Can you try latest version? (0.3.1)Vollervo wrote: Monday 20 May 2024 13:04 FYI: today I played around a bit more with the plugin for the local API and it seems that the actual status of the curtains is only updated every 30*180 seconds and that's a bit too slow for me. If you use touch and go or dzVents to do something with the curtains, the curtains' status is not reflected correctly in the UI for a long period. So, I changed that 180 to 20. Now the status is updated every 10 minutes.
def onHeartbeat(self): if self.hb == 20: Domoticz.Debug("onHeartbeat called") self.getAllSlidesInfo() self.hb = 1 else: self.hb = self.hb + 1
Python plugin: Slide by Innovation in Motion
Lokonli
Re: Python plugin: Slide by Innovation in Motion
Hi Lokonli,
That works just fine.
Vollervo
Vollervo
JeroenL
- Domoticz version: 2023.2
Dear Lokonli, all,
My slide system (local) was working fine for some years. However it was on Buster and I just upgrade to Trixie / Docker.
Now my plugin does not work anymore.
I see 2 locations here on the forum and am a little lost.
The plugin in the config/plugin directory seems to be the one picked up in "Hardware".
Also, re-cloned with into the plug-in directory.
No success. Error message below. Anyone a clue / hint?
Thanks a million.
Jeroen
/opt/domoticz/config/plugins/slide-domoticz-local
and
/opt/domoticz/userdata/plugins/slide-domoticz-local
Thanks a million.
Jeroen
2025-12-22 15:42:50.576 Status: Slide curtain: Started.
2025-12-22 15:42:50.576 Status: Slide curtain: Entering work loop.
2025-12-22 15:42:51.345 Error: Slide curtain: (iim-slide-local) failed to load 'plugin.py', Python Path used was '/opt/domoticz/userdata/plugins/slide-domoticz-local/:/usr/lib/python311.zip:/usr/lib/python3.11:/usr/lib/python3.11/lib-dynload:/opt/venv/lib/python3.11/site-packages:/opt/venv/local/lib/python3.11/dist-packages:/opt/venv/lib/python3/dist-packages:/opt/venv/lib/python3.11/dist-packages'.
2025-12-22 15:42:51.350 Error: Slide curtain: Traceback (most recent call last):
2025-12-22 15:42:51.350 Error: Slide curtain: File "/opt/domoticz/userdata/plugins/slide-domoticz-local/plugin.py", line 62, in <module>
2025-12-22 15:42:51.350 Error: Slide curtain: from goslideapi import GoSlideLocal
2025-12-22 15:42:51.350 Error: Slide curtain: File "/opt/domoticz/userdata/plugins/slide-domoticz-local/goslideapi.py", line 3, in <module>
2025-12-22 15:42:51.350 Error: Slide curtain: import aiohttp
2025-12-22 15:42:51.350 Error: Slide curtain: ModuleNotFoundError: No module named 'aiohttp'
- Domoticz version: 2026.3
Domoticz docker expects the plugin (internally) in /opt/domoticz/userdata/plugins/slide-domoticz-local
This could be outside the container in for example ./config/pugins/slide-domoticz-local
This depends on your docker-compose.yml configuration of your volumes.
Any requirements/python modules for a plugin need to be installed inside the container, see also https://wiki.domoticz.com/Docker#Python_Plugins
JeroenL
Dear Walter, thanks for pointing me into this direction. It now works
Thanks a lot & I can now close my curtains for the X-mas dinner...
rgds Jeroen
rgds Jeroen
