Page 5 of 32
Re: Testers wanted!
Posted: Wednesday 13 January 2016 10:46
by Varazir
ben92 wrote:Nice feature,
Dont know if its a bug or if someone report it..... I cant see blocky ou lua script via mydomoticz.
Its normal ?
If you go to the blocky editor you don't see anything? It works for me using chrome.
Skickat från min Nexus 5 via Tapatalk
Re: Testers wanted!
Posted: Wednesday 13 January 2016 11:37
by ben92
Sorry, tested now and it works !!!!
Re: Testers wanted!
Posted: Thursday 14 January 2016 10:03
by maluko
hi,
any problem with the mydomoticz server? it says always offline :(
i re-configurated again and do the same
thanks
2016-01-14 08:57:40.875 Error: PROXY: Read failed, code = 336130329. Reconnecting: decryption failed or bad record mac
2016-01-14 08:57:50.958 Error: PROXY: Read failed, code = 125. Reconnecting: Operation canceled
2016-01-14 08:57:51.018 Error: PROXY: Connect failed, reconnecting: Operation canceled
Re: Testers wanted!
Posted: Thursday 14 January 2016 10:07
by Varazir
maluko wrote:hi,
thanks
try to disable and enable the service in the settings.
Re: Testers wanted!
Posted: Thursday 14 January 2016 20:40
by JC38
When connected through the proxy to a Rpi version and trying to update to a newly DZ version, screen switches back to the main proxy window.
Re: Testers wanted!
Posted: Saturday 16 January 2016 9:19
by Varazir
JC38 wrote:When connected through the proxy to a Rpi version and trying to update to a newly DZ version, screen switches back to the main proxy window.
If you check few minutes later it hasn't been updated?
Re: Testers wanted!
Posted: Saturday 16 January 2016 10:59
by Mediacj
deejc wrote:2FA error :
I am using this service fora while now and i find its very good with the off glitch but i would like to use 2FA, if i scan the bar code with google authenticator i get an error .:
Invalid Barcode
the barcode 'optauth://totp/
Domoproxy:<MYUSERID>@my.
domoticz.com?
secret=<SECRETKEY SHOWN>&issuer=Domo
Proxy' is not a valid authentication token barcode
any ideas why ?
I have the same error when I scan the qr code within Google authenticator.
Re: Testers wanted!
Posted: Saturday 16 January 2016 12:21
by JC38
Varazir wrote:If you check few minutes later it hasn't been updated?
No :(
Re: Testers wanted!
Posted: Saturday 16 January 2016 19:33
by Varazir
No :(
I just tested and I get the same. Nothing seen in the log ( locally )
Re: Testers wanted!
Posted: Sunday 17 January 2016 9:57
by erik4281
The service seems to be offline at the moment. When going to http://my.domoticz.com, I get the message that Domoticz is offline. I can't even login yet.
Re: Testers wanted!
Posted: Monday 18 January 2016 11:40
by mrjem
Remoticz ?
Re: Testers wanted!
Posted: Tuesday 19 January 2016 23:19
by JC38
Today, with the latest avalaible beta for Rpi, I've made a test to enable again remote Domoticz sharing using the ID.
Things are a little bit better (or the log is more verbose) but still don't work.
On the remote Rpi (the slave) :
2016-01-19 23:01:47.416 PROXY: Master disconnected
2016-01-19 23:02:07.200 PROXY: Authenticate result: success.
2016-01-19 23:02:07.262 Incoming Domoticz connection via Proxy accepted for user Myusername.
2016-01-19 23:02:47.599 PROXY: Master disconnected
On the master Rpi
2016-01-19 22:58:43.294 PROXY: Notification received: slave instanceID online now.
2016-01-19 22:59:03.336 PROXY: Authenticate result: success.
2016-01-19 23:01:04.701 Domoticz TCP connected via Proxy.
2016-01-19 23:02:02.505 PROXY: Authenticate result: success.
2016-01-19 23:02:07.203 PROXY: Notification received: slave instanceID online now.
2016-01-19 23:02:07.297 Domoticz TCP connected via Proxy.
2016-01-19 23:03:02.738 PROXY: Authenticate result: success.
But with these errors :
2016-01-19 23:01:32.396 Error: PROXY: Shared Server access disallowed, denying receive data request.
2016-01-19 23:01:32.397 Error: PROXY: Shared Server access disallowed, denying receive data request.
2016-01-19 23:01:32.431 Error: PROXY: Shared Server access disallowed, denying receive data request.
2016-01-19 23:01:39.739 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-01-19 23:02:32.510 Error: PROXY: Shared Server access disallowed, denying receive data request.
2016-01-19 23:02:32.578 Error: PROXY: Shared Server access disallowed, denying receive data request.
2016-01-19 23:02:32.615 Error: PROXY: Shared Server access disallowed, denying receive data request.
2016-01-19 23:02:43.929 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
So, no remote devices appears on the master.
Re: Testers wanted!
Posted: Tuesday 19 January 2016 23:36
by pepijn
Invalid Barcode
domoticz.com?
any ideas why ?
I experienced the same problem today on my iPhone.
When using Matt Rubin's Authenticator it works fine
https://itunes.apple.com/app/authenticator/id766157276
Re: Testers wanted!
Posted: Friday 22 January 2016 19:40
by JC38
Hello René,
Is-it possible to have a cookie to keep the language information. Or into the user settings ?
Is-it also possible that you update this topic when something is changed regarding the portion of code you are developping ?
Re: Testers wanted!
Posted: Saturday 23 January 2016 20:05
by sclk34
Hello!
I'm a novice. And I did not understand the information from Wikipedia about my.domoticz.com.
I share the instance, but how to use it ? How to see the Web Interface of domoticz server?
Re: Testers wanted!
Posted: Saturday 23 January 2016 21:31
by chimit
mrjem wrote:Remoticz ?
I like that.
Re: Testers wanted!
Posted: Saturday 23 January 2016 21:32
by chimit
JC38 wrote:Today, with the latest avalaible beta for Rpi, I've made a test to enable again remote Domoticz sharing using the ID.
On the master Rpi
To solve this: Check the "Shared Domoticz Allowed" checkbox on the slave instance.
Re: Testers wanted!
Posted: Saturday 23 January 2016 21:34
by chimit
JC38 wrote:Hello René,
Good idea. I will put it on the list. And in case the cookie doesn't exist (yet), I will detect the browser language and display the page accordingly.
Re: Testers wanted!
Posted: Saturday 23 January 2016 21:36
by chimit
Invalid Barcode
domoticz.com?
any ideas why ?
This kind of depends on what 2FA app you are using. Some people report that not all authenticators work whilst others do.
In this case, you can always try to enter the secret code manually. Or download a different authenticator.
As far as I can see, the shown barcode uri is according to the official specification. But if somebody sees a mistake, please do tell me about it.
Re: Testers wanted!
Posted: Saturday 23 January 2016 21:39
by chimit
Does this occur when you have two Domoticz's in your roster (dashboard)? I've seen this before, when one (or both) use the login page.
The cookie path is set wrong in Domoticz for use with MyDomoticz. I will try to submit a patch soon. Meanwhile, trying one or two times more helps for me in such a case.
