Dashticz v3.2.0 beta
madradrakie
Re: v3.2.0 beta
Post by madradrakie »
Lokonli wrote: Friday 22 November 2019 22:16
madradrakie wrote: Tuesday 19 November 2019 20:57
Lokonli wrote: Monday 18 November 2019 22:51
What was your previous version?
The previous version was 3.1.2. It looks like the graphs shows a value which is given by Domoticz every 5 minutes. But the x-axes shows a value every minute. In the previous version the graph only showed a value every 5 minutes and that is probably why the bars appeared bigger?
I think that is the reason indeed. It might be a side effect of the latest version of the chart.js module that is being used.
You can modify the x-axis behavior by adding the following to the block definition:
    options: {
        scales: {
            xAxes: [{
                    distribution: 'series'
Probably I'll will make this default in the next beta release.
problem solved, thanks again!
Lokonli
Re: v3.2.0 beta
Post by Lokonli »
madradrakie wrote: Tuesday 19 November 2019 21:53
Lokonli wrote: Monday 18 November 2019 22:58
madradrakie wrote: Monday 18 November 2019 22:25 and another question. After updating to the new version two of my buttons (which i use for hyperlinks to another slide) are very big. I can not find the problem.
This is the part of the code i always used.
buttons.p1 = {key: 'Scenes', width:3, icon: 'fas fa-home', title: 'Home',slide:1 }
buttons.p2 = {key: 'Beneden', width:2, btnimage: 'img/favicon/largetile.png', title: 'P.2',slide:2 }
buttons.p3 = {key: 'Boven', width:2, btnimage: 'img/favicon/largetile.png', title: 'P.3',slide:3 }
buttons.p4 = {key: 'Energie', width:3, icon: 'fas fa-bolt', title: 'Power',slide:4 }
buttons.p5 = {key: 'Water', width:3, icon: 'fas fa-shower', title: 'Water',slide:5 }
buttons.p6 = {key: 'Muziek', width:2, btnimage: 'img/favicon/largetile.png', title: 'P.6',slide:6 }
Which buttons are bigger? What do you mean with very big?
In beta v3.2.0 the default size of button titles was changed. You can change it via custom.css. Probably:
.dt_title {
	font-size: 100%;
your solution worked but the buttons have a different height than for example my scenes or light buttons (see image). Also the text is shown right from the icon instead of beneath. Is it possible to adjust these things in for example the css file? Do you know how? I have searched the forum but could not find the solution yet.
For all special blocks that are using the new template the title is rendered right of the icon by default.
If you want to render the title below the icon you can add the following to custom.css:
.button {
    flex-direction: column;
    min-height: 85px;
A Domoticz device block normally has a height of 85 pixels (small devices: 75 pixels). With the min-height parameter you set the minimal height, In the previous example the button minimal height is set to the size of the domoticz blocks.
If you only want to change the rendering for a specific button you have to add the key parameter to your button definition, and use the following in custom.css:
[data-id='mykey'].button {
unclekoen
Re: v3.2.0 beta
Post by unclekoen »
EdwinK wrote: Saturday 09 November 2019 12:27 I only get the dashticz v3 is loading thingy, then everything went black :(
Update: I'ts working again. Needs to do some changes though.
Having the same problem with my tablets. Still using v3.1.2 Master. What did you do? See also: https://www.domoticz.com/forum/viewtopi ... 00#p229200
EdwinK
Re: Dashticz v3.2.0 beta
Post by EdwinK »
I just rebooted the device Dashticz is running on (A synology nas).
pvklink
Domoticz version: latest b
Post by pvklink »
Is there a way to get the buttons (off, smoke, beweging....) right of the title?
Jablotron connection, Ikea
HansieNL
Post by HansieNL »
pvklink wrote: Wednesday 27 November 2019 20:55 Is there a way to get the buttons (off, smoke, beweging....) right of the title?
