Re: ATAG ONE thermostaat
Posted: Friday 18 November 2016 14:21
modulation isn't available to be read at all.
curl -H "Content-Type: application/json" -X POST -d '{ "retrieve_message": { "seqnr": 0, "account_auth": { "user_account": "", "mac_address": "<MAC>" }, "device_id": "6808-.......", "info": 64 } }' http://10.0.0.XX:10000/retrieveCode: Select all
"info": 64Code: Select all
{ "retrieve_reply":{ "seqnr":0,"status":{"device_id":"6808-.......","device_status":16385,"connection_status":7,"date_time":560373413},"report":{"report_time":560373413,"burning_hours":0.20,"device_errors":"","boiler_errors":"","room_temp":20.6,"outside_temp":14.0,"dbg_outside_temp":22.1,"pcb_temp":25.1,"ch_setpoint":0.0,"dhw_water_temp":28.5,"ch_water_temp":20.6,"dhw_water_pres":0.0,"ch_water_pres":1.6,"ch_return_temp":20.6,"boiler_status":512,"boiler_config":772,"ch_time_to_temp":0,"shown_set_temp":15.0,"power_cons":0,"tout_avg":14.1,"rssi":36,"current":-80,"voltage":3896,"resets":3,"memory_allocation":2800, "details": "boiler_temp":29.7,"boiler_return_temp":29.7,"dhw_flow_rate":0.0,"min_mod_level":21,"rel_mod_level":0,"boiler_capacity":0,"target_temp":15.0,"overshoot":0.000,"max_boiler_temp":85.0,"alpha_used":0.00083,"regulation_state":0,"ch_m_dot_c":0.000,"c_house":0,"r_rad":0.0000,"r_env":0.0000,"alpha":0.00000,"alpha_max":0.00083,"delay":1000,"mu":0.00,"threshold_offs":15.0,"wd_k_factor":1.6,"wd_exponent":1.2,"lmuc_burner_starts":15,"lmuc_burner_hours":0,"lmuc_dhw_hours":0,"KP":36.100,"KI":0.00568}},"acc_status":2} }Code: Select all
"info": 127Code: Select all
2018-04-15 10:52:06.273 Error: AtagOne: Error getting thermostat data!
2018-04-16 11:16:23.830 Error: AtagOne: Error getting target setpoint data!
"seqnr": 0,
"account_auth": {
"user_account": "",
"mac_address": "AA:BB:CC:DD:EE:FF"
"info": 127
"retrieve_reply": {
"seqnr": 0,
"status": {
"device_id": "XXXX-XXXX-XXXX_XX-XX-XXX-XXX",
"device_status": 1,
"connection_status": 7,
"date_time": 595633942
"report": {
"report_time": 595633942,
"burning_hours": 26.10,
"device_errors": "",
"boiler_errors": "",
"room_temp": 21.1,
"outside_temp": 5.6,
"dbg_outside_temp": 24.7,
"pcb_temp": 23.7,
"ch_setpoint": 0.0,
"dhw_water_temp": 30.6,
"ch_water_temp": 21.1,
"dhw_water_pres": 0.0,
"ch_water_pres": 1.8,
"ch_return_temp": 21.1,
"boiler_status": 0,
"boiler_config": 772,
"ch_time_to_temp": 0,
"shown_set_temp": 17.0,
"power_cons": 0,
"tout_avg": 7.2,
"rssi": 24,
"current": 103,
"voltage": 3895,
"charge_status": 1,
"lmuc_burner_starts": 75,
"dhw_flow_rate": 0.0,
"resets": 86,
"memory_allocation": 13776,
"details": {
"boiler_temp": 38.1,
"boiler_return_temp": 35.8,
"min_mod_level": 22,
"rel_mod_level": 0,
"boiler_capacity": 0,
"target_temp": 17.0,
"overshoot": 0.000,
"max_boiler_temp": 85.0,
"alpha_used": 0.00083,
"regulation_state": 1,
"ch_m_dot_c": 1334.722,
"c_house": 0,
"r_rad": 0.0022,
"r_env": 0.0013,
"alpha": 0.00000,
"alpha_max": 0.00083,
"delay": 1000,
"mu": 0.00,
"threshold_offs": 7.0,
"wd_k_factor": 1.5,
"wd_exponent": 1.3,
"lmuc_burner_hours": 26,
"lmuc_dhw_hours": 8,
"KP": 36.100,
"KI": 0.00568
"control": {
"ch_status": 41,
"ch_control_mode": 1,
"ch_mode": 2,
"ch_mode_duration": 0,
"ch_mode_temp": 17.0,
"dhw_temp_setp": 60.0,
"dhw_status": 13,
"dhw_mode": 1,
"dhw_mode_temp": 150.0,
"weather_temp": 5.6,
"weather_status": 1,
"vacation_duration": 0,
"extend_duration": 0,
"fireplace_duration": 10800
"configuration": {
"report_url": "https://reportprd.atag-one.com:443/api/message",
"download_url": "http://firmware.atag-one.com:8080/atag_proto_v1",
"boiler_id": "XXXXXXXXXX",
"boiler_det_type": 2,
"language": 0,
"pressure_unit": 0,
"temp_unit": 0,
"time_format": 1,
"time_zone": 0,
"summer_eco_mode": 1,
"summer_eco_temp": 22.0,
"shower_time_mode": 0,
"comfort_settings": 0,
"room_temp_offs": 0.0,
"outs_temp_offs": 0.0,
"ch_temp_max": 85.0,
"ch_vacation_temp": 16.0,
"start_vacation": 0,
"wd_k_factor": 1.5,
"wd_exponent": 1.3,
"climate_zone": -12.0,
"wd_temp_offs": 0.0,
"dhw_legion_day": 7,
"dhw_legion_time": 195,
"dhw_boiler_cap": 0,
"ch_building_size": 2,
"ch_heating_type": 6,
"ch_isolation": 2,
"installer_id": "",
"disp_brightness": 80,
"ch_mode_vacation": 604800,
"ch_mode_extend": 3600,
"support_contact": "",
"privacy_mode": 0,
"ch_max_set": 85.0,
"ch_min_set": 20.0,
"dhw_max_set": 65.0,
"dhw_min_set": 40.0,
"mu": 0.00,
"dhw_legion_enabled": 1,
"frost_prot_enabled": 3,
"frost_prot_temp_outs": -3.0,
"frost_prot_temp_room": 10.0,
"wdr_temps_influence": 4,
"max_preheat": 1440
"acc_status": 2,
"seqnr": 0,
"account_auth": {
"user_account": "",
"info": 127
