Page 41 of 51
Posted: Saturday 29 August 2020 16:21
by Chris12
@HansieNL: So did strugle arround some more.
I added the Dummy devices as stated in the script file, and added the lua script to my domoticz (found some info that it should be place here: /volume1/@appstore/domoticz/var/scripts/lua), named the script buienradar.lua and set owner to 'domoticz'.
In the logging of domoticz I cannot see any activity of this script.
In dashticz the block is created, added, and shows the umbrella icon with the text Buienradar 'Hello World' on the dashboard.
Posted: Saturday 29 August 2020 16:29
by madpatrick
You can add the script in the Domoticz dashboard
Go to Setting/Events
add a LUA script and paste the script into the dashboard
Posted: Saturday 29 August 2020 16:38
by Chris12
madpatrick wrote: Saturday 29 August 2020 16:29 You can add the script in the Domoticz dashboard
Ok, I added the script via Setup -> More Options -> Events. Added and saved there as buienradar.lua script (time-based LUA script).
But still nothing visable in the log, and dashticz shows the same 'Hello World' message.
edit: in de logfile staat nu wel
2020-08-29 16:40:00.166 Status: LUA: (Buienradar) Get data from Buienradar
2020-08-29 16:40:03.579 Status: LUA: (Buienradar) os.capture needed more than 1 call: 2
2020-08-29 16:40:03.579 Error: EventSystem: in buienradar.lua: [string "-- script_time_buienradar.lua ..."]:125: attempt to index a nil value (field '?')
Posted: Saturday 29 August 2020 16:47
by madpatrick
Did you made the dummy switched and used the correct names (check for typo's) ?
-- create dummy text device from dummy hardware 'Buien Radar'
-- create dummy rain sensor from dummy hardware 'BuienRadarMeter'
Posted: Saturday 29 August 2020 19:05
by Chris12
I checked the names they're all OK. I even deleted and re-create the Dummy Devices and Virtual sensors.
but still this output in the domoticz logfile:
2020-08-29 18:55:00.148 Status: LUA: (Buienradar) Get data from Buienradar
2020-08-29 18:55:00.303 Error: EventSystem: in buienradar.lua: [string "-- script_time_buienradar.lua ..."]:125: attempt to index a nil value (field '?')
Posted: Saturday 29 August 2020 19:20
by Chris12
Good news, it works!
I took the script out of this post: https://www.domoticz.com/forum/viewtopi ... 25#p176925 ( I first used the one of HansieNL, some post above here), change the lon/lat values to match my location.
Now I can see in the logfile no error anymore, and the 'Hello World' is now replaced with 'No Rain'
2020-08-29 19:15:00.364 Status: LUA: BuienRadar module
2020-08-29 19:15:00.517 Status: EventSystem: Script event triggered: buienradar.lua
No idea whats the difference between the scripts, I can see that the number of lines are different.
Posted: Saturday 29 August 2020 19:37
by Chris12
Now the 'buienradar' part is working fine, I've got one other thing I would like to change for my dashboard.
How can I make the font smaller of the 'currentweather_big_owm' which shows the actual Temperature + City.
I tried to figure it out myself by using the developers tools in Chrome and came up with this css config part, but that does not work.
.dt_block[data-id='currentweather_big'] .dt_title {
  font-size: 15px;
  color: yellow;
Is there a how-to for searching the correct ellements for within the css ?
Posted: Saturday 29 August 2020 20:50
by HansieNL
Chris12 wrote: Saturday 29 August 2020 19:20 Good news, it works!
Did you create the dummy devices like in the script?:
local myBuienRadarDevice = 'Buienradar'
local myBuienRadarMeter = 'RegenData'
local myBuienRadarFlg = 'Paraplu'
Posted: Saturday 29 August 2020 21:32
by HansieNL
Chris12 wrote: Saturday 29 August 2020 19:37 Now the 'buienradar' part is working fine, I've got one other thing I would like to change for my dashboard.
  font-size: 15px;
  color: yellow;
Can you try with:
.title.weatherdegrees,
.weatherloc {
  font-size: 15px !important;
  color: yellow !important;
Posted: Sunday 30 August 2020 14:45
by madpatrick
I've set an img for the LMS icon, but i like to get it bigger
I've set in custom.css
.block_lms .icon {width: 200% !important; height: 200% !important;}
But still it is not getting bigger if i incerease the width value
How do i get the image bigger ?
