Alexa text to speech Topic is solved
Alexa, Google Home and Siri
salopette
Re: Alexa text to speech
Post by salopette »
i nideI need DE Account
Bradds
Post by Bradds »
Hi All
For people having cookie/captcha issues on headless systems, you could try https://github.com/jonferreira/node-red ... exa-remote
This node (for node-red) allows you to send speech to alexa and works fine.
To fill in the cookie window in the node config, do the following.
Connect to your alexa web page.
right click somewhere on the page and click inspect.
Click on the network tab.
Press f5
pick one of the name in the list
click on the header tab
scroll down to cookie ( if you do not see it click on another name)
copy all what is in here and paste it in the cookie section of the node-red node.
( note host : alexa.amazon.com (or whatever country link you use) and paste it to ''amazon page '' field of the node-red node
manutremo
Post by manutremo »
Just installed the script - wow great job. In my case I'm using spanish alexa at alexa.amazon.es. Everything seems to be working fine regarding launching the script, but whatever I ask it to say, alexa always says (in spanish) "Sorry I can't find an answer to your question".
If however I make her speak something like "Alexa connect bluetooth" she will respond as if I had given the order by talking.
In summary she seems to be taking the phrase after the -e speak: command as an order instead of as something she could just convert into speech and repeat.
My settings are:
LANGUAGE='es-ES'
AMAZON='amazon.es'
ALEXA='alexa.amazon.es'
Any idea?
dadogiobbe
Post by dadogiobbe »
the same here in italy...it looks like an order...
johansson
Post by johansson »
Great approach, would be perfect for e.g. temperature alerts or so. After a bit of fiddling the login issues were tackled and everything seems to in order, but the sound is missing.
When I do e.g.:
sudo ./alexa_remote.sh -d Echo -e speak:'Test'
I get as an output:
sending cmd:speak:Test to dev:ALL type:XXX serial:XXX customerid:
Sequence command: Alexa.Speak
{"message":null}
But no sound from any of my devices! Any ideas and/or advice how to solve this? Same applies to traffic announcements, TuneIn radio and so forth.
johansson
Post by johansson »
Solved. It was a cookie/login/whatever issue anyway: I used an extension called cookies.txt to copy the cookie into /tmp/alexa.cookie and now it's suddenly working.
darrepac
Post by darrepac »
johansson wrote: Friday 04 January 2019 21:40 Great approach, would be perfect for e.g. temperature alerts or so. After a bit of fiddling the login issues were tackled and everything seems to in order, but the sound is missing.
When I do e.g.:
I get as an output:
{"message":null}
I got the same when I was using a cookie from Chrome, once I used a cookie from Firefox, everything worked!
satanasinc
Domoticz version: 4.9700
Post by satanasinc »
Hi!
It works perfect in Spanish in my raspberry pi.
Thanx for share your workwithus. It’s great!
Greetings from Spain.
freijn
Domoticz version: Stable
Post by freijn »
I still have the problem that cookies expire after a while ( something like 2 weeks ? )
Anybody found this as well and know a solution?
Very unreliable announcements from Alexa :-(
EdddieN
Post by EdddieN »
Anyone managed to get all the Alexa devices to speak at once?
From the documentation this should work:
./alexa_remote_control.sh -d ALL -e speak:'hello'
Also changing the volume before speaking?
11101101 - www.machinon.com
nigels0
Domoticz version: 3.8153
Post by nigels0 »
I get them speaking in sequence, but timeout after 3 or 4 of them (I have about 10 devices around). Your options are correct
EdddieN
Post by EdddieN »
Same line? -d ALL ?
philchillbill
Post by philchillbill »
In the Alexa app you can setup 'routines' that can be triggered either by a custom voice command or by a smart home event. The result can be another smart home event or it can be a TTS action from Alexa (and these ones don't need cookies). There's an option to have it spoken from any of your echos. Might be worth checking out for people currently trying the Loetzimmer script and struggling.
They only work for devices correctly exposed as being of type CONTACT_SENSOR or MOTION_SENSOR and that proactively report state-changes. HA-Bridge exposes everything as a dimmable light as it fakes Philips Hue, so it won't work with HA-Bridge.
Last edited by philchillbill on Thursday 17 January 2019 9:29, edited 1 time in total.
EdddieN
Post by EdddieN »
Yes I got HA working fine. It is more I like to anoche things in all of the Alexa via the TTS. I got it working for individual ones but when I use the -d ALL does not seem to work, however the script runs ok.
sion
Post by sion »
Just wondering if people have this working reliably?
I worked for me for ages at the start.
Then stopped.
I tryed enabling 2 step, and put the code in the the script for the first go - then took the code out - and this worked for a few days, but stopped again.
I’m going to try and fix the cookie thing, but I don’t have a desktop etc on my pi, so it’s a bit of a job. I have a Mac mini running all the time, so I may have a go on that. But if we are having to redo the cookie every couple of weeks , I may Wait for another solution.
Thanks.
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
EdddieN
Post by EdddieN »
It works for me, although a bit slow...
I used the second script and jq
philchillbill
Works great for a few days until the cookie expires. PITA to have to renew it manually.
Hesmink
Post by Hesmink »
For anyone who has abandoned this because of the cookie thing: There is now support for 2 factor authentication, supposedly eliminating the re-logging in.
Check https://blog.loetzimmer.de/2017/10/amaz ... -echo.html
You have to enable 2 factor authentication at amazon and add another app that will do the 2 factor stuff on linux for you.
emme
Domoticz version: latest
Post by emme »
I use Alexa-Remote2 node in nodered.
works like a charm!!!!! :P :P
"We always done this way"
salopette
Post by salopette »
emme wrote: Monday 02 September 2019 17:13 I use Alexa-Remote2 node in nodered.
How can I install this? Is there a manual for domoticz?
