Page 5 of 15
Re: New project, a small wall display to control Domoticz using CYD (Cheap ESP32 touchscreen)
Posted: Monday 18 March 2024 19:58
by Rik60
I have some information, is this what you meant?
Posted: Monday 18 March 2024 22:10
by Thorgal789
Yes, exactly, thx.
But WTF ! What is this hardware ? First time I see RFX device, seriously what the "Lightning 1"/"philips" have more than the classic "Light/Switch"/"On/Off" ?
So I have modified the code.
- All device of type "Lightning X" are light by defaut, so with subtype "ARC", "AC", "X10", "ELRO AB400"
- All device with subtype ""Impuls" are push button, I presume "impuls" mean "impulse" ?
I have problem with
                        "DimmerLevels" : "0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100",
                        "IsDimmer" : true,
                        "Name" : "Screen boven",
                        "SubType" : "Switch",
                        "Type" : "Light/Switch",
                        "idx" : "714"
It's dimmer device ?
On classic hardware it's "Type" : "Light/Switch", "SubType" : "Switch" AND "switchtype" : "Dimmer". And they haven't "DimmerLevels".
Can you check if your device have too "switchtype" : "Dimmer", I think no, It can explain why your switches haven't command on the device, they are reconised as "passive "switch.
If you haven't "switchtype", I will check for "IsDimmer" : true.
Same for it
                        "DimmerLevels" : "none",
                        "IsDimmer" : false,
                        "Name" : "Zigbee plug 3",
                        "idx" : "730"
This one haven't switchtype=on/off ?
Have pushed the actual change on the branch "test".
Posted: Tuesday 19 March 2024 20:16
by Rik60
Ha, ha, need to explane something.
RFX is a RFXcom tranceiver on 433MHz, mainly used for remote controlled (plugin) powersockets. But there are also dimmers, and other devices remotely controlled on 433MHz. There are some brands (Impuls, Elro, Kaku) using the 433MHz, and using different codes.
So is "Impuls" not a pushbutton, its a brand. In my case they are also remote controlled powersockets on 433MHz. The 433MHz devices are one way direction communication devices.
The dimmer device with idx 714 name "screen boven" is a rollershutter controlled by a Somfy I/O system. I can open or close but also give it a setpoint like a dimmer. This is also for idx 713, 716, 717, 718. 712 is awning controlled by Somfy I/O.
All devices with "relais" in the name are relais connected on the Raspberry GPIO.
Thx.
Posted: Tuesday 19 March 2024 21:09
by Thorgal789
Ok so I need to reverse the code ^^.
Do you have check the presence of field "switchtype" on device "Screen boven" and "Zigbee plug 3" ? (can use http://IP:PORT/json.htm?type=command&param=getdevices&rid=ID)
For me yes, because they are more "standards" devices.
Or you can test with last "test" branch, It will be enought for most of your devices, IDK for RFX dimmer.
Posted: Wednesday 20 March 2024 22:31
by Rik60
I have downloaded the latest test version yesterday evening. It works, i think you can remove the "Ïmpuls" part in Data setup lines 414/417.
At the moment the screens/rollershutters are not working. I can select "screen boven" on the home screen and the second screen with a slide switch appears but i can't move it, it dark, not selectable.
Is the data on the display synchonized with the main Domoticz, is i switch a light on, on a mobile phone, is it on the display also? Or is the dispay acting like a switch with no actual switch status?
I tried also to display a temp en hum sensor on the dispay, it worked but after selecting this device the display was very slow, almost not responding on touch. After removing that device from the display (took some time) the display freezes and had to reset it with the button on the back.
Attached some info about "Screen boven" and "Zibee plug 3".
Thx
Posted: Thursday 21 March 2024 18:43
by Thorgal789
Hu ? It was normaly already removed when you have downloaded the code, I need to check if I haven't made the change on the wrong branch
Yes and no ^^. Yes the code is able to update the widget on homepage, and it does for sensor or warning widget for exemple, but I haven't do something for switch, If you have an idea of something I can do with design ? I prefer avoid use a different icon, because of memory, I can "gray a little" the icon like I do for group, but not realy visible.
