Dashticz v3.8.2 beta: New weather block
Doudy
Re: Dashticz v3.8.2 beta: New weather block
Post by Doudy »
I have install the last version V3.8.2 beta
Now it is ok
Another question : Why are the days in English?
My config :
config['owm_api'] = '5xxxxx2';
config['owm_city'] = 'Rxxxxxx';
config['owm_name'] = 'Météo Rxxxxxx';
config['owm_country'] = 'be';
config['owm_lang'] = 'fr';
config['owm_cnt'] = '4';
config['owm_days'] = true;
HansieNL
Post by HansieNL »
@Doudy
Days are in English (default) if you don't have set any language.
There are two language settings to set the Dashticz language:
config['language'] = 'nl_NL';
config['calendarlanguage'] = 'nl_NL';
Complete settings overview you can find in the manual: https://dashticz.readthedocs.io/en/beta/
Blah blah blah
Dickey
Domoticz version: 2022.1
Post by Dickey »
@Doudy
It's very important to read the manual ( as HansieNL suggested).
My way of getting a nice dashboard and complete the config, is try and error. :D :D
Dz-beta | Dashticz 3.8.10 BETA | Tradfri | RF-Link | Z-Wave | Harmony | Unify | P1 |
Doudy
Post by Doudy »
@ HansieNL
@ Dickey
TroisSix
Domoticz version: 2025.2
Post by TroisSix »
I just updated to the last version, but the weatherwidget.io is not working anymore, I understand there is a new way to configure the weather widget, but why disable the weatherwidget.io within a html frame?
This one is not working anymore:
https://dashticz.readthedocs.io/en/beta ... stom-block
Need help to keep it cause the colors are really nice ;)
Not using Dz anymore.
HansieNL
Post by HansieNL »
TroisSix wrote: Saturday 29 May 2021 11:51 Hi,
Are you sure? It's still working here with latest beta.
Blah blah blah
TroisSix
Post by TroisSix »
Hi HansieNL,
You're right, sorry, that's working on my iPad & IE, but not on firefox anymore (I cleared my cache) :shock:
Anyway, I configured the weather with the new method and I'll keep it now 8-)
Improvments: could it be possible to have an abbreviation of the days (like mon. instead of monday) ?
Great work team!
riko
Post by riko »
Thanks for the update, it sounds great to have more configuration parameters. Only problem is that I cannot get it working (nothing is showed at all on the screen/column where I insert the widget. I use the following code (as in the example)
config['owm_api'] = 'xxxx';
config['owm_city'] = 'Utrecht';
config['owm_name'] = '';
config['owm_country'] = 'nl';
config['owm_lang'] = 'nl';
config['owm_cnt'] = '5';
config['owm_min'] = true;
config['static_weathericons'] = false;
config['use_beaufort'] = true;
blocks['weather1'] = {
    type: 'weather',
    layout: 1,
    count: 7,
    interval: 3,
columns[1] = {}
columns[1]['blocks']  = ['weather1', 'cameras', 'spotify']
columns[1]['width']   = 5;
screens[1] = {}
screens[1]['background'] = 'bg_rik_1.jpg';
I've also tried variants like
  type: 'weather',
  apikey: 'xxx',
  city: 'Amsterdam',
I've also cleared the browser cache to be sure. What do I do wrongly?
whoami
Post by whoami »
I tried all the CSS custom padding adjustments, but I can't get the yellow space smaller.
What is the code to remove this or make it smaller?
Or even better, set a fixed height to the block with all icons and text automatically adjusted to the right size... :)
TroisSix
Post by TroisSix »
@whoami
You could try this:
[data-id='weather'] .max {padding-top:0px !important;}
[data-id='weather'] .description {padding-bottom:0px !important;}
HansieNL
Post by HansieNL »
riko wrote: Thursday 10 June 2021 11:17 Thanks for the update, it sounds great to have more configuration parameters. Only problem is that I cannot get it working (nothing is showed at all on the screen/column where I insert the widget. I use the following code (as in the example)
    type: 'weather',
    layout: 1,
    count: 7,
    interval: 3,
columns[1] = {}
screens[1] = {}
  type: 'weather',
  apikey: 'xxx',
  city: 'Amsterdam',
Tried your config and shows without problems. Can you try to load a config with just the OWM block and see if that works.
Blah blah blah
riko
Post by riko »
HansieNL wrote: Saturday 12 June 2021 16:34 Tried your config and shows without problems. Can you try to load a config with just the OWM block and see if that works.
Just tried to bring down the code. This is all I have left:
var config = {}
config['language'] = 'nl_NL'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SV
config['background_image'] = 'img/bg9.jpg';
config['domoticz_ip'] = 'http://192.168.1.100:8080';
config['app_title'] = 'xxxx';
//Definition of blocks
var blocks = {}
    type: 'weather',
    layout: 1,
    count: 7,
    interval: 3,
//Buttons
//Definition of columns - 12 in totaal
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks']  = ['weather1']
//Definition of screens
var screens = {}
screens[1] = {}
screens[1]['columns'] = [1]
Still a blank screen as result:
Dickey
Post by Dickey »
What is you're Dasticz version?
Go with terminal into the Dasticz folder and enter the git pull command. You will automatic get the latest version.
You need V3.8.3 beta
Think that's you're problem.
riko
Post by riko »
I did, that was the reason why the other OWMs components were not working.
Just did a retry:
pi@raspberrypi:~/dashticz $ git pull
Already up to date.
Dickey
Post by Dickey »
Did try you're config with my credentials. Looks good to me.
HansieNL
Post by HansieNL »
riko wrote: Sunday 13 June 2021 12:01 I did, that was the reason why the other OWMs components were not working.
Does that mean it is working now?
Blah blah blah
riko
Post by riko »
Sorry i was not clear in my previous post. The weather blocks are still not working and i have no clue of the problem. Any ideas?
Dickey
Post by Dickey »
riko wrote: Sunday 13 June 2021 22:21 Sorry i was not clear in my previous post. The weather blocks are still not working and i have no clue of the problem. Any ideas?
Please look at you're menubar at info to see the version you use. Make a screen print.
riko
Post by riko »
Please see my version:
I was also able to see that the configuration was prefilled like this
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
riko wrote: Monday 14 June 2021 15:59 Please see my version:
As mentioned by Dicky, you probably need to upgrade to 3.8.3 BETA
You are on 3.8.0 master.
