Domoticz Google Assistant integration with node-red Easy Free Controlicz alternative!
Alexa, Google Home and Siri
Re: Domoticz Google Assistant integration with node-red Easy Free Controlicz alternative!
salvacalatayud wrote: Tuesday 11 February 2020 19:26 Is there any way to add temperature and thermostat setpoint to your script?
Yes but not very easy and the next update of the temperatures will send the new MQTT message anyway so would there be an added value ?
salvacalatayud
Post by salvacalatayud »
waaren wrote: Wednesday 12 February 2020 17:41
Yes, it works, no problem
FireWizard
Post by FireWizard »
This post will show the flow and a short description.
The input to the json node comes from the MQTT input node, which has subscribed to domoticz/out.
No changes are required for this node.
The node, called "Filter Dimmer" filters all topics, which are not a Dimmer. You might want to change that, but as long as you use the same hardware it is not required.
In order to convert RGB values to HSV values, I created a function node that arranges the RGB values, so that the RGB>HSV node can convert it.
For both nodes, no changes are required.
The output of the RGB>HSV convert node is joined with the original flow.
No changes for the join node are required.
The next node is a Function node, that prepares the data, so that the nora node can handle it.
No changes are required.
The next node before the nora node is the switch node.
You have to configure, as many outputs, as you have MiLight lamps and give them your IDX numbers, so that they are routed to the correct nora node.
Regarding the nora node, you should configure it to your need with the right topic (IDX number) and tick all the boxes, except "If msg arrives on input, pass through to output:"
If everything is correctly configured, it is possible to control the nora node from Domoticz.
You will see that in the text below the node.
Next step is the right side of the nora node. The output to Domoticz.
From the nora node we have to change the HSV values back to RGB values.
So in order to convert HSV values to RGB values, I created a function node that arranges the HSV values, so that the HSV>RGB node can convert it.
For both nodes, no changes are required. Be aware that the box after "Scale Sat/Bri/Val" is ticked.
The output of the HSV>RGB convert node is joined with the original flow.
The next node is a Function node, that prepares the data, so that Domoticz can handle it.
Finally we go to a the json node and the output connects to the MQTT output node, which has subscribed to domoticz/in.
Feel free to implement it and to test it with real MiLight.
Best regards
FireWizard
Please find attached the flow:
[{"id":"8b9fe124.3e6fb8","type":"nora-light","z":"f01779c8.cd1ec","devicename":"Slaapkamerlamp","lightcolor":true,"brightnesscontrol":true,"turnonwhenbrightnesschanges":true,"passthru":false,"statepayload":true,"brightnessoverride":"","roomhint":"Slaapkamer","name":"Slaapkamerlamp","nora":"6f52ea33.833a2c","topic":"332","onvalue":"true","onvalueType":"bool","offvalue":"false","offvalueType":"bool","x":1150,"y":780,"wires":[["73400cd3.d7c65c","9961fafb.4f1698"]]},{"id":"170e5319.3f606d","type":"json","z":"f01779c8.cd1ec","name":"","property":"payload","action":"","pretty":false,"x":150,"y":780,"wires":[["2528055.8fdd3fa"]]},{"id":"bd209b8.55e9b68","type":"function","z":"f01779c8.cd1ec","name":"Function In ","func":"msg.topic = msg.payload[0].idx;\nif (msg.payload[0].nvalue !