Dashticz - Module - Garbage collector Topic is solved
JuanUil
Domoticz version: 4.11083
Re: Dashticz - Module - Garbage collector
Post by JuanUil »
Getting further and further with this wonderful dashboard.
today tried to implement trash.
When implemented this in config.js
//Blocks
var blocks = {} //only once
// Garbage Collector
config['garbage_company'] = 'blink';
config['garbage_zipcode'] = '5721GW';
config['garbage_street'] = 'Kerkstraat';
config['garbage_housenumber'] = '74';
config['garbage_maxitems'] = '4';
config['garbage_width'] = '5';
config['garbage_use_names'] = true;
config['garbage_use_colors'] = true;
config['garbage'] = {
gft: {kliko: 'green', code: '#375b23', name: 'GFT'},
pmd: {kliko: 'orange', code: '#db5518', name: 'PMD'},
rest: {kliko: 'brown', code: '#7c3607', name: 'Restafval'},
papier: {kliko: 'blue', code: '#153477', name: 'Papier'},
I get an error "error getting garbagedata undefined"
Looking in the console I see that there is a 0 before the HTTPS://
How can I change this or remove this 0?
Lokonli
Post by Lokonli »
I guess you redefined the CORS proxy in CONFIG.js.
You can remove that setting from CONFIG.js: just use default.
If your PHP setup is working it will use the internal CORS proxy. It not, a public CORS proxy will be used.
JuanUil
Post by JuanUil »
Thnx again for the help!!
Working now!!
wbouwens
Post by wbouwens »
I have also the garbage collector. since one week the collector show no data found. i have an ical agenda with my trash data.
Lokonli
Post by Lokonli »
If you share the link to the ical agenda I'll check.
In the mean time, can you post the following info:
* Dashticz version
* master or beta branch?
* PHP version
* OS and hardware of the system you run the Dashticz browser.
In Chrome, open DevTools (F12), refresh Dashticz:
* What are the user message on the console tab?
* Which errors are reported on the error tab?
* On the network tab search for the network request to your calendar. You can do this by filtering on garbage or ical in the network tab.
* What is the request response?
Rtificial
Post by Rtificial »
Just checking, my garbage block was working fine, I am using the Belgia recycleapp provider, and since some time today, I get no more data (the block say 'Laden...').
When checking the console, this is the output I get:
<br />
<b>Warning</b>:  Undefined property: stdClass::$accessToken in <b>C:\xampp2\htdocs\vendor\dashticz\garbage\index.php</b> on line <b>303</b><br />
<br />
<b>Warning</b>:  Undefined property: stdClass::$items in <b>C:\xampp2\htdocs\vendor\dashticz\garbage\index.php</b> on line <b>321</b><br />
<br />
<b>Warning</b>:  Trying to access array offset on value of type null in <b>C:\xampp2\htdocs\vendor\dashticz\garbage\index.php</b> on line <b>321</b><br />
<br />
<b>Warning</b>:  Attempt to read property "id" on null in <b>C:\xampp2\htdocs\vendor\dashticz\garbage\index.php</b> on line <b>321</b><br />
<br />
<b>Warning</b>:  Undefined property: stdClass::$items in <b>C:\xampp2\htdocs\vendor\dashticz\garbage\index.php</b> on line <b>343</b><br />
<br />
<b>Warning</b>:  Trying to access array offset on value of type null in <b>C:\xampp2\htdocs\vendor\dashticz\garbage\index.php</b> on line <b>343</b><br />
<br />
<b>Warning</b>:  Attempt to read property "id" on null in <b>C:\xampp2\htdocs\vendor\dashticz\garbage\index.php</b> on line <b>343</b><br />
<br />
<b>Warning</b>:  Undefined property: stdClass::$items in <b>C:\xampp2\htdocs\vendor\dashticz\garbage\index.php</b> on line <b>369</b><br />
<br />
<b>Warning</b>:  foreach() argument must be of type array|object, null given in <b>C:\xampp2\htdocs\vendor\dashticz\garbage\index.php</b> on line <b>369</b><br />
Anyone else experiencing the same?
