Would be a good idea if it could be implemented
Homebridge command not foundMarci wrote:Run...Artic1980 wrote:i have this problem
sudo systemctl status homebridge.service -l
● homebridge.service - HomeBridge Service
Loaded: loaded (/lib/systemd/system/homebridge.service; enabled)
Active: failed (Result: exit-code) since gio 2016-10-13 20:00:50 CEST; 21s ag o
Process: 610 ExecStart=/usr/bin/homebridge (code=exited, status=203/EXEC)
Main PID: 610 (code=exited, status=203/EXEC)
ott 13 20:00:50 octopi systemd[1]: Starting HomeBridge Service...
ott 13 20:00:50 octopi systemd[1]: Started HomeBridge Service.
ott 13 20:00:50 octopi systemd[1]: homebridge.service: main process exited, code =exited, status=203/EXEC
ott 13 20:00:50 octopi systemd[1]: Unit homebridge.service entered failed state.
whi?...to get more useful info.Code: Select all
DEBUG=* homebridge -D
Active: failed (Result: signal) since Sat 2016-10-15 23:04:31 CEST; 1h 25min ago
Process: 890 ExecStart=/usr/bin/homebridge (code=killed, signal=SEGV)
Main PID: 890 (code=killed, signal=SEGV)
Oct 15 23:04:18 raspberrypi systemd[1]: Starting HomeBridge Service...
Oct 15 23:04:18 raspberrypi systemd[1]: Started HomeBridge Service.
Oct 15 23:04:31 raspberrypi systemd[1]: homebridge.service: main process exited, code=killed, status=11/SEGV
Oct 15 23:04:31 raspberrypi systemd[1]: Unit homebridge.service entered failed state.
$ DEBUG=* homebridge -D
/usr/local/lib/node_modules/homebridge/node_modules/mdns/lib/dns_sd.js:35
throw ex;
Error: /usr/lib/arm-linux-gnueabihf/libavahi-client.so.3: unexpected PLT reloc type 0x56
at Error (native)
at Object.Module._extensions..node (module.js:568:18)
at Module.load (module.js:458:32)
at tryModuleLoad (module.js:417:12)
at Function.Module._load (module.js:409:3)
at Module.require (module.js:468:17)
at require (internal/module.js:20:19)
at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/node_modules/mdns/lib/dns_sd.js:24:20)
at Module._compile (module.js:541:32)
at Object.Module._extensions..js (module.js:550:10)
*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
[10/16/2016, 12:42:25 AM] Loaded plugin: homebridge-edomoticz
[10/16/2016, 12:42:25 AM] Registering accessory 'homebridge-edomoticz.eDomoticz'
[10/16/2016, 12:42:25 AM] Registering platform 'homebridge-edomoticz.eDomoticz'
[10/16/2016, 12:42:25 AM] ---
[10/16/2016, 12:42:25 AM] Loaded config.json with 0 accessories and 1 platforms.
[10/16/2016, 12:42:25 AM] Loading 1 platforms...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing eDomoticz platform...
[10/16/2016, 12:42:25 AM] [eDomoticz] Fetching Domoticz lights and switches...
[10/16/2016, 12:42:25 AM] Loading 0 accessories...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Accento Ingresso'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'CPU_Usage'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Cancellino Xmas'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Cupola Esterno'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Cupola Interno'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Cupola Xmas'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Facciata'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Faro Garage'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Faro Retro'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Fioriera'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Fotovoltaico'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Lampada Sala'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Lampione'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Lanterna Ingresso'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Lanterna Nonna'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Luci'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Luci Cancellino'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'MacBook'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Memory Usage'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Presa Volante'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Pulsante Cancello'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Riavvio Modem'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Riavvio RaspBerry'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'Riavvio WiFi'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'iPad'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'iPhone'...
[10/16/2016, 12:42:25 AM] [eDomoticz] Initializing platform accessory 'rgbw'...
