Page 5 of 25
Re: Easiest way to migrate Openzwave to ZWave-JS-UI
Posted: Friday 23 December 2022 9:28
by mgugu
Posted: Friday 23 December 2022 9:34
by Egregius
And also for MQTT and Gateway?
Posted: Friday 23 December 2022 9:45
I have already updated the Wiki with help of your comments.
https://www.domoticz.com/wiki/Zwave-JS- ... n_Domoticz
Posted: Friday 23 December 2022 9:48
by mgugu
- 2022-12-23 09_45_49-Z-Wave JS UI.png (37.82 KiB) Viewed 11567 times
- 2022-12-23 09_44_16-Z-Wave JS UI.png (28.8 KiB) Viewed 11567 times
Posted: Friday 23 December 2022 9:54
by mgugu
Excellent. No more possible confusion now.
And this is valid also for zigbee2mqtt.
Posted: Friday 23 December 2022 10:04
by Egregius
What's the reason to have a different prefix in MQTT and Homeassistant?
Posted: Friday 23 December 2022 10:09
by mgugu
Prefix in HA is used for config messages and MQTT prefix used for update messages. This allows to have 2 different topics, improving readability in MQTT explorer and also to avoid possible MQTT loop.
Posted: Friday 23 December 2022 10:12
by mgugu
And after a successfull integration, NEVER CHANGE the prefixes !
Posted: Friday 23 December 2022 11:40
by Egregius
OK, and which one is set in domoticz then? The MQTT one or the HA one?
Posted: Friday 23 December 2022 11:57
by mgugu
Egregius wrote: Friday 23 December 2022 11:40
Only HA prefix is set in domoticz UI. MQTT prefix, used for updates, is sent automatically to domoticz through config messages
- 2022-12-23 11_45_54-Domoticz.png (250.14 KiB) Viewed 11534 times
Posted: Saturday 24 December 2022 16:13
by JuanUil
HI all,
I also have struggeld a lot with switching to ZWave-JS-UI.
But now all is working verry well and better then in OZW.
I have made a tutorial to complete install.
For the moment it is only in Dutch and maybe not complete.
Coming time I will translate and update.
you can download it from :
https://mega.nz/file/3JxQ3Y7R#LIFf5wcVo ... KTAX1e5dFA
good luck!
Jan
Posted: Saturday 24 December 2022 16:24
by madpatrick
Good Job !!
Posted: Saturday 24 December 2022 17:28
by HansF
Thanks Jan, for putting this together!
Posted: Sunday 25 December 2022 13:05
by gizmocuz
Instead of directly installing these applications/servers on your machine, why not use docker-compose?
I recommend this much more above a direct install
You will have all configuration/data files in each docker-compose folder, and it is very easy to backup/migrate/test/update
Everything is also available in docker-compose
It also does not take any additional system resources
Posted: Sunday 25 December 2022 15:32
by JuanUil
The englisch version of the manual can now be found on:
https://mega.nz/file/jQInXCJI#j-uMcnlrX ... YzUippScHs
Enjoy!
Jan
Posted: Tuesday 27 December 2022 20:44
by madpatrick
@gizmocuz
Is it possible to have a notice up front when OZW will be disabled from Domoticz?
This gives me time to build a latest release from source and to switch to ZWave-JS-UI
Thanks !
Keep up the good work
Posted: Monday 02 January 2023 10:57
by MikeyMan
mgugu wrote: Friday 23 December 2022 8:59
From my experience, contrary to what is suggested in wiki configuration screenshot, retain flag
MUST be set to ON.
This allows the broker to keep in memory the config messages which are necessary each time domoticz is restarted.
If you need to remove definitely devices from domoticz (for example in case you remove a zwave node), you have to remove the corresponding config messages, simply by publishing "" at the config message topic (with MQTT explorer for example).
Hmm... I restarted domoticz several times, but that i didn't notice.
What behaviour did you see that makes you think this? Can check again.
Posted: Monday 02 January 2023 13:10
by mgugu
MikeyMan wrote: Monday 02 January 2023 10:57
Domoticz does not store mqtt config messages, so if these messages are not retained neither by the broker, after a restart yo will still see the devices in domoticz but they are not responding. You then need to make a manual refresh in the mqtt gateway to make them working again.
Posted: Monday 02 January 2023 19:24
by elzorrovega
Hello All,
I take this opportunity to wish you All Happy New Year!
We hesitate to sail unto uncharted waters but then again sometimes we have no choice. After closely following your discussions, I understood that Open Z-Wave development is stopped and the only option is to use Zwave-JS-UI in the very near future.