Not sure if there’s a hard break, but otherwise you can try:
block_438 br:nth-child(2) {
   display: none
If you size your block
height: 100%
than everything will fit in the block.
Blah blah blah
madradrakie
Re: v3.2.0 beta
tarmacalastair wrote: Tuesday 12 November 2019 0:52 Sorry, but I think I've found some more bugs in 3.2.0 beta that were working fine in 3.1.0
When I try to create a menu as per https://dashticz.readthedocs.io/en/beta ... ide-button:
The documentation says, "If you use a button to slide to specific screen (menu button), then the background colour of that button will change if that specific screen is active" - Unfortunately, the colour of the button does not change in this version - also, adding this in the custom.css file does nothing:
.selectedbutton {
  background-color: #cba !important;
For the setting:
config['slide_effect'] = 'flip'; //(or 'slide' or 'fade', etc)
only slide seems to work now.
Thanks for all your hard work.
is the fade function already fixed?
Lokonli
Re: v3.2.0 beta
Post by Lokonli »
madradrakie wrote: Saturday 30 November 2019 20:54
.selectedbutton {
For the setting:
Yes! Fixed in latest beta :)
madradrakie
i can confirm that the fade function is working again!
Thanks again!
pvklink
Post by pvklink »
hi,
i added a original rpi 7inch touch screen(800*480) to my network and i like to use dashticz on it.
Dashticz works more then perfect on my pc.
Problems i have:
- no swiper
- second page is not shown
(for this test i only have two dummy switches 1, 2)
I did add config params for swiper
custum.css
/* png met paint 3d gemaakt
  https://fontawesome.com/icons?d=gallery&m=free
  https://htmlcolorcodes.com/ maroon navy
  met f12 kan je in het tabblad network disable cache aanvinken zodat de nieuwe image wordt geladen...daarna weer aanzetten
  https://www.rapidtables.com/web/color/html-color-codes.html
  https://dashticz-v2.readthedocs.io/en/latest/customcss/customcss.html#block-titles
  https://www.w3schools.com/
.fa-chromecast.on {color: gold;}
.fa-chromecast.off {color: lightgrey;}
.fa-cloud-showers-heavy.on {color: blue !important;}
.fa-cloud-showers-heavy.off {color: lightgrey !important;}
.fa-cloud-sun-rain {color: lightgrey !important;}
.fa-shower.on {color: blue !important;}
.fa-shower.off {color: lightgrey !important;}
.fa-snowflake.on {color: blue;}
.fa-snowflake.off {color: lightgrey;}
.fa-users.on {color: gold !important;}
.fa-users.off {color: lightgrey !important;}
.fa-sun.on {color: gold !important;}
.fa-sun.off {color: gold !important;}
.fa-moon.on {color: gold !important;}
.fa-moon.off {color: gold !important;}
.fa-user-clock.on {color: gold !important;}
.fa-user-clock.off {color: lightgrey !important;}
.fa-lightbulb.on {color: gold;}
.fa-lightbulb.off {color: lightgrey;}
.fa-tasks.on {color: gold;}
.fa-tasks.off {color: lightgrey;}
.fa-history.on {color: gold;}
.fa-history.off {color: lightgrey;}
.fa-glass-cheers.on {color: gold;}
.fa-glass-cheers.off {color: lightgrey;}
.fa-bed.on {color: gold;}
.fa-bed.off {color: lightgrey;}
.fa-toggle-on.on {color: gold;}
.fa-toggle-on.off {color: lightgrey;}
.fa-redo-alt.on {color: gold;}
.fa-redo-alt.off {color: lightgrey;}
.fa-utensils.on {color: gold;}
.fa-utensils.off {color: lightgrey;}
.fa-dove.on {color: gold;}
.fa-dove.off {color: lightgrey;}
.fa-newspaper {color: lightgrey;}
.fa-video {color: lightgrey;}
.fa-microchip {color: lightgrey;}
.fa-trash.on {color: gold;}
.fa-trash.off {color: lightgrey;}
.fa-tree.on {color: gold;}
.fa-tree.off {color: lightgrey;}