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
│ 021-45-154 │
events.js:160
throw er; // Unhandled 'error' event
Error: listen EADDRINUSE :::51826
at Object.exports._errnoException (util.js:1012:11)
at exports._exceptionWithHostPort (util.js:1035:20)
at Server._listen2 (net.js:1252:14)
at listen (net.js:1288:10)
at Server.listen (net.js:1384:5)
at EventedHTTPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/eventedhttp.js:59:19)
at HAPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/HAPServer.js:157:20)
at Bridge.Accessory.publish (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:496:16)
at Server._publish (/usr/local/lib/node_modules/homebridge/lib/server.js:111:16)
at Server.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/server.js:369:14)Code: Select all
Error: listen EADDRINUSE :::51826That's your problem. A symlink to homebridge doesn't exist in /usr/bin - this is covered in first post instructions.Artic1980 wrote:Homebridge command not foundMarci wrote:Run...Artic1980 wrote:i have this problem
Inviato dal mio iPhone utilizzando Tapatalk
What do you see when you view the status?martijnm wrote:For some reason I cannot use Homebridge anymore.
I have installed HomeBridge-eDomoticz with MQTT, loaded with PM2.
App name │ id │ mode │ pid │ status │ restart │ uptime │ memory
homebridge-edomoticz │ 0 │ fork │ 1925 │ online │ 0 │ 18h │ 43.891 M
However, when adding a new accessory with the Eve app it does not find HomeBridge. In iOS 9 I could easily reset HomeKit through settings > Privacy > Homekit. In iOS 10.1 (beta) this function does not exist. What to do?
[xx@raspberrypi:~ $ DEBUG=* homebridge
[2016-10-16 19:21:34] Loaded plugin: homebridge-edomoticz
[2016-10-16 19:21:34] Registering accessory 'homebridge-edomoticz.eDomoticz'
[2016-10-16 19:21:34] Registering platform 'homebridge-edomoticz.eDomoticz'
[2016-10-16 19:21:34] ---
[2016-10-16 19:21:34] Loaded plugin: homebridge-legacy-plugins
[2016-10-16 19:21:34] Registering accessory 'homebridge-legacy-plugins.AD2USB'
[2016-10-16 19:21:34] Registering accessory 'homebridge-legacy-plugins.Carwings'
[2016-10-16 19:21:34] Registering accessory 'homebridge-legacy-plugins.ELKM1'
[2016-10-16 19:21:34] Registering accessory 'homebridge-legacy-plugins.FileSensor'
[2016-10-16 19:21:34] Registering accessory 'homebridge-legacy-plugins.GenericRS232Device'
[2016-10-16 19:21:34] Registering accessory 'homebridge-legacy-plugins.HomeMatic'
[2016-10-16 19:21:34] Registering accessory 'homebridge-legacy-plugins.HomeMaticThermo'
[2016-10-16 19:21:34] Registering accessory 'homebridge-legacy-plugins.HomeMaticWindow'
[2016-10-16 19:21:34] Registering accessory 'homebridge-legacy-plugins.HttpGarageDoorOpener'
[2016-10-16 19:21:34] Registering accessory 'homebridge-legacy-plugins.HttpHygrometer'
[2016-10-16 19:21:34] Registering accessory 'homebridge-legacy-plugins.HttpThermometer'
[2016-10-16 19:21:34] Registering accessory 'homebridge-legacy-plugins.Tesla'
[2016-10-16 19:21:34] Registering accessory 'homebridge-legacy-plugins.X10'
[2016-10-16 19:21:34] Registering accessory 'homebridge-legacy-plugins.mpdclient'
[2016-10-16 19:21:34] Registering platform 'homebridge-legacy-plugins.Domoticz'
[2016-10-16 19:21:34] Registering platform 'homebridge-legacy-plugins.HomeAssistant'
[2016-10-16 19:21:34] Registering platform 'homebridge-legacy-plugins.HomeSeer'
[2016-10-16 19:21:34] Registering platform 'homebridge-legacy-plugins.ISY'
[2016-10-16 19:21:34] Registering platform 'homebridge-legacy-plugins.LIFx'
[2016-10-16 19:21:34] Registering platform 'homebridge-legacy-plugins.SmartThings'
[2016-10-16 19:21:34] Registering platform 'homebridge-legacy-plugins.TelldusLive'
[2016-10-16 19:21:34] Registering platform 'homebridge-legacy-plugins.ZWayServer'
[2016-10-16 19:21:34] Loaded config.json with 0 accessories and 1 platforms.
