Re: Meek Wifi Wall Switch
Posted: Wednesday 09 January 2019 19:18
Meek have 3 models : 1, 2 or 3 switches modules. You can config evrry switch separate inside the webgui. So if you have 1 old switch and replace this one with one of the new once, it's up to you... Add more switches in same wall location. Or buy 1 switch module for every old switch. I have the MP1 for testing and love it.Thuis wrote:I can not see how it will look, if you would have 3 or more holes in the wall, next to each other, and replace 3 switches, which will be in a frame that goes with the switches and is brand specific, with 3 of the meek switches next to each other in the 3 holes, is there any frame ? And what are the dimensions of the switch?Meek wrote: Friday 09 November 2018 19:40 Herewith a small update:
We’ve finalized the development of the Meek MT2 & Meek MT3. These are Wi-Fi enabled dual or triple touch input and dual or triple SSR output switches.
Next week, we will assemble the Meek DDDboard. This is a unit with pre-installed Wi-Fi enabled Doorbell & DSMR compatible P1 smart meter reader input & Development board.
• Doorbell – This will be a Wi-Fi enabled & (arguably) the most flexible doorbell module. It can be used parallel to the existing doorbell or as a standalone module or in mixed mode.
• DSRM/P1 – has an inbuilt P1 port that can be attached to a smart meter to read the Electricity & Gas usage and send this data thru Wi-Fi to a monitoring system like Domoticz.
• Development board – most GPIO pins of the ESPS12 unit are made available to use to do some easy development. Also I2C ports are made external to attached compatible devices.
Next week, I hope to assemble the first alpha board to do some more testing. Once assembled I will report back with a small update.
We’re still searching for partners that can provide us the dual and triple socket wall panels. We have received some samples and are now in discussion with a few potential candidates! Hopefully we can sort things out so we can place every household switch for a Meek variant![]()
Program the switch and create some cool scripts to use it. Or use it as regular on/off switch to on/off bulbs wired.
Verzonden vanaf mijn iPhone met Tapatalk Pro
