(TIP) Increase reception RFXcom433
DomoticaRob
Domoticz version: V4.9700
Re: (TIP) Increase reception RFXcom433
Post by DomoticaRob »
Perhaps it's an idea that the guys of RFXCom look to a new version with more HF power.
Or some hardware to place behind the RFXCom to amplify the power so that you still can use the RFXCom we all have. I think that most of us use the RFXCom as a transmitter and less as a receiver.
b_weijenberg
Post by b_weijenberg »
The RFXtrx transmits already 10mW and it is not allowed to use a higher RF output power.
RFXtrx433, RFXtrx433E, RFXtrx433XL, RFX433XL, RFX868XL
freijn
Domoticz version: Stable
Post by freijn »
Increasing power is much less effective than having a better antenna or a better position of the antenna.
Also with too much power you will get reflections which will result in negative behaviour.
Imagine, in the good old days I have ( radio amateur ) talked to the UK with a 100mw transmitter !
Perfect antenna's and perfect conditions. But mention it for you to get an understanding about 10mw just @ home...
Gerwin
Post by Gerwin »
The receiver standing in de middle of the house the signal works but only for a meter of 5 ,I have already a antenna that's recommended that it should be a bigger reach but nothing is working .
Have someone any idea what I can do
b_weijenberg
Gerwin, I've sent you a PM. The range should be higher under normal conditions.
freijn
Post by freijn »
Gerwin,
Look for other equipment that might generate 'noise' of iron plates shielding the signal.
Make the receiver turn 90 deg , so different position. 5 mm left or right might make a difference.
Same for the transmitting antenna, turn / move and pay attention to for example central heating pipes or iron door frames.
Have a look on the path between those devices and see whats in between. Also, your neighbours could have a device generating noise.
capman
Post by capman »
Gerwin
Post by Gerwin »
Freijn.
Ik try this evening tot place the antenne in a other place .i know that te central heating pipe is verry close to the antenne thanks for this advice
Ik let You know
Gerwin
Post by Gerwin »
Great morning .
I put the antenne on a other place and what a difference
Buy i dont had enough time to test
Buy it looks better
Gerwin
freijn
Post by freijn »
Gerwin wrote: Thursday 17 January 2019 6:40 Buy it looks better
Gerwin
Hope you fix it now :-)
Gerwin
Post by Gerwin »
it looks better ,
its running now for 2 days ,i have placed the antenna to another place far away from the central heating pipe( it was verry close 10 cm ) and more central in the house
everything in the house is working now ,thank a lot for the advice
sorry for my late response but i was in the hospital
freijn
Post by freijn »
Gerwin,
Good to hear you have better results now.
Hope you recover well from your hospital visit! Having Domotica in the home ,means all in control, even when you are not there :-)
azonneveld
Domoticz version: 2024.4
Post by azonneveld »
To improve the transmission and reception of the RFXCom, the RFXcom manual suggests the following:
"Install this antenna on a metal plate of at least 30 cm for optimum result."
Page 61: http://www.rfxcom.com/WebRoot/StoreNL2/ ... _Guide.pdf
The theory behind this, is called counterpoise (wiki)
Make sure the antenna's ground, has a good connetion with the metal plate:
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe - open weather map - wol - BBQ detection - rsync backup
