Pass2PHP
Trigun
Domoticz version: 4.10717
Re: Pass2PHP
Post by Trigun »
poudenes wrote: Friday 03 May 2019 11:02 from SSH:
root@raspberrypi:/var/www/html/secure# php _fetchdomoticz.php
PHP Warning:  require(/var/www/html/config.php): failed to open stream: No such file or directory in /var/www/html/secure/_fetchdomoticz.php on line 12
PHP Fatal error:  require(): Failed opening required '/var/www/html/config.php' (include_path='.:/usr/share/php') in /var/www/html/secure/_fetchdomoticz.php on line 12
from browser:
(A white screen)
ah ok, so you still get the same error?
just put the following files in the following folders and make no changes to the files at all:
2019-05-03 11_33_36-lua - Domoticz-NEW! - WinSCP.png (3.79 KiB) Viewed 1184 times
2019-05-03 11_33_13-www - Domoticz-NEW! - WinSCP.png (2.73 KiB) Viewed 1184 times
2019-05-03 11_32_52-secure - Domoticz-NEW! - WinSCP.png (3.5 KiB) Viewed 1184 times
after that, please test again.
when you put the files in the folders and made no changes to the files(not even your own domoticz IP) it should work
poudenes
Domoticz version: 3.8993
Re: Pass2PHP
Post by poudenes »
Trigun wrote: Friday 03 May 2019 11:35
from browser:
(A white screen)
Moved config.php to /var/www/ and also change the path in the other files back to /var/www
then php _fetchdomoticz.php now I don't see any notices or errors :D
Trigun
Re: Pass2PHP
Post by Trigun »
poudenes wrote: Friday 03 May 2019 11:40
from browser:
(A white screen)
GREAT! now put the "echo"comment after the store line in de _fetch... file.
in the browser you can see the output when you enter http://domoticzip/secure/_fetchdomoticz.php
poudenes
Re: Pass2PHP
Post by poudenes »
With all the support this is how you install pass2php. :D if im archived the way correct haha.
This is what I did now:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install apache
sudo apt-get install mysql-server
sudo apt-get install phpmyadmin
sudo mysql_secure_installation
mysql -u root -p
GRANT ALL PRIVILEGES ON *.* TO 'domotica'@'localhost' IDENTIFIED BY 'domotica';
CREATE DATABASE domotica;
Download the GitHub package zip file. In this zip file you have ‘Create-Update SQL Database.txt'
mysql -u domotica -p domotica < 'Create-Update SQL Database.txt'
mysql -u root -p
MariaDB [(none)]> show databases;
| Database           |
| domotica           |
| information_schema |
| mysql              |
| performance_schema |
4 rows in set (0.00 sec)
sudo ln -s /usr/share/phpmyadmin /var/www/html
Copy all files from the ZIP to:
/var/www/html/
So lots of files are in /var/www/html/
And lots of files are in /var/www/html/secure
move config.php to /var/www/
Edit _fetchdomoticz.php and add 2 lines:
require '/var/www/config.php';
require 'functions.php';
copy from /var/www/html/secure/lua the file
script_device_pass2php
to
/domoitcz/script/lua
Edit _fetchdomoticz.php and add follow line direct below: store($name, $status, $idx, false);
echo $idx.' '.$name.' = '.$status.'<br>';
so it looks like
to fetch all devices in dB:
If everything is correct what I post now, then all devices will be now in database.
open
http://192.168.x.x/phpmyadmin
Login and in database: domotica > devices you can see all the devices
Egregius
Domoticz version: v2024.7
Re: Pass2PHP
Post by Egregius »
Could be that the spaces causes issues, I don't use them in my devicenames. Maybe Sincze can confirm or deny that.
Will look into it a bit later, just accidentally deleted all my devices :o
poudenes
Re: Pass2PHP
Post by poudenes »
Egregius wrote: Friday 03 May 2019 12:05 Could be that the spaces causes issues, I don't use them in my devicenames. Maybe Sincze can confirm or deny that.
