 0;
config['garbage_icon_use_colors'] = 1;
config['garbage_use_colors'] = 0;
config['garbage_use_names'] = 0;
config['garbage_use_cors_prefix'] = 1;
var buttons = {}
buttons.hoofdmenu= {width:12, image: 'img/hoofdmenu_mirror.png', title: 'Hoofdmenu' ,slide:0 }
buttons.huismodus= {width:4, image: 'img/house_mirror.png', title: 'Huismodus' ,slide:1 }
buttons.alarm= {width:4, image: 'img/alarmpanel_mirror.png', title: 'Alarm',slide: 2}
buttons.utility= {width:4, image: 'img/power_mirror.png', title: 'Elektra, Gas & Water' ,slide:3 }
buttons.verlichting= {width:4, image: 'img/Light-off_mirror.png', title: 'Verlichting',slide: 4}
buttons.temperatuur= {width:4, image: 'img/temp_mirror.png', title: 'Temperatuur' ,slide:5 }
buttons.weerstation= {width:4, image: 'img/weer_mirror.png', title: 'Weerstation',slide: 6}
buttons.kas_en_moestuin= {width:4, image: 'img/kas_mirror.png', title: 'Kas & Moestuin' ,slide:7 }
buttons.instellingen= {width:4, image: 'img/settings_mirror.png', title: 'Instellingen',slide: 8}
buttons.media= {width:4, image: 'img/media_mirror.png', title: 'Media' ,slide:9 }
buttons.nieuws= {width:4, image: 'img/nieuws_mirror.png', title: 'Nieuws' ,slide:10 }
buttons.plattegrond= {width:4, image: 'img/floorplan_mirror.png', title: 'Plattegrond' ,slide:11 }//buttons.domoticz= {width:3, image: 'img/weer_mirror.png', title: 'Weather',slide: 0}
var columns = {}
//Column[0] contains the 'goto mainmenu' button, so add column[0] on every screen.
columns[0] ={}
columns[0]['blocks']=['bt_Hoofdmenu',buttons.hoofdmenu]
columns[0]['width']=2;
//with columns[1] [2] [3] I define the first screen, the mainmenu
columns[1] = {}
columns[1]['width'] = 3;
columns[2] = {}
columns[2]['blocks'] = ['bt_Hoofdmenu',buttons.huismodus, buttons.alarm, buttons.utility, buttons.verlichting, buttons.temperatuur, buttons.weerstation, buttons.kas_en_moestuin, buttons.instellingen, buttons.media, buttons.nieuws, buttons.plattegrond]
columns[2]['width'] = 6;
columns[3] = {}
columns[3]['width'] = 3;
//Definition of screens
screens = {}
screens[1] = {
  columns: [0, 1, 2, 3]
screens[2] = {
  columns: [0]
screens[3] = {
  columns: [0]
and my custom.css
/* CSS Document */
.Menu{
padding: 10px 10px !important;
color: Black;
font-size: 40px !important;
font-style: Italic;
text-align: center;
line-height: 0.7em;
background: rgba(0, 0, 0, 0) linear-gradient(#4d4d4d, #999999) repeat scroll 0 0 !important;
box-shadow: inset 1px 0px 0px 0px rgba(255,255,255,0.5) !important;
/* add background and box-shadow for other browsers*/
.Menu .title
color: rgba(48,48,48,1);
font-weight: 700;
font-style: Italic;
//letter-spacing: 1px;
padding-left: 20px;
line-height: 0em;
line-spacing: 0em;
text-shadow: 1px 1px 0 rgba(140,140,140,0.6) , -1px -1px 1px rgba(0,0,0,0.67);
.Menu .buttonimg
max-height:75px;
.Menu .col-xs-1,
.Menu .col-xs-2,
.Menu .col-xs-3,
.Menu .col-xs-4,
.Menu .col-xs-5,
.Menu .col-xs-6,
.Menu .col-xs-7,
.Menu .col-xs-8,
.Menu .col-xs-9,
.Menu .col-xs-10,
.Menu .col-xs-11,
.Menu .col-xs-12 {
padding-top: 10px !important;
padding-right: 2px !important;
padding-left: 2px !important;
Any idea what I am doing wrong?
Jan
Posted: Monday 11 January 2021 17:07
by Lokonli
The button images are relative to the img/ folder.
So instead of:
use
image: 'hoofdmenu_mirror.png'
And I think the first screen is slide:1
Further, it seems 'bt_Hoofdmenu' is not defined yet.
Posted: Monday 11 January 2021 21:58
by JuanUil
got the pictures in now but I can't get the format right.
