joebar
Post by joebar »
I also prefer lua and especially the dzVents framework in lua. So much more control..
the 'on' part controls at what circumstances the script runs, so in this case you can say it should react on the switch, but you can also say only on the switch between 10 and 15 hour and on mon, tue, fri what ever..
	active = true,
		on = 'Xiaomi Wireless switch'	-- which switch?
	execute = function (domotics,switch)
		local light = 'Xiaomi RGB Gateway'	-- which light?
		if (switch.state == 'Click') then
			light.toggleSwitch()	-- toggle on/off every time
		elseif (switch.state == 'Double Click') then
			-- do something else
		elseif (switch.state == 'Long Click') then
			-- and again someting else
	end -- end execute part
} -- end
levynger
Post by levynger »
Does any one knows how to trigger "alert" and "swing" with the cube?
murtadin
Post by murtadin »
Hi all! I wonder if someone have sources backup v3.6441 or close to this beta? Thank you.
Kwintessens
Post by Kwintessens »
I am still getting these errors after adding the gateway and devices in Domoticz (running beta version: 3.6765 on synology):
XiaomiGateway: SendMessageToGateway failed on first attempt, will try again
2017-02-25 10:01:53.921 Error: XiaomiGateway: unable to write command - Invalid Key
Any help?
jelleeelco
Post by jelleeelco »
pikapt wrote:cool, we're getting somewhere!
2017-01-26 00:42:15.357 {"cmd":"report","model":"gateway","sid":"286c0785ad14","short_id":0,"data":"{\"rgb\":1236926719}"}
2017-01-26 00:42:23.330 {"cmd":"report","model":"gateway","sid":"286c0785ad14","short_id":0,"data":"{\"rgb\":0}"}
just got this from the logfile, sid starts with 286c
Hi Corbin,
Did you fix it by adding 286c it by making the sid variable? In having the same issue and my sid starts with 158d.
Jelle
ibniba
Post by ibniba »
Levynger - Thanks for your input but unfortunately I'm still a bit lost.
I have the Xiaomi Gateway set to port 9898
In Devices this is what I have:
You will see that Xiaomi Gateway, Smart Plug, Sensor, Switch and Cube are all listed as 'off'.
And if I click on the light bulb on the left hand side of the screen for Xiaomi RGB Gateway for example to turn it on I get this:
So I guess I need to get these turned on but I don't know how.
In the Switches tab I have this:
Sorry if I don't explain myself very well but I'm struggling here to set it up right.
corbin
Post by corbin »
@jelleeelco yes the prefix is variable now for the gateway, as I thought they all started with 'f0b4', but not all as discovered pikapt. All sensors/devices start with '158d' like yours - if this changes then I will need to update the code to handle.
corbin
Post by corbin »
@Kwintessens
Can you post the exact key you have entered for the Gateway? (you can change it later if you are worried about security)
Also If you want to troubleshoot, please setup a test vm running Windows or Linux, and compile my github repo at https://github.com/corbinmunce/domoticz
jelleeelco
corbin wrote:@jelleeelco yes the prefix is variable now for the gateway, as I thought they all started with 'f0b4', but not all as discovered pikapt. All sensors/devices start with '158d' like yours - if this changes then I will need to update the code to handle.
Thanks Corbin. Then that cannot be the reason that my Domoticz is unable to send instructions to the xiaomi gateway. All statuses are updated correctly, but initiating the action from domoticz doesn't work. This is for the wired wall switch, but also the small round battery switch and the gateway light: if I press them physically they work and the action is visible in robotics, but when using the virtual switch in domoticz nothing happens.
I'll try to compile your version from Git. Never done that before; can I install it over my current beta? And if there are no differences (which is what I suspect since you mention the at one point all your code was in the normal beta), can I go back easily?
Many thanks for all your hard work!
Jelle
corbin
Post by corbin »
The instructions on the wiki to compile are easy to follow: http://www.domoticz.com/wiki/Linux
when you clone the repo, choose a different directory to install to, ie:
git clone https://github.com/domoticz/domoticz.git domoticz-test
And stop your main domoticz install from running, if you are testing on the same machine.