Perhaps a circle under the icon ? Change the background color will be too much for me. Changing the color ? Honneslty I m still thinking use a special icon is the better solution ....
I think it's because the graph, it depend of hardware processor, domoticz json (some of them can be realy hudge).
Can you try with another sensor ? Zigbee one are working for me, else to finish trying the device first, you can comment on device_panel.cpp line 590
pTab = GetGraphValue(SelectedDevice->type, SelectedDevice->idx, &min, &max);
You will miss the grpah but if I right, no more freeze, will take a look later on the json to find the problem.
I m checking all was fine for thoses ones, you have issue with them ?
                        "SwitchType" : "Blinds Percentage",
Strange you need to have 3 buttons on the right (up/stop/down) and a slider on the left. I have just made a try 10 mn ago.
Have updated again the "test" branch 5 mn ago, a crash that can happen for device without data.
Edit:
Have edited the code again, now you have a small "power on" icon on device on "on" state, and it work in real time. Time to find a better display mode.
Posted: Sunday 24 March 2024 21:16
by Rik60
I have downloaded the latest version, commit 3d76de1.
If i disable the group screen but swipe to it, the display crashes and restart, see attachment.
Display very slow when trying to display temp/hum sensor, see also same attachment.
In Domoticz i have created a group (IDX 5) that turns on/off the 4 zigbee devices. Is it possible to have this on the display to?
Suggestion for On/Off indication of a switch: put the text On or Off insteat of the power symbol?
Posted: Monday 25 March 2024 19:11
by Thorgal789
About the freeze for temperature sensor. When I make a try on my side
content Length : 4786
Free memory : 110580
And on your side
content Length : 161936
Free memory : 220
The slower device I have is a device that make temperature+humidity+pression
content Length : 81158
Free memory : 55284
So idk what is this device, can be a setting in domoticz (you can set an interval ) but for me this json is too big for the device, perhaps there is useless stuff inside ? I can perhaps use a filter.
The group/scene feature is still WIP, but yes you can make a try, have corrected the crash. This panel will show ALL groups/scenes (no watchdogs, idk if it can crash) , you can scroll bottom/top, but need to be re-enabled
-DNO_GROUP_PAGE # Disable the Group/scene panel
Need to comment this line, you have it enabled by error during my tests.
So display them like sensor, with a text on right ?
For the moment I display a "on" or nothing if the device is "off" (more visible for me).
New version online in branch "test" 5 mn ago.
Posted: Wednesday 27 March 2024 22:42
by Rik60
I have downloaded the main version, works fine. I think the freeze problem is solved, i was logging the sensors (short log) for 7 days. I changed this setting in Domoticz to 1 day, the graph is working now and no freezing of the display.
Thx
Posted: Thursday 28 March 2024 19:29
by Thorgal789
Ha! good to know I will make test on my side.
But I make a request that return 3 days of data (it's the same you can see in domoticz itself) , so you miss 2 days ? On my side I have set this setting to 3.
In my mind was because this device have report every 5 mn for exemple and mine every 30 mn.
I can make a watchdog, for exemple don't use the fonction if the data size > 100k, but it's perhaps too late, when I check for size, the data is probably already in memory, and thoses devices have so much memory type, IDK if it's the good one that is used.
I can too disable the automatic graph and wait the user press a button to ask for it, display will be faster, but same issue if the user ask for graph, and honnestly you are the first one with issues on them.
@kniazio have memory issue too on big json, but him it's for the "info" panel, it's for that it can be disabled. For here I have found a smaller request with less information, but he don't like the "info panel" and prefere having more page with device, so it's in stand by.
The "group/scene" page is working for you ?
Posted: Thursday 28 March 2024 21:15
by Rik60
I was using 7 days, to test i changed the setting to 1 day yesterday. Domoticz was displaying 7 days in the graph. I can set de short logging in Domoticz to 3 days also. I can try this. I am not shure missing 2 days now because i changed the setting to 1 yesterday
If a graph is displayed, the numbers on the y-axis are not complete, see attachment, the temperature is betweent 20-22 degrees.
