Page 5 of 15
Re: Low cost window/door sensor
Posted: Sunday 24 August 2014 0:53
by nmaster
Thank you Raspberry Piet.
I'll try one on these detector to see if it can work.
Posted: Sunday 24 August 2014 1:26
by Raspberry Piet
nmaster wrote:Thank you Raspberry Piet.
Keep us informed in this topic!
Posted: Monday 25 August 2014 0:07
by Thice
I created a small and simple Arduino based device and some code to be able to link any of these cheap 433Mhz devices to the RFXCOM & Domoticz.
All information can be found here: http://www.thice.nl/convert-cheap-433mh ... convertor/
Works really well here.
Posted: Sunday 21 September 2014 20:28
by roblom
I bought also some of the 2262 switches but due to the fact that it only sends on "Off" or only an "On" command. I thought this wouldn't be a problem because I thought this would be solvable with some blocky events. But it does not send only an "Off" signal but the switch is also on "Off" and stays "Off". Therefore you can create a blocky event but this gets into a loop (switch is set to "on" therefore it is set to "off" and that sets it to "on" etc.) or doesn't doe anything at all.
Somebody knows a solution to this?
Posted: Monday 22 September 2014 0:33
by nmaster
Just received this cheap smoke detector http://www.aliexpress.com/item/433MHz-3 ... 52593.html
It is detected like other 2262.
There is jumper to set 1.5 / 3.3 / 4.7 M and code.
Posted: Wednesday 24 September 2014 17:56
by sultanhq
decrxgarage wrote:I bought also some of the 2262 switches but due to the fact that it only sends on "Off" or only an "On" command. I thought this wouldn't be a problem because I thought this would be solvable with some blocky events. But it does not send only an "Off" signal but the switch is also on "Off" and stays "Off". Therefore you can create a blocky event but this gets into a loop (switch is set to "on" therefore it is set to "off" and that sets it to "on" etc.) or doesn't doe anything at all.
Set an "off delay" for 10 seconds in the switch settings. that' how I use mine
Posted: Thursday 25 September 2014 22:29
by roblom
Can you post a screenshot?
Posted: Monday 29 September 2014 11:44
by sultanhq
Posted: Wednesday 01 October 2014 22:05
by roblom
I have it working now but there is some strange thing in the blocky.
I named the PT2262 switch "Signaalgever - 01" and added a switch off delay of 1 second.
Signaalgever - 01
Signaalgever - 01
Signaalgever - 01.jpg (69.58 KiB) Viewed 7859 times
Then I created a virtual sensor called "Schakelaar - 01"
Schakelaar - 01
Schakelaar - 01
Schakelaar - 01.jpg (57.48 KiB) Viewed 7859 times
With this 2 I created a event.
Blocky
Blocky
Blocky test.jpg (101.88 KiB) Viewed 7859 times
This works but the thing I think is a bug is the "Schakelaar - 01" must be "On" or "Open" but i have to set them to "On" or "Off". So if i change in the above "Open" to "On" and "Closed" to "Off" it doesn't work anymore.
Posted: Thursday 02 October 2014 9:43
by mbliek
I think that schakelaar - 01 must be contact instead of door lock as switch type.
Posted: Sunday 05 October 2014 14:24
by roblom
mbliek wrote:I think that schakelaar - 01 must be contact instead of door lock as switch type.
That's possible but the PT2262 switch is connected to a door so thats why I used the doorswitch. Nevertheless is works but not as I expected because the state is "Open" and it must be set with a "On" command.
Posted: Sunday 05 October 2014 14:35
by mbliek
But a door lock is a electric lock on the door.
So On means door locked and open means door unlocked.
The switch type contact is an magnetic contact that detects if the door is open or closed.
Posted: Wednesday 24 December 2014 22:36
by ThinkPad
I also received this cheap sensor today.
In my case it only sends an 'on' signal. I put the off delay at 5 seconds. If yours only sends 'off', create an 'on' delay ;)
You can then create an event like this:
IF doorcontact = on AND lamp1 = Off
DO SET lamp1 = On FOR 5 minutes
Mine has an PT2264 chip, and is recognized as 'Lighting4', subtype 'PT2262'.
I have the jumper on the yellow place like in this picture: http://i58.tinypic.com/16j3grc.jpg (and also the jumper in the left corner, and the 3M3 jumper).
Posted: Tuesday 30 December 2014 17:20
by Dountill
I cant find my door sensor in Domoticz. Any idea?
- Latest version Domoticz
- Lightning checked on "set mode"
- New Battery
- Allowed to find new hardware
- Red led works.
- Tried 2 new batterys
Posted: Tuesday 30 December 2014 17:38
by Heisenberg
It should work.
What does your log say? Is there a new device recognized like this:
Tue Dec 30 17:27:10 2014 (RFXtrx433E) Lighting 4 (Unknown)
If not then try to set your jumper (a1h) to the lower pins
Posted: Tuesday 30 December 2014 17:51
by Raspberry Piet
Got a 315Mhz version instead of 433Mhz?
(Check printed text on top of the metal saw filter)
Posted: Tuesday 30 December 2014 18:45
by Dountill
Raspberry Piet wrote:Got a 315Mhz version instead of 433Mhz?
There it is. R315A :(
Posted: Wednesday 31 December 2014 16:24
by ThinkPad
Ouch! :(
Fortunately they aren't very expensive :)
Posted: Thursday 01 January 2015 19:46
by Dountill
I already contacted banggood, i ordered the 433 version, so it's not my fault. Anyway, i also ordered 2 others from eBay to play with :)
Posted: Friday 02 January 2015 22:59
by Heisenberg
Is the problem that you've posted here solved yet?: http://www.domoticz.com/forum/viewtopic.php?f=28&t=4740
