Controlicz - Easy Domoticz to Alexa Integration Topic is solved
Alexa, Google Home and Siri
Madgeni
Re: Controlicz - Easy Domoticz to Alexa Integration
Post by Madgeni »
Yes, it is an issue with the response, but I thought I'd fixed it, so was just checking :) will take another look
Peer
Post by Peer »
Yes, now all is fixed!
You are the best!
Madgeni
Post by Madgeni »
Yay! Glad it's working
hayman
Domoticz version: 3.8153
Post by hayman »
please Milight RGB CCT special with CW and WW...
thanks
Madgeni
Post by Madgeni »
Apologies, will plug the bulb in tomorrow and get debugging!
hayman
Post by hayman »
Still have a probleem with Milight (ibox 2) GU10 RGBCCT ....
changing color works good but changing from warmwhite to coolwhite not ..
PHIL63
Post by PHIL63 »
since few days (don't know how many) the command of my blinds are inverted if I use "routines" in alexa parameters.
If I tell to Alexa to open my blinds then she close it and if I tell her to close it then she open it.
Before all works fine and I never have any problem with that.
Another thing, I can't create a routine with only a ON command, if I crate a ON command then in Domoticz it's a "Set level" command that is received and so my blind don't work.
Any idea ?
johansson
Post by johansson »
Reverting back to Controlicz after a while, just to notice that donating 20 euros six months ago ended up into subscription based service! You gotta be kidding me.
The early volunteers donating have enabled you to develop the service, and now we should be subscribing as everybody else. Sounds fair - not.
Madgeni
Post by Madgeni »
Most donators were refunded or the donations were converted to subscriptions, as I've posted it wasn't/isn't my intention to con people. Mail me from your Controlicz profile, and I'll help
hayman
Post by hayman »
the milight still not working as befor ..?
can you look at it please
Madgeni
Post by Madgeni »
Apologies, bought the wrong bulb, bayonet version on it's way - will fix it this week
hayman
Post by hayman »
Okey thanks
It's gu10 RGBCCT with ibox2
Madgeni
Post by Madgeni »
Hi hayman - try now?
hayman
Post by hayman »
With Alexa not working with Google home it's works but some times get freezing at warm white???
hayman
Post by hayman »
any update onthe milight
johansson
Post by johansson »
Madgeni wrote: Friday 14 September 2018 21:38 Most donators were refunded or the donations were converted to subscriptions, as I've posted it wasn't/isn't my intention to con people. Mail me from your Controlicz profile, and I'll help
Dropped you a PM.
johansson
Post by johansson »
Solved, refunded and subscribed. Great work Nick!
Madgeni
Post by Madgeni »
Hi all - made an update to your profiles, so devices will show whether they are in a Room Plan or not. Thats should help with ensuring you're sending all the devices you want to send, and no more :)
hayman
Post by hayman »
Thanks still the milight cctrgb not working:(
Madgeni
Post by Madgeni »
What? So you can't change to blue/green with milight? sorry, honestly thought i'd fixed it