When I try to debug manually, using:
 curl -H "x-consumer: recycleapp.be" -H "x-secret: Qp4KmgmK2We1ydc9Hxso5D6K0frz3a9raj2tqLjWN5n53TnEijmmYz78pKlcma54sjKLKogt6f9WdnNUci6Gbujnz6b34hNbYo4DzyYRZL5yzdJyagFHS15PSi2kPUc4v2yMck81yFKhlk2aWCTe93" "https://recycleapp.be/api/app/v1/access-token" > accesstoken.json
it seems I am not getting a key:
{"host":"http://api-http:8080","identifier":"25d0abc2-4dd7-40c2-ab27-8be5b515fd71","timestamp":"2021-01-28T15:42:14.945Z","status":401,"name":"Unauthorized","message":"Missing authorization"}
geertvercamer
Post by geertvercamer »
yes, I just noticed something similar. I get 'Geen gegevens gevonden'
Gianni
Post by Gianni »
recycleapp has changed the street names
Now it's get the name fron the id of https://data.vlaanderen.be/
https://data.vlaanderen.be/doc/straatnaam/xxxxxx in my case
https://recycleapp.be/api/app/v1/collec ... 3&size=100
jvdz
Domoticz version: 4.107
Post by jvdz »
They have moved away from a fixed secret, which is now defined inside /static/js/main.0b66adb4.chunk.js.
I assume the name of that file can also change so retrieve that from the home page in my implementation.
Hope that helps.
Jos
Lokonli
Post by Lokonli »
jvdz wrote: Monday 01 February 2021 12:06 They have moved away from a fixed secret, which is now defined inside /static/js/main.0b66adb4.chunk.js.
Hope that helps.
Jos
Thanks, Jos. I'll try to implement the same.
Renber
Post by Renber »
hello, to date I see that recyleapp is not yet repaired. For information, there is a change of key as said above. The new key x-secret is: 8a9pIQlfYpgmJZD15KdK70MCTR2xyD0EAvOmi9HCBfiBUY4n34ytxQmqo3AP2OET6tssYy6R4Be6N2M2GtiX3AcbiNxR8G7pOalN45dXPZ4emKE2c1nimx9B1YFciutJwFZHYHI2Qpzo0E0GCDHkg5
vendor/dashticz/garbage/index.php
Linux Debian 12 Server: Domoticz beta + Dashticz beta + Node-Red + Homebridge
Lokonli
Post by Lokonli »
recycleapp has been fixed in latest beta.
Rtificial
Post by Rtificial »
So I did a quick test, just replaced the garbage index.php, and reconfigured again for recycleapp, though this still has the same problem for me.
As for iCal in the garbage collector, this doesn't seem to work with recurring events in the calendar, is that a known issue?
I had all my garbage collections as recurrings, and those worked only the first time. For tomorrow, I did not see any. Now I created a single even for tomorrow, and it shows up in the block.
Lokonli
Post by Lokonli »
Rtificial wrote: Monday 08 February 2021 9:50 So I did a quick test, just replaced the garbage index.php, and reconfigured again for recycleapp, though this still has the same problem for me.
Did you download the beta version of index.php?
What is the PHP version as reported by Dashticz? (upper right settings icon, then Info tab)
What is the result of the recycleapp network request? You can find it in the network tab of DevTools (after pressing F12, and refresh Dashticz).
The network request should look like: (you can filter on recycleapp)
http://dashticz-ip:port/vendor/dashticz/garbage/index.php?service=recycleapp&street=...&sub=...&zipcode=...&nr=..&t=
Can you post the output of that request? (you can open it in a browser)
Rtificial
Post by Rtificial »
I indeed downloaded the beta version.
PHP is reported as 8.0.1
http://192.168.178.65:888/vendor/dashti ... &nr=190&t=
The response is :
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Lokonli
Post by Lokonli »
Rtificial wrote: Monday 08 February 2021 11:25 I indeed downloaded the beta version.
The response is :
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
An error on line 303 on $accessToken means you are using the master version ...
Please fix this first.
After that I've to check compatibility with PHP8.
Rtificial
Post by Rtificial »
My bad :-( It's working fine now, just a bit slow in loading :-)
Renber
Post by Renber »
Works perfectly thanks for the update :)
RuudP1987
Post by RuudP1987 »
I added the calendar for Avalex, but it keeps saying loading.. Did I miss something?
//afvalophaalkalender
blocks['mygarbage'] = {
    company: 'avalex',
    zipcode: '2622 km',
    street: 'straat van malakka',
    housenumber: xx,
    maxitems: 6,
    width: 12
HansieNL
Post by HansieNL »
Did you try the zipcode without a space?
Blah blah blah
