Dashticz - Show your dashboard and how-to's!
Chris12
Domoticz version: 2021.1
Post by Chris12 »
HansieNL wrote: Saturday 31 October 2020 13:48
Chris12 wrote: Saturday 31 October 2020 12:16 Hi, running the latest beta (3.6.6) and I was wondering if I can change the page slide buttons/dots to another color? Especially the inactive page slider are hardly seen when using a dark background. Can the inactive dots color be manipulated via the custom.css file?
Maybe a nice enhancement would be that the color can be set per page, so you can have different colors based on the backgroud (morning/noon/afternoon/night). And maybe the dot can be build like a circle with an outer line and fill, which can be different colors as well?
You can play with following settings:
.-pagination-bullet.swiper-pagination-bullet-active {
    opacity: 0.2 !important;
.swiper-pagination-bullet {
    opacity: 0.8 !important;
It doesn't seem to do a thing when adding the above/below code into my custom.css, when changing the opacity the dotted bullet stays white, and only the active one is shown. The other (2 in my case) are not visable.
I also tried changing the color to yellow, but that doens;t work as well.
/* Page slider buttons */
    color: yellow !important;
Domoticz beta | Dashticz beta | Synology DS415+ | Wall tablet Teclast 11.6inch (Android) | TADO v3 controlled heating
HansieNL
Post by HansieNL »
Chris12 wrote: Saturday 31 October 2020 14:13
Looks like a minus - is copied during copying the code. Just remove it from .-pagination
Blah blah blah
HansieNL
Post by HansieNL »
@Chris12 Opacity is working, but looks like change color is over ruled by other code.
Blah blah blah
Chris12
Post by Chris12 »
@HansieNL Yes opacity is working , but only the active button is show.
What I want to accomplish is, to also make the inactive buttons visable on a black background.
HansieNL
Post by HansieNL »
Chris12 wrote: Saturday 31 October 2020 15:26 @HansieNL Yes opacity is working , but only the active button is show.
I now think the colors are fixed: white (active) and black (inactive). Then you won’t see the black dot on a dark background. We’ll have to ask @Lokonli if we can change this.
EDIT: @Chris12 Can you try with background-color:
Blah blah blah
Lokonli
Post by Lokonli »
HansieNL wrote: Saturday 31 October 2020 16:06
You can configure the styling via custom.css.
Examples:
.swiper-pagination .swiper-pagination-bullet {
    opacity: 1;
    border: white solid 1px;
    background-color: green;
    width: 15px;
    height: 15px;
.swiper-pagination .swiper-pagination-bullet-active {
    border: white solid 1px !important;
    background-color: orange !important;
    width: 25px;
    height: 25px;
.swiper-pagination .swiper-pagination-bullet:nth-child(2) {
    background-color: red;
    width: 5px;
    height: 5px;
This will give a big active orange bullet, smaller green not active bullets. The second bullet will be small and red.
Chris12
Post by Chris12 »
Thanks!! @Lokonli & @HansieNL, it now works like a charm.
	border: yellow solid 2px !important;
        opacity: 1.0 !important;
	width: 15px;
	height: 15px;
	background-color: black !important;
	width: 15px;
	height: 15px;
Maybe one last thing which might can be changed as well: can the spacing between the bullets also be wider, so on a touchscreen (tablet) is more easier to use (without fail-clicking/pressing).
HansieNL
Post by HansieNL »
Chris12 wrote: Saturday 31 October 2020 17:08 Thanks!! @Lokonli & @HansieNL, it now works like a charm.
	width: 15px;
	height: 15px;
	width: 15px;
	height: 15px;
You can change the space between the bullets by changing the 4px to your needs:
.swiper-container-horizontal > .swiper-pagination-bullets .swiper-pagination-bullet {
	margin: 0 4px;
Blah blah blah
Chris12
Post by Chris12 »
thanks! appreciate the quick help & sollutions offered!
joostnl
Post by joostnl »
Worked out great :D :D
Lokonli wrote: Friday 30 October 2020 23:13 See:
https://dashticz.readthedocs.io/en/beta ... ml#styling
Most easy to do this via custom.css
To remove the complete header:
[data-id='my_multi_plant'].graph .graphheader {
    display: none
(The documentation was not correct, which has been fixed in the beta version)
nfuse
Post by nfuse »
annybody any idea how to make the blocks smaller? high: is not an options in blocks and cannot figure it out.
like this
docker with sonos http api / mosquitto / zigbee2mqtt assistant / portainer / dashticz / nodeJS on windows with Zigbee2Mqtt, and some flask builds of my own
Lokonli
Post by Lokonli »
nfuse wrote: Monday 02 November 2020 14:56 annybody any idea how to make the blocks smaller? high: is not an options in blocks and cannot figure it out.
like this
You can add the following to custom.css:
div.mh {
    height: 50px;
    padding-top: 1px !important;
    padding-bottom: 1px !important;
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
Lokonli,
I want to make the height of my Garbage block large and tried this.
div.mh.trash {
    height: 70px !important;
Unfortunaly nothing happens, not even with only div.mh
HansieNL
Post by HansieNL »
madpatrick wrote: Monday 02 November 2020 17:14 Lokonli,
div.mh.trash {
Can you try with:
[data-id='garbage']
Blah blah blah
HansieNL
Post by HansieNL »
HansieNL wrote: Monday 02 November 2020 19:02
div.mh.trash {
Can you try with:
[data-id='garbage']
Blah blah blah
HansieNL
Post by HansieNL »
div.mh.trash {
Can you try with:
[data-id='garbage']
Blah blah blah
madpatrick
nope. doesn't change the height
HansieNL
Post by HansieNL »
madpatrick wrote: Monday 02 November 2020 19:08 nope. doesn't change the height
The { was missing. Can you try again, because it's working here:
[data-id='garbage'] {
Blah blah blah
Lokonli
Post by Lokonli »
or:
div.trash {
madpatrick
Thanks guys !
Both options are working
