Easy Sonos
thorbj
Re: Easy Sonos
Post by thorbj »
HansLe wrote:YEEEEEEESSSSS! I'm able to use TTS on a RPI. As you can read Thorjb had some problems. I had the same. This problem exist when you don't use a file share but you use your RPI as place to read and find the MP3 files. I hope G3rard will change the following recommendations in the source files. If not you can do it by yourself after downloading these file ;)
Now is EasySonos Easy :D
Great, HansLe!
I gave up on this project, but no I'll give it a try again :)
2xRaspberry Pi Model 2 w/RaZberry z-wave chip (master/slave)|Fibaro Wall Plug|Fibaro Universal Dimmer 500W|Aeon Labs Multisensor|RFXtrx433E|Nexa WMR-1000|Nexa Pe-3|Nexa Remote|Nexa LGDR3500|Lightify Gateway|Lightify RGBW bulb
