Page 42 of 86
Re: homebridge-edomoticz Plugin
Posted: Wednesday 12 October 2016 14:56
by possible
I tried to install the following plugin for my sony TV:
npm install -g homebridge-sonybraviatv
I want to turn my Sony Android TV on with this plugin. i added the following configuration to my config.json:
"bridge": {
"name": "Homebridge",
"username": "CC:21:3E:E4:DE:33",
"port": 51826,
"pin": "031-45-154"
"description": "Configuration file for (e)xtended Domoticz platform.",
"platforms": [
"platform": "eDomoticz",
"name": "eDomoticz",
"server": "127.0.0.1",
"port": "8080",
"ssl": 0,
"roomid": 0,
"mqttenable": 0,
"mqttserver": "",
"mqttport": "1883",
"mqttauth": 0,
"mqttuser": "",
"mqttpass": ""
"accessories": [
"accessory": "SonyBraviaTV",
"name": "Sony KDL",
"ipaddress": "192.168.0.150",
"presharedkey": "YOUR PRESHARED KEY HERE"
But when I restart homebridge, homebridge fails:
homebridge.service - HomeBridge Service
Loaded: loaded (/lib/systemd/system/homebridge.service; enabled)
Active: failed (Result: exit-code) since Wed 2016-10-12 12:58:16 UTC; 3s ago
Process: 15505 ExecStart=/usr/local/lib/node_modules/homebridge/bin/homebridge (code=exited, status=1/FAILURE)
Main PID: 15505 (code=exited, status=1/FAILURE)
Oct 12 12:58:16 raspberrypi homebridge[15505]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Oct 12 12:58:16 raspberrypi homebridge[15505]: at Module._compile (module.js:409:26)
Oct 12 12:58:16 raspberrypi homebridge[15505]: at Object.Module._extensions..js (module.js:416:10)
Oct 12 12:58:16 raspberrypi homebridge[15505]: at Module.load (module.js:343:32)
Oct 12 12:58:16 raspberrypi homebridge[15505]: at Function.Module._load (module.js:300:12)
Oct 12 12:58:16 raspberrypi homebridge[15505]: at Function.Module.runMain (module.js:441:10)
Oct 12 12:58:16 raspberrypi homebridge[15505]: at startup (node.js:139:18)
Oct 12 12:58:16 raspberrypi homebridge[15505]: at node.js:974:3
Oct 12 12:58:16 raspberrypi systemd[1]: homebridge.service: main process exited, code=exited, status=1/FAILURE
Oct 12 12:58:16 raspberrypi systemd[1]: Unit homebridge.service entered failed state.
Did I made a typo ?
Posted: Wednesday 12 October 2016 17:04
by Minglarn
Marci wrote:(In fact, the method used to communicate between domoticz master and slave is the exact same method the plugin communicates with domoticz over a network... no need to add a slave into the mix at all)
Great.
Will try to install it on my rpi1
Edit: Changed my mind... Just bought a RPI3
Posted: Wednesday 12 October 2016 19:14
by Minglarn
Hi!
wget http://www.domoticz.com/releases/r ... armv7l.tgz
Seems to be broken... No response from host... Any alternatives?
Posted: Wednesday 12 October 2016 19:18
by Marci
possible wrote:Hi,
"bridge": {
"port": 51826,
"pin": "031-45-154"
"platforms": [
"port": "8080",
"ssl": 0,
"roomid": 0,
"mqttenable": 0,
"mqttserver": "",
"mqttport": "1883",
"mqttauth": 0,
"mqttuser": "",
"mqttpass": ""
"accessories": [
"name": "Sony KDL",
Run it manually and it should hopefully present more useful errors... but note, if using a separate plugin for the TV then that TV shouldn't be listed in Domoticz.
Posted: Wednesday 12 October 2016 19:22
by Marci
S'just the download link for domoticz. Go to downloads section, right click and copy link, paste in place of original... BUT... like it says for option 3 in the first post...
It’s assumed that you have a vague idea of what you’re doing with Linux and will be able to resolve any issues yourself.
If you're getting stuck at that step, start again using the domoticz images instead.
Posted: Wednesday 12 October 2016 20:26
by Minglarn
I did get it from this url:
https://releases.domoticz.com/releases/ ... armv7l.tgz
Posted: Wednesday 12 October 2016 20:43
by possible
Marci wrote:possible wrote:Hi,
"bridge": {
"port": 51826,
"pin": "031-45-154"
"platforms": [
"port": "8080",
"ssl": 0,
"roomid": 0,
"mqttenable": 0,
"mqttserver": "",
"mqttport": "1883",
"mqttauth": 0,
"mqttuser": "",
"mqttpass": ""
"accessories": [
"name": "Sony KDL",
What do you mean with run it manually? The TV is not listed in domoticz.. I only added the plugin and added the accessory to the config file.
Do I have to remove the domoticz part in the configuration file?
debug:
[10/12/2016, 7:05:42 PM] There was a problem reading your config.json file.
