homebridge-edomoticz Plugin
possible
Re: homebridge-edomoticz Plugin
Post by possible »
I tried to install the following plugin for my sony TV:
npm install -g homebridge-sonybraviatv
I want to turn my Sony Android TV on with this plugin. i added the following configuration to my config.json:
    "bridge": {
        "name": "Homebridge",
        "username": "CC:21:3E:E4:DE:33",
        "port": 51826,
        "pin": "031-45-154"
    "description": "Configuration file for (e)xtended Domoticz platform.",
    "platforms": [
            "platform": "eDomoticz",
            "name": "eDomoticz",
            "server": "127.0.0.1",
            "port": "8080",
            "ssl": 0,
            "roomid": 0,
            "mqttenable": 0,
            "mqttserver": "",
            "mqttport": "1883",
            "mqttauth": 0,
            "mqttuser": "",
            "mqttpass": ""
    "accessories": [
            "accessory": "SonyBraviaTV",
            "name": "Sony KDL",
            "ipaddress": "192.168.0.150",
            "presharedkey": "YOUR PRESHARED KEY HERE"
But when I restart homebridge, homebridge fails:
homebridge.service - HomeBridge Service
   Loaded: loaded (/lib/systemd/system/homebridge.service; enabled)
   Active: failed (Result: exit-code) since Wed 2016-10-12 12:58:16 UTC; 3s ago
  Process: 15505 ExecStart=/usr/local/lib/node_modules/homebridge/bin/homebridge (code=exited, status=1/FAILURE)
 Main PID: 15505 (code=exited, status=1/FAILURE)
Oct 12 12:58:16 raspberrypi homebridge[15505]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Oct 12 12:58:16 raspberrypi homebridge[15505]: at Module._compile (module.js:409:26)
Oct 12 12:58:16 raspberrypi homebridge[15505]: at Object.Module._extensions..js (module.js:416:10)
Oct 12 12:58:16 raspberrypi homebridge[15505]: at Module.load (module.js:343:32)
Oct 12 12:58:16 raspberrypi homebridge[15505]: at Function.Module._load (module.js:300:12)
Oct 12 12:58:16 raspberrypi homebridge[15505]: at Function.Module.runMain (module.js:441:10)
Oct 12 12:58:16 raspberrypi homebridge[15505]: at startup (node.js:139:18)
Oct 12 12:58:16 raspberrypi homebridge[15505]: at node.js:974:3
Oct 12 12:58:16 raspberrypi systemd[1]: homebridge.service: main process exited, code=exited, status=1/FAILURE
Oct 12 12:58:16 raspberrypi systemd[1]: Unit homebridge.service entered failed state.
Did I made a typo ?
Minglarn
Domoticz version: v3.8153
Post by Minglarn »
Marci wrote:(In fact, the method used to communicate between domoticz master and slave is the exact same method the plugin communicates with domoticz over a network... no need to add a slave into the mix at all)
Great.
Will try to install it on my rpi1 :)
Edit: Changed my mind... Just bought a RPI3 :)
Last edited by Minglarn on Wednesday 12 October 2016 19:14, edited 1 time in total.
Minglarn
Post by Minglarn »
Hi!
wget http://www.domoticz.com/releases/r ... armv7l.tgz
Seems to be broken... No response from host... Any alternatives?
Marci
Domoticz version: 3.8153
Post by Marci »
possible wrote:Hi,
    "bridge": {
        "port": 51826,
        "pin": "031-45-154"
    "platforms": [
            "port": "8080",
            "ssl": 0,
            "roomid": 0,
            "mqttenable": 0,
            "mqttserver": "",
            "mqttport": "1883",
            "mqttauth": 0,
            "mqttuser": "",
            "mqttpass": ""
    "accessories": [
            "name": "Sony KDL",
Run it manually and it should hopefully present more useful errors... but note, if using a separate plugin for the TV then that TV shouldn't be listed in Domoticz.
DEBUG=* homebridge -D
Marci
Post by Marci »
Minglarn wrote:Hi!
S'just the download link for domoticz. Go to downloads section, right click and copy link, paste in place of original... BUT... like it says for option 3 in the first post...
It’s assumed that you have a vague idea of what you’re doing with Linux and will be able to resolve any issues yourself.
If you're getting stuck at that step, start again using the domoticz images instead.
Minglarn
Post by Minglarn »
Marci wrote:
Minglarn wrote:Hi!
I did get it from this url: https://releases.domoticz.com/releases/ ... armv7l.tgz
possible
Post by possible »
Marci wrote:
possible wrote:Hi,
    "bridge": {
        "port": 51826,
        "pin": "031-45-154"
    "platforms": [
            "port": "8080",
            "ssl": 0,
            "roomid": 0,
            "mqttenable": 0,
            "mqttserver": "",
            "mqttport": "1883",
            "mqttauth": 0,
            "mqttuser": "",
            "mqttpass": ""
    "accessories": [
            "name": "Sony KDL",
What do you mean with run it manually? The TV is not listed in domoticz.. I only added the plugin and added the accessory to the config file.
Do I have to remove the domoticz part in the configuration file?
debug:
[10/12/2016, 7:05:42 PM] There was a problem reading your config.json file.
