Python plugin: Battery Level for Z-Wave Devices
Phantom
Domoticz version: 4.11652
Re: Python plugin: Battery Level for Z-Wave Devices
Post by Phantom »
Hey, thanks for the update but it is not shown in git: https://github.com/999LV/BatteryLevel/ there i still see version 0.4.3
Logread
Post by Logread »
Phantom wrote: Tuesday 22 August 2017 19:13 Hey, thanks for the update but it is not shown in git: https://github.com/999LV/BatteryLevel/ there i still see version 0.4.3
Good pick... forgot to sync my local development folder... should be ok now
Phantom
Post by Phantom »
Logread wrote: Tuesday 22 August 2017 19:20
Yes thanks up to date again :)
PBdA
Domoticz version: 3.5893
Post by PBdA »
Domoticz 3.8153 + Battery level plugin 4.4 on Rasbian Jessie
I have a strange problem with the plugin. My polling interval is 60 mn. I monitor updates in an LUA script. Each hour battery level of my 6 devices are updated but there are several updates. In log file I see:
2017-10-03 11:12:28.503  LUA: --> Piles - Remote Fibaro:55
2017-10-03 11:12:28.549  LUA: --> Piles - Remote Fibaro:55
2017-10-03 11:12:28.594  LUA: --> Piles - Remote Fibaro:55
2017-10-03 11:12:28.640  LUA: --> Piles - Remote Fibaro:55
2017-10-03 11:12:28.685  LUA: --> Piles - Remote Fibaro:55
2017-10-03 11:12:28.731  LUA: --> Piles - Remote Fibaro:55
It appears that each hour there is one more line:
# grep '06:12.*Remote Fibaro:' domoticz.log | wc -l
156
# grep '07:12.*Remote Fibaro:' domoticz.log | wc -l
157
# grep '08:12.*Remote Fibaro:' domoticz.log | wc -l
158
# grep '09:12.*Remote Fibaro:' domoticz.log | wc -l
159
# grep '10:12.*Remote Fibaro:' domoticz.log | wc -l
160
# grep '11:12.*Remote Fibaro:' domoticz.log | wc -l
161
My uptime is 6 days + 16 hours -> 160 updates
The plugin is working well otherwise.
Any idea ?
PBdA
PBdA
Post by PBdA »
Looking at the code, I think that self.BatteryNodes should be reset at in pollnodes(self).
# diff plugin.py.sv plugin.py
133a134
>                 self.BatteryNodes = []
That works for me but I don't know about side effects.
PBdA
Logread
Post by Logread »
@PBdA,
You are correct. Thanks for uncovering the bug. Currently testing the simple fix you suggested. I'll commit to GitHub later today hopefully.
EDIT: Version 0.4.5 is available from GitHub.
Existing users please upgrade (besides issues with the events system, memory usage was building up over time due to the bug uncovered by @PBdA). First post in the thread has been updated accordingly as well.
remb0
Post by remb0 »
thanks! great work!
maybe an idea to make a compatible list?
I have:
Neo CoolCam Power plug 12A+
Aeotec ZW089 Recessed Door Sensor Gen5+
Neo CoolCam Battery Powered PIR Sensor+
Neo CoolCam Water Leakage Detector+
Schlage Link Mini Keypad RFID
Philio Technology Corporation PST02-A 4 in 1 Multi-Sensor+
Danfoss Z Thermostat 014G0013
as you can see in my screenshot ony the danfoss is working:) the battery was really empty.
the zipato keypad mini in domoticz known as (Schlage Link Mini Keypad RFID) is 64. but this is already a few months so I don't believe it's right.
and in openzwave panel there is no info about the battery stats of the zipato.
are the other devices not compatible with battery info or do I have them wrong configured?
Logread
Post by Logread »
@remb0,
Thanks for your insight and feedback. The plugin gets its data from openzwave, no more no less. And I noticed as well some zwave devices have an erratic battery level reporting behaviour. But nothing I can do about it in the scope of the plugin.
For non zwave devices, this is definitively out of scope but may be someone can contribute ?
Brutus
Post by Brutus »
Thnx for this great plugin!
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
dextm80
Domoticz version: 4.10159
Post by dextm80 »
Great plugin!
Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
anton
Post by anton »
I did everything what is write in the manual.
I don’t see the the plug-in by the hardware.
Gr.
Anton
Logread
Post by Logread »
anton wrote: Friday 12 January 2018 12:07 Hi,
Gr.
Anton
Domoticz version ? Platform ?
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
Just came by to say thx...
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
Logread
Post by Logread »
Siewert308SW wrote: Friday 12 January 2018 14:16 Just came by to say thx...
Appreciate :D
anton
Post by anton »
Logread wrote: Friday 12 January 2018 13:56
Gr.
Anton
Raspberry Pi 2
Domoticz 3,885
shturm
Post by shturm »
Gr.
Anton
I'm having the same problem.
Ubuntu 14.04
Domoticz 3.8153
It's installed in ~/git/domoticz
Any idea why I don't see plugin in the list?
Logread
Post by Logread »
@shturm,
Did you try other plugins ? I suspect this is a domoticz plugin framework issue rather than an issue with this particular plugin.
shturm
Post by shturm »
Derik
Post by Derik »
Dear Developer.....
cannot install from the github..
Is there something changed from the wiki?
Everytime i get this error:
root@odroid:/home/root/domoticz/plugins/BatteryLevel# git clone https://github.com/999LV/BatteryLevel.git BatteryLevel
fatal: could not create work tree dir 'BatteryLevel': No such file or directory
And i am sure the map BatteryLevel is in the plugin section..
Phantom
Post by Phantom »
Derik wrote: Saturday 17 February 2018 20:57 Dear Developer.....
I think you need to go back 1 folder as you are already in the BatteryLevel map and trying to create the BatteryLevel in there again.