To this effect Domoticz needs to use MQTT gateways, MQTT Broker like Mosquitto and an application such as Zwave-JS-UI to communicate to field devices. Web pages below have been very helpful - Thanks a lot JuanUil - to allow me to almost succeed this exercise but I still have
some snags!
https://www.domoticz.com/wiki/MQTT - MQTT Broker Mosquitto
https://www.domoticz.com/wiki/Zwave-JS-UI
DOMOTICZ CONFIGURATION
Domoticz version 2022.1 release runs in the following environment
Update Raspberry Pi 3 Model B+
Hardware : BCM2835
Revision : a020d3
Serial : 00000000cc7e2232
Model : Raspberry Pi 3 Model B Plus Rev 1.3
Linux raspberrypi 5.15.76-v8+ #1597 SMP PREEMPT Fri Nov 4 12:16:41 GMT 2022 aarch64 GNU/Linux - Bullseye -64 bit OS
Z-Wave Node
idVendor 0x0658 Sigma Designs, Inc.
idProduct 0x0200 Aeotec Z-Stick Gen5 (ZW090) - UZB
MIGRATION STATUS
Mosquitto Broker is installed and configured as recommended for Raspbian environment
https://randomnerdtutorials.com/how-to- ... pberry-pi/
Docker is installed and running. Below is the ps ouput
pi@raspberrypi:~ $ pstruc.sh | grep erd
root 668 0.1 5.5 1354332 50072 ? Ssl 17:19 0:04 /usr/bin/dockerd
root 521 0.0 3.4 1335144 31576 ? Ssl 17:19 0:02 /usr/bin/containerd
I am new to Docker but to my understanding, one runs an image of an application in localised environment (locally/cloud).
According to
https://zwave-js.github.io/zwave-js-ui/ ... tallation
There are three way to install Zwave-JS-UI image
1- Run using volumes
2- Run using local folder
3- Run as a service
I understood, that in all cases we are to download an Zwave-JS-UI image. I chose the second option and data is placed in store directory. I was able to access the Zwave-JS-UI image after running the following in LCI
sudo docker run --rm -it -p 8091:8091 -p 3000:3000 -e TZ=Europe/Paris --device=/dev/serial/by-id/usb-0658_0200-if00 \
-v $(pwd)/store:/usr/src/app/store zwavejs/zwave-js-ui:latest
Terminal shows activity and web interface allows configuration. However, after restarting the Raspberry Pi, the Zwave-JS-UI is not accessible.
Running docker command again brings back the web interface.
QUESTIONS
JuanUil in his walk-through points to dev/serial/by-id/usb-0658_0200-if00:/dev/zwave' .
I used /dev/serial/by-id/usb-0658_0200-if00.
Is :/dev/zwave a must to communication via Z-Wave node?
Docker documentation recommends to add parameter --restart unless-stopped to docker command line and prefers not to use process managers like upstart, systemd or supervisor.
What is the best way to Start Docker Containers Automatically After a Reboot?
Thanks in advance for your help.
El Zorro.
Posted: Tuesday 03 January 2023 12:01
by sincze
Did a first trial run.
Before I started (on a Pi):
- Spoiler: show
sudo nano /etc/udev/rules.d/99-usb-serial.rules [ or use the vi editor ]
SUBSYSTEM=="tty", ATTRS{idVendor}=="0658", ATTRS{idProduct}=="0200", SYMLINK+="ttyUSB-ZStick-5G"
- Created an overview of all my Domoticz ZWAVE nodeID's in excel so I would be able to identify them later.
- Followed the wiki
(thanks!)
- Disabled the ZWAVE Stick in Domoticz (Production)
- Started the Z-Wave JS UI Docker
- Added Network Security Keys [Settings -> Z-Wave -> Security Keys (S0 Legacy, S2 Unauthenticated, S2 Authenticated, and S2 Access Control))
- After that Control Panel started building up the Network Inventory.
- Unfortunately the Device Names and Locations that I defined in OZW were not transferred into Z-Wave JS.
- Manufacturer name of some Fibaro Power Switching Nodes were and others were not detected (Fibargroup vs Unknown manufacturer 0xXXXX).
Due to time shortage I was unable to test the Battery Powered Nodes. Probably need to open them and press a button or so to speed up detection.
Additionally
- Installed a Domoticz (TEST) docker
- Added the Autodiscovery Hardware
- Enabled MQTT Dicovery in Z-Wave JS UI. + Retained Discovery
- zwave2mqtt.JPG (81.72 KiB) Viewed 11294 times
Result:
The nodes were created
in Domoticz, still only based on their NodeID but that seems logical as the names did not come through from OZW.