== 0)\n{\n    msg.payload = {\n        on : true,\n        brightness : msg.payload[0].Level,\n        color : {\n            spectrumHsv : {\n                hue : msg.payload[1].red,\n                saturation : msg.payload[1].green/100,\n                value : msg.payload[1].blue/100\n            }\n        }\n    }\n}\nelse if (msg.payload[0].nvalue === 0)\n{\n    msg.payload = {\n        on : false,\n        brightness : msg.payload[0].Level,\n        color : {\n            spectrumHsv : {\n                hue : msg.payload[1].red,\n                saturation : msg.payload[1].green/100,\n                value : msg.payload[1].blue/100\n            }\n        }\n    }\n}\nreturn msg;","outputs":1,"noerr":0,"x":730,"y":780,"wires":[["3fd178cf.d784"]]},{"id":"3fd178cf.d784","type":"switch","z":"f01779c8.cd1ec","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"1170","vt":"str"},{"t":"eq","v":"1171","vt":"str"},{"t":"eq","v":"1172","vt":"str"},{"t":"eq","v":"332","vt":"str"}],"checkall":"true","repair":false,"outputs":4,"x":910,"y":780,"wires":[[],[],[],["8b9fe124.3e6fb8"]]},{"id":"c678f72c.24a2c8","type":"function","z":"f01779c8.cd1ec","name":"Function Out","func":"var idx = parseInt(msg.topic);\nif ( msg.payload[0].on === true )\n{\n    msg.payload = {\n        \"command\" : \"setcolbrightnessvalue\",\n        \"idx\" : idx,\n        \"color\" : {\"m\":3,\"t\":0,\"r\":msg.payload[1].red,\"g\":msg.payload[1].green,\"b\":msg.payload[1].blue,\"cw\":0,\"ww\":0},\n        \"brightness\": msg.payload[0].brightness\n    };\n}\nelse if ( msg.payload[0].on === false )\n{\n    msg.payload = {\n        \"command\": \"switchlight\",\n        \"idx\": idx,\n        \"switchcmd\": \"Off\"\n        \n    };\n}\nreturn msg","outputs":1,"noerr":0,"x":1560,"y":780,"wires":[["20adf7d9.b1ec7"]]},{"id":"20adf7d9.b1ec7","type":"json","z":"f01779c8.cd1ec","name":"","property":"payload","action":"","pretty":false,"x":1750,"y":780,"wires":[["c14522c5.76fc68"]]},{"id":"c14522c5.76fc68","type":"debug","z":"f01779c8.cd1ec","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1930,"y":780,"wires":[]},{"id":"a9526656.b39dc8","type":"color-convert","z":"f01779c8.cd1ec","input":"rgb","output":"hsv","outputType":"object","scaleInput":false,"x":570,"y":840,"wires":[["6d505be6.981bac"]]},{"id":"2528055.8fdd3fa","type":"filter","z":"f01779c8.cd1ec","name":"Filter Dimmer","property":"payload.switchType","propertyType":"msg","asArray":false,"itemProperty":"","itemPropertyType":"item","rules":[{"t":"eq","v":"Dimmer","vt":"str","output":1}],"checkall":"true","outputs":1,"x":340,"y":780,"wires":[["963f3ce8.6fbc1","6d505be6.981bac"]]},{"id":"963f3ce8.6fbc1","type":"function","z":"f01779c8.cd1ec","name":"Create RGB Array","func":"msg.payload = {\n    red : msg.payload.Color.r,\n    green : msg.payload.Color.g,\n    blue : msg.payload.Color.b\n};\nreturn msg;","outputs":1,"noerr":0,"x":350,"y":840,"wires":[["a9526656.b39dc8"]]},{"id":"6d505be6.981bac","type":"join","z":"f01779c8.cd1ec","name":"","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":550,"y":780,"wires":[["bd209b8.55e9b68"]]},{"id":"49751c0a.4c20b4","type":"color-convert","z":"f01779c8.cd1ec","input":"hsv","output":"rgb","outputType":"object","scaleInput":true,"x":1370,"y":840,"wires":[["9961fafb.4f1698"]]},{"id":"73400cd3.d7c65c","type":"function","z":"f01779c8.cd1ec","name":"Create HSV Array","func":"msg.payload = {\n    hue : msg.payload.color.spectrumHsv.hue,\n    saturation : msg.payload.color.spectrumHsv.saturation,\n    value : msg.payload.color.spectrumHsv.value,\n};\nreturn msg;","outputs":1,"noerr":0,"x":1150,"y":840,"wires":[["49751c0a.4c20b4"]]},{"id":"9961fafb.4f1698","type":"join","z":"f01779c8.cd1ec","name":"","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1370,"y":780,"wires":[["c678f72c.24a2c8"]]},{"id":"6f52ea33.833a2c","type":"nora-config","z":"","name":"Nora Config","group":"","notify":true}]
Last edited by FireWizard on Wednesday 12 February 2020 20:53, edited 1 time in total.