.fa-fire.on {color: lightgrey !important;}
.fa-fire.off {color: lightgrey !important;}
.fa-hdd.on {color: gold;}
.fa-hdd.off {color: lightgrey;}
.fa-music.on {color: lightgrey;}
.fa-music.off {color: lightgrey;}
.fa-battery-full.on {color: gold;}
.fa-battery-full.off {color: lightgrey;}
.fa-camera.on {color: lightgrey;}
.fa-camera.off {color: lightgrey;}
.fa-print.on {color: gold;}
.fa-print.off {color: lightgrey;}
.fa-tint.on {color: gold;}
.fa-tint.off {color: lightgrey;}
.fa-temperature-low.on {color: gold;}
.fa-temperature-low.off {color: lightgrey;}
.fa-power-off.on {color: lightgrey;}
.fa-power-off.off {color: gold;}
.fa-phone-volume.on {color: red;}
.fa-phone-volume.off {color:green;}
.fa-desktop.on {color: red;}
.fa-desktop.off {color: green;}
.fa-laptop.on {color: red;}
.fa-laptop.off {color: green;}
.fa-tablet-alt.on {color: red;}
.fa-tablet-alt.off {color: green;}
.fa-gamepad.on {color:red;}
.fa-gamepad.off {color:green;}
.fa-tv.on {color:red;}
.fa-tv.off {color:green;}
.fa-bell.on {color: red !important;}
.fa-bell.off {color: green !important;}
.fa-smoking.on {color: red !important;}
.fa-smoking.off {color: green !important;}
.fa-exclamation-triangle.on {color: red !important;}
.fa-exclamation-triangle.off {color: green !important;}
.fa-id-card {color: green !important;}
.fa-id-card.on {color: red !important;}
.fa-id-card.off {color: green !important;}
.fa-door-open.on {color: green;}
.fa-door-closed.off {color: red;}
.fa-shield-alt.on {color: red !important;}
.fa-shield-alt.off {color: green !important;}
div[data-id='nu'] {height: 85px;}
div[data-id='streamplayer'] {height: 85px;}
/* opmaak blokken speciaal calenders */
div[data-id='calendars.dvpeter'] {height: 150px;}
div[data-id='calendars.dvpeter'] .items {height: 100%;overflow-y: auto;}
div[data-id='calendars.dvado'] {height: 343px;}
div[data-id='calendars.dvado'] .items {height: 100%;overflow-y: auto;}
div[data-id='calendars.dvf1'] {height: 300px;}
div[data-id='calendars.dvf1'] .items {height: 100%;overflow-y: auto;}
div[data-id='calendars.dvfam'] {height: 170px;}
div[data-id='calendars.dvfam'] .items {height: 100%;overflow-y: auto;}
/* opmaak blokken speciaal ziggo met title tvguide.dutch zetten*/
div[data-id='ziggo'] {height: 342px;}
.tvguide {height: 100%;overflow-y: auto;}
/* opmaak blokken speciaal clock, sunrise, weather */
div[data-id='clock'] {height: 150px;width:237px}
div[data-id='sunrise'] {height: 150px;width:237px}
/* opmaak blokken speciaal garbage                   div[data-id='garbage'] {background-color: rgba(87, 64, 56, 1) !important;} */
div[data-id='garbage'] {height: 120px;width: 240px;}
div[data-id='garbage'] .items {height: 100%;overflow-y: auto;}
/* opmaak blokken speciaal news are set in the corresponding block news_nualg in custom.js */
[data-id='news_nualg'].news .dt_title {height:25px} /* this only works if the block has a title in custom.js */
[data-id='news_nualg'].news .col-data {height: 100%;overflow-y: auto;} /* this only works if the block has a title in custom.js */
[data-id='news_nusp'].news .col-data {height: 100%;overflow-y: auto;} /* this only works if the block has a title in custom.js */
[data-id='news_nusp'].news .dt_title {height:25px} /* this only works if the block has a title in custom.js */
/* opmaak weather niet nodig */
/* div[data-id='currentweather_big'] {background: none !important;} */
div[data-id='currentweather_big'] {height: 85px !important;}
/* div[data-id='weather_owm'] {height: 250px !important;} WERKT NIET */
/* inputnumber thermostat */
