Page 5 of 5
Re: Nuki lock setup
Posted: Monday 06 June 2022 16:14
by rgroothuis
I purchase the door sensor with the lock. You need to have the door sensor to be able to detect if the door is open or not.
Alternatively, you could check the lock status, if the lock status is open it means that the door is (being) opened. That should also work in my view.
Re: Nuki lock setup
Posted: Monday 06 June 2022 20:08
by xKingx
Thanks again. Yeah older versions of the lock did come with a door sensor. Colleague of mine has that version too. But for the newer version they are sold seperately. OK, will see if I can get it from the lock or need the sensor!
Re: Nuki lock setup
Posted: Monday 03 August 2026 14:14
by llbrt
I created a Nuki bridge integration plugin based on pynuki. Here is the repository: https://github.com/llbrt/DomoticzNukiBridge
I have only an old smart lock (without door sensor) and a bridge, but it should work with several bridges, lock sensors and openers.
It works fine for me with the latest stable version 2026.3
I'd be happy to have some feebacks or suggestions, especially about the support of openers.
If you have a working setup, you may still try it on a separate new Domoticz instance.