EvJd
Post by EvJd »
Thanks a lot you all for helping me! I will give it a try this weekend, cause I see a lot of information and it won't be something I can do in 1 night. But wow how great you want to help me and invest so much time in explaining how everyting works!
I have till 15th of march before Kappelt gBridge shuts down, so I am convinced I will find the sollution before than!
Again, thanks a lot!!!
salvacalatayud
FireWizard wrote:This post will show the flow and a short description.
Best regards
Tested and working, thanks
The only problem is that my lights are rgbw, and I loose the white part...
Enviado desde mi Mi A2 mediante Tapatalk
FireWizard
Hello @salvacalatayud
Do you mean cw (cool white) and ww (warm white) So the temperature color (oK)?
As far as I know it is not implemented yet, but if someone knows what to send to the nora node, it is probably a small step.
See: https://github.com/andrei-tatar/node-re ... /issues/12
FireWizard
IMPORTANT FOR ALL USERS
If you receive multiple messages from NORA elements in Node Red: "socket connection error: not authorized",
you need to update the token in Node-RED with a new one from https://node-red-google-home.herokuapp.com/
Also, you need to unlink NORA (in your Google Home app) and link it again.
This should solve the problem that Google Assistant cannot find NORA.
EvJd
Post by EvJd »
Thanks so much! It works like a charm to change color and set my milights on and off! Only brightness controlls misses, but that not a great thing. Thank you thank you thank you!!!!!
FireWizard wrote: Wednesday 12 February 2020 17:52 Please find attached the flow:
FireWizard
@EvJd
You wrote:
It works like a charm to change color and set my milights on and off! Only brightness controls misses
I do not understand this. Do you really mean brightness and not saturation?
As you know I do not have a real MiLight and the dimmer, I did setup was a virtual dimmer.
However, if I play with the buttons, slider and the color circle, I noticed on the texts below the NORA node, that they change accordingly.
The same happens, if I play with the slider and the colors in the Google Home App.
Also a Voice command, like (in Dutch) "OK, Google, Slaaplamer lamp, Helderheid 60%" functions correctly. The only thing, that I don"t see change is the value.
The only thing, I was not able to do, was to set the saturation by a Voice command. Probably this is just a matter of the right wordings.
Everything is fully synchronized between my virtual dimmer in Domoticz, Google Home, app, Voice commands and the text under the NORA node.
Is this the difference between a virtual dimmer and a real MiLight?
salvacalatayud
xury wrote:Take a look my nora usage and control switches, lights, Panasonic TV etc.:
As you see nora nodes are between domoticz/out and domoticz/in topics.
On the second screen is to control RGBCCT led strips using milight hub plugin https://www.domoticz.com/forum/viewtopic.php?t=27771
If someone interested I can share my flows, but before I have to make sure not leave any tokens etc.
I use more than 50 nora nodes.
I've just installed milight hub esp8266 now, and maybe your flows can be useful for me.
Thanks in avance
MikiG
Domoticz version: 15182
Post by MikiG »
Does anyone know how to integrate blinds into Node-red-contrib-Nora?
FireWizard
Hello
@MikiG
This should not be too difficult, as the information pane of the Nora node indicates only:
Experimental! Represents a Google Home Blinds.
Input payload can have one or more be of the following properties openPercent - number (0-100). represents how open the blinds are;
Output payload has the properties that can be changed from Google Home: openPercent - number (0-100). represents how open the blinds are;
You might want to read the following thread as well:
https://discourse.nodered.org/t/node-re ... ation/4829
This thread does not cover blinds only, but if you do a search on "blinds", you will find some valuable information.
Another link you might be interested in: https://www.npmjs.com/package/node-red- ... controller.
