I format and reinstall everything from the beginning.. I got this
pi@raspberrypi:~ $ DEBUG=* homebridge -D
*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
[10/17/2016, 7:18:25 PM] Loaded plugin: homebridge-edomoticz
[10/17/2016, 7:18:25 PM] Registering accessory 'homebridge-edomoticz.eDomoticz'
[10/17/2016, 7:18:25 PM] Registering platform 'homebridge-edomoticz.eDomoticz'
[10/17/2016, 7:18:25 PM] ---
[10/17/2016, 7:18:25 PM] Loaded config.json with 0 accessories and 1 platforms.
[10/17/2016, 7:18:25 PM] Loading 1 platforms...
[10/17/2016, 7:18:25 PM] [eDomoticz] Initializing eDomoticz platform...
[10/17/2016, 7:18:25 PM] [eDomoticz] Fetching Domoticz lights and switches...
[10/17/2016, 7:18:26 PM] Loading 0 accessories...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Accento Ingresso'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'CPU_Usage'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Cupola Esterno'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Cupola Interno'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Cupola Xmas'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Facciata'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Faro Retro'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Fioriera'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Fotovoltaico'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Lampada Sala'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Lampione'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Lanterna Ingresso'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Lanterna Nonna'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Luci'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Luci Cancellino'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'MacBook'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Memory Usage'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Pulsante Cancello'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Riavvio Modem'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Riavvio RaspBerry'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Riavvio WiFi'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'iPad'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'iPhone'...
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
│ 031-45-154 │
EventedHTTPServer Server listening on port 51826 +0ms
[10/17/2016, 7:18:26 PM] Homebridge is running on port 51826.
EventedHTTPServer [::ffff:13.3.89.220] New connection from client +1s
EventedHTTPServer [::ffff:13.3.89.220] HTTP server listening on port 45433 +4ms
EventedHTTPServer [::ffff:13.3.89.220] HTTP request: /pair-verify +24ms
HAPServer [CC:21:4E:E7:DF:33] HAP Request: POST /pair-verify +1ms
HAPServer [CC:21:4E:E7:DF:33] Pair verify step 1/2 +9ms
EventedHTTPServer [::ffff:13.3.89.220] HTTP Response is finished +51ms
EventedHTTPServer [::ffff:13.3.89.220] HTTP request: /pair-verify +41ms
HAPServer [CC:21:4E:E7:DF:33] Pair verify step 2/2 +3ms
HAPServer [CC:21:4E:E7:DF:33] Client 26DFF16F-5B3E-4454-9CFB-B44E0AE8CBEE verification complete +9ms
EventedHTTPServer [::ffff:13.3.89.220] HTTP Response is finished +3ms
EventedHTTPServer [::ffff:13.3.89.220] HTTP request: /accessories +18ms
HAPServer [CC:21:4E:E7:DF:33] HAP Request: GET /accessories +0ms
EventedHTTPServer [::ffff:13.3.89.220] HTTP Response is finished +26ms
EventedHTTPServer [::ffff:13.3.89.220] HTTP request: /characteristics +458ms
HAPServer [CC:21:4E:E7:DF:33] HAP Request: PUT /characteristics +1ms
Accessory [Homebridge] Processing characteristic set: [{"aid":2,"iid":11,"ev":true},{"aid":2,"iid":14,"ev":true},{"aid":3,"iid":11,"ev":true},{"aid":3,"iid":14,"ev":true},{"aid":4,"iid":11,"ev":true},{"aid":4,"iid":14,"ev":true},{"aid":5,"iid":11,"ev":true},{"aid":5,"iid":14,"ev":true},{"aid":6,"iid":11,"ev":true},{"aid":6,"iid":14,"ev":true},{"aid":7,"iid":11,"ev":true},{"aid":7,"iid":14,"ev":true},{"aid":8,"iid":11,"ev":true},{"aid":8,"iid":14,"ev":true},{"aid":9,"iid":11,"ev":true},{"aid":9,"iid":14,"ev":true},{"aid":10,"iid":13,"ev":true},{"aid":10,"iid":16,"ev":true},{"aid":11,"iid":11,"ev":true},{"aid":11,"iid":14,"ev":true},{"aid":12,"iid":11,"ev":true},{"aid":12,"iid":14,"ev":true},{"aid":13,"iid":11,"ev":true},{"aid":13,"iid":14,"ev":true},{"aid":14,"iid":11,"ev":true},{"aid":14,"iid":14,"ev":true},{"aid":15,"iid":11,"ev":true},{"aid":15,"iid":14,"ev":true},{"aid":16,"iid":11,"ev":true},{"aid":16,"iid":14,"ev":true},{"aid":17,"iid":11,"ev":true},{"aid":17,"iid":14,"ev":true},{"aid":18,"iid":11,"ev":true},{"aid":18,"iid":14,"ev":true},{"aid":19,"iid":11,"ev":true},{"aid":19,"iid":14,"ev":true},{"aid":20,"iid":11,"ev":true},{"aid":20,"iid":14,"ev":true},{"aid":21,"iid":11,"ev":true},{"aid":21,"iid":14,"ev":true},{"aid":22,"iid":11,"ev":true},{"aid":22,"iid":14,"ev":true},{"aid":23,"iid":11,"ev":true},{"aid":23,"iid":14,"ev":true},{"aid":24,"iid":11,"ev":true},{"aid":24,"iid":14,"ev":true}] +37ms
Accessory [Homebridge] Registering Characteristic "Reachable" for events +4ms
Accessory [Homebridge] Registering Characteristic "Category" for events +1ms
Accessory [Homebridge] Registering Characteristic "Reachable" for events +1ms
Accessory [Homebridge] Registering Characteristic "Category" for events +0ms
Accessory [Homebridge] Registering Characteristic "Reachable" for events +0ms
so in debug it works.. either no.. What? Why?
