Oficial Docker Container Topic is solved
DAVIZINHO
Re: Oficial Docker Container
Post by DAVIZINHO »
hello to all
im try to setup fail2ban inside the docker container.
someone can try this??
i setup all as the tutorial of fail2ban but not works :-(
EddyG
Post by EddyG »
Fail2ban uses logfiles, and those logfiles are not present inside the domoticz container.
You should setup fail2ban on the Raspberry OS itself.
DAVIZINHO
Post by DAVIZINHO »
EddyG wrote: Saturday 07 August 2021 19:44 Fail2ban uses logfiles, and those logfiles are not present inside the domoticz container.
Not exactly.
You can setup de logfiles in the domoticz container only editing one user variable. I have it in /etc/domoticz.txt
And i use docker in synology not raspberry :-)
EddyG
Post by EddyG »
Oke, you only want to protect the domoticz container with fail2ban.
Perhaps you could make a new container which include fail2ban and all of the dependencies.
DAVIZINHO
Post by DAVIZINHO »
now i have fail2ban teorically runing.
I install it, disable the sshd profile in the jail.conf
after this start service fail2ban, i monitor the state and check if really works. i will tell here
EddyG
Post by EddyG »
You could also use a fail2ban synology container en monitor the domoticz.log file.
See: https://github.com/sosandroid/docker-fail2ban-synology
bartplessers
Post by bartplessers »
Where is the location of the theme's if domoticz is running in docker?
My docker-compose:
version: '3.3'
services:
  domoticz:
    image: domoticz/domoticz
    container_name: domoticz
    restart: unless-stopped
    # Pass devices to container
    # devices:
    #   - "/dev/serial/by-id/usb-0658_0200-if00:/dev/ttyACM0"
    ports:
      - "8080:8080"
    volumes:
      - ./config:/opt/domoticz/userdata
    environment:
      - TZ=Europe/Amsterdam
      #- LOG_PATH=/opt/domoticz/userdata/domoticz.log
to add a plugin, I did following
cd /opt/domoticz/config/plugins
git clone https://github.com/stas-demydiuk/domoticz-zigbee2mqtt-plugin.git zigbee2mqtt
docker restart domoticz
This worked for me, and plugin is available and working
However, to add a theme, following did NOT work
cd /opt/domoticz/config/www/styles
git clone https://github.com/domoticz/machinon.git machinon
QUESTION
Where do I have to place my themes to get them available in domoticz?
kind regards,
Bart Plessers
DAVIZINHO
Post by DAVIZINHO »
i find a solution but probably is not the best solution.
I map a folder in my local called themes and maped to the folder /themes2 in the container.
enter in the container and COPY all the files of origintal themes folder to my /themes2 folder
stop the container
change the maped folder and now my local themes maped to the original route in the container /themes
Now the themes folder are visible out of the container and you can put your personal themes and domoticz detect it
antonlamers
Domoticz version: 2021.1
Post by antonlamers »
Yesterday I did update the container.
Now is the screen view from everyting wrong
Version: 2021.1 (build 13689)
Build Hash: d29a27ffe
Compile Date: 2021-10-05 08:15:57
dzVents Version: 3.1.8
Python Version: 3.7.3 (default, Jan 22 2021, 20:04:44) [GCC 8.3.0]
Last edited by antonlamers on Wednesday 06 October 2021 12:17, edited 1 time in total.
Greating,
Anton
Version: 2023.2
Build Hash: 19efd039c
Compile Date: 2023-07-21 17:23:44
Python Version: 3.9.2 (default, Feb 28 2021, 17:03:44) [GCC 10.2.1 20210110]
DAVIZINHO
Post by DAVIZINHO »
same for me, i think its a cache failure. but i not have time to clear it in the brower and test again
antonlamers
I don't think it's a cache failure, because it's also on the phone and other computers
Greating,
Anton
Version: 2023.2
DAVIZINHO
Post by DAVIZINHO »
still have this problem in 13703
Try with browser in incognito/privacy mode. If it works you have to clear your browser cache (see my signature for a link to the instruction)
DAVIZINHO
Post by DAVIZINHO »
waltervl wrote: Saturday 09 October 2021 22:12 Try with browser in incognito/privacy mode. If it works you have to clear your browser cache (see my signature for a link to the instruction)
same problem for me in incognito/privacy mode with various browsers
Are you using the default theme as some custom theme like machinon and aurora were not working anymore due to a change in theme processing. If you are on default theme then this change is not docker compatible it seems.
DAVIZINHO
Post by DAVIZINHO »
waltervl wrote: Sunday 10 October 2021 0:35 Are you using the default theme as some custom theme like machinon and aurora were not working anymore due to a change in theme processing. If you are on default theme then this change is not docker compatible it seems.
I use default theme in docker
I made a note in Github issue https://github.com/domoticz/domoticz/issues/4960
Could be the same issue...
Please note that you can now also use Stable 2021.1 in docker (although I do not know how to load that)
https://hub.docker.com/r/domoticz/domoticz/tags
DAVIZINHO
Post by DAVIZINHO »
waltervl wrote: Thursday 14 October 2021 16:05 Please note that you can now also use Stable 2021.1 in docker (although I do not know how to load that)
in synology when you download the image, you can select the stable tag. the latest is the beta.
where do you use docker?
I do not use docker, just bringing the news.....
As the developer of the new tags is not documenting it I hope someone here knows how to use this :-)
The documentation is on Github https://github.com/domoticz/domoticz-docker
