Dashticz - Alternative Dashboard
robgeerts
- Domoticz version: 3.7067
Re: WIP - Dashticz - Alternative Dashboard
I'm also running it from a Windows-pc (Win 8.1) and works, but, do you get any errors?
Could you open the console (in your browser, CTRL+SHIFT+J in Google Chrome) and see if it shows any errors?
jjnj
I only get a blank page with and in the header/title Dashticzrobgeerts wrote:I'm also running it from a Windows-pc (Win 8.1) and works, but, do you get any errors?
Console gives me:
GET http://192.168.2.19:8080/plugins/bootst ... ap.min.css
dash:21 GET http://192.168.2.19:8080/plugins/morrisjs/morris.css
dash:27 GET http://192.168.2.19:8080/plugins/font-a ... me.min.css
dash:30 GET http://192.168.2.19:8080/plugins/weathe ... ns.min.css
dash:29 GET http://192.168.2.19:8080/plugins/icomoon/icomoon.css
dash:18 GET http://192.168.2.19:8080/plugins/bootst ... slider.css
dash:28 GET http://192.168.2.19:8080/plugins/custom ... -icons.css
dash:52 GET http://192.168.2.19:8080/plugins/bootst ... rap.min.js
dash:51 GET http://192.168.2.19:8080/plugins/jquery ... -ui.min.js
dash:53 GET http://192.168.2.19:8080/plugins/raphael/raphael-min.js
dash:54 GET http://192.168.2.19:8080/plugins/morrisjs/morris.min.js
dash:50 GET http://192.168.2.19:8080/plugins/jquery ... ery.min.js
dash:55 GET http://192.168.2.19:8080/plugins/bootst ... -slider.js
dash:56 GET http://192.168.2.19:8080/plugins/skycons/skycons.js
dash:58 GET http://192.168.2.19:8080/js/dashticz.js 404 (Not Found)
all in red
robgeerts
The console shows you it cant find the files requested...
You are trying to open Dashticz in a subfolder /dash but it is looking for some files in the root.
Try adding this line in index.html (open with notepad) right after <head>:
Hope this will fix your problem for now..
<base href="http://192.168.2.19:8080/dash/" />
jjnj
That did the trick!! Thanksrobgeerts wrote:The console shows you it cant find the files requested...
Hope this will fix your problem for now..Code: Select all
wilmardo
First, thanks for the cool dashboard!
I installed it yesterday and I like it very much but I would like to use it on my tablet but the dash would not load? I see nothing but a white page, I see no errors in my Nginx log and the dash loads fine on desktop.
Do you have a clue what could cause that? I tried the remote debugging through Chrome but my phone is not seen in chrome://inspect. If you would like the output of the console I could borrow someones phone and try it again.
I do not know if this is the right place to suggest a functionality but I would like to see the 'Actuele vertrektijden' from the NS api (http://www.ns.nl/api/home) on my dash. So if my train is delayed I could see it directly on my tablet on the wall
drogert
Nice! I installed it and it looked really cool. I did notice my normal dashboard was slower when the other was running. Also.. How did you get the buienradar widget? I have Forecast IO installed but I think I would like buienradar too!
Thanks and keep up the good work
RPI 3b+, PiFace 2, RFcom, Aeon Zwave USB, Aeon Home Energy Meter Gen 5, several Shelly switches, several ESP8266 sensors.
gdelaat
- Domoticz version: 2.2982
I've made some changes to dashtics.js in order to re-activate the display of buienradar. I've added the following code on line 134 (I'm not familiar with GitLab, so I'm posting my info here
$.ajax({
url: _HOST_DOMOTICZ+'/json.htm?type=command¶m=getconfig&jsoncallback=?',
type: 'GET',async: false,contentType: "application/json",dataType: 'jsonp',
success: function(data) {
_LATITUDE = data.Latitude;
_LONGITUDE = data.Longitude;
Patrick
- Domoticz version: 3.5877
Nice dashboard, but if I try to display it on my iPad1 the sliders are not displaying correctly. Also the pop-up showing the camera is to big for the screen. Is there a way to fix this?
Tommertom
I am not sure if there is still development on this tool, but after looking at the alternatives in this forum (appoticz, dashicz, themes on defaul UI) I would like to use it to some development myself as the setup is actually quite nice and the code comprehensible.
I would like to extend it to do the following in order to improve my WAF for this beautiful hobby:
1- blocks in different sizes, pending content, pretty responsive for tablet and mobile devices
2- no graphs in the overall dashboard (see 4)
3- buttons and sliders etc on the panels, not as panel footer as currently implemented
4- the panel background clickable which leads to a deep-dive panel showing more detail (for instance, elaborate info on weather, graphs, etc.). I already created a panel using the xml feed for detailed weather info and news.
5- adding blocks through virtual devices ("text device") for weather, sonos, and all other required blocks not related to domoticz devices (such as nzb, wunderground, etc.)
6- changing the edit mode - block configuration through preamble in name of device - if the name starts with underscore, it will be allowed in the dashboard (I regard the domoticz UI as a administrator panel, not a user panel). Sorting should remain.
7- multi user support for 6.
A long list and I want to start with the first 4 of which 1,2,3 are easy and already done. For 4 I need to find out how to make the background of a panel clickable without losing the click function on the buttons on the panel itself. Anyone knows how?
Once it seems to work out well, I will be happy to share.
Tom
Tom
Ingmar
Is this still in development?
I only get a white screen... console says the following:
I've installed Dashticz on my Synology NAS. What is wrong?
Gr. Ingmar
Gr. Ingmar
Synology NAS with stable release, AEON Z-wave, RFXCOM, Toon, Echo Dot, HAbridge, HarmonyHUB, Dashticz.
klontje
Same here, just a white screen and base url is set correct.
robgeerts
Currently I'm not actively developing on Dashticz. Although, I'm checking regularly for any replies on this topic and when needed, I'll reply or will find a solution.
Has Dashticz worked in the past for the both of you?
Ingmar
Nope, it's a first time try for me. It looks and sounds good so want to give it a go
Do you still have plans to develop it further Rob?
robgeerts
Could you give me a printscreen of the network-tab in console?
One of the requests will be red..
I try to develop some more on Dashticz but unfortunately I do not have any spare time at the moment...
Ingmar
See below the screenshot of the network tab. I can't see anything red to be honest...
Time is always a precious thing, we're happy with whatever you manage to put into Dashticz
- jfhautenauven
I'm new to this forum. Been interested in a while in alternative dashboards for Domoticz;
I've been recently working on the code of Dashticz and did the following so far :
- Added translation to French
- Modified texts that were in Dutch to move them to the translation files
Is anyone still interested in this stuff or am I the only one?
I would be glad to contribute to the project
- gizmocuz
besides the custom theme, translation work is always appreciated.jfhautenauven wrote:Hello,
The theme'ing stuff in domoticz is still not where it should be, so unless this is fixed, it makes not a real difference how domoticz looks like
As i always say, try to theme your cisco router... .... thats a no
- jfhautenauven
Well, theming a Cisco sounds odd lol
I guess I could be of some use at some point, but I'm C# .Net Senior dev who knows very little about js ...
Anyways, I think that it's Rob Geerts who does the stuff for dashticz? (not domoticz, the Dashticz frontpage) , so maybe we could arrange something so that I could post code on his repo?
Or is there another place where I could do it?
ps : I don't want to steal anything from anyone, just trying to help here ... got some time for the moment, so ...
inbedrijf
Awesome skin, and got it working on mij server. but i also have this problem : 2- no graphs in the overall dashboard. Is there a solution for this problem?
