#2215 Custom Icons uploader Implemented
aDAMrus
Re: #2215 Custom Icons uploader Implemented
I trying to upload custom icons. I can choose and save new icon in sensor edit menu, but in floorplan this sensor looks like domoticz logo. Same situation with standart icon set if I use "custom sensor" - in floorplan they all are "domoticz logo". Whats wrong I do?
Thank
___
V3.8394 (on prev. beta same)
RPi2
Thank
___
RPi2
- wm62
- Domoticz version: 4.97
Look here
viewtopic.php?f=6&t=14435&hilit=floorplan+custom+icons
- wm62
@Domoticz Team
Still not possible to 'customize' sensors and smoke detectors ????
aDAMrus
Its helped. Thank you!wm62 wrote: Sunday 05 November 2017 13:53 Look here
- htilburgs
Yeelight Smart Light Strip
- YeeLED48_On.png (2.79 KiB) Viewed 9818 times
- YeeLED48_Off.png (2.38 KiB) Viewed 9818 times
- YeeLED.zip
- (7.62 KiB) Downloaded 303 times
Hardware:
febalci
Logitech Harmony Touch
- domoticz_HarmonyTouch.zip
- (7.38 KiB) Downloaded 344 times
febalci
Philips Hue Go:
- domoticz_HueGo.zip
- (9.88 KiB) Downloaded 308 times
febalci
Philips Hue
- domoticz_HueBulb.zip
- (6.78 KiB) Downloaded 338 times
- htilburgs
Nest Thermostaat
- Nest Thermostaat48_On.png (4.66 KiB) Viewed 9798 times
- Nest Thermostaat48_Off.png (3.95 KiB) Viewed 9798 times
- Nest Thermostaat.zip
- (11.22 KiB) Downloaded 398 times
Hardware:
mraichura
- Domoticz version: 3.8153
Here is a toggle icon set based on Font Awesome font icons
- PE7S_On.png (495 Bytes) Viewed 9359 times
- PE7S_Off.png (582 Bytes) Viewed 9359 times
- domoticz_custom_icon_Toggle Switch.zip
- (2.34 KiB) Downloaded 360 times
1 x RASPBERRY PI 1 MODEL B+ running Domoticz since June 2016
1 x RASPBERRY PI 3 MODEL B running Domtoicz since August 2017
Charley
- Domoticz version: V3.9030
I have made two icon sets
One for Audio
and One for Bose Soundtouch
One for Audio
HM31
custom icon for Sengled Pulse Bluetooth speaker/light bulb
HM31
Zipato Mini-Keypad
- Zipato Min-Keypad.zip
- (9.04 KiB) Downloaded 285 times
HM31
Zooz Zen06 plug with USB ports
- LiPeR
3D Printer Switch
- 3dPrinter.zip
- (5.32 KiB) Downloaded 322 times
schumi2004
- Domoticz version: 4.10603
Thanks for the icons but for some reason i only see them on floorplan and not in dashboard or switches overview.
Is this a known issue?
- FireWizard
Hi All,
For switches you have the option to select Custom Icons, if you have uploaded these to Domoticz.
You will see them both in the "Switches Tab" and on the Floor plan.
If you define a Custom Sensor and use a Custom Icon you will see these in the "Utility Tab", but on the Floor plan you will see the Domoticz Logo.
This question has raised before, approx. 2 years ago and it seemed that there was a solution. However I do not see the solution.
Or is this functionality still not implemented for other sensors except switches?
Last edited by FireWizard on Tuesday 17 September 2019 23:03, edited 1 time in total.
RduPre
I tried to upload custom icons on several Domoticz systems, running latest beta, but they all fail
The error is (in Dutch) "Probleem met uploaden van de pictogrammen: undefined"
I used this before, many months ago and at that time it worked.
There is no error in the logs..
Misiek
Two more icons - led halogen and xiaomi air purifier.
- purifier.zip
- (7.72 KiB) Downloaded 249 times
- halogen.zip
- (12.28 KiB) Downloaded 245 times