The group/scene is working for me, with a remark. If i switch a group "On", all lamps are going on, but i can't switch the group Off. I have to swipe to the Home screen and back to the group screen and then i can switch off.
Thx
Posted: Friday 29 March 2024 15:18
by Thorgal789
Ok, so new version online in branch "Beta".
For your display issue,on device_panel.cpp
#if DEVICE_SIZE == 1
            lv_chart_set_axis_tick(chart, LV_CHART_AXIS_PRIMARY_Y, 3, 2, 4, 1, true, 25);
#else
            lv_chart_set_axis_tick(chart, LV_CHART_AXIS_PRIMARY_Y, 3, 2, 4, 1, true, 35);
#endif
25 is for small device, have set 35 for yor device, but it's random, tell me if you need a better value.
Have set a scale of 4 value instead of 3 for graph on Y.
Have rewrited the group code.
- Different color for group and scene
- All the button is grayed for group
- Solve your issue.
Posted: Friday 29 March 2024 20:31
by Rik60
Thx,
These changes are working for me.
I think i have 1 last question/ issue, i have a CO2 sensor that is displaying its values on the home screen, but i don't get a graph.
Thanks for your help and very quick responding
Posted: Saturday 30 March 2024 11:18
by Thorgal789
New version on branch "test".
- Have added the custom sensor
- The minimum in graph is now 0 if 0 is the lower value.
- Corrected a problem on range.
And BTW, I get data for 3 days, but I display only the last 24h, so a range on X axis is 6h.
Posted: Saturday 30 March 2024 17:48
by Rik60
Thanks again.
No more issues at the moment, works for me now.
Posted: Sunday 31 March 2024 23:35
by vestale
Great project!
I have a Sunton ESP32-8048S070 ESP32-S3 7inch with 8048S070C display, and based on 8048S043C I tried to integrate on https://github.com/YO8SDE/CYD-Domoticz- ... /8048C070C fork.
But on tests, I am able to see only the right half of the screen.
Touch screen is working ok and with other projects, like Tastmota is 100%, but I want Domoticz ;)
Posted: Monday 01 April 2024 14:35
by Thorgal789
Strange it look like a resolution issue, but all seem fine.
Have found this driver, if you can test it
#include <lgfx/v1/platforms/esp32s3/Panel_RGB.hpp>
#include <lgfx/v1/platforms/esp32s3/Bus_RGB.hpp>
#include <driver/i2c.h>
class LGFX: public lgfx::LGFX_Device {
    public:
    lgfx::Bus_RGB _bus_instance;
    lgfx::Panel_RGB _panel_instance;
    lgfx::Light_PWM _light_instance;
    lgfx::Touch_GT911 _touch_instance;
    LGFX(void) {
            auto cfg = _bus_instance.config();
            cfg.panel = &_panel_instance;
            cfg.pin_d0 = GPIO_NUM_15; // B0
            cfg.pin_d1 = GPIO_NUM_7; // B1
            cfg.pin_d2 = GPIO_NUM_6; // B2
            cfg.pin_d3 = GPIO_NUM_5; // B3
            cfg.pin_d4 = GPIO_NUM_4; // B4
            cfg.pin_d5 = GPIO_NUM_9; // G0
            cfg.pin_d6 = GPIO_NUM_46; // G1
            cfg.pin_d7 = GPIO_NUM_3; // G2
            cfg.pin_d8 = GPIO_NUM_8; // G3
            cfg.pin_d9 = GPIO_NUM_16; // G4
            cfg.pin_d10 = GPIO_NUM_1; // G5
            cfg.pin_d11 = GPIO_NUM_14; // R0
            cfg.pin_d12 = GPIO_NUM_21; // R1
            cfg.pin_d13 = GPIO_NUM_47; // R2
            cfg.pin_d14 = GPIO_NUM_48; // R3
            cfg.pin_d15 = GPIO_NUM_45; // R4
            cfg.pin_henable = GPIO_NUM_41;
            cfg.pin_vsync = GPIO_NUM_40;
            cfg.pin_hsync = GPIO_NUM_39;
            cfg.pin_pclk = 42;
            cfg.freq_write = 12000000;
            cfg.hsync_polarity = 0;