.input-number {font-size: 12px !important}
/* Make the background of the titleblocks less high */
.transbg.titlegroups {height: 50px;padding: 0px;font-size: 12px;}
.transbg[class*="col-xs"] {border-radius: 20px;}                             /* Rounded corners */
/* general titleblocks
.colbar {background-color: rgb(66, 29, 25) !important; color: white !important;}*/
.titlegroups {background-color: rgb(119,110,97) !important; color: white !important;}
.blocktitle .dt_title {height: 25px;padding: 0px;font-size: 18px;color: white;}
/* Swiper
.swiper-pagination-bullet {width: 0px;height: 0px;}
.swiper-pagination-bullet {width: 35px !important;height: 35px !important;}
.swiper-pagination {text-align: right !important;} */
.far,.fas,.wi {
   font-size:30px !important;
config.js
var config = {}
config['domoticz_ip'] = 'http://<deleted  ip:port>';
config['user_name'] = 'admin';
config['pass_word'] = 'xxxxx';
config['app_title'] = 'xxx';
config['room_plan'] = '0';
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = '30';
config['default_cors_url'] = '';
config['dashticz_php_path'] = './vendor/dashticz/';
config['standby_call_url'] = '';
config['standby_call_url_on_end'] = '';
config['theme'] = 'default';
config['background_image'] = 'img/bg3.jpg';
config['standby_after'] = '0';
config['auto_swipe_back_to'] = '';
config['auto_swipe_back_after'] = '';
config['auto_slide_pages'] = '';
config['slide_effect'] = 'slide';
config['standard_graph'] = 'hours';
config['blink_color'] = '255, 255, 255, 1';
config['language'] = 'nl_NL';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM.YYYY HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['calendarurl'] = '';
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = '';
config['gm_zoomlevel'] = '';
config['gm_latitude'] = '';
config['gm_longitude'] = '';
config['speak_lang'] = 'nl-NL';
config['wu_api'] = '';
config['wu_city'] = 'Amsterdam';
config['wu_name'] = '';
config['wu_country'] = 'NL';
config['owm_api'] = 'ad2f8b7da8481b3bf02ad443947e7c21';
//config['owm_city'] = 'Rijswijk';
config['owm_city'] = 2748075;
config['owm_name'] = 'Rijswijk (zh)';
config['owm_country'] = 'nl';
config['owm_lang'] = 'nl';
config['owm_cnt'] = '5';
config['owm_days'] = 1;
config['owm_min'] = 0;
config['idx_moonpicture'] = '';
config['longfonds_zipcode'] = '';
config['longfonds_housenumber'] = '';
config['switch_horizon'] = '';
config['host_nzbget'] = '';
config['spot_clientid'] = '';
config['sonarr_url'] = '';
config['sonarr_apikey'] = '';
config['sonarr_maxitems'] = '';
config['garbage_company'] = 'avalex';
config['garbage_icalurl'] = '';
config['google_api_key'] = '';
config['garbage_calendar_id'] = '';
config['garbage_zipcode'] = '2286MA';
config['garbage_street'] = 'Cornelia Schellingerlaan';
config['garbage_housenumber'] = '11';
config['garbage_housenumberadd'] = '';
config['garbage_maxitems'] = '12';
config['garbage_width'] = '6';
config['setpoint_min'] = '5';
config['setpoint_max'] = '40';
config['loginEnabled'] = 0;
config['disable_update_check'] = 0;
config['no_rgb'] = 0;
config['auto_positioning'] = 0;
config['use_favorites'] = 0;
config['disable_googleanalytics'] = 0;
config['last_update'] = 1;
config['hide_topbar'] = 0;
config['security_button_icons'] = 0;
config['edit_mode'] = false;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 0;
config['hide_mediaplayer'] = 0;
config['garbage_icon_use_colors'] = 1;
config['garbage_use_colors'] = 1;
config['garbage_use_names'] = 1;
config['garbage_use_cors_prefix'] = 1;
config['vertical_scroll'] = 0;
