Page 5 of 9
Re: Harmony support, new hardware?
Posted: Monday 03 November 2014 23:24
by Yihaaa
Confirmed. I am also still using the old method. It just works and I see no need to move to the new method.
Posted: Tuesday 04 November 2014 8:02
by markk
I'm running Domoticz on windows so I don't think I can use the old method
Might be time to install Domoticz on a Pi!
Posted: Tuesday 04 November 2014 11:45
by gb160
Yihaaa wrote:Confirmed. I am also still using the old method. It just works and I see no need to move to the new method.
The old method is perfectly reliable but lacks the functionality to update domoticz if activity changes are initiated via the harmony remote.its not a big deal but it's a nice function.
In the old harmony thread someone posted a script which gives this functionality however the script has to run on a loop so can increase the load on the pi quite significantly, depending in the frequency of the loop.
It works, but it's not perfect.
Posted: Wednesday 05 November 2014 9:53
by gizmocuz
make sure you enabled 'accept new hardware devices' before adding the harmony, or enabled it, disable/enable the harmony hardware.
Just added a new activity some days ago, forgot about it in domoticz, checked just now, and its already there
Posted: Wednesday 05 November 2014 10:49
by gb160
gizmocuz wrote:make sure you enabled 'accept new hardware devices' before adding the harmony, or enabled it, disable/enable the harmony hardware.
Many thanks for your hard work (and @codeitaway) and this tip in particular....as a beginner of all things Domoticz i had no idea this option even existed!
So far good news, my harmony activities are successfully added, the log no longer gets filled with errors, one slight issue from my end:
I can switch between activities ok, but can't power off....
Is there anything i need to do or should this be automatic ?
Im running 2096 on a Pi.
Posted: Wednesday 05 November 2014 10:51
by markk
@gizmocuz, you are an absolute genius
I disabled the "accept new hardware" last week because I kept picking up loads of byron SX devises
All working perfectly again now
Posted: Sunday 07 December 2014 11:17
by gb160
Hi..im getting errors when using the native support...causing my hub to lock up completely, i can only use the hub again after restarting domoticz, when this occurs i can't even use my harmony remote.
The issue is similar to the original problems on the pi....
My log shows...
2014-12-07 10:07:57 Harmony Hub: Too many commands missed. Resetting connection.
2014-12-07 10:08:00 Hardware Monitor: Fetching data (System sensors)
2014-12-07 10:08:04 Harmony Hub: Authentication succesfull
2014-12-07 10:08:30 Hardware Monitor: Fetching data (System sensors)
2014-12-07 10:08:32 Harmony Hub: Too many commands missed. Resetting connection.
2014-12-07 10:09:00 Error: Harmony Hub hardware (14) thread seems to have ended unexpectedly
2014-12-07 10:09:00 Hardware Monitor: Fetching data (System sensors)
2014-12-07 10:09:27 Harmony Hub: Authentication succesfull
2014-12-07 10:09:30 Hardware Monitor: Fetching data (System sensors)
2014-12-07 10:09:33 Harmony Hub: Too many commands missed. Resetting connection.
2014-12-07 10:10:00 Error: Harmony Hub hardware (14) thread seems to have ended unexpectedly
2014-12-07 10:10:00 Hardware Monitor: Fetching data (System sensors)
2014-12-07 10:10:27 Harmony Hub: Authentication succesfull
2014-12-07 10:10:30 Hardware Monitor: Fetching data (System sensors)
2014-12-07 10:10:33 Harmony Hub: Too many commands missed. Resetting connection.
2014-12-07 10:10:54 Incoming connection from: 192.168.1.42
2014-12-07 10:11:00 Hardware Monitor: Fetching data (System sensors)
2014-12-07 10:11:00 Error: Harmony Hub hardware (14) thread seems to have ended unexpectedly
I haven't changed my harmony hub configuration recently in any way.
It can happen three or four times in a day, or can sometimes go a few days without happening at all.
@CodeItAway any ideas what could be causing this ? its an excellent feature but I've had to disable it because of this problem.
Im running v2.2145 on a Pi.
Posted: Tuesday 16 December 2014 20:46
by gb160
Anyone else experiencing this?
id love to have my native harmony control back
Posted: Sunday 04 January 2015 11:34
by markk
I'm getting the following message: "Logitech web service login failed"
I can't be sure but it seems to have been since I flashed my RFX433 to FW v81. Was working perfectly beforehand.
Anyone else experiencing the same or can offer and explanation/advice please?
Posted: Sunday 04 January 2015 13:25
by mbtr
It's still working for me, even after installing beta build 2.2187. I haven't flashed (new) RFXCom firmware but I don't believe the RFXCom is reponsible for communication (it's through web services). Make sure the password is correct, 'Login failed' suggests that's where the problem is.
Posted: Sunday 04 January 2015 15:24
by markk
Thanks for your reply. The password is definately correct. I'm stumped.
Posted: Sunday 04 January 2015 16:22
by Yihaaa
Pull out all electricity cables etc and make a fresh start up?
Posted: Sunday 04 January 2015 17:14
by markk
Do you mean on the Harmony Hub? I've rebooted that, still the same. I thought the IP of the hub may have changed but that is still the same too.
Posted: Monday 05 January 2015 23:42
by markk
How odd. As a last resort I downgraded my RFXCom firmware back to FW v71, rebooted everything and the Harmony Hub authenticated and logged in perfectly straight away.
Posted: Thursday 08 January 2015 14:52
by Mooky
I have domoticz 2187 + pi + harmony hub + RFX v69.
Login OK, activities show up and turn on OK.
But turning off doesnt't work also for me.
Posted: Thursday 08 January 2015 15:03
by markk
Mooky wrote:I have domoticz 2187 + pi + harmony hub + RFX v69.
I got round this by adding "all off" as an activity on the Harmony hub. This then appears in your devices and can be added to Domoticz to turn everything off when pressed.
Posted: Thursday 08 January 2015 16:35
by Mooky
markk wrote:Mooky wrote:I have domoticz 2187 + pi + harmony hub + RFX v69.
Thanks for the advice, I'll try that when I get home.
But isn't that why the "Harmony Off" device (automatically created) is made for ?
Maybe I chose the wrong type, I set it up as a "Push Off button". Is that correct ?
Posted: Thursday 08 January 2015 19:19
by markk
Use that one and set it up as a push on button. That should work.
Posted: Friday 09 January 2015 19:58
by Mooky
markk wrote:Use that one and set it up as a push on button. That should work.
Yay it works !
Thank you very much
Posted: Saturday 10 January 2015 16:07
by pipari
Hi Guys!
Ordered the Logitech Harmony Ultimate yeasterday and got some questions.. hope someone have the answers!
Is it possible to turn off / on switches in domoticz with the remote (through the harmony hub)?
Anyone that could take som screenshoots or maybe a video? is trying to do as much as possible before the device is at my door!
Best regards
