Control Thermosmart thermostat
rednas
Re: Control Thermosmart thermostat
Post by rednas »
So, let's go on here since gizmocuz thinks i am not a developer: http://www.domoticz.com/forum/viewtopic.php?f=6&t=9140
But, I know how to code but just need some help to find the scripts in my installation.
However, why is paultie able to pause and unpause the Thermosmart and why the code embedded in Domoticz not?
paultie wrote:This last step (action 5) does the actual pausing. The pause:true pauses it. if you change that to pause:false it unpauses.
gizmocuz
Post by gizmocuz »
Made a new beta, changed the way the pause is set.
From the previous script post (thanks!) i see that it is set via json, hope it works now
changes are in Beta #3769
the code that sets the pause state is in
void CThermosmart::SetPauseStatus(const bool bIsPause)
paultie
Domoticz version: V2.3272
Post by paultie »
I'll Try to do some tests later this week and I will let you know.
Thanks.
Raspberry Pi B+ with Zwave GPIO board, P1 interface and RFXCOM receiver.
gizmocuz
Post by gizmocuz »
pauze and unpauze is now working in the latest beta, and you can also specify your own outdoor temperature sensor from the hardware settings page
rednas
Post by rednas »
I am not able to select an outdoor sensor at the hardware page. The settings are the same as before.
Is this right?
wboerhoop
Post by wboerhoop »
did you update to V2.3771, i can use the outside temp. ;)
RFXcom-433E last FW
Aeon Z-stick Gen5
Zigbee
Synology and Raspberry Pi4 last Beta
gizmocuz
Post by gizmocuz »
maybe clear your browser cache
rednas
Post by rednas »
Alright, now it's working!
paultie
Post by paultie »
paultie wrote:I'll Try to do some tests later this week and I will let you know.
Thanks.
Indeed it works now, thanks for fixing this.
gizmocuz
Post by gizmocuz »
thanks for all feedback
patrickb
Domoticz version: v2.3867
Post by patrickb »
wboerhoop wrote:did you update to V2.3771, i can use the outside temp. ;)
Took me some time to find if and how to use this excellent feature :) Only thing I had to do was to switch to the beta channel and updated to v2.3867. Than it took less than 1 minute to configure things (already setup Weather Underground to get a good temp reading of a very nearby PWS).
markvdb
Domoticz version: 2.4088
Post by markvdb »
Integrated my Thermosmart succesfully into Domoticz! Very nice feature, now I can also see and adjust the room temperature directly with Domoticz and (un)pause my Thermosmart. Next step will be to add another KAKU switch to be able to pause the Thermosmart automatically when the door to the garden is opened for longer than a minute or so...
Bikey
Domoticz version: 2020.x
Post by Bikey »
Hi, great integration work with ThermoSmart!
I'm now using this for a couple of weeks, and now would like to log some additional information from the API. Specifically I would like to log when and how much the burner of my heating system was working.
This is available as OpenTherm-data and can be requested by the ThermoSmart API and is probably already received by Domoticz when polling for the actual setpoint and room temperature.
So question is: could this data be made available in an additional device, or as additional s_value data?
mrefex
Domoticz version: 3.7041
Post by mrefex »
I also use this device and like it very much.
But i cannot find any sollution to set the temperature in an event in blockly or lua.
I want to create a switch when pressed the temperature is set to 15degrees.
Anybody can help me?
Bikey
Post by Bikey »
This is an easy one: I think this is what you are looking for (tested it and it works):
Notice that if you set the setpoint manually, the program is paused. So therefore I added the "Else" clause to unpause the program again.
mrefex
Post by mrefex »
Bikey wrote:This is an easy one: I think this is what you are looking for (tested it and it works):
If i look in my blockly event editor i don't see the set setpoint block...i use ver 3.5877
am i missing some steps?
Bikey
Post by Bikey »
It should be in devices. If not you probably need an update of Domoticz:
mrefex
Post by mrefex »
I think it's because i installed the last stable version and not the beta.
so if i install the latest beta i probably will see these settings.
mrefex
Post by mrefex »
I just went to a beta update 3.7041 and still i don't see these two new options..setpoints and Zwave Alarms . refreshed the browser but nothing more...
i don't get it...
** CLEARED BROWSER CACHE ** now it's all visible... :lol:
paultie
Post by paultie »
Just kicking this one up since this is where the integration of the thermosmart was born :D
Since a few weeks I am having troubles with the pause feature.
Apperently when sending a pause switch command it takes a while to process towards the thermosmart backend. If in that time domoticz retreives the status of the thermostat pause it resets is to the off value.
I see domoticz is updating the status of all its elements with thermosmart every 30 seconds. Isn't that to often?
I think every 60 seconds should be more than sufficient.
Does anyone know if this is changeable somewhere?
This might solve the issues for me.