config['enable_swiper'] = 2;
//Configuring the OWM parameters https://home.openweathermap.org/api_keys   locatie-id 2748075 of 76
config['garbage_mapping'] = {
    rest: ['grof', 'grey', 'rest', 'grijs','grijze'],
    gft: ['gft', 'tuin', 'refuse bin', 'green', 'groen', 'Biodégradables', 'snoei'],
    pmd: ['plastic', 'pmd', 'verpakking', 'kunststof', 'valorlux'],
    papier: ['papier', 'blauw', 'blue', 'recycling bin collection'],
    kca: ['chemisch', 'kca','kga'],
    brown: ['brown', 'verre'],
    black: ['black', 'zwart'],
    milieu: ['milieu'],
    kerstboom: ['kerst'],
config['garbage'] = {
    gft: {kliko: 'green', code: '#FFFFFF', name: 'GFT (groene bak)', icon: 'img/garbage/kliko_green.png'},
    pmd: {kliko: 'orange', code: '#FFFFFF', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
    rest: {kliko: 'grey', code: '#FFFFFF', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
    papier: {kliko: 'blue', code: '#FFFFFF', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
    kca: {kliko: 'red', code: '#FFFFFF', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
    brown: {kliko: 'brown', code: '#FFFFFF', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'},
    black: {kliko: 'black', code: '#FFFFFF', name: 'Zwart', icon: 'img/garbage/kliko_black.png'},
    milieu: {kliko: 'yellow', code: '#FFFFFF', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'},
    kerstboom: {kliko: 'green', code: '#FFFFFF', name: 'Kerstboom', icon: 'img/garbage/tree.png'},
var frames = {}
deleted
var calendars = {}
deleted
var tvguide = {}
	tvguide.dutch = {key:'ziggo',title:'Ziggo', icon: 'fas fa-tv', width:12, channels: [1,2,3,4,31,36,37,34,466,420], maxitems: 20 }
var buttons = {}
	buttons.nunl	= {key:'nu', width:4, icon: 'fas fa-newspaper', title: 'Nu.nl', url: 'http://www.nu.nl'}
// BLOKKEN
var blocks = {}
blocks['news_nualg']	= {title: 'Nu.nl (algemeen)', feed: 'http://www.nu.nl/rss/algemeen', maxheight: 150}
blocks['news_nusp']	= {title: 'Nu.nl (sport)', feed: 'http://www.nu.nl/rss/sport', maxheight: 150}
blocks[1]	= {title: 'test1', hide_data: true, width: 12}									//, speakOn: 'Lantaarn is aan', speakOff: blocks[2]	= {title: 'test2', hide_data: true, width: 12}									//, speakOn: 'Lantaarn is aan', speakOff:
// KOLOMMEN clock
var columns = {}
columns[1] = {blocks: ['currentweather_big_owm','weather_owm'], width: 8}
columns[2] = {blocks: [1], width: 4}
columns[3] = {blocks: [2,calendars.fam,'garbage'], width: 6}
columns[4] = {blocks: ['clock','sunrise',calendars.ado,calendars.f1], width: 6}
columns[5] = {blocks: ['news_nualg','news_nusp',tvguide.dutch,1472], width: 12}
// SCHERMEN
var screens = {}
screens['default'] = {}
screens['default']['maxwidth'] = 800;
screens['default']['maxheight'] = 480;
// 720 bij 480 werkt niet en 640 bij 480 ook niet
screens['default'][1] = {}
screens['default'][1]['background'] = 'bg1.jpg';
screens['default'][1]['columns'] = [1,2]
screens['default'][2] = {}
screens['default'][2]['background'] = 'bg1.jpg';
screens['default'][2]['columns'] = [3,4]
screens['default'][3] = {}
screens['default'][3]['background'] = 'bg1.jpg';
screens['default'][3]['columns'] = [5]
jake
Post by jake »
pvklink wrote:hi,
Problems i have:
- no swiper
After updating last weekend from Dashticz 3.1 to 3.2 I had the same experience, even after adding the new necessary swiper enable parameter. I finally solved it by emptying the browser cache on the tablet (app settings in Android)
pvklink
Post by pvklink »
mm, i did with f5, perhaps f5 (chrome) is not enough..
