GoodWe Solar: get data from the new semsportal (lua script)
pvdgulik
Domoticz version: 2023.1
Re: GoodWe Solar: get data from the new semsportal (lua script)
Post by pvdgulik »
I added in the calculation script the following, which takes the W from the
After reading out the powergeneration out of the device in:
PowerGeneration, EnergyGeneration = otherdevices_svalues[GenerationDeviceName]:match("([^;]+);([^;]+)")
Add:
PowerGeneration=PowerGeneration:sub(0,-2)
This resolved the problem for me.
uermend
Domoticz version: 4.10055
Post by uermend »
hi,
I have updated the script to get output power, temperature of the inverter, output voltage, output current etc.
output_power = getValue(splitString, "output_power")
last_refresh_time = getValue(splitString, "last_refresh_time")
eDay = getValue(splitString, "eDay")
work_mode = getValue(splitString, "work_mode")
temperature = getValue(splitString, "tempperature")
stroom = getValue(splitString, "output_current")
spanning = getValue(splitString, "output_voltage")
print("last_refresh_time :" .. last_refresh_time)
print("output_power :" .. output_power)
print("eDay :" .. eDay)
print("work_mode :" .. work_mode)
print("temperature :" .. temperature)
print("stroom :" ..stroom)
print("spanning :" ..spanning)
current = tonumber(stripchars(output_power, "pv:(W)"))
dayTotal = tonumber(stripchars(eDay, "sum:"))*1000
temp = tonumber(temperature)
UpdateDevice(sensorSolarPanels, current..";"..dayTotal)
I see these vallues in the log but I do not get them into Domoticz.
I think I have to change the UpdateDevice commands and cannot get it working.
can someone help me with this?
Regards,
Sander
I'm running Domoticz V4.10055 in a docker image on Raspi3
sandeman684
Post by sandeman684 »
It seems GoodWe has (again) changed something but, at least for me, the script is no longer working. Instead of the JSON data, I now get the HTML of the login page. Anybody any ideas on how to fix this?
supergroover
Post by supergroover »
sandeman684 wrote: Friday 15 November 2019 8:46 It seems GoodWe has (again) changed something but, at least for me, the script is no longer working. Instead of the JSON data, I now get the HTML of the login page. Anybody any ideas on how to fix this?
I'm using the PHP version from @sinze and this no longer works for me either.
Rensticar
Domoticz version: Stable
Post by Rensticar »
Same problem since wednesday 13 november 2:45
bldewit
Post by bldewit »
Same here, nov.13.....
Running on rPi 4b (main) and rPi 3b (somfy), both RFLink
IthoRemote, Xiaomi Gateway, KAKU
sjoemie1985
Post by sjoemie1985 »
i have also some problem i think.
i see the following error in my domoticz system, any one who knows how to solve it.
or has this also to do with the problems you all got?
2019-12-03 10:49:44.809 Error: (Semsportal): Async Secure Read Exception: 1, stream truncated
CrazyFrog
Post by CrazyFrog »
Sorry I've been very busy for a while.
I picked up this issue again today and expect next week
post a new working script here.
At this moment I already have extract the data from the site, now I just have to strip it and pass it on to domoticz.
Just be patient
CrazyFrog
Post by CrazyFrog »
sandeman684, supergroover, Rensticar, bldewit, sjoemie1985
hereby a new script.
-- Created by Raymond Wiertz
-- DateTime: 2020-02-13
-- Tracking your token
-- To find out your token, you must execute the CURL command below from the command line.
-- curl -d 'account=[LOGINNAME]&pwd=[PASSWORD]&code=' https://www.semsportal.com/Home/Login;
local UserName = ""
local Password = ""
local token = ""
local refresh_time = 180 -- secondens
local sensorSolarPanels = "solar panels" -- name of your
-- get login token
local loginCommand = string.format("curl --silent --output /dev/null --cookie-jar - -c cookie.txt -d 'account=%s&pwd=%s&code=' https://www.semsportal.com/Home/Login",UserName,Password)
-- get data from site
local getDataCommand = string.format("curl -b cookie.txt -d 'str={\"api\":\"v1/PowerStation/GetMonitorDetailByPowerstationId\",\"param\":{\"powerStationId\":\"%s\"}}&s=v1/PowerStation/GetMonitorDetailByPowerstationId' 'https://www.semsportal.com//GopsApi/Post?s=v1/PowerStation/GetMonitorDetailByPowerstationId'",token)
i=1
function isempty(s)
  return s == nil or s == ''
function getExecuteCommand(command)
  local f = assert(io.popen(command, 'r'))
  s = assert(f:read('*a'))
  f:close()
  return s
function stripchars(str, chrs)
    local s = str:gsub("["..chrs:gsub("%W","%%%1").."]", '')
    return s
function getValue(value, searchString)
   local response = ""
   searchString = string.format("%q", searchString)
   dummy, startPos = string.find(value, searchString )
   if not(startPos == nil) then
      dummy, endPos = string.find(value, ",", startPos)
      response = string.sub(value, startPos, endPos-1)
      response = string.gsub(response, ":", "")
      response = string.gsub(response, "\"", "")
      response = string.gsub(response, " ", "")
   return response
function timedifference(s)
    year    = string.sub(s, 1, 4)
    month   = string.sub(s, 6, 7)
    day     = string.sub(s, 9, 10)
    hour    = string.sub(s, 12, 13)
    t1 = os.time()
    t2 = os.time{year=year, month=month, day=day, hour=hour, min=minutes,sec=seconds}
    return difference
function UpdateDevice(device, data)
    idx = otherdevices_idx[device]
    if (idx == nil) then
        print('** Unknown device'..device)
        commandArray[i] = {['UpdateDevice'] = idx..'|0|'..data}
        i = i+1
difference = timedifference(otherdevices_lastupdate[sensorSolarPanels])
if (difference > refresh_time) then
    getExecuteCommand(loginCommand)
    local data = getExecuteCommand(getDataCommand)
--print(data)
    if (isempty(data) == false) then
        output_power = getValue(data, "output_power")
        last_refresh_time = getValue(data, "last_refresh_time")
        eDay = getValue(data, "eDay")
        current = tonumber(stripchars(output_power, "kwhKWH"))
        dayTotal = tonumber(eDay)*1000
hopefully the script will continue to work in the near future.