[2016-10-16 19:21:34] Loading 1 platforms...
[2016-10-16 19:21:34] [eDomoticz] Initializing eDomoticz platform...
[2016-10-16 19:21:34] [eDomoticz] Fetching Domoticz lights and switches...
[2016-10-16 19:21:34] Loading 0 accessories...
[2016-10-16 19:21:35] [eDomoticz] There was a problem connecting to Domoticz.Code: Select all
"bridge": {
"name": "Homebridge",
"username": "CC:22:3D:E3:CE:30",
"port": 51826,
"pin": "031-45-154"
"description": "This is an example configuration file with one fake accessory and one fake platform. You can use this as a template for creating your own configuration file containing devices you actually own.",
"accessories": [ ],
"platforms": [
"platform": "eDomoticz",
"name": "eDomoticz",
"server": "user:[email protected]",
"port": "8080",
"ssl": 0,
"roomid": 0
pi@raspberrypi:~ $ sudo systemctl status homebridge.service -l
Active: failed (Result: exit-code) since Sun 2016-10-16 23:54:17 CEST; 26min ago
Process: 1027 ExecStart=/usr/bin/homebridge (code=exited, status=1/FAILURE)
Main PID: 1027 (code=exited, status=1/FAILURE)
Oct 16 23:54:17 raspberrypi homebridge[1027]: at Module.load (module.js:458:32)
Oct 16 23:54:17 raspberrypi homebridge[1027]: at tryModuleLoad (module.js:417:12)
Oct 16 23:54:17 raspberrypi homebridge[1027]: at Function.Module._load (module.js:409:3)
Oct 16 23:54:17 raspberrypi homebridge[1027]: at Module.require (module.js:468:17)
Oct 16 23:54:17 raspberrypi homebridge[1027]: at require (internal/module.js:20:19)
Oct 16 23:54:17 raspberrypi homebridge[1027]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/node_modules/mdns/lib/dns_sd.js:24:20)
Oct 16 23:54:17 raspberrypi homebridge[1027]: at Module._compile (module.js:541:32)
Oct 16 23:54:17 raspberrypi homebridge[1027]: at Object.Module._extensions..js (module.js:550:10)
Oct 16 23:54:17 raspberrypi systemd[1]: homebridge.service: main process exited, code=exited, status=1/FAILURE
Oct 16 23:54:17 raspberrypi systemd[1]: Unit homebridge.service entered failed state.Code: Select all
pi@raspberrypi:~ $ DEBUG=* homebridge -D
throw ex;
Error: /usr/lib/arm-linux-gnueabihf/libavahi-client.so.3: ELF file OS ABI invalid
at Error (native)
rwijbenga wrote:What do you see when you view the status?
Did you try to delete the accessories and persist folders?
I just delete the house in IOS when everything else fails and add it again....
