Page 5 of 5
Re: Dashticz - Custom CSS
Posted: Thursday 27 February 2020 10:47
by Lokonli
That is indeed an enhancement I'm looking into how to implement.
In the mean time, most blocks can be identified using the Domoticz device id they use:
if your Domoticz device id is 379, then class 'block_379' is applied to the block. So you can style in custom.css with:
.block_379 {
    background: yellow !important;
For most special blocks you can add the 'key' parameter. Example:
If you've added the parameter key: 'buienradar' to a button block definition, then you can select this button in custom.css with:
[data-id='buienradar'].button {
Then you don't have to change your styling when you add/remove blocks ...
Posted: Thursday 27 February 2020 10:55
by flemm
Thanks for your reply!
That is indeed the method i'm using now. But because i use different 'kinds' of blocks, all with normal, hover and active states and also a day- and night mode, the list becomes quite large. A custom class, 'stat-block, or 'switch-block' for example, would result in a lot dryer and easier to maintain code. Now, when a block IDX changes or i add a block, i have to edit that for all the specified style selectors. So, definately a +1 from me for this possible feature :D
Posted: Saturday 21 November 2020 20:04
by Vondee
I moved from Dashticz version 2 to version 3, but I struggling to get the text correct in the blocks on my Ipad.
On my Ipad version 2 look like:
Text place well within the blocks.
In Dashticz version 3 first I had to make the icons smaller by:
far,.fas,.wi {
  font-size:15px;
But the text keeps to the right.
I tried to shift the text more to the left by:
.title {
    margin-left: -15px !important;
But the text on row 2 and 3 keeps to the right where it will have issues on other blocks
Any idea how I can move all rows further to the left and having more characters on one line?
Attached css file:
CUSTOM CSS FILE
.far,.fas,.wi {
  font-size:15px;
.fas.fa-lightbulb.on {color: yellow}
.fas.fa-door-open.on {color: red}
.fas.fa-unlock.on {color: red}
.fas.fa-desktop.on {color: yellow}
.far.fa-hdd.on {color: yellow}
.fas.fa-bullseye.on {color: yellow}
.fas.fa-music.on {color: yellow}
.fa.fa-warning.on {color: red}
.fas.fa-rss-square.on {color: yellow}
.fas.fa-battery-half.on {color: yellow}
.fas.fa-bed.on {color: yellow}
.fas.fa-female.on {color: green}
.fas.fa-male.on {color: green}
.fas.fa-power-off.on {color: yellow}
.fas.fa-podcast.on {color: yellow}
.far.fa-snowflake.on {color: yellow}
.fas.fa-home.on {color: yellow}
.far.fa-moon.on {color: yellow}
.fas.fa-bolt.off {color: red}
.fas.fa-leaf.on {color: yellow}
.fas fa-seedling.on {color: yellow}
.fas.fa-exclamation-triangle.on {color: red}
.fas.fa-wifi.on {color: yellow}
.fas fa-tint.on {color: yellow}
.fas fa-bolt.off {color: red}
.fas fa-bolt.on {color: grey}
.fas.fa-car.on {color: yellow}
.fas.fa-car.off {color: grey}
.far fa-snowflake.on {color: yellow}
.fa.fa-fire.on {color: yellow}
.fas.fa-car.CLOSED {color: yellow}
.fas.fa-car.OPEN {color: grey}
/*.fa-info-circle:before{color: yellow} */
.transbg.col-xs-1, .transbg.col-xs-2, .transbg.col-xs-3, .transbg.col-xs-4, .transbg.col-xs-5, .transbg.col-xs-6,
.transbg.col-xs-7, .transbg.col-xs-8, .transbg.col-xs-9, .transbg.col-xs-10, .transbg.col-xs-11,
.transbg.col-xs-12
	padding-top:15px;
	padding-bottom:15px;
	border: 3px solid rgba(0,0,0,0);
	background: rgba(0,0,0,0.7);
	background-clip:
	padding-box;
	border-radius: 20px;
/* Transparent background for buttons Thermostat */
.input-groupBtn .btn-number {
    opacity: 0.5;
    color: white;
    background-color: rgb(34, 34, 34);
    border-radius: 0px;
    padding: 6px 10px 6px 10px;
    line-height: 20px;
    background-color: transparent;
/* Height of the blocktitles and center text in new height */
div.mh.titlegroups {
    height: 60px !important;
    padding-top: 3px !important;
/* Hoogte van Weather_owm */
.weatherfull > .transbg {
  height: 170px !important;
  white-space: nowrap !important;
.title {
    font-size:13px;
.clock {
    font-size:20px !important;
.warning {
   background: rgba(199,44,44,0.3) !important;
    background-clip: padding-box;
.warningblue {
   background: rgba(45,119,204,0.3) !important;
.warningyellow {
   color: Yellow;
.warningred {
   color: Red;
.warningredbg {
   background: rgba(255,0,0,1) !important;
/* Fontsize of specific blocks */
.block_88 {
   font-size:30px !important;
.block_94 {
   font-size:16px !important;
