Page 5 of 7
Re: Dashticz v3.8.2 beta: New weather block
Posted: Thursday 27 May 2021 9:12
by Doudy
I have install the last version V3.8.2 beta
Now it is ok
Another question : Why are the days in English?
My config :
config['owm_api'] = '5xxxxx2';
config['owm_city'] = 'Rxxxxxx';
config['owm_name'] = 'Météo Rxxxxxx';
config['owm_country'] = 'be';
config['owm_lang'] = 'fr';
config['owm_cnt'] = '4';
config['owm_days'] = true;
Posted: Thursday 27 May 2021 17:43
by HansieNL
@Doudy
Days are in English (default) if you don't have set any language.
There are two language settings to set the Dashticz language:
config['language'] = 'nl_NL';
config['calendarlanguage'] = 'nl_NL';
Complete settings overview you can find in the manual: https://dashticz.readthedocs.io/en/beta/
Posted: Thursday 27 May 2021 19:55
by Dickey
@Doudy
It's very important to read the manual ( as HansieNL suggested).
My way of getting a nice dashboard and complete the config, is try and error. :D :D
Posted: Friday 28 May 2021 7:42
by Doudy
@ HansieNL
@ Dickey
Posted: Saturday 29 May 2021 11:51
by TroisSix
I just updated to the last version, but the weatherwidget.io is not working anymore, I understand there is a new way to configure the weather widget, but why disable the weatherwidget.io within a html frame?
This one is not working anymore:
https://dashticz.readthedocs.io/en/beta ... stom-block
Need help to keep it cause the colors are really nice ;)
Posted: Saturday 29 May 2021 12:45
by HansieNL
TroisSix wrote: Saturday 29 May 2021 11:51 Hi,
Are you sure? It's still working here with latest beta.
Posted: Saturday 29 May 2021 13:40
by TroisSix
Hi HansieNL,
You're right, sorry, that's working on my iPad & IE, but not on firefox anymore (I cleared my cache) :shock:
Anyway, I configured the weather with the new method and I'll keep it now 8-)
Improvments: could it be possible to have an abbreviation of the days (like mon. instead of monday) ?
Great work team!
Posted: Thursday 10 June 2021 11:17
by riko
Thanks for the update, it sounds great to have more configuration parameters. Only problem is that I cannot get it working (nothing is showed at all on the screen/column where I insert the widget. I use the following code (as in the example)
config['owm_api'] = 'xxxx';
config['owm_city'] = 'Utrecht';
config['owm_name'] = '';
config['owm_country'] = 'nl';
config['owm_lang'] = 'nl';
config['owm_cnt'] = '5';
config['owm_min'] = true;
config['static_weathericons'] = false;
config['use_beaufort'] = true;
blocks['weather1'] = {
    type: 'weather',
    layout: 1,
    count: 7,
    interval: 3,
columns[1] = {}
columns[1]['blocks']  = ['weather1', 'cameras', 'spotify']
columns[1]['width']   = 5;
screens[1] = {}
screens[1]['background'] = 'bg_rik_1.jpg';
I've also tried variants like
  type: 'weather',
  apikey: 'xxx',
  city: 'Amsterdam',
I've also cleared the browser cache to be sure. What do I do wrongly?
Posted: Thursday 10 June 2021 15:30
by whoami
I tried all the CSS custom padding adjustments, but I can't get the yellow space smaller.
What is the code to remove this or make it smaller?
Or even better, set a fixed height to the block with all icons and text automatically adjusted to the right size... :)
Posted: Thursday 10 June 2021 20:09
by TroisSix
@whoami
You could try this:
[data-id='weather'] .max {padding-top:0px !important;}
[data-id='weather'] .description {padding-bottom:0px !important;}
Posted: Saturday 12 June 2021 16:34
by HansieNL
riko wrote: Thursday 10 June 2021 11:17 Thanks for the update, it sounds great to have more configuration parameters. Only problem is that I cannot get it working (nothing is showed at all on the screen/column where I insert the widget. I use the following code (as in the example)
    type: 'weather',
    layout: 1,
    count: 7,
    interval: 3,
columns[1] = {}
screens[1] = {}
  type: 'weather',
  apikey: 'xxx',
  city: 'Amsterdam',
Tried your config and shows without problems. Can you try to load a config with just the OWM block and see if that works.
Posted: Saturday 12 June 2021 20:01
by riko
HansieNL wrote: Saturday 12 June 2021 16:34 Tried your config and shows without problems. Can you try to load a config with just the OWM block and see if that works.
Just tried to bring down the code. This is all I have left:
var config = {}
config['language'] = 'nl_NL'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SV
config['background_image'] = 'img/bg9.jpg';
config['domoticz_ip'] = 'http://192.168.1.100:8080';
config['app_title'] = 'xxxx';
//Definition of blocks
var blocks = {}
    type: 'weather',
    layout: 1,
    count: 7,
    interval: 3,
//Buttons
//Definition of columns - 12 in totaal
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks']  = ['weather1']
//Definition of screens
var screens = {}
screens[1] = {}
screens[1]['columns'] = [1]
Still a blank screen as result:
Posted: Saturday 12 June 2021 20:46
by Dickey
What is you're Dasticz version?
Go with terminal into the Dasticz folder and enter the git pull command. You will automatic get the latest version.
You need V3.8.3 beta
Think that's you're problem.
Posted: Sunday 13 June 2021 12:01
by riko
I did, that was the reason why the other OWMs components were not working.
Just did a retry:
pi@raspberrypi:~/dashticz $ git pull
Already up to date.
Posted: Sunday 13 June 2021 19:40
by Dickey
Did try you're config with my credentials. Looks good to me.
Posted: Sunday 13 June 2021 20:49
by HansieNL
riko wrote: Sunday 13 June 2021 12:01 I did, that was the reason why the other OWMs components were not working.
Does that mean it is working now?
Posted: Sunday 13 June 2021 22:21
by riko
Sorry i was not clear in my previous post. The weather blocks are still not working and i have no clue of the problem. Any ideas?
Posted: Monday 14 June 2021 12:02
by Dickey
riko wrote: Sunday 13 June 2021 22:21 Sorry i was not clear in my previous post. The weather blocks are still not working and i have no clue of the problem. Any ideas?
Please look at you're menubar at info to see the version you use. Make a screen print.
Posted: Monday 14 June 2021 15:59
by riko
Please see my version:
I was also able to see that the configuration was prefilled like this
Posted: Monday 14 June 2021 16:28
by madpatrick
riko wrote: Monday 14 June 2021 15:59 Please see my version:
As mentioned by Dicky, you probably need to upgrade to 3.8.3 BETA
You are on 3.8.0 master.