MikiG
Post by MikiG »
FireWizard wrote: Thursday 19 March 2020 14:48 Hello
@MikiG
salvacalatayud
MikiG wrote: Thursday 19 March 2020 13:17 Does anyone know how to integrate blinds into Node-red-contrib-Nora?
I've got them working, what do you need?
MikiG
Post by MikiG »
salvacalatayud wrote: Thursday 02 April 2020 11:16
Hello, I have the blinds with shelly 2.5 in Domoticz, and I wanted to control them by voice through node red in google home. I would like to control them all from the same flow
salvacalatayud
Here is my shutter function from domoticz to nora:
msg.topic = msg.payload.idx
var percent = 100 - msg.payload.svalue1
if (msg.payload.nvalue === 1)
    msg.payload = 100
else if (msg.payload.nvalue === 0)
    msg.payload = 0
else if (msg.payload.nvalue === 2)
    msg.payload.openPercent = percent
    return msg;
And this one from nora to domoticz:
var openPercent = 100 - msg.payload.openPercent
msg.payload = { "command": "switchlight", "idx": idx, "switchcmd": "Set Level", "level": openPercent };
return msg
Hope this helps
MikiG
Post by MikiG »
salvacalatayud wrote: Thursday 02 April 2020 17:25 Here is my shutter function from domoticz to nora:
    msg.payload = 100
    msg.payload = 0
    return msg;
return msg
Hope this helps
Thank you very much, it works perfect!!!
P.D. : He visto que eres de España, un saludo y muchas gracias en español
salvacalatayud
MikiG wrote: Thursday 02 April 2020 18:43
    msg.payload = 100
    msg.payload = 0
    return msg;
return msg
Hope this helps
Great!!!
Me alegra!!!
twoenter
Domoticz version: 4.10
Post by twoenter »
installed node-red on my synology nas
connection works with google
but I don't get connection with mosquitto. My ESPeasy clients connects without problems to domoticz via mqtt.
when i test some examples of mqtt to/from domoticz i get message:
3-4-2020 09:45:45node: test
msg : string[28]
"missing broker configuration"
and
3-4-2020 10:45:07node: localhost:1883
msg : error
"SyntaxError: Invalid regular expression: /(?:^|(?<=\s))(([0-9a-fA-F]{1,4}:){7,7}[0-9a-fA-F]{1,4}|([0-9a-fA-F]{1,4}:){1,7}:|([0-9a-fA-F]{1,4}:){1,6}:[0-9a-fA-F]{1,4}|([0-9a-fA-F]{1,4}:){1,5}(:[0-9a-fA-F]{1,4}){1,2}|([0-9a-fA-F]{1,4}:){1,4}(:[0-9a-fA-F]{1,4}){1,3}|([0-9a-fA-F]{1,4}:){1,3}(:[0-9a-fA-F]{1,4}){1,4}|([0-9a-fA-F]{1,4}:){1,2}(:[0-9a-fA-F]{1,4}){1,5}|[0-9a-fA-F]{1,4}:((:[0-9a-fA-F]{1,4}){1,6})|:((:[0-9a-fA-F]{1,4}){1,7}|:)|fe80:(:[0-9a-fA-F]{0,4}){0,4}%[0-9a-zA-Z]{1,}|::(ffff(:0{1,4}){0,1}:){0,1}((25[0-5]|(2[0-4]|1{0,1}[0-9]){0,1}[0-9])\.){3,3}(25[0-5]|(2[0-4]|1{0,1}[0-9]){0,1}[0-9])|([0-9a-fA-F]{1,4}:){1,4}:((25[0-5]|(2[0-4]|1{0,1}[0-9]){0,1}[0-9])\.){3,3}(25[0-5]|(2[0-4]|1{0,1}[0-9]){0,1}[0-9]))(?=\s|$)/: Invalid group"
The broker is configured correcty as I can see.
the flow is deployed and i can change the state of the switch from google home and see it changing in node red. Don't see a green bullit near the mqqt node.
Please help!
Check my Domoticz tutorials, ESP8266 and Synology blog at https://www.twoenter.nl/blog
