Pilot: Home Automation Control (iOS app)
patoo77
Re: Pilot: Home Automation Control (iOS app)
Post by patoo77 »
A few comments:
* Pilot has been portrait only for quite some time now. :)
* I will see what I can do for the size of the text
* Logitech support will require more work. Not going to do it on this version
If you want to help with the translation, feel free to send me an email with all the typos you find. [email protected] :)
patoo77
Post by patoo77 »
Looking for someone who has RGB lights, need to test something.
Please PM me :)
pvm
Domoticz version: 4.10538
Post by pvm »
Tested 3008, I am not able to select a range for the graphs :
The range field is empty for the sensors I've checked (quite some).
patoo77
Post by patoo77 »
pvm wrote: Sunday 28 April 2019 0:52 Tested 3008, I am not able to select a range for the graphs :
That should be fixed with 3009 (forgot to add the NL translations^^)
pvm
Post by pvm »
Ok, fixed, ranges can be selected now
pvm
Post by pvm »
For graphs with multiple lines (like the P1 power meter) all lines are shown in the same color, multiple colors would be nice
rgroothuis
Post by rgroothuis »
I think I found another bug, with the Philips HUE lamps. When trying to select a different colour within the Pilot application, the colour doesn't change but the light is being switch off. So the colour selection is not working.
Nautilus
Post by Nautilus »
I would like to see utility sensor readings in Pilot to resemble what you see on the Domoticz web UI. For example power consumption meters, counters etc. typically show the daily value. It does not make too much sense to show for example what the total consumption since the beginning of time has been for the house - instead it is interesting to see how much we have consumed today...:)
edit: and it would also be nice if there could be bar charts / histrograms for those utility types that use it also in Domoticz web UI.
patoo77
Post by patoo77 »
Pilot 3 is officially available on the App Store! :)
More info here: https://pilot.patrickferreira.com/pilot-3-0/
I would like to thank all the beta testers for their tremendous help.
As usual, let me know what you think! ;)
EdddieN
Domoticz version: 4.9700
Post by EdddieN »
Aargh ! Still no update available for me! Can’t wait to test
11101101 - www.machinon.com
rgroothuis
I'm still having challenges getting the camera's to work in the App. It is not a 3.0.0 issue but more a configuration issue which I don't know how to resolve. When going directly via the web-interface to Domoticz I'm able to see the camera's and they are also streaming. Via the Pilot app I cannot see the video. It stays as a black screen. Any suggestions on how to fix this?
EdddieN
Post by EdddieN »
For future releases, would be nice to be able to change the theme colour of the interface (not everyone is fond of orange)?
And even a dark theme?
mvveelen
Post by mvveelen »
Using the test-version one question raised:
Would it be possible to use other icons for the devices? For example: I have 4 iPhones (dummy's) in my set-up and in the Pilot app they are light bulbs (on / off). It would be nice if I could change them and this would be 'remembered' with every update. Maybe also a possibility to change on/off to home/away or something like that?
MikeF
Domoticz version: V2022.2
Post by MikeF »
Crashes immediately on my iPhone 6S iOS 11.3.1
- I briefly see 'Whats new' screen, then goes to iOS home screen.
Also, new version not appearing in UK App Store on my iPad - still shows previous version.
patoo77
Post by patoo77 »
rgroothuis wrote: Friday 17 May 2019 9:48 I'm still having challenges getting the camera's to work in the App. It is not a 3.0.0 issue but more a configuration issue which I don't know how to resolve. When going directly via the web-interface to Domoticz I'm able to see the camera's and they are also streaming. Via the Pilot app I cannot see the video. It stays as a black screen. Any suggestions on how to fix this?
I wish I knew how to fix this. FYI I am also getting this bug at home, but I can't reproduce it every time. /:
I don't despair from finding a bugfix tho :P
EdddieN wrote: Friday 17 May 2019 18:42 For future releases, would be nice to be able to change the theme colour of the interface (not everyone is fond of orange)?
Yes.
mvveelen wrote: Saturday 18 May 2019 12:50 Using the test-version one question raised:
Adding this to my backlog, can't promise anything tho.
MikeF wrote: Saturday 18 May 2019 18:08 Crashes immediately on my iPhone 6S iOS 11.3.1
That's weird. Can you try reinstalling the app, see if it fixes the crash?
As for the update, you can either wait for it to update automatically, or go to the "updates" tab in the app store and get it manually. ;)
Right now,preparing a 3.0.1 that will fix some issues.
Also working on bringing Pilot to another platform.... But that's a whole other thing :P
rgroothuis
patoo77 wrote: Monday 20 May 2019 23:18
Can i help somehow to investigate what is going on? It would be great if I can see my camera’s via the app remotely (out side the house).
By the way, when I’m at home I also can not see the video stream :-(
patoo77
Post by patoo77 »
rgroothuis wrote: Monday 20 May 2019 23:23
I would recommend buying a new house :P I'm sure your wife will agree, you get a bigger house, and all. Much easier :lol:
Are you using SSL? I have noticed it fails a lot more when using SSL. /:
MikeF
Post by MikeF »
Reinstalled, but still crashes. (I'll wait for 3.0.1)
rgroothuis
patoo77 wrote: Monday 20 May 2019 23:25
LOL, a bigger house means more camera's and thus the problem becomes even worse. developing a new app that works with camera streams is probably easier and cheaper. :lol: :lol: :lol:
What is wrong with SSL? The Pilot connection to the Domoticz is indeed using SSL with a self-signed certificate! Is that not the correct setting?
ahjwinth
Post by ahjwinth »
Thanks for the great app. It is running stable on my IPhone.
One thing I noticed is the reading from the energy meters. Both Gas and electricity show an reading in the pilot app different then from on the Domoticz screen.
Is it possible to show the m3/day value in the pilot app. Instead of the total.