pi@raspberrypi:~ $ systemctl -l status homebridge
Active: failed (Result: exit-code) since Mon 2016-10-17 15:12:44 UTC; 2min 52s ago
Process: 1146 ExecStart=/usr/bin/homebridge (code=exited, status=203/EXEC)
Main PID: 1146 (code=exited, status=203/EXEC)Code: Select all
sudo raspi-config
sudo apt-get update
sudo apt-get upgrade
sudo reboot
sudo rpi-update
sudo reboot
sudo apt-get install libdevice-serialport-perl
sudo apt-get install telnet
mkdir ~/domoticz
cd ~/domoticz
wget http://releases.domoticz.com/releases/release/domoticz_linux_armv7l.tgz
tar xvfz domoticz_linux_armv7l.tgz
rm domoticz_linux_armv7l.tgz
sudo cp domoticz.sh /etc/init.d
sudo chmod +x /etc/init.d/domoticz.sh
sudo update-rc.d domoticz.sh defaults
cd ~/domoticz
sudo ./domoticz
[ctrl-c]
sudo service domoticz.sh start
# INSTALL HOMEBRIDGE
cd ~/
sudo apt-get install apt-transport-https
sudo apt-get remove nodejs
sudo rm -rf /usr/local/{lib/node{,/.npm,_modules},bin,share/man}/{npm*,node*,man1/node*} /var/db/receipts/org.nodejs.*
hash -r
wget https://nodejs.org/dist/v6.3.1/node-v6.3.1-linux-armv7l.tar.gz
tar -xvf node-v6.3.1-linux-armv7l.tar.gz
cd node-v6.3.1-linux-armv7l
sudo cp -R * /usr/local/
cd ~/
sudo apt-get install libavahi-compat-libdnssd-dev
sudo apt-get install npm
sudo npm install -g homebridge --unsafe-perm
sudo npm install -g homebridge-edomoticz --unsafe-perm
mkdir ~/.homebridge
sudo pico ~/.homebridge/config.json
——Config.json
"bridge": {
"username": "CC:21:4E:E7:DF:33",
"port": 51826,
"pin": "031-45-154"
"description": "Configuration file for (e)xtended Domoticz platform.",
"platforms": [
"server": "127.0.0.1",
"port": "8080",
"ssl": 0,
"roomid": 0
"accessories": []
sudo pico /lib/systemd/system/homebridge.service
[Unit]
Description=HomeBridge Service
After=multi-user.target
[Service]
User=pi
Type=idle
[Install]
WantedBy=multi-user.target
sudo chmod 644 /lib/systemd/system/homebridge.service
sudo systemctl daemon-reload
sudo systemctl enable homebridge.service
sudo reboot
#STATUS HOMEBRIDGE
sudo systemctl status homebridge.service -lCode: Select all
[10/17/2016, 7:18:25 PM] Loaded plugin: homebridge-edomoticz
[10/17/2016, 7:18:25 PM] Registering accessory 'homebridge-edomoticz.eDomoticz'
[10/17/2016, 7:18:25 PM] Registering platform 'homebridge-edomoticz.eDomoticz'
[10/17/2016, 7:18:25 PM] ---
[10/17/2016, 7:18:25 PM] Loaded config.json with 0 accessories and 1 platforms.
[10/17/2016, 7:18:25 PM] Loading 1 platforms...
[10/17/2016, 7:18:25 PM] [eDomoticz] Initializing eDomoticz platform...
[10/17/2016, 7:18:25 PM] [eDomoticz] Fetching Domoticz lights and switches...
[10/17/2016, 7:18:26 PM] Loading 0 accessories...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Accento Ingresso'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'CPU_Usage'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Cupola Esterno'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Cupola Interno'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Cupola Xmas'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Facciata'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Faro Retro'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Fioriera'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Fotovoltaico'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Lampada Sala'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Lampione'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Lanterna Ingresso'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Lanterna Nonna'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Luci'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Luci Cancellino'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'MacBook'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Memory Usage'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Pulsante Cancello'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Riavvio Modem'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Riavvio RaspBerry'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'Riavvio WiFi'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'iPad'...
[10/17/2016, 7:18:26 PM] [eDomoticz] Initializing platform accessory 'iPhone'...
│ 031-45-154 │
EventedHTTPServer Server listening on port 51826 +0ms
[10/17/2016, 7:18:26 PM] Homebridge is running on port 51826.
