Page 5 of 5
Re: Toon Energy Readings on Domoticz
Posted: Saturday 30 July 2016 9:10
by anandus
I have Zon op Toon, but I can't see it under Toon in devices.
I do see the P1-meter (usage and return), but not the Zon op Toon-Kwh meter.
What do I need to do to see the generated power in Domoticz?
Posted: Monday 02 January 2017 20:12
by Martijn85
My Toon device has arrived today. I have added the hardware in Domoticz, all seems to work very well.
I don`t see any KWh meter, i only have the gas meter. Is this option not available anymore?
2017-01-02 19:44:31.423 ToonThermostat: Worker started...
2017-01-02 19:45:08.473 (Toon) Thermostat (Room Setpoint)
2017-01-02 19:45:08.476 (Toon) Temp (Room Temperature)
2017-01-02 19:45:08.478 (Toon) Lighting 2 (HeatingOn)
2017-01-02 19:45:08.482 (Toon) Lighting 2 (TapwaterOn)
2017-01-02 19:45:08.485 (Toon) Lighting 2 (PreheatOn)
2017-01-02 19:45:08.489 (Toon) P1 Smart Meter (Unknown
Posted: Tuesday 03 January 2017 2:22
by HansieNL
2017-01-03 02:15:14.539 (Toon Thermostaat) P1 Smart Meter (Elektra)
2017-01-03 02:15:14.552 (Toon Thermostaat) P1 Smart Meter (Gas)
Does it already show the right values on the thermostat?
Posted: Tuesday 03 January 2017 8:20
by Martijn85
Never mind, I'm not patient enough. Today the values are filled and the meter has arrived in Domoticz.
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: Toon Energy Readings on Domoticz
Posted: Tuesday 27 February 2018 17:48
by michaelm86
kurniawan77 wrote: Wednesday 02 March 2016 9:38
marktn wrote:kurniawan77 wrote:
I could give it a try... Beloof niks
See PM
Nailed it!!! Issue solved by configuring your local IP addresses in settings (no username and password)
hi guys, i hav ethe same issues but i cannot find what it is.. can you guys give any advise?
what do you mean by "Issue solved by configuring your local IP addresses in settings (no username and password)"?
here are my settings.
- toon4.jpg (131.37 KiB) Viewed 2040 times
Posted: Wednesday 05 June 2019 21:06
by PeJeWe
Is it possible to read the (slimmeMeter P1) data from the toon?