Since I updated the path of config I can fetch without any errors... Everything is now in dB
Egregius
Re: Pass2PHP
Post by Egregius »
Great, next step would be create a device script on a motion sensor to switch the light on.
And after that a cron script to switch it back off.
If that is working you're started to use pass2php ;)
poudenes
Re: Pass2PHP
Post by poudenes »
Egregius wrote: Friday 03 May 2019 12:17 Great, next step would be create a device script on a motion sensor to switch the light on.
have a virtual switch "Switch-Hall-MEEK"
created a PHP file Switch-Hall-MEEK.php
add:
if ($['status']['s']=='On') {
    sw('Dressoir-All', 'On');
is this correct?
Egregius
Re: Pass2PHP
Post by Egregius »
Nope, it should be:
if ($status=='On') {
$status holds the new status of the changed device.
$d array holds all the previous statusses.
poudenes
Re: Pass2PHP
Post by poudenes »
Egregius wrote: Friday 03 May 2019 12:51 Nope, it should be:
Changed it and there is nothing happen. Can I check a log to see what happend?
switch name is correct in dB, also the IDX is correct.
php filename is exact same as device name stored in dB, include case sensitive parts.
Trigun
Re: Pass2PHP
Post by Trigun »
poudenes wrote: Friday 03 May 2019 12:54
Sorry, I really don't understand this.
does it mean that for everything I want to switch I also have to make a new dummy switch?
That means I am going to have a whole lot of extra switches.
also, what do I need to do when I just want to switch a light on/off?
thnx guys!
Egregius
Re: Pass2PHP
Post by Egregius »
poudenes wrote: Friday 03 May 2019 12:54 Changed it and there is nothing happen. Can I check a log to see what happend?
If your domoticz log is at /var/log/domoticz.log it should have extra lines in it. These aren't shown by the domoticz GUI log viewer.
You can use this to view the log in realtime thru SSH:
tail -f /var/log/domoticz.log
Every switch line from pass2php starts with "(SWITCH)".
Egregius
Re: Pass2PHP
Post by Egregius »
Trigun wrote: Friday 03 May 2019 13:39 Sorry, I really don't understand this.
thnx guys!
You don't need any dummy switch.
How do you want to switch of the light? From the floorplan or from a schedule?
Trigun
Re: Pass2PHP
Post by Trigun »
Egregius wrote: Friday 03 May 2019 13:55
thnx guys!
I was wondering if I switch a light on/off via the domoticz dashboard if I also could use pass2php
sincze
Domoticz version: 2024.4
Re: Pass2PHP
Post by sincze »
This issue is now solved for Pass2php in latest Domoticz release. Tnx @Gizmocuz
https://github.com/domoticz/domoticz/is ... -489075040
Sent from my ONEPLUS A6003 using Tapatalk
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
poudenes
Re: Pass2PHP
Post by poudenes »
Egregius wrote: Friday 03 May 2019 13:54
hmm I don't see anything happen ...
Egregius
Re: Pass2PHP
Post by Egregius »
Are the new statusses automatically available in the devices MySQL table?
If not, is the lua script in place?
Egregius
Re: Pass2PHP
Post by Egregius »
Trigun wrote: Friday 03 May 2019 14:14 I was wondering if I switch a light on/off via the domoticz dashboard if I also could use pass2php
Yes, of course. All statusses are sent with the lua script to pass2php. So you can do everything with them.
Trigun
Re: Pass2PHP
Post by Trigun »
Egregius wrote: Friday 03 May 2019 16:58
GREAT!!! I am getting closer and closer to the final result where I can go completely haywire with scripts :)
Ok, if i press a light to go On in domoticz what do I need to write in the php file?
Egregius
Re: Pass2PHP
Post by Egregius »
I'm afraid I don't really understand what you're trying to achive.
Do you want to use the floorplan to control everything, or do you just want to use pass2php for scripting?