[10/12/2016, 7:05:42 PM] Please try pasting your config.json file here to validate it: http://jsonlint.com
/usr/local/lib/node_modules/homebridge/lib/server.js:194
throw err;
SyntaxError: Unexpected end of input
at Object.parse (native)
at Server._loadConfig (/usr/local/lib/node_modules/homebridge/lib/server.js:188:19)
at new Server (/usr/local/lib/node_modules/homebridge/lib/server.js:49:23)
at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:26:16)
at node.js:974:3
Posted: Thursday 13 October 2016 11:31
by TheRamon
possible wrote:Marci wrote:possible wrote:
"bridge": {
"port": 51826,
"pin": "031-45-154"
"platforms": [
"port": "8080",
"ssl": 0,
"roomid": 0,
"mqttenable": 0,
"mqttserver": "",
"mqttport": "1883",
"mqttauth": 0,
"mqttuser": "",
"mqttpass": ""
"accessories": [
"name": "Sony KDL",
It looks like you're missing the last accolade "}" in your config json.
Try:
"bridge": {
"port": 51826,
"pin": "031-45-154"
"platforms": [
"port": "8080",
"ssl": 0,
"roomid": 0,
"mqttenable": 0,
"mqttserver": "",
"mqttport": "1883",
"mqttauth": 0,
"mqttuser": "",
"mqttpass": ""
"accessories": [
"name": "Sony KDL",
Posted: Thursday 13 October 2016 14:10
by possible
Try:
"bridge": {
"port": 51826,
"pin": "031-45-154"
"platforms": [
"port": "8080",
"ssl": 0,
"roomid": 0,
"mqttenable": 0,
"mqttserver": "",
"mqttport": "1883",
"mqttauth": 0,
"mqttuser": "",
"mqttpass": ""
"accessories": [
"name": "Sony KDL",
That did the trick! But if I want to add multiple accessoires, What code do I have to use ?
I probably made a mistake again:
"accessories": [
"name": "Televisie",
"presharedkey": "wereld213"
"accessory": "Xbox",
"name": "Xbox",
"ipAddress": "192.168.0.171",
"liveId": "KEY"
Posted: Thursday 13 October 2016 20:02
by Artic1980
i have this problem
sudo systemctl status homebridge.service -l
● homebridge.service - HomeBridge Service
Active: failed (Result: exit-code) since gio 2016-10-13 20:00:50 CEST; 21s ag o
Process: 610 ExecStart=/usr/bin/homebridge (code=exited, status=203/EXEC)
Main PID: 610 (code=exited, status=203/EXEC)
ott 13 20:00:50 octopi systemd[1]: Starting HomeBridge Service...
ott 13 20:00:50 octopi systemd[1]: Started HomeBridge Service.
ott 13 20:00:50 octopi systemd[1]: homebridge.service: main process exited, code =exited, status=203/EXEC
ott 13 20:00:50 octopi systemd[1]: Unit homebridge.service entered failed state.
whi?
Posted: Thursday 13 October 2016 21:00
by rwijbenga
"accessories": [
"name": "Xbox",
"liveId": "KEY"
The middle ] needs to go, it should be:
"accessories": [
"name": "Xbox",
"liveId": "KEY"
You can always check your json on this url:
http://jsonlint.com/#
Posted: Friday 14 October 2016 9:11
by possible
"accessories": [
"name": "Xbox",
"liveId": "KEY"
"accessories": [
"name": "Xbox",
"liveId": "KEY"
yeah i checked the website, but it keeps failing on:
Error: Parse error on line 31:
... }, "accessory": "Xbox", "name":
Expecting 'EOF', '}', ',', ']', got ':'
Posted: Friday 14 October 2016 9:40
by binbakker
Seems you miss the { at the start of Xbox accessoire:
"bridge": {
"port": 51826,
"pin": "031-45-154"
"platforms": [{
"port": "8080",
"ssl": 0,
"roomid": 0,
"mqttenable": 0,
"mqttserver": "",
"mqttport": "1883",
"mqttauth": 0,
"mqttuser": "",
"mqttpass": ""
"accessories": [{
"name": "Xbox",
"liveId": "KEY"
Posted: Friday 14 October 2016 14:24
by TheRamon
Have just added an experimental feature to the MQTT branch, namely changing colours through RGB instead of Hue & Saturation. Hue and Saturation never worked the way it should, so I'm hoping RGB will.
Will try this out tonight.
For reference:
https://github.com/domoticz/domoticz/issues/909
Posted: Friday 14 October 2016 18:23
by simon_rb
TheRamon wrote:Have just added an experimental feature to the MQTT branch, namely changing colours through RGB instead of Hue & Saturation. Hue and Saturation never worked the way it should, so I'm hoping RGB will.
For reference:
Top man, any further ideas/development on the 'cache' idea. Or are you waiting for MQTT to be completely finished?
Posted: Saturday 15 October 2016 9:45
by Marci
Been reading thru the source of hap-nodejs - there doesn't seem to be a cache that's usable in this way... unless I've missed something??
Posted: Saturday 15 October 2016 9:47
by Marci
Artic1980 wrote:i have this problem
whi?
Run...
...to get more useful info.
Posted: Saturday 15 October 2016 9:49
by Marci
*ignore*
Posted: Saturday 15 October 2016 10:01
by simon_rb
Something TheRamon mentioned last week.
Posted: Saturday 15 October 2016 10:18
by Marci
Yep, I saw... what I was getting at is that there doesn't appear to be an existing method already in homebridge / hap-nodejs that we can use for this, so would need our own mechanism.