EventedHTTPServer [::ffff:13.3.89.220] New connection from client +1s
EventedHTTPServer [::ffff:13.3.89.220] HTTP server listening on port 45433 +4ms
EventedHTTPServer [::ffff:13.3.89.220] HTTP request: /pair-verify +24ms
HAPServer [CC:21:4E:E7:DF:33] HAP Request: POST /pair-verify +1ms
HAPServer [CC:21:4E:E7:DF:33] Pair verify step 1/2 +9ms
EventedHTTPServer [::ffff:13.3.89.220] HTTP Response is finished +51ms
EventedHTTPServer [::ffff:13.3.89.220] HTTP request: /pair-verify +41ms
HAPServer [CC:21:4E:E7:DF:33] Pair verify step 2/2 +3ms
HAPServer [CC:21:4E:E7:DF:33] Client 26DFF16F-5B3E-4454-9CFB-B44E0AE8CBEE verification complete +9ms
EventedHTTPServer [::ffff:13.3.89.220] HTTP Response is finished +3ms
EventedHTTPServer [::ffff:13.3.89.220] HTTP request: /accessories +18ms
HAPServer [CC:21:4E:E7:DF:33] HAP Request: GET /accessories +0ms
EventedHTTPServer [::ffff:13.3.89.220] HTTP Response is finished +26ms
EventedHTTPServer [::ffff:13.3.89.220] HTTP request: /characteristics +458ms
HAPServer [CC:21:4E:E7:DF:33] HAP Request: PUT /characteristics +1ms
Accessory [Homebridge] Processing characteristic set: [{"aid":2,"iid":11,"ev":true},{"aid":2,"iid":14,"ev":true},{"aid":3,"iid":11,"ev":true},{"aid":3,"iid":14,"ev":true},{"aid":4,"iid":11,"ev":true},{"aid":4,"iid":14,"ev":true},{"aid":5,"iid":11,"ev":true},{"aid":5,"iid":14,"ev":true},{"aid":6,"iid":11,"ev":true},{"aid":6,"iid":14,"ev":true},{"aid":7,"iid":11,"ev":true},{"aid":7,"iid":14,"ev":true},{"aid":8,"iid":11,"ev":true},{"aid":8,"iid":14,"ev":true},{"aid":9,"iid":11,"ev":true},{"aid":9,"iid":14,"ev":true},{"aid":10,"iid":13,"ev":true},{"aid":10,"iid":16,"ev":true},{"aid":11,"iid":11,"ev":true},{"aid":11,"iid":14,"ev":true},{"aid":12,"iid":11,"ev":true},{"aid":12,"iid":14,"ev":true},{"aid":13,"iid":11,"ev":true},{"aid":13,"iid":14,"ev":true},{"aid":14,"iid":11,"ev":true},{"aid":14,"iid":14,"ev":true},{"aid":15,"iid":11,"ev":true},{"aid":15,"iid":14,"ev":true},{"aid":16,"iid":11,"ev":true},{"aid":16,"iid":14,"ev":true},{"aid":17,"iid":11,"ev":true},{"aid":17,"iid":14,"ev":true},{"aid":18,"iid":11,"ev":true},{"aid":18,"iid":14,"ev":true},{"aid":19,"iid":11,"ev":true},{"aid":19,"iid":14,"ev":true},{"aid":20,"iid":11,"ev":true},{"aid":20,"iid":14,"ev":true},{"aid":21,"iid":11,"ev":true},{"aid":21,"iid":14,"ev":true},{"aid":22,"iid":11,"ev":true},{"aid":22,"iid":14,"ev":true},{"aid":23,"iid":11,"ev":true},{"aid":23,"iid":14,"ev":true},{"aid":24,"iid":11,"ev":true},{"aid":24,"iid":14,"ev":true}] +37ms
Accessory [Homebridge] Registering Characteristic "Reachable" for events +4ms
Accessory [Homebridge] Registering Characteristic "Category" for events +1ms
Accessory [Homebridge] Registering Characteristic "Reachable" for events +1ms
Accessory [Homebridge] Registering Characteristic "Category" for events +0ms
Accessory [Homebridge] Registering Characteristic "Reachable" for events +0ms
Accessory [Homebridge] Registering Characteristic "Category" for events +0msYes i have two pi's :@kiala:
Is Domoticz running on port 8080 on that Raspberry Pi too? And is the IP of your other Pi really 192.168.0.96?
Try http://192.168.0.96:8080/json.htm?type= ... filter=all in your browser. See what that gives you. You should probably get a username/password dialog first.
Users browsing this forum: felek and 1 guest