            cfg.hsync_front_porch = 8;
            cfg.hsync_pulse_width = 2;
            cfg.hsync_back_porch = 43;
            cfg.vsync_polarity = 0;
            cfg.vsync_front_porch = 8;
            cfg.vsync_pulse_width = 2;
            cfg.vsync_back_porch = 12;
            cfg.pclk_idle_high = 1;
            _bus_instance.config(cfg);
        _panel_instance.setBus( &_bus_instance);
          auto cfg = _panel_instance.config();
          cfg.memory_width = 800;
          cfg.memory_height = 480;
          cfg.panel_width = 800;
          cfg.panel_height = 480;
          cfg.offset_x = 0;
          cfg.offset_y = 0;
          _panel_instance.config(cfg);
          auto cfg = _panel_instance.config_detail();
          cfg.use_psram = 1;
          _panel_instance.config_detail(cfg);
          auto cfg = _light_instance.config();
          cfg.pin_bl = 2;
          //cfg.freq = 44100;
          //cfg.pwm_channel = 7;
          _light_instance.config(cfg);
        _panel_instance.light( &_light_instance);
          auto cfg = _touch_instance.config();
          cfg.x_min = 0;
          cfg.x_max = 800;
          cfg.y_min = 0;
          cfg.y_max = 480;
          cfg.pin_int = -1;
          cfg.bus_shared = false;
          cfg.offset_rotation = 0;
          // I2C
          cfg.i2c_port = I2C_NUM_0; // I2C(0 = SPI or 1 = Wire)
          cfg.pin_sda = 19; // SDA
          cfg.pin_scl = 20; // SCL
          cfg.pin_rst = 38; // RST
          cfg.freq = 100000; // I2C
          cfg.i2c_addr = 0x5D; // I2C 0x5D or 0x14
          _touch_instance.config(cfg);
          _panel_instance.setTouch( &_touch_instance);
        setPanel( &_panel_instance);
Have found another project that use
cfg.hsync_pulse_width = 10;
But for me better to reverse width and Height, and play with rotation.
For me the missing part is 480*480.
For exemple the esp32-E32S3RGB43 use same value than you in the driver
but have them reversed in platoformio.ini
    -DTFT_WIDTH=480
    -DTFT_HEIGHT=800
I know it's like you have done, but this part is realy "try and retry" for me ^^.
I haven't found a logic, and the code is not perfect for them, so no way to be sure.
I will wait for your device is working and update all the code with good dimension.
Posted: Monday 01 April 2024 19:50
by vestale
Thank YOU!
One video will speak for me: https://youtu.be/bQmj5jpGSt8 ;)
This is the driver : esp32-8048S070C.h in /driver folder
    public:
    LGFX(void) {
            cfg.pin_pclk = 42;
          cfg.offset_x = 1000;
          cfg.offset_y = 2000;
          cfg.use_psram = 1;
          cfg.pin_bl = 2;
          //cfg.freq = 44100;
          cfg.x_min = 0;
          cfg.x_max = 480;
          cfg.y_min = 0;
          cfg.y_max = 800;
          cfg.pin_int = -1;
          // I2C
          cfg.freq = 100000; // I2C 8000 de incercat
Posted: Tuesday 02 April 2024 10:36
by Thorgal789
Thx ^^.
Do you want to make the PR ? or can i Use yours files ?
By the way the square is the symbol "µ" ?
I have another used with issue with special characters. It's possible to use custom police with more chart, but need to se if I can just add 1 char on an existing one.
Posted: Tuesday 02 April 2024 11:50
by vestale
I did 2 Push Request, first on the main branch and the second one on test.
Yes, the square box is a "µ" , can be change to "u". For my situation I resolved in Domoticz.
I did some tests on switched and they are working ok.
Thank you once again for your help and work!