Have fun with it.
Last edited by CrazyFrog on Monday 24 February 2020 12:15, edited 1 time in total.
sandeman684
CrazyFrog wrote: Thursday 20 February 2020 22:51 sandeman684, supergroover, Rensticar, bldewit, sjoemie1985
Have fun with it.
Thanks a lot.
I had to add i=1 to get it working, but now it works fine.
CrazyFrog
Post by CrazyFrog »
sandeman684 wrote: Saturday 22 February 2020 16:49
Have fun with it.
Thanks a lot.
Hello sandeman684
why did you have to put this variable, the code does not use this variable?
Could you indicate where you have placed this declaration so that other users can take it over when referenced.
Thank you in advance for the information.
sandeman684
CrazyFrog wrote: Monday 24 February 2020 9:27
sandeman684 wrote: Saturday 22 February 2020 16:49 I had to add i=1 to get it working, but now it works fine.
I got an error at the following line:
Adding i=1 here:
i=1
solved this.
CrazyFrog
Post by CrazyFrog »
sandeman684 wrote: Monday 24 February 2020 9:50
Adding i=1 here:
i=1
solved this.
:D tx.
oops forgotten with copy-past :?
I have update the code above.
Gruzi
Post by Gruzi »
Thanks for the script CrazyFrog, if functions well overhere!
However, it causes an error in my log file about one time per hour:
2020-02-28 07:35:10.354 Error: EventSystem: Warning!, lua script SolarPanels has been running for more than 10 seconds
Is there a way to increase the timer for script?
CrazyFrog
Post by CrazyFrog »
yes you can, but with an update it is set back to 10 seconds
sandeman684
It seems there is still an issue with the daily production. Very often a value is used for two consecutive days, as you can see in the image. The correct values should be:
Tue 7.2
Wed 2.4
Thu 1.7
Fri 6.2
Sat 5.6
Sun 6.4
Mon 2.7
Tue 0.3
So, often the value of the previous day is used, but not always.
EDIT: it seems like the previous day is used when its value is larger than the current day value.
Gruzi
Post by Gruzi »
Same behaviour here.
Values should be (checked on Sems portal) :
Wed - 5.8
Thu - 2.4
Fri - 8.6
Sat - 9
Sun - 13.2
Mon - 4.5
Tue - 20.5
It is also remarkable that today Wed is already filled in with 20.5
Gruzi
Post by Gruzi »
@CrazyFrog @Sandeman684
I investigated further and I think that the problem Sandeman684 and I have is not caused by the script from Crazyfrog.
The script is giving Domoticz the right values for Power and Energy (I created logfiles over the day) but Domoticz doesn't process them well.
This seems a more common problem from the sensor Electric (Instant and Counter) and I found another post on the forum where I have reported this.
See my post:
https://www.domoticz.com/forum/viewtopi ... 73#p241673
Trigun
Domoticz version: 4.10717
Post by Trigun »
Hi Sincze,
I used your PHP script but I am getting a fatal Curl error which leaves the output.errors blank and also No feedback in the domoticz log.
this is the output:
PHP Fatal error:  Uncaught Error: Call to undefined function curl_init() in /home/pi/domoticz/scripts/pass2php/goodwe-inverter.php:66
Stack trace:
#0 /home/pi/domoticz/scripts/pass2php/goodwe-inverter.php(40): retrieve_goodwe_data('test')
#1 {main}
  thrown in /home/pi/domoticz/scripts/pass2php/goodwe-inverter.php on line 66
Stack trace:
#1 {main}
  thrown in /home/pi/domoticz/scripts/pass2php/goodwe-inverter.php on line 66/code]
  just the be sure:
  entering my username and password, is the actual Semsportal login, correct?
 thnx in advance!
hvolkers
Post by hvolkers »
hi
i tried to use the LUA scripts (2 versions) but both do not work
first of all the request to get the TOKEN must be wrong as I got back "0" as an answer on two different accounts within the Semsportal
where is the token used for?
the LUA script is giving errors while checking under raspbian os
Lua 5.1.5 Copyright (C) 1994-2012 Lua.org, PUC-Rio
lua: script_device_SEMS Portal.lua:82: attempt to index global 'otherdevices_lastupdate' (a nil value)
stack traceback:
script_device_SEMS Portal.lua:82: in main chunk
[C]: ?
who is able to help me out?
kind regards
Henri