Posted: Sunday 30 August 2020 15:08
by HansieNL
I don’t use a Squeezebox, but the icon looks an image to me. Can you try to replace .icon with img (no dot in front).
Posted: Sunday 30 August 2020 15:12
by madpatrick
Correct. I'm using a .png image.
I've tried :
.block_lms img {width: 800% !important; height: 800% !important;}
but does not change the size
------- update --------
i've tried with another block and there i can adjust the size of the image
Looks something in the block is limiting the size of the image
Posted: Monday 31 August 2020 7:40
by Chris12
HansieNL wrote: Saturday 29 August 2020 20:50
No I did create the devices with the names stated in the script file. This is surely the issue it was not working in the first place! Thanks for clarifying this.
Posted: Monday 31 August 2020 7:42
by Chris12
HansieNL wrote: Saturday 29 August 2020 21:32
  font-size: 15px;
  color: yellow;
Can you try with:
.weatherloc {
No this does unfortunatelly not do a thing/change for the actual weather.
Posted: Tuesday 01 September 2020 8:08
by lzwfkv
Chris12 wrote: Monday 31 August 2020 7:42
  font-size: 15px;
  color: yellow;
Can you try with:
.weatherloc {
Must do with the right block class:
.big .weatherloc,
.big .weatherdegrees {
  font-size: 15px;  /*default font you see is 24px, decrease that number at will if you want a smaller font or increase otherwise*/
to change fonts of every block having class "big"; to change specific OWM big weather block only:
[data-id="currentweather_big"].big .weatherloc,
[data-id="currentweather_big"].big .weatherdegrees {
Alternatively you can use:
".block_currentweather_big_owm" class, or ".containsweather" class instead of ".big".
Posted: Tuesday 01 September 2020 8:29
by Chris12
@lzwfkv: Thanks this works!
How do you determine such CSS config? Is there a step-by-step how to?
Because now the font is smaller, how can I align the font and the weather icon to both center.
Posted: Thursday 03 September 2020 6:15
by lzwfkv
Chris12 wrote: Tuesday 01 September 2020 8:29 @lzwfkv: Thanks this works!
Sorry for answering with some delay, i have been busy.
Well, it is difficult to explain all of that in a step-by step guide here and, by the way, i am not that skilled with it to be able to explain, however i will try below.
You should at leat have some very basics of html/javascript/CSS and you can learn some basic syntax on all of them on a site like https://www.w3schools.com/ or serching with google when needed (e.g. syntax or CSS attributes meaning).
Also read/refer to the Dashticz doc at this sections which will explain how the Dashticz blocks are usually composed graphically: https://dashticz.readthedocs.io/en/beta ... icz-blocks (Domoticz Blocks and Special Blocks sections).
Basically every block in Dashticz is made of hierarchical subblocks/sections where all the various elements (title, value/data, icon/image) are placed:
Domoticz devices blocks typical structure:
block ID
|-> col-icon (holds the icon/image associated to the block)
|-> col-data (holds various data as below)
|-> title
|-> state/value
|-> last update
Special blocks typical structure:
block ID
|-> col-icon
|-> dt_content
|-> dt_title
|-> dt_state
So you have to identify the section of the block that you need to change/manipulate and set your needed values in CSS for those classes. You can do that, by running the browser's developer tools (press F12 key while on the page) which will allow you to analyse various aspects of the web page, debug network calls, etc. as well as to browse through the rendered page layout in the first Tab (page analysis), so you will be able to determine the CSS fields and classes to manipulate which on turn will have to refer to the HTML element mount point that you can find in the developer tool.
As to the icon position, it is not possible by default, as you can see it is placed in the col-icon subsection which is always the leftmost subblock under the block box; if you really want to change it, you should redefine the width of the col-icon and col-data subsections under the block in custom.css and it might be a bit complex.
Posted: Thursday 03 September 2020 15:04
by Chris12
Thansk for explaining, I will have to do some reading/homework! (not my 2 most favorite topics ;-) )
Posted: Friday 25 September 2020 21:25
by Krenstik
Here is my one, still under development :-)
( 24" touch screen )
Posted: Friday 25 September 2020 22:26
by EdwinK
Looks nice :)
