Page 5 of 26
Re: Domoticz App
Posted: Friday 23 June 2017 10:59
by Andree
FIRST OF ALL - Congratulations,very nice work and i love to see italian localization!
Tested on iPhone 6s iOS 10.2 and iPhone 7 iOS 11b2
- The status bar should be white,black to black it's not good
- In the graph page there is a big button
- button_graph.jpg (55.33 KiB) Viewed 3531 times
and IMHO and request!
- "Search" in italian language will be "Cerca". "Filtro" it means "Filter".
- find.jpg (18.99 KiB) Viewed 3531 times
- You can consider,for principal panel,an option like "minimal" so arrange in a little space more switch possible!
- minsample.jpg (76.93 KiB) Viewed 3531 times
Re: Domoticz App
Posted: Friday 23 June 2017 11:05
by galadril
Thanks for the feedback!
Re: Domoticz App
Posted: Friday 23 June 2017 11:40
by galadril
Uploading some quick fixes just before my holidays:
- Weird scaled graph filter icon
- Connection issues to HTTPS connections (make port settings optional)
- Add next/previous buttons to the welcome setup screen
- Add a close button to all popups
Re: Domoticz App
Posted: Friday 23 June 2017 12:12
by marcotrumpet
galadril wrote:Uploading some quick fixes just before my holidays:
Waiting the update
Inviato dal mio iPhone utilizzando Tapatalk
Re: Domoticz App
Posted: Friday 23 June 2017 12:17
by bdormael
First feedback on beta testing:
- As mentioned above, make minimal layout to prevent too much scrolling
- I have lots of contact sensors to detect if a door/window is open or not, it shows the status correct in your app, but it also shows a big "ON" button, which is confusing for the user, can't this just show "Open" or Closed" as read only ?
- Temperature : Is it possible it shows the temperature also bigger on the right iso only at the status line so it's easier to have an overview ?
- Thermostats : maybe this is already in progress, but it would be nice to change the setpoint more userfriendly then free text field
- When changing settings (eg. in the dashboard), this is not refreshed or applied without roced closing the app and re-opening
- Security Panel : when changing status it pops-up for which status you want to change -> "Favorite" looks like it is part of the options, which is confusing for the user, can't "Favorite" be shown less emphasised ? (because once you're favorites are set, normally you don't change a lot
- Security Panel : Can the status be more emphasised (like also on the right side), so it's directly obvious which status it has been set to ?
All in all, a very nice first beta version, thx for all the effort
Re: Domoticz App
Posted: Friday 23 June 2017 14:10
by galadril
There is a setting allready for more or less information
bdormael wrote:- I have lots of contact sensors to detect if a door/window is open or not, it shows the status correct in your app, but it also shows a big "ON" button, which is confusing for the user, can't this just show "Open" or Closed" as read only ?
This is also the case with the web ui at this moment. it's a 'readyonly' pushon/off device.
But ill add this to the list.. maybe i can set the door contacts on default readonly devices..
bdormael wrote:- Temperature : Is it possible it shows the temperature also bigger on the right iso only at the status line so it's easier to have an overview ?
Ill add this to the list
Not yet, there is not a nice arc seekbar control available at this moment.. but probably somewhere in the future!!
you can also pull down the list to refresh, or what settings are you talking about?
Re: Domoticz App
Posted: Friday 23 June 2017 19:11
by bdormael
Thx for the swift answer, much appreciated.
With settings I mean change something in the settings page like eg. show stats or hide stats, then going back to the dashboard, the old setting is still shown until the app is force quit and restarted.
- I noticed there is a setting to show less stats to have a condensed layout, but there is still a lot of white space per device, it would be nice if the space is optimized.
- Another thing I noticed is that the app doesn’t refresh the current state when going to the iPhone home screen and go back in the app, the only way to refresh is to pull down, it would be nice if it refreshes each time the app is opened in the foreground
Verzonden vanaf mijn iPad met Tapatalk
Re: Domoticz App
Posted: Friday 23 June 2017 21:34
by galadril
New version is available via testflight
Re: Domoticz App
Posted: Friday 23 June 2017 21:49
by marcotrumpet
galadril wrote:New version is available via testflight
It's me or now everything seems bigger, zoomed? Like an ios app not optimized..
Re: Domoticz App
Posted: Friday 23 June 2017 22:27
by G3rard
Yep, there is indeed a difference with the previous version. Made a screenshot before upgrading after I saw your post and indeed it's looking zoomed now.
Re: Domoticz App
Posted: Saturday 24 June 2017 22:40
by Nautilus
Nice work! I'm on iPhone SE (yeah, our company policy sucks
) with iOS 10.3.2. Most of the points I had already mentioned here. For some reason the Dashboard shows two of my utility sensors at the very top although the mode is "use server sorting" and there they are in the last section. Also, it would be very nice to be able to sort them manually (in each screen).
The "last seen" is also still showing the last seen time in format "10 hours 20 minutes" which is easy to confuse it has been seen this long ago. So as suggested, I'd vote for either showing just a timestamp (10:20:22) or then calculate the actual "time ago" and add "ago" at the end ("10 hours 20 minutes ago").
What kind of extras have you been thinking about for the paid version?
Keep up the good work!
Re: Domoticz App
Posted: Sunday 25 June 2017 9:58
by marcotrumpet
Tested the app also on my ipad pro 9,7 with ios 11 beta 2. I agree with someone before me, too dark background and text coloro on the top bar
Re: Domoticz App
Posted: Monday 26 June 2017 19:54
by rgroothuis
can i participate in the beta testing as well. i can and will test the app on a iPhone 7 plus and a iPad Pro.
Re: Domoticz App
Posted: Monday 26 June 2017 21:05
by Dahl1632
I would also like to test
Thank you in advance
Re: Domoticz App
Posted: Tuesday 27 June 2017 12:01
by Thelion
Any chance of becoming another beta user?
Re: Domoticz App
Posted: Tuesday 27 June 2017 17:04
by LanWolf
Hi. Would love to test.
I was beta tester fir Pilot and Domotix before too.
Re: Domoticz App
Posted: Friday 30 June 2017 12:04
by G3rard
Some more findings after testing v0.05 on iPhone 7, iOS 10.3.1.
* Version is zoomed (like an old app which is not made for larger screens of new iPhones)
* Temperature devices show the temperature twice, at status and temperature
- temperature.png (88.38 KiB) Viewed 3243 times
* Rain sensor shows data from field Data, better is to use fields Rain and RainRate as that is shown in Domoticz as well
- rain.png (68.39 KiB) Viewed 3243 times
* When select a protected switch and pressing Cancel, the switch is changed in the view although it isn't actually switched
- protected.png (36.19 KiB) Viewed 3243 times
Re: Domoticz App
Posted: Friday 30 June 2017 12:07
by G3rard
* When a dimmer value is changed, that value is not updated in the app.
- change-dimmer-value.png (50.38 KiB) Viewed 3244 times
* It's not possible to toggle a group in the Scenes tab, when pressing on a group, you only get the possibility to add it to the Favorites or show the Log
- IMG_6070.PNG (172.56 KiB) Viewed 3244 times
@galadril, keep up the good work and enjoy your holidays!
Re: Domoticz App
Posted: Friday 30 June 2017 12:30
by TroisSix
Hello
I was waiting for an IOS version for a so long time, I would be very interested to test the beta version. Can I have this beta version for helping you to test it? Thx
Re: Domoticz App
Posted: Friday 30 June 2017 12:32
by galadril
@G3rard Thanks, all valid points!
Verstuurd vanaf mijn SM-T713 met Tapatalk