Kwintessens
corbin wrote:@Kwintessens
I've tried multiple times with the password from the app, as instructed:
Am I missing anything? I find it strange it updates/adds devices initially but stops working thereafter. In the meantime I will run a VM as soon as I have access to my notebook.
Mooseknuckle
Post by Mooseknuckle »
I made icon files for the cube and the round selector switch. Grab them if you like.
xiaomi.zip
(4.63 KiB) Downloaded 123 times
cube.zip
(4.08 KiB) Downloaded 142 times
RPI 3, Philips Hue,Toon Thermostat, Harmony Smart Control, Yeelights
Mysensors wifi gateway + sensors, RFXtrx433E, Kaku stuff, Xiaomi gateway + sensors
Domoticz controlled DIY ambilight, Selectplus chime, Mi-light led controller
jelleeelco
corbin wrote:The instructions on the wiki to compile are easy to follow: http://www.domoticz.com/wiki/Linux
Hi Corbin,
I followed the instructions but get an error. First stopped domoticz. Then I created the directory domoticz-test and grabbed your git version (into the test directory). The first error is when i do the cmake from within the test directory; i get the message that i have to provide the source file. I then go to the home dir and type "cmake domoticz-test". That worked.
Then " make" and at the end i get the following error:
   [ 99%] Building CXX object CMakeFiles/domoticz.dir/tinyxpath/tinyxmlparser.cpp.o
[ 99%] Building CXX object CMakeFiles/domoticz.dir/tinyxpath/xpath_expression.cpp.o
[100%] Building CXX object CMakeFiles/domoticz.dir/tinyxpath/xpath_static.cpp.o
Linking CXX executable domoticz
/usr/bin/ld: cannot open output file domoticz: Is a directory
collect2: error: ld returned 1 exit status
CMakeFiles/domoticz.dir/build.make:4971: recipe for target 'domoticz' failed
make[2]: *** [domoticz] Error 1
CMakeFiles/Makefile2:64: recipe for target 'CMakeFiles/domoticz.dir/all' failed
make[1]: *** [CMakeFiles/domoticz.dir/all] Error 2
Makefile:136: recipe for target 'all' failed
make: *** [all] Error 2
pi@raspberrypi:~ $
Any clue??
corbin
Post by corbin »
@jelleeelco, you didn't specify if you installed the required libraries first, so just want to make sure you ran all these commands:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install build-essential nano cmake git libboost-dev libboost-thread-dev libboost-system-dev
sudo apt-get install libsqlite3-dev curl libcurl4-openssl-dev libssl-dev libusb-dev zlib1g-dev python3-dev
cd ~
cd domoticz
cmake -DCMAKE_BUILD_TYPE=Release .
make
corbin
Post by corbin »
Kwintessens wrote: Am I missing anything? I find it strange it updates/adds devices initially but stops working thereafter. In the meantime I will run a VM as soon as I have access to my notebook.
Sounds like the problem is fixed already in my repo, hope to have it updated in the main beta soon.
jelleeelco
corbin wrote:@jelleeelco, you didn't specify if you installed the required libraries first, so just want to make sure you ran all these commands:
sudo apt-get update
cd ~
cd domoticz
make
Hi Corbin,
No, I did all that but I think it has to do with the boostfiles. Found something on the wiki....
BUT.....
I build a complete new system from scratch. Compiled your version and guess what...didn't work. Then I looked BETTER at the IP address of the Gateway and found that that was WRONG!!
So, if the IP address of the gateway is wrong in the settings, Domoticz will still get all the status updates. But it cannot control the gateway of course. So I put in my production SD card again and changed the IP address to the correct one: EVERYTHING WORKS!!
Many thanks for all your help!!
Rgds
Jelle
levynger
Post by levynger »
woody4165 wrote:
deennoo wrote:Rotation value is a text device who appear once you rotate cube once.
Just wrote a small script, but since I'm not a coder, I'm sure it can be optimized... :roll:
In my case, I want that the dimming works only if the lamp is already On.
