Marstek OpenAPI
willemd
Re: Marstek OpenAPI
Post by willemd »
manuloup wrote: Wednesday 15 April 2026 14:37 [
willemd, are you able to ?
Sorry, I can't help with this. I only use hame relay outside of domoticz and am not using hm2mqtt.
If I were you I would open a few terminal sessions and use mosquiito_sub to subscribe to the relevant topics for your system (the same topics you used for testing hame relay). Then you should be able to see the mqtt messages that are being exchanged and see whether those match expectations.
Snakfy
Re: Marstek OpenAPI
Post by Snakfy »
This morning there was software update of the app.
And just now software update of Marstek E V3.
I enable the Open Api again and we will see if it does not reset the device anymore..........
Snakfy
Re: Marstek OpenAPI
Post by Snakfy »
NO , also after this latest firmware update (22042026 V1.48) the Open API is still killing the settings.
Reverting back to disabling Open API
manuloup
Re: Marstek OpenAPI
Post by manuloup »
I also upgraded the app but no New firmware version was proposed at the moment.
Keeping my way with hame-relay active anyway.
Rapberry PI B+ (RaspBian), RFXtrx433E USB 433.92MHz Transceiver, AEON LABS Controler Z-Wave, Aeon Labs Z-Stick S2, Everspring ST814 Temperature Sensor, Everspring SF812 Smoke Detector, 2x Fibaro Wallplug, Aeon Zwave Miniremote , Xbee Teleinfo USB
Snakfy
Re: Marstek OpenAPI
Post by Snakfy »
I just noticed that the app mentioned "there is a software update version 1.44".
But there is version 1.48 on my device currently.
So in other words, I think they made a mistake with firmware checking??
Because from 1.48 to 1.44 sound like downgrading ;-)
tonbor
Re: Marstek OpenAPI
Post by tonbor »
got firmware version 148-3 yesterday API is working again
manuloup
Re: Marstek OpenAPI
Post by manuloup »
tonbor wrote: Tuesday 28 April 2026 18:22 got firmware version 148-3 yesterday API is working again
which venus version ? No new firmware version on Venus E gen 3.
willemd
Re: Marstek OpenAPI
Post by willemd »
The real question is whether it remains stable during longer time (multiple days) Can it be used constantly without causing any full resets of the battery system? One day is not enough.
tonbor
Re: Marstek OpenAPI
Post by tonbor »
manuloup wrote: Tuesday 28 April 2026 18:46
Venus E v3
manuloup
Re: Marstek OpenAPI
Post by manuloup »
Still nothing here (France) . May be it depends from your location.
tonbor
Re: Marstek OpenAPI
Post by tonbor »
Running ok for days
manuloup
Re: Marstek OpenAPI
Post by manuloup »
This is great news. Still no update on my side, can't wait for it.
willemd
Re: Marstek OpenAPI
Post by willemd »
tonbor wrote: Thursday 07 May 2026 7:02 Running ok for days
And which version of the plugin are you using? The standard one (developed initially for Venus A) or the async one (developed for Venus E) ?
willemd
Re: Marstek OpenAPI
Post by willemd »
manuloup wrote: Thursday 07 May 2026 8:00 This is great news. Still no update on my side, can't wait for it.
A quick update: I am now at 149.121.1.110.3 and I switched on Open API yesterday morning.
Running stable so far, although I wonder whether they have implemented a workaround by having the Open API ON after a reset instead of OFF. In that way, you don't notice when there is a spontaneous reset, because it will continue running after the reset.
I am having this suspicion because I normally switch OFF the LED display and I see that sometimes it is ON again, so maybe a reset took place? I don't mind such a workaround, as long as Open API and Surplus feed-in keep functioning, that is what I need.
manuloup
Re: Marstek OpenAPI
Post by manuloup »
OK great, support told me 2 days ago that there is no firmware update from version. 148...
I hope I will be able to upgrade it soon too.
May be they just added a watchdog, like you said.
manuloup
Re: Marstek OpenAPI
Post by manuloup »
For the record I just have been upgraded to firmware version 148-7 today.
Running the API currently and waiting to see if it fails or not.
jslegers
Domoticz version: 2026.2
Re: Marstek OpenAPI
Post by jslegers »
I was wondering if the open api is stable now with the new version of the firmware.
John
manuloup
Re: Marstek OpenAPI
Post by manuloup »
Yes, finally!
On my Venus E gen3, I use firmware version 148-7.
willemd
Re: Marstek OpenAPI
Post by willemd »
Yes, same here, has een stable for a few weeks already. Currently also on 148.7 and using both my domoticz plugin for venusA OpenAPI and mqtt via hamerelay
jslegers
Re: Marstek OpenAPI
Post by jslegers »
manuloup wrote: Monday 15 June 2026 17:25 Hi,
Yes, finally!
That is good news. I just installed the Venus E v3 this weekend and in the IOS App I see that it has version 148 (This is the latest version). But it must be version 148.7 then?