[10/12/2016, 7:05:42 PM] Please try pasting your config.json file here to validate it: http://jsonlint.com
/usr/local/lib/node_modules/homebridge/lib/server.js:194
    throw err;
SyntaxError: Unexpected end of input
    at Object.parse (native)
    at Server._loadConfig (/usr/local/lib/node_modules/homebridge/lib/server.js:188:19)
    at new Server (/usr/local/lib/node_modules/homebridge/lib/server.js:49:23)
    at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:26:16)
    at node.js:974:3
TheRamon
Post by TheRamon »
possible wrote:
Marci wrote:
possible wrote:
    "bridge": {
        "port": 51826,
        "pin": "031-45-154"
    "platforms": [
            "port": "8080",
            "ssl": 0,
            "roomid": 0,
            "mqttenable": 0,
            "mqttserver": "",
            "mqttport": "1883",
            "mqttauth": 0,
            "mqttuser": "",
            "mqttpass": ""
    "accessories": [
            "name": "Sony KDL",
It looks like you're missing the last accolade "}" in your config json.
Try:
    "bridge": {
        "port": 51826,
        "pin": "031-45-154"
    "platforms": [
            "port": "8080",
            "ssl": 0,
            "roomid": 0,
            "mqttenable": 0,
            "mqttserver": "",
            "mqttport": "1883",
            "mqttauth": 0,
            "mqttuser": "",
            "mqttpass": ""
    "accessories": [
            "name": "Sony KDL",
possible
Post by possible »
TheRamon wrote:
possible wrote:
Try:
    "bridge": {
        "port": 51826,
        "pin": "031-45-154"
    "platforms": [
            "port": "8080",
            "ssl": 0,
            "roomid": 0,
            "mqttenable": 0,
            "mqttserver": "",
            "mqttport": "1883",
            "mqttauth": 0,
            "mqttuser": "",
            "mqttpass": ""
    "accessories": [
            "name": "Sony KDL",
That did the trick! But if I want to add multiple accessoires, What code do I have to use ?
I probably made a mistake again:
 "accessories": [
            "name": "Televisie",
            "presharedkey": "wereld213"
            "accessory": "Xbox",
            "name": "Xbox",
            "ipAddress": "192.168.0.171",
            "liveId": "KEY"
Artic1980
Post by Artic1980 »
i have this problem
sudo systemctl status homebridge.service -l
● homebridge.service - HomeBridge Service
Active: failed (Result: exit-code) since gio 2016-10-13 20:00:50 CEST; 21s ag o
Process: 610 ExecStart=/usr/bin/homebridge (code=exited, status=203/EXEC)
Main PID: 610 (code=exited, status=203/EXEC)
ott 13 20:00:50 octopi systemd[1]: Starting HomeBridge Service...
ott 13 20:00:50 octopi systemd[1]: Started HomeBridge Service.
ott 13 20:00:50 octopi systemd[1]: homebridge.service: main process exited, code =exited, status=203/EXEC
ott 13 20:00:50 octopi systemd[1]: Unit homebridge.service entered failed state.
whi?
rwijbenga
Post by rwijbenga »
possible wrote:
TheRamon wrote:
 "accessories": [
            "name": "Xbox",
            "liveId": "KEY"
The middle ] needs to go, it should be:
 "accessories": [
            "name": "Xbox",
            "liveId": "KEY"
You can always check your json on this url: http://jsonlint.com/#
possible
Post by possible »
rwijbenga wrote:
possible wrote:
 "accessories": [
            "name": "Xbox",
            "liveId": "KEY"
 "accessories": [
            "name": "Xbox",
            "liveId": "KEY"
yeah i checked the website, but it keeps failing on:
Error: Parse error on line 31:
... }, "accessory": "Xbox", "name":
Expecting 'EOF', '}', ',', ']', got ':'
binbakker
Post by binbakker »
Seems you miss the { at the start of Xbox accessoire:
	"bridge": {
		"port": 51826,
		"pin": "031-45-154"
	"platforms": [{
		"port": "8080",
		"ssl": 0,
		"roomid": 0,
		"mqttenable": 0,
		"mqttserver": "",
		"mqttport": "1883",
		"mqttauth": 0,
		"mqttuser": "",
		"mqttpass": ""
	"accessories": [{
		"name": "Xbox",
		"liveId": "KEY"
TheRamon
Post by TheRamon »
Have just added an experimental feature to the MQTT branch, namely changing colours through RGB instead of Hue & Saturation. Hue and Saturation never worked the way it should, so I'm hoping RGB will.
Will try this out tonight.
For reference: https://github.com/domoticz/domoticz/issues/909
simon_rb
Post by simon_rb »
TheRamon wrote:Have just added an experimental feature to the MQTT branch, namely changing colours through RGB instead of Hue & Saturation. Hue and Saturation never worked the way it should, so I'm hoping RGB will.
Top man, any further ideas/development on the 'cache' idea. Or are you waiting for MQTT to be completely finished?
Marci
Post by Marci »
Been reading thru the source of hap-nodejs - there doesn't seem to be a cache that's usable in this way... unless I've missed something??
Marci
Post by Marci »
Artic1980 wrote:i have this problem
whi?
Run...
...to get more useful info.
Marci
Post by Marci »
*ignore*
simon_rb
Post by simon_rb »
TheRamon wrote: @marci, sometime later we should probably cache the on/off state (and other variables) of the devices in the eDomoticzAccessory. Then, update the state with the status JSON (ideally later on in the process through tapping MQTT messages). Then, whenever Siri or HomeKit asks the status of the device we IMMEDIATELY return the cached value without asking Domoticz first. :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Something TheRamon mentioned last week.
Marci
Post by Marci »
Yep, I saw... what I was getting at is that there doesn't appear to be an existing method already in homebridge / hap-nodejs that we can use for this, so would need our own mechanism.
