Page 5 of 7
Re: Python Plugin: Domoticz-Google-Plugin
Posted: Wednesday 22 April 2020 0:26
by tjabas
anyone got this plugin working?
the audio notifications works ony once.
or is there another similar working plugin?
Posted: Wednesday 22 April 2020 2:19
by Dnpwwo
@tjabas,
Audio works pretty well for me although because the audio is created on the internet sometimes timing is an issue.
Can you turn on debugging on the plugin and post the log?
Posted: Wednesday 22 April 2020 13:15
by tjabas
thank you for your answer, i havent got the plugin installed yet, but im thinking of install it again tonight, if it looks to be the timing issue you talked about, where can i change the setting for that?
Posted: Wednesday 13 May 2020 19:24
by jaaap
I got the plugin working, adding devices, and controlling volume of the casts. Very nice! However, I can't find any Play, Pause, Next buttons. Where are they located?
Posted: Sunday 07 June 2020 13:59
by tjabas
Hi!
is there a way to disable the plugin from searching for new devices?
i have a smart tv with chromecast built in, this chromecast in the tv i dont use, and the tv is only on for a couple of hours every night, the problem is that when i turn on the tv this google plugin sees the tv and ads the tv in domoticz, but when the tv is of i constantly get messages in the log that the tv is unavalible, can i disable this somehow?
Posted: Sunday 07 June 2020 16:31
by tjabas
Is there a way to change to another voice when google talks back?
i have it set to swedish, and that women sounds slightly retarded
Or how can i get the voice to speak English instead?
Posted: Tuesday 30 June 2020 13:42
by tjabas
is it possible to add several voice/devices?
so i can get the same spoken audio notification in several other google homes?
i have tried with a speakergroup i made in the google home app, its works for a while but the volume on each device included in the group i getting lower and lower after each voice notification, very strange
Posted: Wednesday 01 July 2020 15:26
by DewGew
This plugin seems not to support Google Nest Hub:
2020-07-01 15:16:59.811 Error: (Chromecast) Unsupported device type: 'Hall', Model: 'Google Nest Hub', UUID: '2078a80e-3b4c-e1b6-547e-126d7a185f15' + IP: '192.168.2.19:8009'
Posted: Friday 03 July 2020 15:09
by DAVIZINHO
Someone tested it on a docker container?
im trying but not discover any devices, maybe i make something wrong
Posted: Tuesday 07 July 2020 11:24
by Flappie
Does anybody know how to use this plugin?
I installed it, and it found my Google Home Mini.
How do i send a notification to my Home Mini with blockly? Can't get it to work.
And when i enable or disable the plugin under "Hardware", my whole Domoticz crashes....
Posted: Tuesday 07 July 2020 11:39
by mark.sellwood
I have the following issues with the plugin: -
When i enable or disable the plugin under "Hardware", my whole Domoticz crashes....
The plugin stops working after <24 hours, all the devices turn red
It only plays the first message then nothing
Long messages (over 5 - 6 words) are truncated, the mp3 file gets deleted while playing.
Posted: Tuesday 07 July 2020 11:53
by tjabas
i had the same problem, mine also chrashed and the spoken audio chrashed, but after i updated domoticz to the latest stable version it suddenly worked.
Posted: Tuesday 07 July 2020 12:04
by mark.sellwood
I only built mine last week so I'm using the latest :-
Buster image (May 2020)
Domoticz 2020.2
Python version 3.7.3
Posted: Tuesday 07 July 2020 12:18
by tjabas
mark.sellwood wrote: Tuesday 07 July 2020 12:04
Domoticz 2020.2
ok, then i dont know
Posted: Friday 17 July 2020 12:23
by tjabas
can i deactivate the automatic discovery of new devices somehow?
Posted: Monday 20 July 2020 12:17
by tjabas
has anyone else encountered this error in the log?
(google ) Invalid web request received, file '/home/pi/domoticz/plugins/Domoticz-Google-Plugin/Messages/4823bbe1-aaf8-3ed9-3a0b-20a7b5907208.mp3' does not exist
it has been working fine until a coulple of days ago.
Posted: Monday 20 July 2020 18:09
by DoMoAD
I've got multiple nest devices in my house. I made a speakergroup in de google home app and changed the setting voice device/group to the speakergroup.
When i send a notification i only hear the message on one device. Any suggestion? I've tested the devices separatly and then they work.
update: just played spotify to the speakergroup en changed de audio. Now it also works for the domoticz notifications.
Posted: Tuesday 21 July 2020 11:56
by markjgabb
hey all
trawling trhough the forum i cant seem to find any examples of how to put together a dzvents script that uses the notification
i can see where everyone says use notifications, but im not sure how this si done?
Posted: Tuesday 21 July 2020 12:00
by tjabas
sorry to say but this plugin has stopped working.
Posted: Tuesday 21 July 2020 12:06
by markjgabb
damn.... any good replacements?