-- Run only if the cube has been rotated clockwise or anti-clockwise
if devicechanged['Xiaomi Cube Switch'] == "clock_wise" or devicechanged['Xiaomi Cube Switch'] == "anti_clock_wise" then
   -- Runs only if the light is already On
    if (otherdevices['YeeLight Salone'] == "On" or otherdevices['YeeLight Salone'] == "Set Level") then
	-- grab the actual dimming value
    	actual_dimming = tonumber(otherdevices_svalues['YeeLight Salone'])
        --if the cube has been rotated clockwise and dimming is below 100
        if ((otherdevices['Xiaomi Cube Switch'] == "clock_wise") and actual_dimming < 100) then
            -- need to find only the integer value
            actual_rotation = otherdevices_svalues['Xiaomi Cube Text']
            virgola = string.find(actual_rotation, ",")
            numero = string.sub(actual_rotation, 1, virgola-1)
            -- Add the rotation value to the actual dimming, and if is greater than 100, set it to 100
            new_dim_value = actual_dimming + tonumber(numero)
            if new_dim_value > 100 then
                new_dim_value = 100
            comando = "Set Level "..new_dim_value
            commandArray['YeeLight Salone']=comando
        --if the cube has been rotated anti-clockwise and dimming is above 1
        if (otherdevices['Xiaomi Cube Switch'] == "anti_clock_wise" and actual_dimming > 1) then
            -- Add the rotation value (in this case is a negative value), to the actual dimming, and if is smaller than 1, set it to 1
            if new_dim_value < 1 then
                new_dim_value = 1
It seems to work, if you have any suggestion, please share it!
thanks, recieved my cube, and used your script, modified it abit to allow turning on/off as well based on rotation is someone interfested in:
if devicechanged['Xiaomi Cube'] == "clock_wise" or devicechanged['Xiaomi Cube'] == "anti_clock_wise" then
    --if (otherdevices['CorridorLight'] == "On" or otherdevices['CorridorLight'] == "Set Level") then
       actual_dimming = tonumber(otherdevices_svalues['CorridorLight'])
       print("the Current YeeeLightSvalue: " .. actual_dimming)
        if ((otherdevices['Xiaomi Cube'] == "clock_wise") and actual_dimming < 100) then
                new_dim_value = 100
            commandArray['CorridorLight']=comando
        if (otherdevices['Xiaomi Cube'] == "anti_clock_wise" and actual_dimming > 1) then
            print("a test print")
            print("the new value to reduce to: " .. new_dim_value)
            if new_dim_value <= 1 then
                new_dim_value = 0
    --end
deennoo
Post by deennoo »
Using 3.6807, i'm facing a issue :
Heartbeat doesn't only update status, it change statut device too :
Using a 230v double switch, one button is connected to a real bulb, no probleme with this, the second oneis use to drive a yeelight bt bedside lamp (will provid an how to to drive it later) via a script
if 230 switch statut change (no matter on or off) and bed side lamp is off then turn on bed side lampe
elseif  230 switch statut change (no matter on or off) and bed side lamp is on then turn offbed side lampe
advantage to don't care about on or off switch state is that action act as a simple push on button
but heartbeat trigger script each time he "update" or check the device :
2017-03-01 09:22:10.053 User: Admin initiated a switch command (2704/Chevet Nico/Off)
2017-03-01 09:22:10.053 {"cmd":"heartbeat","model":"ctrl_neutral2","sid":"158d000153b50f","short_id":18029,"data":"{\"channel_0\":\"off\",\"channel_1\":\"off\"}"}
2017-03-01 09:22:10.233 Executing script: /home/nico/domoticz/scripts/shell/yeelightbt/off.sh
it confirm by the log
No way to just update device if heartbeat provid a different status from the last one ?
exemple : if heartbeat for ctrl_neutral2 channel_0 = Off and Channel 0 is already Off then do nothing, else if Channel 0 is On then update
http://domo-attitude.fr
corbin
Post by corbin »
Is anyone using the "no_motion" updates? I could just ignore any messages that are not the 2 minute of no motion update:
"data":"{\"no_motion\":\"120\"}"}
only other way I can think of to ensure "off" for the PIR is only sent once is to query the database for the current state each time a "no_motion" message is received.
corbin
Post by corbin »
jelleeelco wrote: Many thanks for all your help!!
Rgds
Jelle
Glad you got it going! And good of you to admit your mistake :)
