PiFace support added
Moderators: fantom, leecollings
Keptenkurk
Re: PiFace support added
Post by Keptenkurk »
Will +12V/50mA suit it?
According to Ohm's law the current will never exceed 12V divided by 2000 ohm equals 6 mA. So your 50mA supply will do easily.
/paul
NickHead
Post by NickHead »
Just tried the beta and the piface/domoticz interface does not recognize any rfx meters.
i am going round in circles again
A lot of stuff that is doing my head in.
Dlanor
Post by Dlanor »
NickHead wrote:i am going round in circles again
Just try this:
BigDog wrote:I have reinstall domoticz with the image and did a full update upgrade and downgrade to the kernel 3.10.25+ with the code:
 sudo rpi-update 2ef601a50b68eebeeb4dc3c6c525855961891be6
and all is working now :)
Domoticz| Zigbee | SONOFF
NickHead
Post by NickHead »
I would ask the question of compatibility. Mine is a Pi 2 B+ and I have seen that it could corrupt the installation.
The PiFace is a Digital 2, and therefore it may not have the drivers written.
Anyways, I am talking myself into doing this, it doesn't work at the moment therefore what can happen - not work even more at the moment - I may do it later.
Cheers for the reply.
Nick
NickHead
Post by NickHead »
I think I fixed mine :)
I went here and did some of the examples.
Mine wouldn't count, now it does, not sure if correct yet.
I was fed up of hearing other had the same problem as me and I searched for ages and came up with this,
http://www.element14.com/community/mess ... face#93804
also put this in my PI2, something to do with RPI Update.
sudo apt-get --reinstall install libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 raspberrypi-bootloader
sudo reboot
Make sure you backup/be safe before any modifications.
I take no responsibility for doing this, however, I did do it and restored faith in my PiFace Digital 2.
Hope it helps.
jadijkstra2000
Post by jadijkstra2000 »
mmm does not work in my config :(
r2 + piface2
NickHead
Post by NickHead »
Sorry to hear that Jadi,
I have tried many examples on counting with piface d2 and they never worked, this IS the only one I got to work.
I got myself believing that people say they work, when they don't, because nobody gave an explanation, they just clamped up when examples were requested.
Hence why I put my findings up and I believe it mad a difference
Maybe a bit more digging about may solve things
NickHead
Post by NickHead »
PI D2 and added light sensor
Last one was too big
Last edited by NickHead on Wednesday 05 August 2015 22:38, edited 1 time in total.
NickHead
Post by NickHead »
Also the proof that it is counting
jadijkstra2000
My problem however is a little different :) When I reboot the pi, the inputs are available (again) as switches, not as counters... (when I have enabled the inputs). After trying the 'blink' example, it works again...until I do a reboot
NickHead
Post by NickHead »
Hi Jadi,
just tested mine and it has also stopped. Just trying to find a way to kickstart it again.
NickHead
Post by NickHead »
rebooted a few times, now it's working again. Really random.
NickHead
Post by NickHead »
Back running - here's a 2kW input, don't know if it is synchronised with the readings but it works for now.
Getting there slowly.
Looks about 1750 Watts, a bit out but my generator timing maybe out as well, near though.
Just looked at it over 20 minute cycle and it's 1.98 kWh pulse, so maybe more accurate than I thought.
Even nearer, yay
NickHead
Post by NickHead »
Sorry Maciek,
I have just noticed that I was answering someone else's question and totally hi-jacked you thread.
My sincere apologies bud.
Nick
NickHead
Post by NickHead »
I didn't re-install Domoticz, I have 3 Pi's, the counter is on V 2.2657, never had to downgrade so not sure and I don't want to corrupt your system totally.
If not, we'll have another look at what's wrong. I am no god on this, still learning.
Cheers
Nick, UK
NickHead
Post by NickHead »
This is with my 1kW Arduino LED Pulse Simulator, being sampled by the Pi 2.
Reads as 998 Watts over the 1 hour duration, the 2 Watts probably being the
actual LED "ON" state that was not accounted for in the program.
macieiks
Post by macieiks »
So I am after tests. I did test 2 times: one time on stable 2.563 and second on latest beta 2.2703. Both failed but here are the results :D :
I connected my S0 meter to PiFace Digital2 input 0 (schematic from domoticz wiki, source +12V) and Photo Sensor is connected to input 2 (source 3.3V).
Stable 2.563:
I can see RFXMeter icons in Device window and after enabling them they report each 10 seconds but they does not increment / count.
If I add S0 meter input into Domoticz (called: 0_test_S0) there are not any rising/falling edges.
Photo:
However on my multimeter I can see drops from 0.5V to ~0. And there is a beep sound :) I am curious if this voltage - in period when there is no impulse - is not too low? I used this schematic http://www.domoticz.com/forum/download/file.php?id=188 and of course 2N7000 is onboard.
I also tried to run your pfinit.py and I had seen blinking leds,then restarded domoticz with no success.
My last observation, If I click on Photo Sensor input icon (2_test_photo_sensor) I can see rising/falling edges so Domoticz see impulses, photo:
but RFXMeter still does not incerase.
Beta: 2.2703:
I can not see RFXMeter icons, only "Lighting 1" icons. The RFX are just simply not present in Device window. Initializing PiFace from python script does not improve situation :D .
I would like to try your exact beta version, could you please give me a link to download it? Because I just only see v2.2703.
Maciek
RPI2 + RFLink + PiFace D2 + Aeon Z-Wave Gen5 + Foscams FI9821P&R2 + MySensors + UPS APC Back-UPS 950VA
RPI2 + RFXtrx433e + Foscams FI9821P + MySensors + UPS APC Back-UPS 950VA
RPIB+ + TP-Link MR3420 + Huawei E173 GarageDomoticz :)
Dlanor
Post by Dlanor »
I have tried to install a new piface 1 on RPI B+. I was told this should work fine. It boots fine but cannot add the piface. SPI is activated. Can anyone tell if the B+ can handle the Piface 1?
NickHead
Post by NickHead »
My beta version was an update from the Domoticz system itself,
I did not download it as a file, it came down as a beta update.
However, saying that, the bugs are usually ironed out as the updates progress, by the look of it
you are on a version well past mine so it should be even better, if not still work/not work as it does not.
So, not sure on what I can do from here.
Older versions can be found here http://sourceforge.net/projects/domoticz/files/
but not on there for long.
NickHead
Post by NickHead »
The pin-outs on the PI B+ are exactly the same as the PI 2, so I would reckon
that it should be the same, and work OK.
I maybe wrong, and I can't take my B+ offline to check, so not sure, but would err on the yes.