I did a more cleanuo with f12, still no pages and sliders
perhaps something wrong in my css or js
toro
Post by toro »
I updated from 3.1.2 to 3.3.3
Most is fixed, changed button images to btnimage etc.
But now, I can’t get my camera image showing in a larger size.
It’s a button on screen 4, if someone is at the door is slides to this screen.
Touching it, or after 10 seconds, it slides back to screen 1.
The camera image is not a real stream, it updates every second.
I changed the size in custom.css but it is probably not the best way to do this. It was just trial and error and it worked for the older version.
CONFIG.js
buttons.webcam = {width:12, isimage:true, refreshimage:2000, forcerefresh: true, image: 'http://192.168.1.150:8888/shotDoorBig.jpg?nocache=<?php echo time(); ?>',refreshurl: 2000, forcerefresh: true, slide:0}
columns[11] = {}
columns[11]['blocks'] = [buttons.webcam]
columns[11]['width'] = 12;
screens[4] = {}
screens[4]['background'] = '../dashticz/custom/img/bgZwartPaars02.jpg';
screens[4]['columns'] = [11]
F12 console of the buttons:
//v3.1.2
<div id="block_41">
	<div class="col-xs-12 hover  transbg buttons-41 slide slide0" data-id="buttons.41">
		<img id="buttonimg_41" style="max-width:100%;" src="./vendor/dashticz/nocache.php?http://user:[email protected]:443/tmpfs/auto.jpg">
	</div>
</div>
//v3.3.3
<div id="block_44" div="" <="">
	<div class="transbg col-xs-12 button dt_block hover">
		<div class="dt_content">
			<div class="dt_state">
				<img style="max-width:100%;" src="./vendor/dashticz/nocache.php?http://user:[email protected]:443/tmpfs/auto.jpg">
			</div>
		</div>
	</div>
</div>
custom.css
#buttonimg_41 {
	height:650px !important;
	max-width: 300% !Important;
Camera image big and small.jpg (27.78 KiB) Viewed 1688 times
Lokonli
Post by Lokonli »
The class definitions indeed changed a bit from 3.1.2 to 3.3.3.
The easiest way is as follows:
Add a 'key' parameter to your button definition to be able to uniquely identify your button:
buttons.webcam = {width:12, isimage:true, refreshimage:2000, forcerefresh: true, image: 'http://192.168.1.150:8888/shotDoorBig.jpg?nocache=<?php echo time(); ?>',refreshurl: 2000, forcerefresh: true, slide:0,
key:'webcam'}
Then add the following to custom.css to set a fixed width:
[data-id='webcam'] img {
   width: 600px;
Don't forget to rename image to btnimage in your CONFIG.js (Your CONFIG.js seems to be incorrect ...)
toro
Post by toro »
Lokonli, thank you very much! This works like a charm.
I tried so many things and couldn’t get it to work, but you make it seem so easy ;-)
You are right about the btnimage. I already did change it, but copied the old version here by mistake.
Thanks again for your quick reply and good solution!
